查看: 1022|回复: 3
ATMEGA329P的EEPROM怎么编写?
发表于 2014-11-26 14:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
需要写数据到EEPROM中再读出来需要怎么编写程序,望大神赐教啊!急。。。
5 s' Z5 h# v. u4 M/ ^, @4 t
    2025-11-19 15:14
    发表于 2014-12-29 13:16 | 只看该作者
    没用过ATMEGA329P,用ATMEL16\32,用它的库来读写EEPROM,这是用AVR编译器的
    ; r" `* L# C8 r* t0 c7 R#include <avr/eeprom.h>
    % n$ Y4 \  K+ F' Uvoid EEPROM_WRITE(unsigned char eep_address,unsigned char wr_number,unsigned char* p_header)
    - R2 B& a6 A/ n. E6 _' \9 Q  A{        ; b% b4 E% Z) w5 H
            eeprom_busy_wait();) Q. p9 @; c& V  S$ I
            eeprom_write_block (p_header,eep_address, wr_number);
    + O5 h8 q6 i7 z+ j+ {& S$ v! E  o}
    ; t; Q4 q1 L- ]2 h" y; L6 C5 ~/ W4 b
    ' }( K: w! x4 H* |! o& C7 n6 u6 Vvoid EEPROM_READ(unsigned char eep_address,unsigned char rd_number,unsigned char * p_header)1 ?# F2 p: ]5 t: N: `+ c( B
    0 ~2 P) }, F0 L( C8 m        eeprom_busy_wait();5 D! l* q6 ^' x: p$ R9 l
            eeprom_read_block (p_header,eep_address,rd_number);+ |  {/ m6 q' c! c  ~
    ' q- d' t! i7 m$ O  @/ D$ `8 k' G
     楼主| 发表于 2015-1-6 16:38 | 只看该作者
    fresco_xy 发表于 2014-12-29 13:16
    7 \8 |! z1 L4 m没用过ATMEGA329P,用ATMEL16\32,用它的库来读写EEPROM,这是用AVR编译器的; R% a; |$ f! J/ |
    #include ' ]( n) X4 ?6 o) f" A! o, r; Y
    void EEPROM_WRITE ...
    * A9 _# S! u) U% ]6 i0 v' I3 b% V0 t
    thank you!2 l+ P( c+ P5 K1 Y4 @% c& M
    GMT+8, 2025-11-23 17:24 , Processed in 0.140625 second(s), 23 queries , Gzip On.
