查看: 7007|回复: 3
求助-QUARTUS II版本:13.0编译程序出现的问题
发表于 2014-2-11 14:17 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
QUARTUS II版本:13.0# o# q  U, g/ u" I+ X+ D6 a
FPGA型号:EP2C8Q208
8 ^( w# L! O& g) o" g在编译的过程中出现了如下的警告:& t8 m0 k4 k( R& X2 x; F! S8 P+ f
(1)Critical Warning (332012): Synopsys Design Constraints File file not found: 'exp08_demo.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
& W9 n: t& o* G/ ?7 ~; aCritical Warning (332012): Synopsys Design Constraints File file not found: 'exp08_demo.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
/ N* f7 d) \  O  \7 G- cCritical Warning (332148): Timing requirements not met
+ L- H! t; F% nCritical Warning (332148): Timing requirements not met
% g/ X* t! _) D& x+ L/ l! @
, R4 M! j1 R3 ]: P( S9 x2 y(2)Warning (306006): Found 4 output pins without output pin load capacitance assignment
% ?4 Y6 ]( }! _7 [& p8 I- P6 j        Info (306007): Pin "Data_Out[0]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
$ O0 g  m/ C* \. X$ l+ [        Info (306007): Pin "Data_Out[1]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
  h6 [* M" b& t" U2 K2 l4 g        Info (306007): Pin "Data_Out[2]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
) v, n$ J% G/ D+ g1 o1 T        Info (306007): Pin "Data_Out[3]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis" ~1 u+ j$ q# a+ n; O  J
程序是黑金开发板提供的程序:PS2解码 ,仔细检查了下,程序没有问题。
) n. }/ A  c% m8 O' r/ o" W$ y( y# H8 l; c$ w
求助大侠,有没有什么好的方法来解决上述两个问题。。。谢谢
发表于 2014-3-24 19:06 | 只看该作者
这个 E 文 说,要用 TimeQuest Timing Analyzer 去产生时序约束文件。没有这个,编译器无法工作
发表于 2014-3-11 19:23 | 只看该作者
这时说,你的电路没有时序约束文件。在13.0和之后的版本,软件都默认要求开发者提供时序约束文件,如果没有提供,就会给出 “332012” 警告。再者,如果没有提供,软件会自动按照1GHz的要求来进行编译,时序要求当然就达不到了,就会得到“332148”警告。后面几条警告,是说输出引脚没有分配电容负载
发表于 2014-2-20 20:22 | 只看该作者
有种东西叫衣来伸手饭来张口
GMT+8, 2025-11-28 23:37 , Processed in 0.140625 second(s), 25 queries , Gzip On.
