下面贴上源代码!
9 p- X- t- @1 r3 U2 t0 R`define UD #1
" S9 I3 M! C+ K3 X; e
, B3 j7 G) I0 m( L! ^ N4 H Zmodule KEY_TEST8 J! G( y, ^( D0 N* U( L, k) j
(8 T& G4 ]/ b2 y% i
//Input ports.! c( s. b. M- h( ]: B" F6 B
SYSCLK,
4 F* o$ E' I! E( w$ a RST_B,
1 s: g @$ q9 N7 [( a/ v& x* W KEY_B,
" }( H/ a( k) { B
* |/ h- B/ |; i //Output ports.& _# M, ~) F1 G! G. q$ b: M
LED_B
5 i1 E* R# B ?; |6 o' ? );
u1 e6 I6 L" q* F5 w0 M2 u$ D }$ c- J. g: }5 G. q d% ?2 V# Z
//===========================================================================' x W) T6 i6 F! k/ e4 E; m
//Input and output declaration
. S. h, `* f4 X5 T//===========================================================================
3 B# v0 [5 L! x0 q9 q2 ~' B$ J+ O6 D1 ]
input SYSCLK; //System clock, 50MHz.$ v$ [& ]' ?. J& y: U
input RST_B; //Global reset, low active., e# F" i+ C8 |3 ^) v: N
input KEY_B; //Key input, low active.
! _$ ?! K% L0 _, i7 K$ B: I: l! j" n' u g% M
output LED_B; //Led output, low active.3 k8 Z- z# ^/ N/ w& C
2 G7 e6 S. h2 ^; c3 R; i
//===========================================================================9 q2 T& p0 ~& S2 d
//Wire and reg declaration
/ M) z4 Y$ k, h! q* O6 O//===========================================================================
8 S F* X! W9 K, B
0 _* V" k3 {: p i+ _; I0 L+ {wire SYSCLK;. }+ d1 ~( n# a2 R' A) s6 K& G
wire RST_B;
4 m& V' c4 i! w2 O# s: gwire KEY_B;3 y! t9 T& Y6 f; K: B/ ~7 k4 \
4 C/ L$ F; z ~6 K7 Y3 ?7 ?
reg LED_B;
5 @6 `4 T! y; ]- G+ c( q9 R V8 @" N* r# L9 r8 A+ \; K
//===========================================================================9 B: v) ]- i' y! x5 }: ~
//Wire and reg in the module . \" x' |& b# K
& B9 K$ l( s2 y" r# D! f5 M* R* j5 ^. N
reg [19:0] TIME_CNT; //Counter, count press key time.
: u. Y: P( o/ d1 vreg [1:0] KEY_REG; //Save the input one cycle every 20ms.0 m7 |" ?4 v w. d: ^2 D4 B8 D* G
reg LED_B_N; //Next value of LED_B.2 N0 _3 U/ R( x0 F' f# b& S1 K9 t
' B6 a/ D8 s$ V( }% f' N. D0 ~
wire [19:0] TIME_CNT_N; //Next value of TIME_CNT.; z2 E b) T# `5 |( t$ @2 s8 [
reg [1:0] KEY_REG_N; //Next value of KEY_REG.0 h; d9 Q2 h9 y! P7 V: r7 G2 U
6 X; \9 @. \: s& x ~. o//===========================================================================$ `1 W+ Q. ?6 J% W) O# w3 i
//Logic
1 t% p# z0 s; H, V' J- R; s5 m ]//===========================================================================
; b* I- |; {6 i
4 e6 r. G# T$ {4 n7 E$ u6 R& O//Count the time the key is pressed, free running.1 x0 m K5 h0 f4 A" Q Y2 W
always @ (posedge SYSCLK or negedge RST_B)9 g0 P: z D# m) W2 @9 D# Q
begin1 N! V8 H7 G3 G- f' k6 T
if(!RST_B)
: @3 d& b& _9 f& _6 A: \9 [, j TIME_CNT <= `UD 20'h0;: ~& ]" u7 p) p" e
else
# L$ |3 j* g2 ]) `, Y2 V TIME_CNT <= `UD TIME_CNT_N;
. T4 |4 U* H- a; ]end* ^0 l6 l. F V c s. H3 P* u6 A
0 c, M( E2 x. k f//Count cycle 20ms
5 U) \. W! b+ P! A9 `; d; c; u2 gassign TIME_CNT_N = (TIME_CNT == 20'hf4240) ? 20'h0 : TIME_CNT +1'h1;( J" H- ^9 ?: {. ]# W; r8 _) u
1 e! V9 k9 ?) {6 f# M
//Save the key value when some key is press.
& t6 Z4 G0 ^1 H' u9 N: n3 j5 Z# Walways @ (posedge SYSCLK or negedge RST_B)
- j# F9 Q5 v; A3 l4 S* qbegin
1 [ v# I1 @+ m0 W; U if(!RST_B): s; [6 O* g0 ~: Y" d% ~
KEY_REG <= `UD 2'h3;% H7 m" r0 D+ t0 w$ _" u- X
else
; }4 I# O% w6 h' b* v' o% z KEY_REG <= `UD KEY_REG_N;1 u- _& s9 ^& ~0 w
end- q* g! l/ L: E3 y
4 T9 V9 l! \# ?4 t. jalways @ (*)
; ~( `; X4 n, Y2 d" O; ^7 obegin
9 Y1 V0 M! x1 `3 u if(TIME_CNT == 20'h0)
9 x' m% g9 v0 V KEY_REG_N = {KEY_REG[0] , KEY_B};8 D0 t6 {4 r2 J. Z1 b
else
5 }3 W/ F/ E7 F. `- o* u; i) _( G KEY_REG_N = KEY_REG;
9 m" K7 D6 O% l" c. a# C( |' Wend/ p B* ?9 F8 ]7 Z. E( z6 ^1 q
) z1 m$ @- D* n& H//Output control.7 h& @. h+ z- ~
always @ (posedge SYSCLK or negedge RST_B)3 }; I( x7 n" Q! a" \2 W$ O4 `
begin
7 Q& s5 Z$ I1 b7 z0 L+ B( A if(!RST_B)2 f, b S4 O: P- N
LED_B <= `UD 1'h1;( K) M5 w% D# `4 a
else" x- T! x, w5 l9 {
LED_B <= `UD LED_B_N;
0 {+ O" u& q# y( L2 oend
" p1 f8 t# O/ U% p3 x8 ^5 `3 e! n# C0 t. q
always @ (*)! z( E6 I z1 `& a( P
begin$ d2 O9 U3 X5 c' t8 E! Y9 a; |4 J
if((KEY_REG == 2'b01) && (TIME_CNT == 20'hf4240))
7 ~* J) m, }/ ?+ t5 x LED_B_N = ~LED_B;. I. l# h4 d* W& k9 ]1 ~
else
9 D4 {6 v$ P8 g( S" z( _ LED_B_N = LED_B;: N, ?" r0 ?9 Q: o
end
# @! v3 j, s6 q$ |" g- g1 c
& B/ ^, i# l. t l7 Cendmodule
) j6 p1 N+ H' b* h b1 C |
