小弟最近做了一块板,导入网表时出错,请各位高手提供些建议!谢了!
2 j- q( Z' A8 m' ]) j; i(---------------------------------------------------------------------)* n2 h- r! N4 v- N% t
$ u# d7 n6 v% ]0 g3 i6 P( Netrev allegro Import Logic )' f: E) X; C# u" g6 f
" O% R2 s: d, g2 Z( f( Drawing : DUDEMO.brd )
6 o( q$ X6 K6 \+ |! x$ G( Software Version : 16.3p004 )1 I. t5 H N( R
( Date/Time : Sun Jun 09 19:07:58 2013 )
7 a7 x( P% [- y; @' e/ N$ L* ]4 q( )
5 _1 D$ I# T' h) ?(---------------------------------------------------------------------)+ E7 a2 i. A+ C% V9 G) F
! U+ ^/ J/ y) p' f
; J, y4 N& w. |/ G+ j------ Directives ------4 j1 F2 o' S4 P3 h" t) Q3 ~5 k! `3 N
U- [! g& Q' E: I2 aRIPUP_ETCH FALSE;0 e R) H( r0 }0 M9 |: c
RIPUP_SYMBOLS ALWAYS;
$ L& k" c2 c4 O4 B: W; d3 O0 YMissing symbol has error FALSE;
* o( |+ `* b2 ~) [* XSCHEMATIC_DIRECTORY 'D:/mypcblib/mypojc';
, ]; j- }. i* H0 F9 e9 vBOARD_DIRECTORY '';
2 z# a, v* J8 P: WOLD_BOARD_NAME 'D:/mypcblib/mypojc/DUDEMO.brd';
, ~3 a+ b( T2 gNEW_BOARD_NAME 'D:/mypcblib/mypojc/DUDEMO.brd';! v5 @) V2 N1 Q; ^9 s+ L; C/ m7 B
) i, A5 ^( s# t" p' Y6 DCmdLine: netrev -$ -i D:/mypcblib/mypojc -y 1 D:/mypcblib/mypojc/#Taaaaaa15232.tmp8 A6 e. H- k7 |
7 A8 j) ?. u& a- M3 t5 O
------ Preparing to read pst files ------/ I5 S: {. X5 @& g( f
! y$ c. G9 `* o" N5 T. q, k
. b5 u0 `9 s& c, a0 q# \
#1 ERROR(24) File not found
& x( ]! @: F5 L9 b# z Packager files not found
, y: z0 t( s: k7 V, f/ J7 e( I3 t1 ^5 K! V9 j
#2 ERROR(102) Run stopped because errors were detected2 d. }! L, h! t3 |( k) L4 `) z
$ A6 z5 ]1 I5 w2 S* e. Inetrev run on Jun 9 19:07:58 2013
3 h- j. r0 f1 y% R) ~3 x) t) Y" |" s5 Y
COMPILE 'logic'
! s5 V/ v" v& a CHECK_PIN_NAMES OFF$ h* q9 T, l5 x+ n: A) `: g- i
CROSS_REFERENCE OFF
$ G7 L# T! a+ p7 @8 [ FEEDBACK OFF) e" ]* E! A M8 U) S
INCREMENTAL OFF0 k0 X6 ^0 ^* j4 I1 Z+ y
INTERFACE_TYPE PHYSICAL+ T- h( @$ ]$ }* R* W+ ]
MAX_ERRORS 5009 y) F+ [8 G. C: j: r5 @
MERGE_MINIMUM 5
+ R" q% i' w6 u7 v( s3 e1 Q& m9 D! q NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'# P2 s4 j% E7 c8 L ~+ n3 w
NET_NAME_LENGTH 245 O3 \$ W2 g* J
OVERSIGHTS ON- T. h5 g8 `0 L! H3 `
REPLACE_CHECK OFF
8 H' f! F" f8 n" k; ~2 ` SINGLE_NODE_NETS ON. q" \9 A, o2 {' {4 w6 ^
SPLIT_MINIMUM 0
* q& w/ x2 Y7 o4 ?. ? SUPPRESS 203 U X( k" B) Z' B, m( A* O
WARNINGS ON. R0 z) Y& i( S& |' y4 t
3 F: o. G4 N1 Z2 A 2 errors detected& e' ~- O$ E0 t* b
No oversight detected) O* z8 S% x/ b0 K1 h7 Z
No warning detected6 m& h; O5 O3 P
9 Q1 w4 @* w- V2 }- p5 R
cpu time 0:00:582 F0 e+ |5 y# ~! A9 e. R7 f
elapsed time 0:00:008 _; e2 ^! \( ]5 f& W$ \! r
# L2 n3 k+ \8 x; P, Y* y, T: C
