查看: 7017|回复: 3
ALLEGRO导网表出现的错误,请各位前辈帮忙看看
发表于 2013-8-13 10:38 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
cadence Design Systems, Inc. netrev 16.2 Tue Aug 13 10:30:45 2013- s' q6 q6 A* {# _+ m$ k
(C) Copyright 2002 Cadence Design Systems, Inc.( C. Z0 F; ]/ P/ w: U9 ]
/ a7 a2 e% R9 \6 U
------ Directives ------
" {3 P' J$ Q4 j; `" {0 H
4 ?7 ^! q- E. `; d/ URIPUP_ETCH FALSE;1 p9 r/ ~, s- ~8 o! @% @# F' B
RIPUP_SYMBOLS ALWAYS;
8 K$ M; H% t9 l# N  D' @Missing symbol has error FALSE;
- a# U8 P+ c7 xSCHEMATIC_DIRECTORY 'F:/zgc/DOREAL_DECODER V1.0--20130812/allegro';
, z" B% \5 ]7 f5 I$ i1 C; t: UBOARD_DIRECTORY '';2 w9 |9 E) ?1 y: X+ x0 F' G& Z
OLD_BOARD_NAME 'F:/zgc/DOREAL_DECODER V1.0--20130812/DOREAL_DECODER V1.0--2013081201.brd';
2 c$ D, k6 t6 |, oNEW_BOARD_NAME 'F:/zgc/DOREAL_DECODER V1.0--20130812/DOREAL_DECODER V1.0--2013081201.brd';
4 B6 d( Q: q  G
$ n0 b4 ?3 {& p& g  y/ f* G! SCmdLine: netrev -$ -i F:/zgc/DOREAL_DECODER V1.0--20130812/allegro -y 1 -z F:/zgc/DOREAL_DECODER V1.0--20130812/#Taaaaaa04968.tmp6 y, G2 p* t2 F" u+ k
+ s" ~5 O+ ], W------ Preparing to read pst files ------6 T' }% v, {3 i, F* v# Y5 ~6 T/ R
; W7 k  E; B- m5 G% t6 l
Starting to read F:/zgc/DOREAL_DECODER V1.0--20130812/allegro/pstchip.dat
7 B7 [( l1 q2 s& q3 ?  O( M: I0 m   Finished reading F:/zgc/DOREAL_DECODER V1.0--20130812/allegro/pstchip.dat (00:00:00.10)
$ B: c' D9 F2 p' |/ o2 {Starting to read F:/zgc/DOREAL_DECODER V1.0--20130812/allegro/pstxprt.dat
0 f3 u  s5 n( h5 m$ G6 r   Finished reading F:/zgc/DOREAL_DECODER V1.0--20130812/allegro/pstxprt.dat (00:00:00.03)# E: i; q: C4 [: y- j" V4 |
Starting to read F:/zgc/DOREAL_DECODER V1.0--20130812/allegro/pstxnet.dat
# X* y; N. v% Y% H+ F3 U   Finished reading F:/zgc/DOREAL_DECODER V1.0--20130812/allegro/pstxnet.dat (00:00:00.01)/ n$ z8 U! f. ?4 U9 t8 i; S' i
9 ?8 Z! e: ~0 N4 a- O
------ Oversights/Warnings/Errors ------
: Q" g( L% l0 }5 v7 R! H2 r2 [1 p  V4 ^" g( m, q4 |8 ^% `
# T+ A6 q/ ~  @/ ?/ w; N% W
#1   ERROR(SPMHNI-176): Device library error detected.
& l! d+ k5 x8 m; |% v7 ]+ I4 S
# S0 q7 {( G' A/ i$ T( ]ERROR(SPMHUT-115): Pin 'DDR_COMP' for function 'TYPE20' on device 'BCM7581_15X15_BOS_P8MM_35_BGA26' has a swap/pinuse inconsistency.. p* r$ a4 H5 u' ^/ i
- O: l9 M& k4 X; U( A
#2   ERROR(SPMHNI-176): Device library error detected.
6 G& _# d3 Y+ }2 \1 f' w. \5 J& C
ERROR(SPMHUT-115): Pin 'DDR_VREF' for function 'TYPE20' on device 'BCM7581_15X15_BOS_P8MM_35_BGA26' has a swap/pinuse inconsistency.8 n/ @6 x& K: t% K  {
" Z! F- E) F6 d
ERROR(SPMHNI-170): Device 'BCM7581_15X15_BOS_P8MM_35_BGA26' has library errors. Unable to transfer to Allegro.$ |) c. c& j. w
$ h$ @3 |9 e$ @4 l6 n
------ Summary Statistics ------
" s, p+ p- q8 i7 j3 f$ a4 s( L1 v! W% V
8 r. F" }. b; N9 H1 [; l; q5 t$ P
#3   Run stopped because errors were detected. ?* |' ?$ L' L; m0 a: h; N
, p" v: ~2 d4 L4 F
netrev run on Aug 13 10:30:45 2013
9 V- C5 q* W) f   DESIGN NAME : 'DOREAL_DECV100_20130812A'
2 V, X' {- K# R: K5 h: l   PACKAGING ON Sep 28 2008 21:55:15
& r4 M8 \* K3 J& B( S
5 {! e6 b9 M5 ?. k0 l! x   COMPILE 'logic'
8 i/ l& s, V9 u' w   CHECK_PIN_NAMES OFF
* m) A/ {  d5 f* A* t8 d1 T) H   CROSS_REFERENCE OFF- t1 r6 K& P# N/ _
   FEEDBACK OFF
" t7 F! h; H' {2 s4 M9 D   INCREMENTAL OFF4 N0 y2 @2 p- v3 V
   INTERFACE_TYPE PHYSICAL
$ d, Z( W8 k# d5 R4 s( S& @   MAX_ERRORS 500+ X* O% G1 D# E/ {( A. _' w
   MERGE_MINIMUM 5- R% f5 N/ a5 O5 E1 e" ^! y$ D1 c
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
; C( R, q7 {" d3 R! E: P+ Y   NET_NAME_LENGTH 24# h, I; [- w6 G! o' u4 W. J) X
   OVERSIGHTS ON
( U& g  B' v! {) J7 Q- c   REPLACE_CHECK OFF
9 e1 F' C& w  ?1 R   SINGLE_NODE_NETS ON8 E8 Z3 R& N2 @( c+ h' h
   SPLIT_MINIMUM 0
  c, g" O% X8 R$ ~   SUPPRESS   20
# F) i( A: F' F   WARNINGS ON
, n( X( H" F, G, K* o, z# W" w9 y* Z8 n  s6 q# z# g
  3 errors detected2 q; V9 |2 L0 y, t- _
No oversight detected; B/ r" u8 i9 K0 H  n' O  f/ \
No warning detected
$ ^/ l& f! n, P8 ~( Y8 Y2 Y; \9 l, K6 j; F2 R& X# V) b+ ]
cpu time      0:04:11
0 |! e, p4 f) G. C3 Xelapsed time  0:00:01
' ^' @2 m0 p+ v3 C; r- |
2 p) m6 A' c1 O/ k5 Z& H0 o
发表于 2015-1-5 22:04 | 只看该作者
打开器件,选择View -> Package;然后选择Edit -> Properties;然后看看相同的PinGroup里面的Type属性是否是一样的,如果不需要进行pin交换的话,其实PinGroup这一列可以不用分组的。  `! q! P6 a, e: v3 V
3 b6 b0 n# H9 ?/ \) ~+ G" f
发表于 2015-1-6 15:12 | 只看该作者
用allegro.dll 的路过
发表于 2015-1-4 10:33 | 只看该作者
我跟你遇到同样的问题了,请问你是怎么解决的???
GMT+8, 2025-11-24 17:33 , Processed in 0.187500 second(s), 28 queries , Gzip On.
