Unable to import file D:\Pcblib\SI_Model\LatticeECP3_FPGA_IBIS_Models.ibs due to the following errors found by ibischk5:2 x( d# e C5 [3 F/ E8 d. j# Q- w, h
3 `5 o9 d! z$ a% `& y& u' _' z0 uIBISCHK5 V5.0.3
! i/ A( ]0 F# A7 x: L S
. L+ I: ~* w j9 d7 m/ j, N5 \Checking D:\Pcblib\SI_Model\LatticeECP3_FPGA_IBIS_Models.ibs for IBIS 3.2 Compatibility...% [$ W, ~* ?& e7 K
S& N2 b' {' c8 m0 I0 Z. {
ERROR (line 8) - File name opened 'LatticeECP3_FPGA_IBIS_Models.ibs' not the same as File_name 'ecp3.ibs'.2 P& ~3 }9 i* p
WARNING - Model lvc330s040caaaaaaaio: The [Rising Waveform]
) Y" `* f8 S3 S/ R7 Y9 v1 c with [R_fixture]=50 Ohms and [V_fixture]=3.3V
8 J* O h) ^- V" W* n has TYP column DC endpoints of 2.89V and 3.30v, but
& l) Y6 V6 m8 m- N6 ?, n an equivalent load applied to the model's I-V tables yields1 s, R0 }! d% f
different voltages ( 2.88V and 3.30V),: s* t) u9 o" B9 R
a difference of 2.06% and 0.59%, respectively.
1 c- g) V2 r0 }- o5 a4 D+ Z. }" pWARNING - Model lvc330s040caaaaaaaio: The [Falling Waveform]
9 g" a" P$ Q8 z+ R$ r with [R_fixture]=50 Ohms and [V_fixture]=0V
) u9 I, }! E# i9 [ has TYP column DC endpoints of 0.00V and 0.43v, but
/ J% I0 Y6 V9 M* G: r an equivalent load applied to the model's I-V tables yields+ @! M+ O+ S+ ]1 H& {1 ~
different voltages (-0.00V and 0.42V),* ]. B: q+ b5 G- ~0 G
a difference of 0.73% and 2.15%, respectively.
# l7 K. t& g/ R5 w# z5 x8 C+ KWARNING - Model lvc330s040caaaaaaaio: The [Rising Waveform]
, c$ p$ j8 G$ p* i, K with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V
7 u. e0 g: T; a3 D; U& D has MAX column DC endpoints of 3.10V and 3.47v, but
2 \7 Z, }3 Z5 o( |. |( r! ` an equivalent load applied to the model's I-V tables yields7 t8 t: v$ Z2 X3 S0 q5 G" r& L
different voltages ( 3.09V and 3.47V),* q) H( W# p2 }0 w! V; `) u/ @% c
a difference of 2.43% and 0.60%, respectively.
5 ^2 M/ J, e9 |# i$ V; P b, N$ {7 dWARNING - Model lvc330s040caaaaaaaou: The [Rising Waveform]
, T& f: B4 o+ l! f! M E( J ? with [R_fixture]=50 Ohms and [V_fixture]=3.3V
: d6 Q( E2 ?0 Y1 Y has TYP column DC endpoints of 2.89V and 3.30v, but
F' n) q$ } V7 ]% F an equivalent load applied to the model's I-V tables yields, K7 a9 L' \8 |
different voltages ( 2.88V and 3.30V),* \9 R) `# l3 d' r' Q
a difference of 2.06% and 0.59%, respectively.2 a, Y4 ?8 r& j. [+ v# |
WARNING - Model lvc330s040caaaaaaaou: The [Falling Waveform] 3 q; p7 T' D6 y- {/ {# _
with [R_fixture]=50 Ohms and [V_fixture]=0V! i% d; s! a% {- C. F/ E
has TYP column DC endpoints of 0.00V and 0.43v, but. e* T4 ]" f9 g4 e8 a: r" U
an equivalent load applied to the model's I-V tables yields! s/ \' y% w8 Q9 R/ I+ S3 d4 H: u. n
. x+ U. f* I3 @! K5 s( x a difference of 0.73% and 2.15%, respectively.% P q4 u$ }( w. \, P0 o
WARNING - Model lvc330s040caaaaaaaou: The [Rising Waveform] * ^# k$ S: V5 d3 K F$ g
with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V0 ]: ?; p) ?' f6 q: c( ^
$ v* a, j k1 b an equivalent load applied to the model's I-V tables yields! G" K) c5 ]7 V2 O) b
0 @0 ]1 r0 T( `5 g6 e9 w- N a difference of 2.43% and 0.60%, respectively.
# c+ E2 l/ D) y- i cWARNING - Model lvc330s040daaaaaaaio: The [Rising Waveform] 4 p+ p7 q5 j. z+ B# ^1 D
+ S& e" X7 o5 y5 ` has TYP column DC endpoints of 2.89V and 3.30v, but
+ o% k- v" Y i: N0 f, N: d6 I an equivalent load applied to the model's I-V tables yields
- n1 v, f8 O0 q" F. s# ]8 K" p different voltages ( 2.88V and 3.30V),. b' @( ?9 Y. \6 s1 m
0 Q2 K0 ^7 f% P7 sWARNING - Model lvc330s040daaaaaaaio: The [Falling Waveform]
5 O# \* Z; G1 w# a* K with [R_fixture]=50 Ohms and [V_fixture]=0V
7 m& }; f2 e* H has TYP column DC endpoints of 0.00V and 0.43v, but# v! G9 h7 z3 @2 W
an equivalent load applied to the model's I-V tables yields- x4 ]3 |& V7 w! `
5 x/ i# r# Z% A8 d; @ a difference of 0.73% and 2.15%, respectively.
' G/ E$ r1 }1 a' f2 H( w9 _WARNING - Model lvc330s040daaaaaaaio: The [Rising Waveform]
; Y2 T/ T- x5 e. B9 z+ r. H, g with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V) V8 i# V3 y5 F- c* j& t, W
- t0 {2 l" ^0 m an equivalent load applied to the model's I-V tables yields% c( ?' F m5 g
4 M3 c9 Y6 ~5 |. `0 `; f a difference of 2.43% and 0.60%, respectively.2 h) P, l K' ~* H
WARNING - Model lvc330s040gaaaaaaaio: The [Rising Waveform]
' c p; {$ c1 [/ x) h with [R_fixture]=50 Ohms and [V_fixture]=3.3V
* ?2 i' ?) d q6 e2 i has TYP column DC endpoints of 2.89V and 3.30v, but
# x, ^9 C# g- k- _* L! h an equivalent load applied to the model's I-V tables yields
. @3 f& {3 v. t" M different voltages ( 2.88V and 3.30V),
# k/ s' L3 ]! W2 }0 p( ? a difference of 2.06% and 0.59%, respectively.
$ B8 n* S# |# `- n) Z) f5 aWARNING - Model lvc330s040gaaaaaaaio: The [Falling Waveform]
6 r- O) y- H+ g) z with [R_fixture]=50 Ohms and [V_fixture]=0V1 ^, D. q5 H) u2 N* n1 L L
9 g% f; E: ~# Q) k an equivalent load applied to the model's I-V tables yields# a+ S' H9 Q' b9 E: v
* e' ]) {) |! | P- g+ w7 S; k1 g a difference of 0.73% and 2.15%, respectively.. z4 L6 k4 {0 R& [
: s7 c# h+ y& z0 g# {2 a; W/ j with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V
& h/ C& V& k# m) w% j! y" R) A has MAX column DC endpoints of 3.10V and 3.47v, but- f: s/ K) f5 U2 Y9 s( i1 c+ s% r
' m' _7 L0 h T different voltages ( 3.09V and 3.47V),+ M. O+ _7 t8 R% a. R: [0 z
0 F. `: U8 Y& i/ W# e [! @; wWARNING - Model lvc330s040gaaaaaaaou: The [Rising Waveform] 6 G1 Y7 ~, t! `" W. Z* ~
with [R_fixture]=50 Ohms and [V_fixture]=3.3V2 J4 K, X+ x, Q
has TYP column DC endpoints of 2.89V and 3.30v, but0 V' E( i/ f R, F
1 m8 h2 `# Q$ M. ^+ n- K! A g2 L. n different voltages ( 2.88V and 3.30V),
; N8 h8 D) V8 `8 [% @. K$ l a difference of 2.06% and 0.59%, respectively.
2 `+ D; ?# m( v& b' ~WARNING - Model lvc330s040gaaaaaaaou: The [Falling Waveform] % g0 ^1 d% n) V6 W p5 e
" F# D- u, C5 i& J; Z9 ^( } F; G* [ has TYP column DC endpoints of 0.00V and 0.43v, but+ K4 V5 V4 O. a- N2 \9 N; s
! T; M' {; O1 t7 z different voltages (-0.00V and 0.42V),8 o! a6 V* M+ d1 n+ y7 y
a difference of 0.73% and 2.15%, respectively.& C- D |$ O. _0 B7 [8 P* S, X' v1 I
, f# b9 H9 I: _* x9 Z with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V
+ C7 }+ b. h( o. S, E1 i* p" K9 c has MAX column DC endpoints of 3.10V and 3.47v, but
" B1 n& V/ S! b2 s+ C6 @ an equivalent load applied to the model's I-V tables yields
7 g" ^$ i% [ S/ f: i3 m6 K different voltages ( 3.09V and 3.47V),
Q; Q Z3 z- }7 w8 G/ c0 l' P a difference of 2.43% and 0.60%, respectively.
: d2 k @1 V0 Y9 z/ r! LWARNING - Model lvc330s040haaaaaaaio: The [Rising Waveform] . @5 T6 N$ u* R) X- k# j0 O+ L
with [R_fixture]=50 Ohms and [V_fixture]=3.3V) G7 y$ v ^6 @. ]; I
0 Z) h% R3 d3 n% x4 N W+ }' g \ an equivalent load applied to the model's I-V tables yields$ |6 D! @" U7 @! N
different voltages ( 2.88V and 3.30V),/ }3 i1 L, T/ \% k
a difference of 2.06% and 0.59%, respectively.# q! @) i+ E7 |4 X& h/ d6 t( R* r
WARNING - Model lvc330s040haaaaaaaio: The [Falling Waveform] 0 a& a0 p# Y: k: N* `
9 Z2 M, ?& D- k( c has TYP column DC endpoints of 0.00V and 0.43v, but
" A- m. X+ ^9 ?6 o8 k an equivalent load applied to the model's I-V tables yields* h* |# ]: a/ {+ ]: X9 |
different voltages (-0.00V and 0.42V),' ], h; S: o7 I( {$ X
' f" S- ~3 I% n) r3 mWARNING - Model lvc330s040haaaaaaaio: The [Rising Waveform] + g5 ?* g% G% f" T. i) L
with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V* m( s$ f$ l/ O0 d
/ u) `( ^$ N+ h. l3 w3 g1 N! n an equivalent load applied to the model's I-V tables yields
2 T% f& _( @' Y8 v/ i different voltages ( 3.09V and 3.47V),. V$ U7 q% I+ r' K/ j. d
; F7 y+ J% f) @ OWARNING - Model lvt330s040caaaaaaaio: The [Rising Waveform] 0 Q! T& ]8 A: t: M) [/ `1 o H
with [R_fixture]=50 Ohms and [V_fixture]=3.3V" G1 q0 s6 _( ?4 q9 c, U
9 `$ I- i3 c* [* W an equivalent load applied to the model's I-V tables yields0 \2 p4 h! b& G1 o# y+ K2 C
different voltages ( 2.88V and 3.30V),' B2 o& w, t! z/ N& p ]
4 E! ]/ [: E8 N6 T3 ^/ v) jWARNING - Model lvt330s040caaaaaaaio: The [Falling Waveform]
) T8 O- Q5 o' [% x with [R_fixture]=50 Ohms and [V_fixture]=0V
5 K v* M6 x8 h+ Q1 \$ x: n2 s has TYP column DC endpoints of 0.00V and 0.43v, but
4 H0 I, K: f' J& d, m/ A, l. } l an equivalent load applied to the model's I-V tables yields
1 Y" D" O9 [# h3 P/ }4 B different voltages (-0.00V and 0.42V),6 @) r) D% B8 O3 n
$ K! E1 h2 R/ \8 KWARNING - Model lvt330s040caaaaaaaio: The [Rising Waveform] . q1 K4 H' J0 F, m$ x0 F
% Y# n6 i+ `% D- I# @+ g has MAX column DC endpoints of 3.10V and 3.47v, but
* u" s/ Q+ q# I7 J2 T' p. { an equivalent load applied to the model's I-V tables yields
" j" c9 R6 J( o, z3 c different voltages ( 3.09V and 3.47V),
( M4 L' n2 O+ |" v a difference of 2.43% and 0.60%, respectively.$ _6 _4 {3 {% J/ i) B
WARNING - Model lvt330s040caaaaaaaou: The [Rising Waveform]
: L8 w1 Q3 h/ }: @6 U V with [R_fixture]=50 Ohms and [V_fixture]=3.3V
! `8 m6 x* ^" A# Z, T6 n) N has TYP column DC endpoints of 2.89V and 3.30v, but8 |: E+ z% d N, ]/ s% z+ U7 l4 K
) @, _4 ~% C! y, q5 [6 M. ]3 L different voltages ( 2.88V and 3.30V),* m5 c V. ~8 f$ f! _ d, Z
a difference of 2.06% and 0.59%, respectively.# z: \$ ~+ x: \
WARNING - Model lvt330s040caaaaaaaou: The [Falling Waveform]
, `0 I+ q1 q/ m F' m' F with [R_fixture]=50 Ohms and [V_fixture]=0V% T3 `' q; b- _4 K
has TYP column DC endpoints of 0.00V and 0.43v, but/ s+ @/ R+ B$ ~+ ? W6 f! w% _1 R
an equivalent load applied to the model's I-V tables yields0 m$ Z6 m0 |$ X% k5 i$ B7 Z+ H5 r
# Y, y- l# A3 W- i9 W a difference of 0.73% and 2.15%, respectively.( z5 d$ [3 D7 `* F$ F9 h
# A# p* }1 _1 }' [1 G with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V, v5 |% o7 G4 `/ l7 {" u: p
has MAX column DC endpoints of 3.10V and 3.47v, but) u; w" [8 N( L% `' o
7 Q( k) Z- l; _3 p; t4 \6 ` different voltages ( 3.09V and 3.47V),
, h& k1 j6 S- ~3 |0 H4 K a difference of 2.43% and 0.60%, respectively.% O/ L0 \+ m& U9 S6 Q3 j) @
WARNING - Model lvt330s040daaaaaaaio: The [Rising Waveform]
U6 ?! c2 M; z1 R4 j with [R_fixture]=50 Ohms and [V_fixture]=3.3V
7 l; W# H2 b1 [1 `5 i has TYP column DC endpoints of 2.89V and 3.30v, but
3 S5 `/ q4 g; I+ i' N% t an equivalent load applied to the model's I-V tables yields* N) I3 W7 G3 n8 h, e$ L8 o* }
different voltages ( 2.88V and 3.30V),; u! t$ b- {0 ~. e& D
; s8 p- |6 n# v3 `7 P, [. AWARNING - Model lvt330s040daaaaaaaio: The [Falling Waveform]
' C6 L0 t6 S: F$ A( s. ? with [R_fixture]=50 Ohms and [V_fixture]=0V
% i; H, v2 x" c8 N7 W$ p/ h8 h, v. V/ Z has TYP column DC endpoints of 0.00V and 0.43v, but
8 X4 [9 s$ e, b$ { an equivalent load applied to the model's I-V tables yields# y2 b$ d4 p8 A2 H" e) e1 Z) P# w
different voltages (-0.00V and 0.42V),8 [* X' r! P! C* N$ m! k5 k
a difference of 0.73% and 2.15%, respectively.+ a* G; ^2 h/ X; i+ O
WARNING - Model lvt330s040daaaaaaaio: The [Rising Waveform] 0 J' N Z; L/ p/ v Y
with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V4 |. W* T5 _% u9 W V" F
! V" B1 R3 V# } an equivalent load applied to the model's I-V tables yields9 g7 D2 _, u6 D
9 ~0 ~5 ^5 d( I0 B9 u. R& @7 @! h a difference of 2.43% and 0.60%, respectively. y& Z# `+ Y) K, [6 p2 g6 v* O+ v; }
WARNING - Model lvt330s040gaaaaaaaio: The [Rising Waveform] 0 k, \; C% u! d% x/ k
with [R_fixture]=50 Ohms and [V_fixture]=3.3V9 N( ^) p0 i- c& ]
has TYP column DC endpoints of 2.89V and 3.30v, but* H' ^, |) M8 M: n) z/ }- M
) z6 Y5 ~0 ^& j2 W5 w" N different voltages ( 2.88V and 3.30V),
) C3 f% m7 \0 y9 \! a- ?$ ~' } a difference of 2.06% and 0.59%, respectively.
+ B, ?) a% w7 L6 R" rWARNING - Model lvt330s040gaaaaaaaio: The [Falling Waveform] % x' c _. [0 m E" h( [. l; }; _
with [R_fixture]=50 Ohms and [V_fixture]=0V9 @1 t$ {8 N! m
has TYP column DC endpoints of 0.00V and 0.43v, but; L! N$ H6 H9 n; ]- C6 G
3 y( |! h1 x! R0 d' \( f6 o9 U different voltages (-0.00V and 0.42V),
# `/ G1 f; H4 j5 Q4 R/ C) {, G a difference of 0.73% and 2.15%, respectively.- }: t) f! |' n2 x2 p7 J
WARNING - Model lvt330s040gaaaaaaaio: The [Rising Waveform] % [. W, h. F. N6 W1 X' I6 v+ }
# X+ [! Z% y3 W$ d" l8 X; y7 l has MAX column DC endpoints of 3.10V and 3.47v, but$ P% g2 W. w& o- f4 N
6 q- Z. i6 P+ k: p different voltages ( 3.09V and 3.47V),/ I1 W" j* L% u9 i: [/ d. A
% W& v3 K- e- U; C V! y; rWARNING - Model lvt330s040gaaaaaaaou: The [Rising Waveform] $ V8 ~2 |2 B% e9 [4 I+ u
with [R_fixture]=50 Ohms and [V_fixture]=3.3V+ @5 ]# V0 d9 C! L4 w
0 }0 x7 }$ g$ }: t+ u- U an equivalent load applied to the model's I-V tables yields
" b! V1 g6 ]8 P: W' U: y different voltages ( 2.88V and 3.30V),
2 o' A3 p! i/ t$ t* A7 A a difference of 2.06% and 0.59%, respectively.
& S9 _7 Z- a! ^. W0 h) |WARNING - Model lvt330s040gaaaaaaaou: The [Falling Waveform] / f( `0 r: b `6 ]6 h* |8 ?
2 Z7 v. u% [- ?5 I% e3 p- X has TYP column DC endpoints of 0.00V and 0.43v, but0 @2 u, `* a2 [1 E) t: t4 u$ _
2 p$ }; f1 U) [7 t9 D( G different voltages (-0.00V and 0.42V),; k& p9 v% y' w
: }. M8 j6 [" Y7 v0 ZWARNING - Model lvt330s040gaaaaaaaou: The [Rising Waveform] 8 n# M5 U- `: ]' ?: S% R9 C
( `4 h& j1 W# @3 F* G has MAX column DC endpoints of 3.10V and 3.47v, but
& b% ~% z# P) F$ p# x an equivalent load applied to the model's I-V tables yields
* J$ a9 V1 g6 n, | different voltages ( 3.09V and 3.47V),6 c$ a: j) L% u
/ A U# i) s6 w! MWARNING - Model lvt330s040haaaaaaaio: The [Rising Waveform] * ~' l0 f2 m" e6 i! f" \8 z
$ b9 L! x# U- x- @$ b has TYP column DC endpoints of 2.89V and 3.30v, but% x! j/ _( W: W+ c) k
' K6 ^) W3 {; ?7 G1 e7 b. U4 ?. V1 O" C* h8 Z different voltages ( 2.88V and 3.30V),
! y! P- b4 ^4 k5 z a difference of 2.06% and 0.59%, respectively.
7 L4 ^0 M& g4 ]$ y, ^3 iWARNING - Model lvt330s040haaaaaaaio: The [Falling Waveform]
& X1 c9 |* D5 W+ } with [R_fixture]=50 Ohms and [V_fixture]=0V
; F2 Z2 `4 n2 v) Z( W$ J/ }3 u+ a8 C has TYP column DC endpoints of 0.00V and 0.43v, but K# [5 ~$ g, b5 `/ r d
2 n/ I8 o* G5 J2 {9 p/ z7 H- o different voltages (-0.00V and 0.42V),
& t9 O3 [1 i7 M! [ n9 Q4 W a difference of 0.73% and 2.15%, respectively.
6 `( v5 T# Q# d" V$ HWARNING - Model lvt330s040haaaaaaaio: The [Rising Waveform] 4 ], I2 K# v) T& y$ D( n
% T% \, k) ^, ]5 V% U, P has MAX column DC endpoints of 3.10V and 3.47v, but$ d* a- o/ D7 g; i
an equivalent load applied to the model's I-V tables yields3 s2 u7 w; t, U% G. A" U1 }
different voltages ( 3.09V and 3.47V),2 x; f: g' q7 b& u
9 k, A6 F. W/ f( [3 d3 cWARNING - Model lvc250s040caaaaaaaio: The [Rising Waveform]
3 k- F1 p( F! F. y4 h& G with [R_fixture]=50 Ohms and [V_fixture]=2.5V, _/ D- Y4 f" q: c2 Y& i
has TYP column DC endpoints of 2.10V and 2.50v, but3 j9 J/ r/ l; v6 b
8 m. M" D6 K8 _2 Q8 c2 d different voltages ( 2.09V and 2.50V),8 t3 B g& r6 y& f! h4 W- Z
a difference of 2.06% and 0.59%, respectively.7 r9 N' L; O3 v" _4 {, V
WARNING - Model lvc250s040caaaaaaaio: The [Rising Waveform] . J& ~; Z9 s/ Q, K4 ~! s
with [R_fixture]=50 Ohms and [V_fixture_max]=2.63V1 |. H( O. H# \/ _( t" \! ]( {
has MAX column DC endpoints of 2.27V and 2.63v, but' S5 b2 W# y: J& u% ^, L8 [
z2 E" Z& R l; K- @% v0 [ different voltages ( 2.26V and 2.63V),
. J. l9 {5 z% s8 ]9 x a difference of 2.43% and 0.62%, respectively.
! G% A; p5 o. l2 D; ?WARNING - Model lvc250s040caaaaaaaou: The [Rising Waveform] - y* m! ]% n9 Y( ^6 V4 q
with [R_fixture]=50 Ohms and [V_fixture]=2.5V( t3 x2 M/ V& F4 a6 ]/ g' V! R
* ]* r a7 y! z; y6 v5 g an equivalent load applied to the model's I-V tables yields
0 Z% u" d- R9 y% U" N8 l different voltages ( 2.09V and 2.50V),
0 F" I" ^4 i5 k0 H/ t. b a difference of 2.06% and 0.59%, respectively.. L" M1 H1 E1 `: j
9 v: J6 v! C9 a9 a+ ^4 d; S$ H% \ with [R_fixture]=50 Ohms and [V_fixture_max]=2.63V
! ^4 v+ N( M2 \1 E& P has MAX column DC endpoints of 2.27V and 2.63v, but6 v# W8 m# f& K, _$ @5 A# R
6 F& Y1 X9 \$ j% r+ ^, ^ different voltages ( 2.26V and 2.63V),
% o* Z4 a3 w3 v a difference of 2.43% and 0.62%, respectively.6 Z! M/ x5 q7 A! |( u
WARNING - Model lvc250s040daaaaaaaod: The [Rising Waveform]
# {* E& T' [, ~3 @; B with [R_fixture]=50 Ohms and [V_fixture]=2.5V2 G- f) S+ O' v: K
) R) d# W' M6 C) U2 b" M, e an equivalent load applied to the model's I-V tables yields+ m" f/ a6 l8 U2 {
5 Z1 ]. E$ }9 }0 t) g2 y z# q' E a difference of 2.52% and 0.02%, respectively.3 S1 @& L. D) t$ D
WARNING - Model lvc250s040gaaaaaaaio: The [Rising Waveform] 9 `2 `- c3 g( S( v2 z( ]$ h
( x5 Z% e, r' n0 e has TYP column DC endpoints of 2.10V and 2.50v, but
d! _' u4 J4 M6 R1 ~/ h an equivalent load applied to the model's I-V tables yields$ s5 z. M) _7 m2 l5 z; s
different voltages ( 2.09V and 2.50V)," Y2 x' o5 ^* _# A# w% {
; |) S& v) ^$ w. tWARNING - Model lvc250s040gaaaaaaaio: The [Rising Waveform]
- y0 p4 k5 _, O" u with [R_fixture]=50 Ohms and [V_fixture_max]=2.63V
- O, u) i& p9 y3 i ], i5 y has MAX column DC endpoints of 2.27V and 2.63v, but; V+ U! ]' F* Z5 d/ h
an equivalent load applied to the model's I-V tables yields7 r; | B' y) t" F6 |/ x0 A
different voltages ( 2.26V and 2.63V),; t9 D4 u. y* a- ?7 R' ^% F
a difference of 2.43% and 0.62%, respectively.0 _ ^) i& j3 ~7 F% S$ R$ Q _4 F
WARNING - Model lvc250s040gaaaaaaaou: The [Rising Waveform]
% j6 R; S& T8 F+ ?' R# F4 ~( w with [R_fixture]=50 Ohms and [V_fixture]=2.5V" }6 G6 l4 V2 _, M5 S
has TYP column DC endpoints of 2.10V and 2.50v, but" {1 L/ d2 z, A* s8 d
' @- H! R+ J% d" J different voltages ( 2.09V and 2.50V),
, S9 u- t0 [/ [ a difference of 2.06% and 0.59%, respectively.0 |- y8 @3 ~6 b
; {% }# E2 |5 M. R& C# k with [R_fixture]=50 Ohms and [V_fixture_max]=2.63V- W+ D) R c: I9 N5 c) P
has MAX column DC endpoints of 2.27V and 2.63v, but" L8 h; j* A, K8 k% _$ J
. p. k% C, H. \, o( K+ N& Q different voltages ( 2.26V and 2.63V),- g5 J' t F1 v: |6 Z: n
a difference of 2.43% and 0.62%, respectively.' c* R$ |- ]. G& z8 I7 `" L
WARNING - Model lvc250s040haaaaaaaod: The [Rising Waveform] % b. K m4 z9 A; C! f* l. S' h# b
# {- l9 u7 R' [1 [( ?! Z: u has TYP column DC endpoints of 2.10V and 2.50v, but8 J2 F! o! c% p3 T, a1 \0 C
an equivalent load applied to the model's I-V tables yields2 N7 E: |! C( U$ |4 c% s5 M) ^
1 N/ i/ w. J6 I; R& z+ `5 _ a difference of 2.52% and 0.02%, respectively.
" E( R2 J7 }$ u" b) }: o2 f6 h: W: M) iWARNING - Model lvc180s040baaaaaaaio: The [Falling Waveform] , H* Y! f0 }% U' Z/ r! z
with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V
( W- q& ^. E7 @ has MAX column DC endpoints of 1.53V and 1.89v, but
9 j5 q9 [1 O& Y3 p) ~1 Z- P- H an equivalent load applied to the model's I-V tables yields
# x* [" V( l1 O, k/ ~4 b( D. n different voltages ( 1.53V and 1.89V),
" _" x; f4 x) F C& y5 r Z1 M a difference of 2.48% and 0.34%, respectively. C8 B! t( @ t* R
WARNING - Model lvc180s040baaaaaaaou: The [Falling Waveform] . L9 c7 t, j, t& f9 N
9 z# K% P; J! |6 c- I$ ` has MAX column DC endpoints of 1.53V and 1.89v, but# W2 g) U0 X2 T+ `7 H0 T
an equivalent load applied to the model's I-V tables yields5 l$ O- X- j! q" r# o8 v" |
different voltages ( 1.53V and 1.89V),7 T; i8 I( Y& L* W
5 f* `1 H9 \3 m" lWARNING - Model lvc180s040caaaaaaaio: The [Rising Waveform] 8 |7 F7 f1 D0 h. j( e
with [R_fixture]=50 Ohms and [V_fixture]=1.8V9 K/ O0 |$ w( H, q4 x5 b
has TYP column DC endpoints of 1.41V and 1.80v, but4 W0 @; V( |/ G5 r
9 `+ k( K/ V5 V6 K$ I) |0 V* B different voltages ( 1.40V and 1.80V),
$ y$ [# C! T' f9 D a difference of 1.99% and 0.58%, respectively.. _2 j8 t7 E ?# t% E F; F
WARNING - Model lvc180s040caaaaaaaio: The [Falling Waveform]
. {+ v* I. u3 W1 S with [R_fixture]=50 Ohms and [V_fixture]=0V0 D% k9 M5 i; S2 ~ L5 |& z: H
has TYP column DC endpoints of 0.00V and 0.39v, but
' |4 I7 @ @( b" Y, Z7 | an equivalent load applied to the model's I-V tables yields4 k' w. {" J, e* ^
different voltages (-0.00V and 0.38V),0 `8 w$ V/ y$ Y$ J4 [! x
a difference of 0.56% and 2.13%, respectively.
5 C H6 F4 f8 UWARNING - Model lvc180s040caaaaaaaio: The [Falling Waveform] 6 r6 }; w' }- x& `( k: w! _
with [R_fixture]=50 Ohms and [V_fixture_min]=0V. F- r+ d$ m3 @8 V. Y
has MIN column DC endpoints of 0.00V and 0.37v, but
( R* M4 r" Z( f( R8 t+ E- \- G an equivalent load applied to the model's I-V tables yields' k$ e3 F) D' {/ k8 ~8 I8 k3 M
different voltages (-0.00V and 0.36V),
; J& b9 o) Q4 ^, d6 v% z/ R! | a difference of 1.00% and 2.21%, respectively.
' ]7 J, D2 D1 ]0 Z! E/ hWARNING - Model lvc180s040caaaaaaaio: The [Rising Waveform]
+ A" l+ f4 J) z2 K( n+ k/ X0 _ with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V' Z5 a9 b! u& k0 L8 Z; Z
has MAX column DC endpoints of 1.52V and 1.89v, but
. l) L/ x$ ^: b% Q an equivalent load applied to the model's I-V tables yields/ q/ K m$ N, F+ ?: e* |& O, F
different voltages ( 1.52V and 1.89V),
5 }9 H$ |+ Y5 |7 _5 B" T, n. u a difference of 2.28% and 0.63%, respectively.
1 j) @5 M0 p* R& I2 _% J# mWARNING - Model lvc180s040caaaaaaaio: The [Falling Waveform] 3 i9 i, T/ N/ d4 Z7 o7 f2 e
with [R_fixture]=50 Ohms and [V_fixture_max]=0V
- [) w0 F2 G$ c: f5 Q( B has MAX column DC endpoints of 0.00V and 0.37v, but7 d$ E, o/ S% z- ^* M# X
; k) n/ m/ [& I6 @" N4 g different voltages ( 0.00V and 0.36V)," o1 _; w, j6 F5 b, A
a difference of 0.06% and 2.14%, respectively.% Y: a6 z2 K' H/ z# F
WARNING - Model lvc180s040caaaaaaaou: The [Rising Waveform] & Q- @. [- A4 h* }+ h; f) V
, r; A" ?/ {+ H( I: z% n7 O has TYP column DC endpoints of 1.41V and 1.80v, but5 N) e( o5 }5 H- ]& {" f. |
an equivalent load applied to the model's I-V tables yields7 D! C ^# n( Z* X: U
. M9 C! z) ?: l4 l a difference of 1.99% and 0.58%, respectively.
1 U0 E/ j/ D% i ?WARNING - Model lvc180s040caaaaaaaou: The [Falling Waveform]
- y# ]& f( f5 e* f' V% s) U+ o! r2 ? with [R_fixture]=50 Ohms and [V_fixture]=0V
( A) p' d, `4 N2 p- s4 o* k has TYP column DC endpoints of 0.00V and 0.39v, but
, O. H- d. U7 v' E, }) I an equivalent load applied to the model's I-V tables yields
" a* Y& N6 ~& Y; ?5 ~2 x5 d! N' D" t different voltages (-0.00V and 0.38V),
4 X3 m0 {: K# Y: z a difference of 0.56% and 2.13%, respectively.
7 q' i# d0 G/ `7 }7 V) X- OWARNING - Model lvc180s040caaaaaaaou: The [Falling Waveform] 7 I6 g7 N9 W2 R5 A* W, j
/ e6 l- E( k3 q# B' o1 i0 J has MIN column DC endpoints of 0.00V and 0.37v, but/ j6 h. Y/ P) l* |+ N& g
: A W9 x+ N. X6 O different voltages (-0.00V and 0.36V),# ]+ {7 p3 s: s4 W# i9 g3 @4 p
/ W! |/ x7 U' J; U' L* F4 G( H7 J6 lWARNING - Model lvc180s040caaaaaaaou: The [Rising Waveform]
6 }; C9 B" L7 ]; O with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V, p7 R/ F3 K, G9 l1 j
$ f# o/ Z) P8 G- |2 M an equivalent load applied to the model's I-V tables yields
: ] K! c9 J0 Z different voltages ( 1.52V and 1.89V),
+ z$ d9 x4 r: g) k* {* `5 D a difference of 2.28% and 0.63%, respectively.
) n. w9 q8 ]* q, ]) |2 KWARNING - Model lvc180s040caaaaaaaou: The [Falling Waveform]
" x* w T- a! J( p with [R_fixture]=50 Ohms and [V_fixture_max]=0V, I" {( G0 `% q; B$ W+ a9 c- K0 ^
4 R$ s& [: }) N' I" P( J an equivalent load applied to the model's I-V tables yields
9 L3 a0 ?8 L4 u' E$ d/ ?+ ] different voltages ( 0.00V and 0.36V),
. C6 {8 d0 _8 O( P# M a difference of 0.06% and 2.14%, respectively.
* z% }5 Q" j# n xWARNING - Model lvc180s040daaaaaaaio: The [Falling Waveform] ) G6 X$ _" M. u
with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V( U \+ E- M$ N( S2 U
e- _# @1 e8 p8 O* P an equivalent load applied to the model's I-V tables yields0 f2 a5 u8 z* N c& z( ]. x
! U6 Z6 z: E5 ^1 N' K) ~# x a difference of 2.48% and 0.34%, respectively.
+ a4 j- v) S6 W/ H& V; @+ f" |4 RWARNING - Model lvc180s040daaaaaaaod: The [Rising Waveform] % S, h/ a" F( f5 N0 s; d
with [R_fixture]=50 Ohms and [V_fixture_min]=1.71V
3 E# X8 K2 g6 Y9 c9 R has MIN column DC endpoints of 1.25V and 1.71v, but$ N9 O/ U. r" W' l% C( K
/ Z4 U' Q$ u- d+ V# f+ s9 E; n different voltages ( 1.27V and 1.71V),
* z. `/ q3 b- i% N* Z ~ a difference of 4.46% and 0.02%, respectively." [( C J, d, U) E. ]; ~/ v/ ]0 N0 D% V
WARNING - Model lvc180s040daaaaaaaou: The [Falling Waveform]
# C5 `8 l8 X! N/ |7 \( Z3 I/ {+ J with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V
, b m [6 K: |" \$ W1 t has MAX column DC endpoints of 1.53V and 1.89v, but
# d1 W* _1 f# G6 } an equivalent load applied to the model's I-V tables yields! Y0 r) e' k* F7 a- q9 N1 o G
different voltages ( 1.53V and 1.89V),; F4 o; z R( l5 a& U
a difference of 2.48% and 0.34%, respectively.* v: s! D/ ?3 e
WARNING - Model lvc180s040faaaaaaaio: The [Falling Waveform] 3 n' ^: t+ d$ c2 k$ u: D% ^
/ M( X J* y4 m; D V j has MAX column DC endpoints of 1.53V and 1.89v, but
/ D+ N5 \$ _/ d an equivalent load applied to the model's I-V tables yields
$ h2 L ~) e4 I4 C% O/ J% U different voltages ( 1.53V and 1.89V),' X2 G( Z" O+ E* G& S9 D! A
+ t6 i- D# F( a$ U# N, OWARNING - Model lvc180s040faaaaaaaou: The [Falling Waveform]
7 z; B+ r0 A6 |2 D with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V
V8 i. f4 |" x7 [6 t6 [! w has MAX column DC endpoints of 1.53V and 1.89v, but
; q! q F/ q0 @+ J( U2 b; y an equivalent load applied to the model's I-V tables yields
: x$ T% U. r7 o1 } different voltages ( 1.53V and 1.89V),
) C' i2 k3 S$ s7 `0 k a difference of 2.48% and 0.34%, respectively.( L4 F, `" ?3 k, V5 c: ]' K0 F \
WARNING - Model lvc180s040gaaaaaaaio: The [Rising Waveform]
# E. G7 ^+ K3 b: H9 e with [R_fixture]=50 Ohms and [V_fixture]=1.8V
; r3 R# Q2 v; F has TYP column DC endpoints of 1.41V and 1.80v, but7 x4 ]! o5 f! e
an equivalent load applied to the model's I-V tables yields2 y1 }: C1 P1 g2 S& ?
different voltages ( 1.40V and 1.80V)," O& b! q) l0 E8 ]+ D6 t! @- G
a difference of 1.99% and 0.58%, respectively.7 A) k. z) u! U$ T; q( a
WARNING - Model lvc180s040gaaaaaaaio: The [Falling Waveform] 7 u3 o% u7 N1 }% z
8 M+ a7 {! K2 }$ R has TYP column DC endpoints of 0.00V and 0.39v, but
$ p5 {6 c3 ^) ?% V an equivalent load applied to the model's I-V tables yields f3 d' f- W2 X' n8 n$ v& M6 v
different voltages (-0.00V and 0.38V),4 M1 ]/ s9 R3 E+ [% V4 z3 w0 {
a difference of 0.56% and 2.13%, respectively.# l% f, y- N2 c% g0 }
WARNING - Model lvc180s040gaaaaaaaio: The [Falling Waveform] & R, R0 L( c. L s
3 v7 s i/ s; }2 O0 X has MIN column DC endpoints of 0.00V and 0.37v, but
) x) `, m' D% Z" S ?3 e an equivalent load applied to the model's I-V tables yields! _* ~9 b% j2 s; H! Z4 v Q4 J- `, ]
( ]2 s3 o$ P% `0 F a difference of 1.00% and 2.21%, respectively., o0 @9 A- K* J6 v" R
2 f6 j9 a* H, g0 Z. y% T3 K0 p; r2 \ with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V
6 [1 J; Z' y3 T/ m) O$ I8 Z6 Q* [ has MAX column DC endpoints of 1.52V and 1.89v, but0 Z7 R4 c( m$ B2 R
an equivalent load applied to the model's I-V tables yields' J9 @. j/ F4 C3 }% f
different voltages ( 1.52V and 1.89V),2 K$ f* L8 ~5 M6 n! E. c7 T3 Q: {
a difference of 2.28% and 0.63%, respectively.$ V7 u" h1 M& P8 \1 f" T7 w; W- ]
+ \4 g3 \+ N0 C' J- ^ with [R_fixture]=50 Ohms and [V_fixture_max]=0V
& I9 R# }/ @8 R5 B2 @ has MAX column DC endpoints of 0.00V and 0.37v, but7 J! Y, H1 w# `( d/ o( g
an equivalent load applied to the model's I-V tables yields, e; ~ ^% [, U
different voltages ( 0.00V and 0.36V),4 y; P* c' T! y% q
a difference of 0.06% and 2.14%, respectively.- Q5 T) j0 i& a
WARNING - Model lvc180s040gaaaaaaaou: The [Rising Waveform] * M, j- R0 O# b- t
3 f% ~# n6 e# d; M8 s( g has TYP column DC endpoints of 1.41V and 1.80v, but
0 ]4 S3 t; a6 B! f an equivalent load applied to the model's I-V tables yields
5 P# v$ `, J& C, \ different voltages ( 1.40V and 1.80V),
0 r' [$ r9 Z5 V" H0 Q$ W8 a; R: k% k a difference of 1.99% and 0.58%, respectively.
$ q8 i3 R" d7 h! `% IWARNING - Model lvc180s040gaaaaaaaou: The [Falling Waveform]
9 U: K9 i1 L; O: F5 _ with [R_fixture]=50 Ohms and [V_fixture]=0V) P. Z" ?" B4 @' ?3 k8 R2 Y
has TYP column DC endpoints of 0.00V and 0.39v, but5 B% L/ Z3 M4 |7 q& B2 @+ O! ^
an equivalent load applied to the model's I-V tables yields7 r4 E; I9 j- G+ Z w7 \
& d) k+ G. |- k. `, R- O/ } a difference of 0.56% and 2.13%, respectively.
) F: d* K1 @* m8 a3 F0 CWARNING - Model lvc180s040gaaaaaaaou: The [Falling Waveform] ! w9 E* U, E" ^9 _) j, x. w
with [R_fixture]=50 Ohms and [V_fixture_min]=0V' V, _3 z/ d5 A/ J$ C3 u! n+ X
# l' W, l5 M9 j2 O an equivalent load applied to the model's I-V tables yields
0 x4 p% O+ t( \" I5 C3 I different voltages (-0.00V and 0.36V),
) c) v: Q: `" ^3 B) p3 h y a difference of 1.00% and 2.21%, respectively.
) K9 E( A3 T( L, A! i- O. c3 s, X6 VWARNING - Model lvc180s040gaaaaaaaou: The [Rising Waveform]
0 J7 _# m5 ^) d+ U. I with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V: `' |# y* Z k+ j% S) \1 D
has MAX column DC endpoints of 1.52V and 1.89v, but+ n& F4 ~# ]9 }3 o5 `* ]( s% `
an equivalent load applied to the model's I-V tables yields$ |5 I) i5 W) d. Z9 t
different voltages ( 1.52V and 1.89V),! @3 P4 e: D3 j/ x( J. P+ K
a difference of 2.28% and 0.63%, respectively.9 p% u' P$ p7 e2 y
WARNING - Model lvc180s040gaaaaaaaou: The [Falling Waveform] : e- P" [5 h$ v- C, Q, S3 Q" p
; w P$ @% `+ Y! F* r has MAX column DC endpoints of 0.00V and 0.37v, but
% G2 E+ l" j( U% ?9 ?& | an equivalent load applied to the model's I-V tables yields" {( l9 P5 c' P3 S7 x
t' d" V' Y0 ^5 b9 O$ v a difference of 0.06% and 2.14%, respectively.: g( z& o& I( }$ [$ e
WARNING - Model lvc180s040haaaaaaaio: The [Falling Waveform]
9 P) C+ W1 T' K o! F. T with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V
- Y7 g+ Z4 ?% r; W6 Y: r5 u5 P has MAX column DC endpoints of 1.53V and 1.89v, but
. ~" a6 C2 c( N6 H an equivalent load applied to the model's I-V tables yields6 m# h- S+ U4 u7 Z; ]
different voltages ( 1.53V and 1.89V),) K- y$ T: r/ D, {7 i+ w
a difference of 2.48% and 0.34%, respectively.; J0 e# o) ~2 d3 w" G* M
WARNING - Model lvc180s040haaaaaaaod: The [Rising Waveform] * w4 P/ X. L6 U
! ? S5 F5 P( |! @1 u) K" q- u has MIN column DC endpoints of 1.25V and 1.71v, but
. R. `) `2 f2 }* c0 [0 y+ R an equivalent load applied to the model's I-V tables yields
0 D, f* o9 B$ j/ Q different voltages ( 1.27V and 1.71V), Y! U. G* h( D! P
3 B+ }0 s @4 H/ p. f2 U7 AWARNING - Model lvc180s040haaaaaaaou: The [Falling Waveform] 8 P" r6 f: {% u7 L8 S$ a8 |6 G
with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V7 w4 @, T7 Q5 Y0 ?( g# ~. S6 e
; r+ H m/ v3 g/ W' p( m. [) q an equivalent load applied to the model's I-V tables yields4 F. Q- u/ V2 ?2 W1 U- {5 h
) S& l* R' V* R" N a difference of 2.48% and 0.34%, respectively.. i: Y% I3 u1 G8 y, H0 v) M
WARNING - Model lvc150s040baaaaaaaio: The [Falling Waveform] 0 |' e w% ~& Z5 [
with [R_fixture]=50 Ohms and [V_fixture]=1.5V
# Z2 L( q! o# [. Q1 f) H. _. b has TYP column DC endpoints of 1.12V and 1.50v, but! g/ i% D- I9 v! Y# [& l
an equivalent load applied to the model's I-V tables yields% u3 M8 L& X: ?1 R
different voltages ( 1.12V and 1.50V),# r6 P$ E1 x' H) j5 L
a difference of 2.13% and 0.00%, respectively.4 k& l8 B x# h) h
WARNING - Model lvc150s040baaaaaaaio: The [Rising Waveform]
9 B& A8 v0 D9 F2 p& v, ]1 I with [R_fixture]=50 Ohms and [V_fixture_max]=0V
# j, e# n8 O% i0 } has MAX column DC endpoints of 0.00V and 0.32v, but
+ S0 b% Q+ H: e3 f" ^ an equivalent load applied to the model's I-V tables yields
* x! C- C/ |2 V different voltages ( 0.00V and 0.32V),
{ h5 v+ ^, o$ W. t- w a difference of 0.02% and 2.56%, respectively.
2 r1 s& {1 v3 n$ {" b nWARNING - Model lvc150s040baaaaaaaou: The [Falling Waveform] ; m* p% p8 `) l* R4 }
4 ~# W- C4 C* k/ w' E/ d* f has TYP column DC endpoints of 1.12V and 1.50v, but
0 w2 X- \5 \6 M2 M4 }) M3 f an equivalent load applied to the model's I-V tables yields
; s+ f8 c0 [4 q- { different voltages ( 1.12V and 1.50V),) r$ H: \/ Z% N/ P9 M' I6 r
7 Z# i7 C7 n$ k. ]/ |" HWARNING - Model lvc150s040baaaaaaaou: The [Rising Waveform]
% a& O& ?/ E# g, Y4 t with [R_fixture]=50 Ohms and [V_fixture_max]=0V7 b; l% s L9 ?6 n% ?# a! y
has MAX column DC endpoints of 0.00V and 0.32v, but' K5 I( F0 H( C7 q# N( m3 f
an equivalent load applied to the model's I-V tables yields" I a g, e6 G2 p v# W
3 c' F; Y+ [+ l |$ J1 P& \% ^ a difference of 0.02% and 2.56%, respectively.
* s( |# [+ n" x6 c7 q- ]. `& CWARNING - Model lvc150s040caaaaaaaio: The [Falling Waveform] 9 G$ t3 V: h) q" \. x1 u; p( J1 g! m
7 Q( n! o$ \% n8 l( K% s1 w has TYP column DC endpoints of 0.00V and 0.34v, but
5 ~ T6 x0 h' y7 {4 L: n$ R& r an equivalent load applied to the model's I-V tables yields
, k% x, g0 [8 P, W4 f" O different voltages (-0.00V and 0.33V),
# Z9 h. [( o8 N! ]; o* ?3 I r! a( `% z a difference of 0.61% and 2.35%, respectively.
* n& X, k2 U/ j. S+ eWARNING - Model lvc150s040caaaaaaaio: The [Falling Waveform] + d+ u# w( s# e5 \" k: Y; s3 L
with [R_fixture]=50 Ohms and [V_fixture_min]=0V, Q% p& b1 x7 d; L6 r
has MIN column DC endpoints of 0.00V and 0.35v, but
) |$ Z2 {% x* P7 ]) f" n9 B an equivalent load applied to the model's I-V tables yields
+ J' y3 i# s, l# `6 e! ?7 D- v, ?1 M different voltages (-0.00V and 0.34V),4 F# U, `$ k$ ?
a difference of 0.94% and 2.22%, respectively.
% B3 b9 w, ?& v- H+ \& Q7 WWARNING - Model lvc150s040caaaaaaaio: The [Rising Waveform]
3 G- ]0 M) O/ N$ ~$ X: a- x% e with [R_fixture]=50 Ohms and [V_fixture_max]=1.58V- G9 |9 @! S$ F! d. z" ~; L6 D
has MAX column DC endpoints of 1.22V and 1.58v, but5 n) A7 H: C& B8 F |. e
5 [; l: L4 Y3 n1 z- b different voltages ( 1.21V and 1.58V),4 E8 L8 u4 v6 F& B6 U$ S# h
a difference of 2.26% and 0.66%, respectively.
9 R9 R! c0 v0 l8 lWARNING - Model lvc150s040caaaaaaaio: The [Falling Waveform] 7 B8 B0 z% R4 n R: n% B2 J
- G4 z; d, ^! e8 g0 J# D has MAX column DC endpoints of 0.00V and 0.32v, but
% K' g3 g9 m7 r an equivalent load applied to the model's I-V tables yields
) w J+ e8 b1 f+ }2 Q4 r. f different voltages ( 0.00V and 0.31V),$ _+ u* O1 h" G* S7 D
a difference of 0.10% and 2.37%, respectively.: ?* m0 N, w1 u4 x/ a: S' R
WARNING - Model lvc150s040caaaaaaaou: The [Falling Waveform] ' n7 ^. ~" l' m: W
0 g/ ^/ a6 w/ f has TYP column DC endpoints of 0.00V and 0.34v, but
& I" U( X0 h. J an equivalent load applied to the model's I-V tables yields, r3 W; g) `+ ^7 N* d3 ~
/ {* t. y3 \. Y+ K a difference of 0.61% and 2.35%, respectively.
0 S* o) p% }: g2 |9 }WARNING - Model lvc150s040caaaaaaaou: The [Falling Waveform] 8 ]0 S8 U8 O- ^4 d( Y U! k
with [R_fixture]=50 Ohms and [V_fixture_min]=0V( y, A% q9 X3 V H$ v8 w- _
5 i- A/ o* g- c N; i+ } an equivalent load applied to the model's I-V tables yields
( J, x8 J: e5 S% |; ~$ @ different voltages (-0.00V and 0.34V),
# I* ?) |$ t( @, I a difference of 0.94% and 2.22%, respectively.
2 p* ^7 v) W1 {WARNING - Model lvc150s040caaaaaaaou: The [Rising Waveform] % }2 @) \3 F0 g% C" F
with [R_fixture]=50 Ohms and [V_fixture_max]=1.58V5 l. ^/ O" t! u1 B9 T( t7 Z
has MAX column DC endpoints of 1.22V and 1.58v, but; I6 s( }' e& l! u( y4 l, l8 _
) D1 k! F: h, ^ different voltages ( 1.21V and 1.58V),
e p' C0 E! J8 t5 `2 Z7 P a difference of 2.26% and 0.66%, respectively.# v- ]$ U; I# _# N2 i8 r
6 H3 Z# y& Y" J+ a with [R_fixture]=50 Ohms and [V_fixture_max]=0V( m7 F! ^' G! y% R; h
$ n/ ]3 `/ s3 ]/ a an equivalent load applied to the model's I-V tables yields
: T6 y T9 ?2 v' j) \ different voltages ( 0.00V and 0.31V),$ j+ A( ^; y. V; y* ~
% v/ v( g) ~* n. E- wWARNING - Model lvc150s040daaaaaaaio: The [Falling Waveform] & x, @8 H0 Y2 Y) a/ o; z, k# C3 m
with [R_fixture]=50 Ohms and [V_fixture]=1.5V% k; k; n2 S, p% C, f m, `
has TYP column DC endpoints of 1.12V and 1.50v, but7 C# P; n' B4 S: n( j# _. [
an equivalent load applied to the model's I-V tables yields# X1 P8 k, m. i! W! }
different voltages ( 1.12V and 1.50V),3 o% j, ?" M5 k& _1 x( u! o; E1 z
" M: D- D7 S# ~! BWARNING - Model lvc150s040daaaaaaaio: The [Rising Waveform] ) I0 V' }2 i' M
/ P! E- Y6 M. o w, _% B1 Q has MAX column DC endpoints of 0.00V and 0.32v, but
' P9 B) x" E% i/ g% L5 s. \: @ an equivalent load applied to the model's I-V tables yields
" {' j4 I/ P: O/ r, B& Y( F# ^ different voltages ( 0.00V and 0.32V),
/ |2 {- \5 `. ]* H1 Y% `% c2 j1 Q a difference of 0.02% and 2.57%, respectively.
- v2 o" A8 z4 V3 RWARNING - Model lvc150s040daaaaaaaou: The [Falling Waveform] ' ?0 H% T" ~& j% U2 _3 H% L4 I: M2 V
with [R_fixture]=50 Ohms and [V_fixture]=1.5V- N3 E- ~5 f& c
has TYP column DC endpoints of 1.12V and 1.50v, but: C8 G7 Q8 R8 N$ ?/ s; H% p! l, Y
an equivalent load applied to the model's I-V tables yields& j/ z$ h7 x& f
different voltages ( 1.12V and 1.50V),7 c4 e1 D: @) b5 c: U! I
5 T# p& r, C4 U+ Y( q( [3 N' E5 a8 [; XWARNING - Model lvc150s040daaaaaaaou: The [Rising Waveform] / _! m# T5 ~4 s% W1 T
( \# G! x! k4 _$ A1 i+ }2 c0 b has MAX column DC endpoints of 0.00V and 0.32v, but
4 w, p3 ^, \, G9 N9 { m! z an equivalent load applied to the model's I-V tables yields/ ]: N# M6 `% @4 x- C Y
different voltages ( 0.00V and 0.32V),7 o! [ M9 E, r6 y& b
- b' n2 l9 ^" \0 T+ L' K% rWARNING - Model lvc150s040faaaaaaaio: The [Falling Waveform] & A2 N8 F* ~' [ ~/ m2 b. I9 M8 ~
with [R_fixture]=50 Ohms and [V_fixture]=1.5V6 r" W2 b. F9 N# _& q
has TYP column DC endpoints of 1.12V and 1.50v, but, d; k% H- \2 H7 y
an equivalent load applied to the model's I-V tables yields0 ?( @1 G1 Z6 G% ^6 d
( H% E2 d: v8 Z. O! n t a difference of 2.13% and 0.00%, respectively.
- C/ p0 {5 ~3 _. M. e X& vWARNING - Model lvc150s040faaaaaaaio: The [Rising Waveform] F" O X& Z( \2 _4 c
) ?' `, o! X9 l* a8 } [ has MAX column DC endpoints of 0.00V and 0.32v, but( \! V1 F; t. I
+ ~3 Y1 g. r- a* X) n different voltages ( 0.00V and 0.32V),
: f; j8 S$ I9 g" ?7 q7 V a difference of 0.02% and 2.56%, respectively.3 I0 }4 ]5 C% A; t. {6 c9 H
WARNING - Model lvc150s040faaaaaaaou: The [Falling Waveform] ; B; o& H3 u" {2 r. x
" d% Q0 X5 f) N/ t4 x/ q" z has TYP column DC endpoints of 1.12V and 1.50v, but
; [2 U( s8 p% ^7 F1 K# [. i9 z2 [ an equivalent load applied to the model's I-V tables yields
, C1 a7 R1 F& N- _ | different voltages ( 1.12V and 1.50V),
# |: Y$ a- _; c7 t9 n1 P7 z a difference of 2.13% and 0.00%, respectively.
/ |( @4 e. v6 n4 dWARNING - Model lvc150s040faaaaaaaou: The [Rising Waveform] 9 e* @! k/ y$ E4 b+ O ~$ t+ e! p
% D& \+ ]2 r3 J) h: i has MAX column DC endpoints of 0.00V and 0.32v, but1 ]# K7 l) J$ F. ~" {$ W( q' O5 B
3 i. F8 L$ Q/ ]$ P different voltages ( 0.00V and 0.32V),
$ m# r0 A5 J! r5 G; y a difference of 0.02% and 2.56%, respectively.
s2 W# F/ [* Z+ H+ XWARNING - Model lvc150s040gaaaaaaaio: The [Falling Waveform]
Z4 U. u. ^6 Z6 J' j# [0 _; `0 ` with [R_fixture]=50 Ohms and [V_fixture]=0V
- m( j3 R( _3 r; x1 q" A1 y4 p4 | has TYP column DC endpoints of 0.00V and 0.34v, but
3 k! `0 M$ y& {+ Q' P- j8 m# m an equivalent load applied to the model's I-V tables yields
- T' T) I2 p9 K; f2 b! w7 ~- ? different voltages (-0.00V and 0.33V),
5 d, q$ B( P5 a/ y) `: z a difference of 0.61% and 2.35%, respectively.! U9 s/ h" i: k( l1 m
# P; O) e+ m' J1 A with [R_fixture]=50 Ohms and [V_fixture_min]=0V
: {. R- ~; Z; X/ N; R6 q: |" x. y, f' g has MIN column DC endpoints of 0.00V and 0.35v, but
2 x& g5 t+ ^2 c7 W/ |7 \6 T" D an equivalent load applied to the model's I-V tables yields
) d2 f/ ]8 q* w/ w different voltages (-0.00V and 0.34V),
! ], I) p4 M) d; i) m% s) k a difference of 0.94% and 2.22%, respectively.
u3 t3 Z1 @9 A# g$ |' v+ U* K! `WARNING - Model lvc150s040gaaaaaaaio: The [Rising Waveform] b' b* m; l* K- E' S
with [R_fixture]=50 Ohms and [V_fixture_max]=1.58V* H7 }( q: j) U/ q$ N
has MAX column DC endpoints of 1.22V and 1.58v, but8 D+ {' Q& o' h0 R5 X5 D: V
an equivalent load applied to the model's I-V tables yields" v7 g& @) R1 }/ U9 M- i. F9 @
/ h: O, _( Z/ q% C9 \: | a difference of 2.26% and 0.66%, respectively.
% }( n0 t j0 }WARNING - Model lvc150s040gaaaaaaaio: The [Falling Waveform]
5 G. U7 P- O9 [" G; I/ J2 [, J' j5 T with [R_fixture]=50 Ohms and [V_fixture_max]=0V
|- c4 X: @1 H+ f/ }( j has MAX column DC endpoints of 0.00V and 0.32v, but# g) k# a8 U3 d* P# k
an equivalent load applied to the model's I-V tables yields% u: K; |. G2 d7 a" G6 h
) w/ |1 }# @6 x a difference of 0.10% and 2.37%, respectively.
/ t3 D# u+ u# C S0 N+ X- {; KWARNING - Model lvc150s040gaaaaaaaou: The [Falling Waveform] & g8 K( c) B) r: R: R' \+ l
with [R_fixture]=50 Ohms and [V_fixture]=0V9 ]+ p' Y) J' X# M) c
0 k7 l+ m+ f, ]) L7 R5 J2 H an equivalent load applied to the model's I-V tables yields2 [7 Q0 T. O/ g; Z
! n: ? a- K# ^7 [) u7 B2 V2 Y$ o a difference of 0.61% and 2.35%, respectively.
. f. _; y y' oWARNING - Model lvc150s040gaaaaaaaou: The [Falling Waveform] + M; I; I* n& @' p s4 c& g7 t ]
& P& I- B- w3 E5 ?" } has MIN column DC endpoints of 0.00V and 0.35v, but
; U0 f' o T1 @; _1 u9 ^ an equivalent load applied to the model's I-V tables yields/ k0 d4 X9 d( Z; M6 K! m2 q2 e
different voltages (-0.00V and 0.34V),1 m6 ]+ i5 T* O$ J! W
0 J( L/ {( ^$ Y q. E! P8 j& e/ QWARNING - Model lvc150s040gaaaaaaaou: The [Rising Waveform] 6 e+ y, v7 F' l+ @+ F
with [R_fixture]=50 Ohms and [V_fixture_max]=1.58V0 [; b6 Q! K( [. a: D2 h
) n s+ i* U9 \' |& z an equivalent load applied to the model's I-V tables yields
: h0 _- A+ n6 i6 P5 M different voltages ( 1.21V and 1.58V),& `0 w" F0 x3 H1 E6 M E
a difference of 2.26% and 0.66%, respectively.8 _3 k. l: w7 ?' P) i! B/ [) n
WARNING - Model lvc150s040gaaaaaaaou: The [Falling Waveform] * ^" X4 I7 |3 e9 f
% L* X$ Y2 j* g$ t has MAX column DC endpoints of 0.00V and 0.32v, but
/ o/ M! Q! A* q) o& I" Z+ f8 U an equivalent load applied to the model's I-V tables yields
. }- @* X8 g9 E. d2 y7 U7 _: c different voltages ( 0.00V and 0.31V),0 X) Q) Z: D: N ]6 q3 O
" M8 V7 C' A) O3 E; c4 Y% s# HWARNING - Model lvc150s040haaaaaaaio: The [Falling Waveform]
2 m9 ^; d" Y; f. I( Y% a: [ with [R_fixture]=50 Ohms and [V_fixture]=1.5V
# c$ G: n9 d- ?. ` a has TYP column DC endpoints of 1.12V and 1.50v, but
/ A4 d* J+ D7 n& `/ L! c7 k an equivalent load applied to the model's I-V tables yields
% s" m& {6 p9 |& h m$ d different voltages ( 1.12V and 1.50V),
' l+ T) F3 X7 v- J0 c+ } a difference of 2.13% and 0.00%, respectively.
, q8 O, T9 E( i$ [5 rWARNING - Model lvc150s040haaaaaaaio: The [Rising Waveform]
' i, H6 u u; R5 c' S, p+ j( g with [R_fixture]=50 Ohms and [V_fixture_max]=0V6 t$ u) w2 [# k2 i( F v) R0 g+ O
has MAX column DC endpoints of 0.00V and 0.32v, but' t9 B& [# {+ E( Z# V
an equivalent load applied to the model's I-V tables yields6 C: M+ U0 P1 ^4 R* w! ~( |3 ^
different voltages ( 0.00V and 0.32V),, S% p: W) i% j8 ]6 u! e- x
a difference of 0.02% and 2.57%, respectively.9 R/ @" P3 K* M+ P8 q1 ^
WARNING - Model lvc150s040haaaaaaaou: The [Falling Waveform] " ?7 {' g v. P8 y# n
with [R_fixture]=50 Ohms and [V_fixture]=1.5V g; }& S+ R8 H) o2 j# I. j
& t& i3 h( W9 n# X an equivalent load applied to the model's I-V tables yields
* x; u1 e. A, H& a+ E* \# d different voltages ( 1.12V and 1.50V),/ \! I" ]2 N3 ~2 s2 @
a difference of 2.13% and 0.00%, respectively.- h, s6 w: Q, c2 F' m8 {
WARNING - Model lvc150s040haaaaaaaou: The [Rising Waveform] : `# I5 s3 I2 U/ J) k- I4 {1 {
- ^1 [$ a; a1 H7 M; u- u' | has MAX column DC endpoints of 0.00V and 0.32v, but
- A$ U1 V$ ]; N an equivalent load applied to the model's I-V tables yields; ^9 x" R+ o1 M+ L# ]
$ ~* n2 L4 E0 t4 ?$ r1 s' F8 ? a difference of 0.02% and 2.57%, respectively.
) s) J$ b7 w# l1 u, _WARNING - Model lvc120f020caaaaaaaio: The [Rising Waveform]
; g6 ?5 ?7 X$ x# u" ^ with [R_fixture]=50 Ohms and [V_fixture_min]=0V; z/ Z! o# h7 g! M
has MIN column DC endpoints of 0.00V and 0.41v, but
7 j6 H, ]2 G- B$ [ an equivalent load applied to the model's I-V tables yields, K0 D; D Y) a' X* B
different voltages (-0.00V and 0.40V),. H) ^) E6 z2 [
a difference of 0.27% and 2.30%, respectively.# Y9 f+ c4 t# t
* k3 ]+ A8 |$ Z' ]# |$ ? with [R_fixture]=50 Ohms and [V_fixture_max]=0V
. V( p6 S3 B8 h has MAX column DC endpoints of 0.00V and 0.68v, but
, c3 V3 X4 H9 K0 h& w6 ^3 r an equivalent load applied to the model's I-V tables yields
- u+ h% x6 [ ]# x# L# L different voltages ( 0.00V and 0.67V),
3 z9 H& k& g: S4 _( s a difference of 0.06% and 2.27%, respectively.+ m7 O2 b: {; A; \& U
WARNING - Model lvc120f020caaaaaaaou: The [Rising Waveform] - U- C5 V; ~ U. A( r2 ^- [" \
with [R_fixture]=50 Ohms and [V_fixture_min]=0V' {% T8 L, V y
: \$ r' l) k w# W5 a" v. c an equivalent load applied to the model's I-V tables yields
# q1 v8 H6 h; P/ P# _$ N3 b2 ]" g: l1 M2 Z different voltages (-0.00V and 0.40V),
$ r# K6 b7 e) D& d- A a difference of 0.27% and 2.30%, respectively.
6 o$ E+ K# [( q' Q1 VWARNING - Model lvc120f020caaaaaaaou: The [Rising Waveform] Y6 h" I$ j$ A. W
with [R_fixture]=50 Ohms and [V_fixture_max]=0V1 e9 Q* J4 N' v2 }; Q- f3 ]
has MAX column DC endpoints of 0.00V and 0.68v, but$ [) ?% |3 q3 |: h. R
+ n* z1 }+ G, n different voltages ( 0.00V and 0.67V),
8 P z# A" ^7 i0 F; Y a difference of 0.06% and 2.27%, respectively.
0 j8 G( `8 Q! I) z. SWARNING - Model lvc120f020gaaaaaaaio: The [Rising Waveform]
4 z$ M% d8 {: W: V with [R_fixture]=50 Ohms and [V_fixture_min]=0V/ `) H& V1 x' \; O+ `3 y
has MIN column DC endpoints of 0.00V and 0.41v, but" A& d- _+ p& ?7 q& O" s/ ^3 W* J4 t
an equivalent load applied to the model's I-V tables yields& h+ H/ u; U3 V
" d# G6 C x4 V( J/ N a difference of 0.27% and 2.30%, respectively.
7 S; v1 \. ?* P$ I- hWARNING - Model lvc120f020gaaaaaaaio: The [Rising Waveform] 2 @+ R& a6 H* X; f% C8 ]8 n3 `
3 Z8 v5 U. M4 o! b9 I2 p has MAX column DC endpoints of 0.00V and 0.68v, but. z; ^ o2 q0 q6 s/ |( @! x
" i4 N, g! V( O6 {9 u3 l different voltages ( 0.00V and 0.67V),5 K& R- O0 t; ~: ^% L: z
: {1 z( S: U) g; Y$ z& z3 N* ZWARNING - Model lvc120f020gaaaaaaaou: The [Rising Waveform] 9 m. R- j8 o" ~- R
with [R_fixture]=50 Ohms and [V_fixture_min]=0V; l4 ^( C, G; e. b4 ?7 \5 z
has MIN column DC endpoints of 0.00V and 0.41v, but# u) P" b3 i0 F; b$ J
" A# B0 R* X. t9 d different voltages (-0.00V and 0.40V),
1 D. x1 _/ q# \9 P a difference of 0.27% and 2.30%, respectively.
1 P" t" o1 a4 B7 H/ \WARNING - Model lvc120f020gaaaaaaaou: The [Rising Waveform] ; x) w0 M K8 I6 `6 O5 m" P
7 [% s( v: `" c! \2 c; O: z has MAX column DC endpoints of 0.00V and 0.68v, but" p) M3 ~5 V! g
an equivalent load applied to the model's I-V tables yields5 O1 s' B! m, y B& H
different voltages ( 0.00V and 0.67V)," ]+ X3 z. A+ o$ w* b
a difference of 0.06% and 2.27%, respectively.) S( w k* x& j! x4 x" E
WARNING - Model lvc120s020aaaaaaaaio: The [Falling Waveform]
; ^( F5 `5 @7 h7 g with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V0 W% u3 j5 K( d N6 M2 x
has MIN column DC endpoints of 0.75V and 1.14v, but! L; z" U! I" h% i' ~
an equivalent load applied to the model's I-V tables yields" J% E1 c; s/ t* q
different voltages ( 0.74V and 1.14V),
1 s2 u! i5 `2 A4 C a difference of 2.07% and 0.00%, respectively.& t- o/ q! R; e* }0 I5 y
WARNING - Model lvc120s020aaaaaaaaou: The [Falling Waveform]
/ u8 ~) h+ M/ m with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V
9 r1 f# I; e x1 d has MIN column DC endpoints of 0.75V and 1.14v, but
5 Z0 L1 E# z: e5 | an equivalent load applied to the model's I-V tables yields) \/ T3 R2 A+ t' g
6 K2 w0 p1 ]/ r( f$ ?1 _0 \ a difference of 2.07% and 0.00%, respectively./ d7 G) z5 C8 z! W/ m* U; N
WARNING - Model lvc120s020caaaaaaaio: The [Rising Waveform] , x7 L6 `) N" s3 s$ V Y) Y" @
with [R_fixture]=50 Ohms and [V_fixture_min]=0V, V& d; p7 Z/ g3 A
" j$ ^! U# \# |/ M4 l5 H# s an equivalent load applied to the model's I-V tables yields
: [7 S! q% e* w- l different voltages (-0.00V and 0.40V),8 V- R1 `7 Z) O. O( q
a difference of 0.66% and 2.16%, respectively.$ t6 v' e, z6 a
WARNING - Model lvc120s020caaaaaaaio: The [Falling Waveform]
+ G ?5 r: D3 |# _3 |9 G with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V
- \3 g3 c* ~1 ~ has MIN column DC endpoints of 0.75V and 1.14v, but
% _" w7 R f |0 K" k0 ~ an equivalent load applied to the model's I-V tables yields
. Z9 ^, o7 n" p& L1 S* l different voltages ( 0.74V and 1.14V),
8 P$ t( i- ], H5 c2 _; D+ s+ J- z a difference of 2.89% and 0.47%, respectively.
+ u2 O; ~7 ~# w2 e7 HWARNING - Model lvc120s020caaaaaaaio: The [Rising Waveform] ; y. z# K; @% V- k! S# {3 z
with [R_fixture]=50 Ohms and [V_fixture_max]=1.26V+ V: U2 O" o/ X# i0 G) {, U; D
has MAX column DC endpoints of 0.91V and 1.26v, but2 ?6 b$ }7 C5 ~4 O
, C7 D1 @( [( ?4 D different voltages ( 0.90V and 1.26V),
4 U$ n$ e/ r5 k/ v* v a difference of 2.23% and 0.43%, respectively.
\$ x& Z% ^1 u- e8 PWARNING - Model lvc120s020caaaaaaaou: The [Rising Waveform]
: |9 G s2 q0 {6 y' L: x6 x with [R_fixture]=50 Ohms and [V_fixture_min]=0V# X! a/ T2 U3 q- b$ q \1 \" V
3 ^, _9 e) j% L5 o- c0 O1 w4 d an equivalent load applied to the model's I-V tables yields
" j3 r, Q$ ?$ ?$ C! w different voltages (-0.00V and 0.40V),( C& Y1 a- @6 a7 l1 b5 B+ y
a difference of 0.66% and 2.16%, respectively.7 r/ M7 O; N9 C1 i1 |
WARNING - Model lvc120s020caaaaaaaou: The [Falling Waveform]
3 s$ f9 q9 L) V" H& u with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V
7 b$ B, L* [9 K) t, T has MIN column DC endpoints of 0.75V and 1.14v, but
; d, J+ n1 S3 K* U+ w q an equivalent load applied to the model's I-V tables yields
$ a1 ]$ }6 e& N! `( V) C different voltages ( 0.74V and 1.14V),5 j, p% R: Q- o/ h
a difference of 2.89% and 0.47%, respectively.8 h0 n% T3 ^0 k1 h; V# U6 u% I# |/ c
7 ~6 k2 ^0 Z: C ] with [R_fixture]=50 Ohms and [V_fixture_max]=1.26V7 J' p2 [& I" f0 U
has MAX column DC endpoints of 0.91V and 1.26v, but6 ~* p( h! ~/ b& C! R( N
. Z& p4 ?' k; R/ U9 Y different voltages ( 0.90V and 1.26V),
0 S5 M/ A) z1 Y2 x- }7 W a difference of 2.23% and 0.43%, respectively.
0 S7 Q- P8 ?( K& C/ ~WARNING - Model lvc120s020eaaaaaaaio: The [Falling Waveform] 6 m$ h1 y+ H% U: O9 b
with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V% c4 e7 a2 v% V! y+ {, b
4 V5 k' d. V8 v( x an equivalent load applied to the model's I-V tables yields
# q V; |7 h2 { different voltages ( 0.74V and 1.14V)," F0 f; ^" Y) r7 Z |
- U( u+ [3 j) ^WARNING - Model lvc120s020eaaaaaaaou: The [Falling Waveform]
& b' m4 w. N/ q with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V5 m) K J- C, |/ x: A
has MIN column DC endpoints of 0.75V and 1.14v, but" Y- K, X- X0 O2 f
an equivalent load applied to the model's I-V tables yields* a. g' w3 \1 h0 |' v! y
different voltages ( 0.74V and 1.14V),0 [2 [3 q6 H, V; { w
- I' C5 B5 z+ D- A2 @6 p! f! hWARNING - Model lvc120s020gaaaaaaaio: The [Rising Waveform] 4 e- h4 X) g' ^* e
with [R_fixture]=50 Ohms and [V_fixture_min]=0V! T, p/ V- X/ Q
& Z& E7 d0 T# f: n/ z5 _ z an equivalent load applied to the model's I-V tables yields
) `$ I0 P5 I+ }3 A" u different voltages (-0.00V and 0.40V),
' Z/ ?3 C' @& N a difference of 0.66% and 2.16%, respectively.) @* J4 C) W" T0 B' K$ e
WARNING - Model lvc120s020gaaaaaaaio: The [Falling Waveform] ! D0 h& { U* N% ]& ]( Q" N# l2 N8 m
with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V( ~) F, t0 r# e2 _/ l/ W- y. R
has MIN column DC endpoints of 0.75V and 1.14v, but6 a# ?% y5 Y0 c4 b
8 Z. q4 V1 k' k! m8 B$ @' y: u different voltages ( 0.74V and 1.14V),4 @. e4 G& T7 V( W
a difference of 2.89% and 0.47%, respectively.% Y1 k; M4 a# {# @3 u: b
WARNING - Model lvc120s020gaaaaaaaio: The [Rising Waveform] 4 ?* _* z: V" O8 {- w) E0 I8 L
; i: o8 D/ f$ B; c. i1 z has MAX column DC endpoints of 0.91V and 1.26v, but
7 |7 s, A" {3 \" M0 R% @ an equivalent load applied to the model's I-V tables yields
o) J& h3 G$ d+ ?; h different voltages ( 0.90V and 1.26V),+ v( `6 o' P: O5 A
a difference of 2.23% and 0.43%, respectively.. v+ T6 V) b: s" v
WARNING - Model lvc120s020gaaaaaaaou: The [Rising Waveform]
" j! n- H ^2 p4 { with [R_fixture]=50 Ohms and [V_fixture_min]=0V
% o; x1 \+ w) O: x$ Z has MIN column DC endpoints of 0.00V and 0.41v, but
$ G5 N5 k, L' z$ u0 @ an equivalent load applied to the model's I-V tables yields6 p/ j# _) p( Q
different voltages (-0.00V and 0.40V),& \% [7 c7 M. y; H' x/ ^
# Z) u& w: D0 w5 C, ?WARNING - Model lvc120s020gaaaaaaaou: The [Falling Waveform] - P6 ^, A7 F# q3 Z3 d
+ i+ w5 M- g" k2 w) ?: \" j/ b' Y; S" y has MIN column DC endpoints of 0.75V and 1.14v, but# u! g6 H5 Q! q4 O
an equivalent load applied to the model's I-V tables yields2 Z F0 h4 p2 V4 F7 A
2 U5 R' c h- v/ f' {- M a difference of 2.89% and 0.47%, respectively.% F! F/ N, x. D( `2 g' M
WARNING - Model lvc120s020gaaaaaaaou: The [Rising Waveform] * f2 E' M/ u% a0 H, {
with [R_fixture]=50 Ohms and [V_fixture_max]=1.26V& D7 i* C) }5 V8 ^( q
has MAX column DC endpoints of 0.91V and 1.26v, but) ]( N0 q6 f$ Y
5 h9 B. @# Z+ W( z4 r; u4 m different voltages ( 0.90V and 1.26V),
' w! \3 x0 b* Z6 y a difference of 2.23% and 0.43%, respectively.
. X7 g$ X, t- D# K2 r# M; z. e1 ]WARNING - Model lvc120s040haaaaaaaod: The [Rising Waveform]
3 W! f$ A( s9 R1 ? }" s6 \ with [R_fixture]=50 Ohms and [V_fixture]=1.2V
5 {6 ]( _" S# [/ }2 y8 E. } has TYP column DC endpoints of 0.83V and 1.20v, but: P) q; M2 C3 _" f2 E' o, U, E" r
, p! f6 y+ J! u+ J0 r9 | different voltages ( 0.85V and 1.20V),* J" O/ l+ B% l7 m: X
a difference of 4.83% and 0.00%, respectively.
$ Z* V& X" X: @: l% \" m, h- k! Y
Errors : 1/ u6 g& J0 X- S' _* V
Warnings: 133* u( Z" B. i& B# T+ ]! V
' E* B% ~& I5 g) e
File Failed
# `3 {1 Y. G$ n5 t* M |
