查看: 1108|回复: 3
出gerber出错,请各位帮忙看一下
发表于 2013-5-16 21:19 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
(------------------------------------------------------------)+ @4 p6 Y9 B* z, O8 b0 l6 T6 z
(                                                            )) p! {5 d9 s& N6 U0 `
(        ARTWORK LOG                                         )0 y4 f4 f1 t5 s/ C2 F* I+ \  E
' w# @0 \' K/ _& |. I(        Drawing          : MSI-1358_V1_1-key.brd            )
1 T8 L' O* j( A' Y9 {4 u(        Software Version : unreleased                       )/ q2 }% @' T  r- u: d/ ~. Q
(        Date/Time        : Thu May 16 21:19:25 2013         )
9 T1 _. M1 w  l, g9 m- H3 d! g9 J(                                                            )5 S% f2 y) t) W! t! G
(------------------------------------------------------------)2 O) s# Y% B( |8 g) {/ O
- \6 N' a# m* ]7 |* x
2 g# G: _3 N3 C2 ~) U1 D# }" L7 Q1 G0 y/ h
******************************************5 m1 v/ D4 J  l
WARNING: DRC OUT OF DATE on this layout.
% w& P8 u8 y" g' n$ T ******************************************$ X2 O- R" U8 M. ?, w8 J3 z
: W* u" j, v5 f$ D) v+ y
---- Photoplot outline rectangle not found ... using drawing extents
, k  \2 |# ^9 T& z2 K' m8 Z/ b3 e6 l3 G# Y& X
4 U) z' j$ S: @/ Y  b" u
+ C8 \( _- L- H3 `Results from parameter file ...  C* f! A! z$ X- n! q
    DEVICE-TYPE           GERBER_RS274X
$ z1 Q" Q  e$ F& d$ }( }5 H+ g) I    OUTPUT-UNITS          INCHES
5 H+ X% a3 K5 W    FILM-SIZE             24000 16000
+ l6 c* d. J. |5 }5 i    FORMAT                5.3
, h  h& E  @9 }    ABORT-ON-ERROR        NO0 i0 ^1 B) d0 J" h, s0 l7 N" ~7 _
    SCALE                 1# H+ S, ]3 q7 A* L. ~; H
    SUPPRESS-LEAD-ZEROES  YES
2 z8 E8 k. Y& n3 Y0 o# K$ F    SUPPRESS-TRAIL-ZEROES NO- M4 W/ `  \* r- S0 R* n
    SUPPRESS-EQUAL        YES
! v1 L- y+ n; ~7 V    UNDEF-APT-CONT        NO
7 M6 S" D0 ?$ S( T1 X( T& {# h- |. M+ X2 ]2 |! E" b& l
WARNING: for raster artwork formats, artwork accuracy must be  O4 _5 }- Z* L" Q" L
  at least one place greater than the database accuracy, up3 L, p( e* Y0 F7 y6 X0 O3 f' j
  to the maximum accuracy allowed by the selected output format.6 x/ S8 J: a* D' Y9 z$ Y4 P1 K- E
- Q2 K3 L2 _0 r3 O  Increase the accuracy by increasing the "Decimal Places" in5 J. A. O- Z- m
  the FORMAT section of the artwork parameters and then rerun
+ }+ d; l# j. R  artwork.
3 s6 u% x7 s0 x" b* H1 G
7 `0 k" f3 R. E, I+ }; x  The current output is rounding down the data.  Failure to change$ Y0 o3 p+ O; M
  the format may result in inaccurate arc coordinates in the output3 ?" w" w  R, N) @% |) f
  files and possible shape/void plotting failures.
3 i* M$ u. h7 \7 ^- n( _5 Q! y0 L: g8 ^  \7 g+ ~! d8 U
$ x5 @/ z  S% ?. q2 n" I) F$ K
& i) q: K. V9 ~: ]$ k. e8 D     PROCESSING FILM < drill >! {# Q' O% r. j. b4 ?
     TO FILE < D:/Documents/Desktop/99/drill.art > ..." X; N$ j3 `$ V8 v: R
, u2 o8 A) L9 u5 L9 A) `+ D1 r7 o( a
  FILM PARAMETERS :
5 x% G' O9 x5 H' j; r, l  ---------------------------------------------------------
% o  y6 a4 x- J% }  Undefined line width                5.00. n8 I% K# `( l; a
  Mirror code                         NONE2 o' d* G+ h8 N+ f
  Rotate angle                        NONE
. A  G1 H, O7 a$ y) d8 ]" W: ^8 R  Offset x:                           0.00. }  j  t6 R* @
  Offset y:                           0.00
4 Z! e, f! C, a6 U  Plot negative                       NO  ^; ]  |/ v; y. S
  Suppress unconnected internal pads  NO5 v! V: x0 ?! n. T$ }
; E' ]( v, I+ k+ T
    WARNING: 0 width line found at (17257.00 7693.00)
  b* y5 Z: B# B           ... using undefined line width of 5.00# {# `6 \' B+ [2 s% H& E( A
) x/ r3 f/ j. y/ ~; {    WARNING: Multiple 0 width lines; all will be treated the same as the first.7 b1 K$ n* c5 v- `6 A9 D
* C7 I. W. I  b9 p# F, }$ O0 C- J4 A. B6 j7 O9 I; T# G/ @( p
    WARNING: text composed 0 width line found at (17706.50 10596.50)3 f( ^3 C0 z. H6 y9 L
5 G# A$ ]: \9 Q6 P" D' g4 A
: [# ]3 H: Y: {    WARNING: text having Multiple 0 width lines; all will be treated the same as the first.2 [7 f: E3 T3 D6 d
           ... using undefined line width of 5.00) y/ j  Y4 A1 W3 e. A9 `! u
- O( V& \, S2 N- y- S
' x6 u) h. T; Y$ @4 C, e
' a9 L. z. S/ W; V8 S
  APERTURES USED:
9 y& R3 T( H. O  Q7 X, ?# \  ---------------------------------------------------------& L" s) y; G' f" \+ h% |4 Y
  TYPE       SIZE/NAME                   ROT   MIRROR MODE
. J7 P# H, l9 P2 C8 C  ---------------------------------------------------------
/ T# L) U( P2 B9 E) ~+ @  CIRCLE     0.00500                                  DARK
" ]) {6 ?* v2 A+ |* t& K
8 B# c3 |' w2 B: T: P     drill created with warnings: Z1 B' `, g0 {8 H' f  y3 W
) u$ B0 }6 p9 u2 J: ]- z
4 }% L& K' w# h7 o; z: U  w9 Q
2 K/ H: z$ K' }2 g- h     PROCESSING FILM < solder_bot >9 r  P% ~% {. b; g+ z4 c
     TO FILE < D:/Documents/Desktop/99/solder_bot.art > ...
. A: h0 y6 _: h6 ]& ~: R================================================================
  X1 y& e1 ?* v* M" n% K6 H8 f
! P  e7 N" h1 a  FILM PARAMETERS :9 Y5 t) [8 i! A" Q( y/ X  f* z
  ---------------------------------------------------------, ~5 b6 }3 F3 M1 V7 m- [$ w1 g
, H+ s; \" d) ~; {8 @  U& ~+ s  Mirror code                         NONE9 x9 {2 F+ j: |$ {, K
  Rotate angle                        NONE' K# p( E" ]- M; ^8 l$ E
  Offset x:                           0.00; H4 B& t  w3 U! _. O: A7 J
  Offset y:                           0.002 A/ L1 T# P, b2 H7 m; y6 \5 p
  Plot negative                       NO+ q7 W& |+ z0 A% c' `2 ?9 G
2 w5 v9 e$ @0 y% ?4 p1 F( e. F: k# S  J5 r# k
9 S3 a: H& R8 ]: [
" @/ E9 {% F) G7 r  m$ r  APERTURES USED:0 b5 Y7 q  ?9 i) g1 Z/ S
, l5 K" }1 P- `& K, }; ~  TYPE       SIZE/NAME                   ROT   MIRROR MODE 0 U3 A/ ]( \' D4 {& F. b1 S& N
& a) `# t+ u% j4 P0 _* f  CIRCLE     0.00500                                  DARK
2 G- p; V4 D$ B0 d3 i: u8 l  CIRCLE     0.03000                                  DARK
- v( f% U, J8 s. _5 S& O  CIRCLE     0.04330                                  DARK ; V8 }# z# o$ e) Z* t
  CIRCLE     0.04600                                  DARK - \7 h0 |2 ]; l* w
  CIRCLE     0.04900                                  DARK 9 f) r7 Y' R2 w# Q: }  g
  CIRCLE     0.05300                                  DARK
3 M- E: T9 n/ l9 o3 w" j% h  CIRCLE     0.06000                                  DARK . P6 [9 d0 x- i" y$ z
  CIRCLE     0.06100                                  DARK
1 ~/ W" |# d6 ]9 {  SQUARE     0.04200                     0.000 NO     DARK
/ t2 ?: S' }4 p  T2 v. u* P7 R  SQUARE     0.04600                     0.000 NO     DARK
. c& s% _0 ?0 x$ m) L0 C( i* {% U  RECTANGLE  0.02600     x 0.03000       0.000 NO     DARK
: F4 J4 n/ B* I2 Q4 m  RECTANGLE  0.02600     x 0.03000      90.000 NO     DARK & N, G; M9 n; K/ D
  RECTANGLE  0.03800     x 0.02600       0.000 NO     DARK - f9 T9 y  _1 w6 z3 _. i
  RECTANGLE  0.04000     x 0.03600       0.000 NO     DARK ! c! @2 h1 r. p7 ~1 n- Y
  RECTANGLE  0.04000     x 0.03600      90.000 NO     DARK , G! i1 Q' b( {+ H
  RECTANGLE  0.04200     x 0.05600       0.000 NO     DARK   \7 U( _% }. T" M  X
  RECTANGLE  0.19685     x 0.19685      90.000 NO     DARK / s( t3 l0 `% J) E3 p0 l* m) S
  OBLONG     0.01378     x 0.04331       0.000 NO     DARK * t# k2 m9 s4 L
  OBLONG     0.01378     x 0.04331      90.000 NO     DARK
  Z( E6 Y5 o0 m8 a  OBLONG     0.01600     x 0.03600       0.000 NO     DARK 3 R' P- P" o+ K: w4 m
  OBLONG     0.01600     x 0.03600      90.000 NO     DARK
& _! T9 ?- ?' P  OBLONG     0.06000     x 0.15900       0.000 NO     DARK
6 R! Q9 f$ W1 T9 F; E7 L  OBLONG     0.07100     x 0.14400       0.000 NO     DARK
1 Z+ \: H7 o2 A- K$ ~% ?  OBLONG     0.07100     x 0.16700       0.000 NO     DARK
2 C) J5 c9 T1 D" A% A5 K! m  OBLONG     0.07500     x 0.15600       0.000 NO     DARK
3 Q- J% \4 x& |& ?& I9 s, U7 k  PAD SHAPE  SHAPE26X34                 90.000 YES    DARK
7 o+ X. n% C9 T5 ?4 b+ v  PAD SHAPE  SHAPE26X34                270.000 YES    DARK
+ n$ h9 s- m6 V5 x
! ~% z9 D7 ~0 Z     solder_bot created with warnings. l) v( F4 h8 H8 q
+ h5 [2 _/ G9 s) c' z. [# V$ l4 N
5 t; `4 X8 S" x5 B# b0 w================================================================
( S. x  _# f. |8 B     PROCESSING FILM < solder_top >" ]0 A( _$ h: w6 Z1 D5 r6 }
     TO FILE < D:/Documents/Desktop/99/solder_top.art > ...
/ _  R3 I+ |; S$ |; B================================================================% W* C2 r3 d( g5 t: A
, b: Q$ W" ^6 h7 l; `8 v; c# x
  FILM PARAMETERS :
  w  [3 N0 l( q# B3 Y7 F9 h  ---------------------------------------------------------
) B: |% F/ c- C: x. d  Undefined line width                5.00
+ J) r! U9 E& j- [; G3 D  Mirror code                         NONE
, ^) i6 U3 B1 ^  Rotate angle                        NONE
  h* x$ h1 [5 K% m  Offset x:                           0.00
- W8 H! H+ d; n. ]- e# S  Offset y:                           0.00. o, ]# ]2 k3 [
  Plot negative                       NO
1 ]4 A* Q8 ^6 _5 c2 m! B: b  Suppress unconnected internal pads  NO  [: V; R- a8 d4 X
8 f8 c- z0 O, L/ _0 Q0 k7 ]
$ m& G& q3 H" A6 x$ r
6 q; c" \0 j' x& H2 E5 J
  APERTURES USED:0 X2 z) H' q' E) O1 \
) }9 f- ?$ b( D- E  TYPE       SIZE/NAME                   ROT   MIRROR MODE 0 k0 a! n# P8 M9 _
  ---------------------------------------------------------( n: t1 ?+ L7 d& a! }' ?8 A) r' p
  CIRCLE     0.00500                                  DARK . G8 [0 c4 g9 K: t& c
  CIRCLE     0.03000                                  DARK
7 C% g, M% I3 W4 ~* ?; M  CIRCLE     0.04600                                  DARK
7 l) U1 T" J6 c; }5 J1 ~4 }  CIRCLE     0.04724                                  DARK 9 A8 b% a; d4 S  q) @
  CIRCLE     0.04900                                  DARK
) C2 b8 p- t, |$ p  CIRCLE     0.05300                                  DARK
+ S! W; v# i+ Y  S, M  CIRCLE     0.06100                                  DARK ( L9 Q. a- ^1 l4 q: {! V
3 q# a* o2 Z9 X/ f/ H/ \  RECTANGLE  0.01600     x 0.05300       0.000 NO     DARK   H! R/ k6 p; s# g
  RECTANGLE  0.01700     x 0.10800       0.000 NO     DARK ) K+ A$ b( r5 Y) O6 {3 {- O4 ~
  RECTANGLE  0.03600     x 0.10400       0.000 NO     DARK
' g/ [: K) Z5 }7 l, L  RECTANGLE  0.03800     x 0.10400       0.000 NO     DARK
6 Z; W! T1 ~" e) R# W& F5 M# E  RECTANGLE  0.04900     x 0.10400       0.000 NO     DARK 6 _! q" t3 [& R# Y# {" [5 y% L
  RECTANGLE  0.05500     x 0.10400       0.000 NO     DARK
( T1 o# o( X6 l* j4 E' n. U7 g  RECTANGLE  0.06300     x 0.08900       0.000 NO     DARK
; S/ \. I$ S0 i/ @  RECTANGLE  0.06500     x 0.08500       0.000 NO     DARK
6 M- D8 A( |/ n& X1 o9 p  RECTANGLE  0.07100     x 0.08100       0.000 NO     DARK / A  Q' s3 ~! Y
  RECTANGLE  0.09300     x 0.14400       0.000 NO     DARK
$ f+ n' R- x! ?5 i' J  OBLONG     0.03100     x 0.08100       0.000 NO     DARK ) O$ ?! n$ M5 @1 i8 m
  OBLONG     0.04100     x 0.08100       0.000 NO     DARK ( A: A) j3 e( W$ j/ ~! B1 e( j
- j8 x5 _6 E1 F3 X) T+ ~  OBLONG     0.07100     x 0.14400       0.000 NO     DARK
& E8 B) T! [1 o1 y2 H+ t  OBLONG     0.07100     x 0.16700       0.000 NO     DARK 6 U. R+ d( y' n8 M. S; |9 d
  OBLONG     0.07500     x 0.15600       0.000 NO     DARK 2 S. @7 D6 ^- u' _- M- s5 x
  OBLONG     0.08394     x 0.03346       0.000 NO     DARK
, a) W8 F$ j! s6 y! J5 I  PAD SHAPE  SHAPE26X34                  0.000 NO     DARK
! c, ^5 Y, C0 A+ \8 b/ F1 Y3 E% ]  PAD SHAPE  SHAPE26X34                180.000 NO     DARK - b5 t3 _7 }" g
& M, O) `. e. d: E! G5 L( l% d: h* U     solder_top created with warnings
4 k, l0 X; w( e1 q
' p) b7 d& X3 ^, e4 V' t* w+ t- ?* I' B- H; G' e
  K! i  F: j" N! S, p     PROCESSING FILM < paste_bot >
/ e  c9 J8 J! n' Z( J     TO FILE < D:/Documents/Desktop/99/paste_bot.art > ...1 i& d( S8 W9 S; d3 W! z7 Q
; g4 O" I9 a: ]+ g
4 u! z; m4 k& Q# P  FILM PARAMETERS :& q- g3 m+ w: f8 Y% N% y' y
  ---------------------------------------------------------& n# G1 L) X" R
4 i( a" [. F+ x5 V: _) Q  Mirror code                         NONE
/ e% W3 Y3 }' U! J  Rotate angle                        NONE7 K% i6 o8 K  T. D7 A8 W! b( w
  Offset x:                           0.00, z( E7 O) m# I9 j1 s/ R
  Offset y:                           0.008 m( W  X; Q  _- @6 ^
  Plot negative                       NO
2 M3 j  U1 _" g" y8 G# g  Suppress unconnected internal pads  NO% N% _7 |% _2 m( D) q
" n; Q' _' A5 I% c8 j% E# j9 D; f7 H
6 I' {8 G' K5 d) E% i
3 e7 C. s6 w( X7 z3 B; L; {) O& Z  APERTURES USED:. M0 }  b( i' U2 ~$ z, f: P7 [7 {" V$ f
, j3 @/ y# P' l# Z+ |  TYPE       SIZE/NAME                   ROT   MIRROR MODE 4 v+ D5 d6 ^7 Q) y" P$ X6 ]4 ~
  ---------------------------------------------------------, R+ A9 |0 q- N( H- l0 Q  [: }: _
  CIRCLE     0.00500                                  DARK * `( M+ T# O& Y+ N
  CIRCLE     0.03940                                  DARK
# ~' O& r0 r( t8 N) D( M  }  CIRCLE     0.06000                                  DARK 8 b0 k: e* \. M$ z' G% L
  SQUARE     0.03600                     0.000 NO     DARK
; q/ _( L" v' G% k8 A  j6 x  RECTANGLE  0.02000     x 0.02400       0.000 NO     DARK / w0 L7 ^# `6 }9 V+ T
  RECTANGLE  0.02000     x 0.02400      90.000 NO     DARK $ `: o' C4 R0 U) q, \4 `
  RECTANGLE  0.03200     x 0.02000       0.000 NO     DARK
0 h# Y6 C; p( d# }' m: d) N/ f  RECTANGLE  0.03400     x 0.03000       0.000 NO     DARK & @! Q0 H. |5 J" u7 ~8 T' S9 j) z
  RECTANGLE  0.03400     x 0.03000      90.000 NO     DARK
% i2 R8 D+ E# s  RECTANGLE  0.03600     x 0.05000       0.000 NO     DARK
; _0 V* a4 ~5 H: J8 ^  OBLONG     0.00984     x 0.03937       0.000 NO     DARK , ~" g8 ]8 K1 f, w& ~/ i
  OBLONG     0.00984     x 0.03937      90.000 NO     DARK
: U( |: U$ |, l- U9 D  OBLONG     0.01200     x 0.03200       0.000 NO     DARK 2 {( x% l5 u; M$ Q1 H( |* e- _
  OBLONG     0.01200     x 0.03200      90.000 NO     DARK
, ?# U: H% a7 _9 ?0 N/ B% L' d/ ]  OBLONG     0.19291     x 0.19291      90.000 NO     DARK $ R7 o4 S1 J/ @; W$ N* B+ A
  PAD SHAPE  SHAPE20X28                 90.000 YES    DARK
, J7 n+ r" B5 M  V8 X1 w' w" V  PAD SHAPE  SHAPE20X28                270.000 YES    DARK ) l7 v' Y! d, ^, J  @
/ i2 l) W  i4 C, E
     paste_bot created with warnings
; m, N) @$ R  x; Y
/ U8 }7 j; |+ Q) ~* W( I1 R$ V2 v8 v' E8 n1 \+ x6 f. D6 |
================================================================  _8 B: r% g9 M8 q3 Y  F3 s
     PROCESSING FILM < paste_top >
2 h, g2 X( z8 \; y. Z     TO FILE < D:/Documents/Desktop/99/paste_top.art > ...2 ]/ O8 w, S# {! v) m2 p
; B3 w( M1 Q1 Y& R+ d$ C8 P3 F2 d0 t2 |3 l  |( a6 [6 V
  FILM PARAMETERS :
4 ]/ V; {/ p5 j. Q. B/ v  ---------------------------------------------------------
2 G% X( \3 \5 y, h# {, X  Undefined line width                5.00; L, N+ y' m% ^; L6 Q8 {+ K
  Mirror code                         NONE" H$ U' s$ y3 m
  Rotate angle                        NONE
" @; H" v2 X2 O. J7 F  Offset x:                           0.00
+ k2 {3 [+ @+ c2 K1 t: i3 H% V# d  Offset y:                           0.00$ [& {$ V- ^& y% g
  Plot negative                       NO
. G+ t1 H+ d. g7 z. P+ E' x8 Z: J% e  Suppress unconnected internal pads  NO
& ^' `  D. C' W9 J5 i
/ h" S; `2 T% F* f# i/ e& |
4 m) J  J' V8 Q3 M8 Z1 ^* w- N" m6 q3 D6 t6 S) w' d. W
  APERTURES USED:: W$ O" ]4 G- H5 d2 l/ E
  ---------------------------------------------------------+ X( P8 u; {5 O: ~
  TYPE       SIZE/NAME                   ROT   MIRROR MODE 2 X% Q% ?) y! k9 C3 g4 E3 P
0 B( G1 p9 D) S& W; `' l  CIRCLE     0.00500                                  DARK
6 S7 {& G) G0 l4 r* N" @+ r  CIRCLE     0.04000                                  DARK
3 A; |) y! j# [3 z  CIRCLE     0.04724                                  DARK 2 T; D1 Q. Y% \* D3 h  n
  CIRCLE     0.05500                                  DARK
- i: ]7 K7 c% V& U' H  O) ^  SQUARE     0.04000                     0.000 NO     DARK : L5 C5 F9 H0 I. P
  RECTANGLE  0.01000     x 0.04700       0.000 NO     DARK
8 `& M- k) b% ?' Y8 X$ ]2 g  RECTANGLE  0.01100     x 0.10200       0.000 NO     DARK ( `# G6 b/ j5 g' Z5 n' q! F  f* ?
  RECTANGLE  0.03000     x 0.09800       0.000 NO     DARK % b( ~. v3 U; I
  RECTANGLE  0.03200     x 0.09800       0.000 NO     DARK
/ c( q* e+ n  T. ?  RECTANGLE  0.04300     x 0.09800       0.000 NO     DARK
( k& ~; J' R4 B" l- ?  H  q  RECTANGLE  0.04900     x 0.09800       0.000 NO     DARK $ k. G) `) @, {) S
  RECTANGLE  0.05700     x 0.08300       0.000 NO     DARK " \. o# K  }/ I1 ?( t" N
  RECTANGLE  0.05900     x 0.07900       0.000 NO     DARK $ Z8 }2 k, F7 |! f8 d, r
  RECTANGLE  0.06500     x 0.07500       0.000 NO     DARK / ?. ^5 `% g; D3 A. ~
  RECTANGLE  0.08700     x 0.13800       0.000 NO     DARK , V9 g1 e& Z0 Y/ T
  OBLONG     0.02500     x 0.07500       0.000 NO     DARK ( P: |, L% t/ B! \1 U
  OBLONG     0.03500     x 0.07500       0.000 NO     DARK
2 m& q( E) }- d8 K  OBLONG     0.05400     x 0.15300       0.000 NO     DARK
! v4 \5 o. d. Z; M  OBLONG     0.06500     x 0.13800       0.000 NO     DARK
) m$ F* x8 l- c  ~4 e2 v  OBLONG     0.06500     x 0.16100       0.000 NO     DARK / F" A9 t4 s: _* u( l9 y& q# ]
  OBLONG     0.06900     x 0.15000       0.000 NO     DARK
, R( G6 r. l3 U  OBLONG     0.08000     x 0.02953       0.000 NO     DARK
* r6 p5 }) m2 k- r  PAD SHAPE  SHAPE20X28                  0.000 NO     DARK % k* d2 q6 L3 \9 Y. J5 T/ Q  m
  PAD SHAPE  SHAPE20X28                180.000 NO     DARK ) ]; O2 ]2 j) |! d
- Z- Z  Q9 [+ p6 Z     paste_top created with warnings
9 `+ I9 }5 |* `
: {0 O5 ?) ^( t/ K5 |2 A) S4 _, S; B! F- ^" B
================================================================5 ?$ b: a% ^$ v/ `5 l! A: ^
     PROCESSING FILM < SILK_BOT ># D# `0 F' _! T( e& g  K+ D
     TO FILE < D:/Documents/Desktop/99/SILK_BOT.art > ...% M: F; E9 _4 a: L# {! C; [* T) i; |
6 ?/ Z  p) R" y4 f& p- Q6 U
9 x9 o8 q! r$ ~  FILM PARAMETERS :( l- f6 b4 F& B! ?- G$ t2 N
  ---------------------------------------------------------9 s5 c, Y% g  s& Q; t1 m
  Undefined line width                5.00- k3 Y9 b# R% b0 r, S. O  H) b
  Mirror code                         NONE' O5 \# t6 k, U! L( }. v* C( X
  Rotate angle                        NONE5 A9 K/ A. ?( N6 r4 a
  Offset x:                           0.00" ^+ J4 `! c- v% E
  Offset y:                           0.001 {* H" I/ E- k, Z: J+ N9 Y, f
  Plot negative                       NO
& P9 L8 Q- v1 b1 o  Suppress unconnected internal pads  NO3 j  L7 E; q+ n4 X, Q6 h3 n: O3 m
  z- J, s- l7 l& H8 H9 X0 w  E3 `6 _; N1 |, m4 I/ T! _( O
( e  l* X8 u; L1 K3 F+ j  APERTURES USED:
: h. K/ Z) E/ }, {  c0 c% ]# z& u6 U7 M9 E  ---------------------------------------------------------7 i+ W4 `, h! m* a* _2 ~% {, x2 w
; t  @0 C# d; G  ---------------------------------------------------------/ C- l1 d. m5 Z8 F" X) }
  CIRCLE     0.00390                                  DARK + [4 q, P1 ]1 O; b$ O
  CIRCLE     0.00500                                  DARK 0 W8 y! K  @2 y: Y$ ?9 ~
: c- G% O" Z" N7 r7 N9 F7 h
     SILK_BOT created with warnings
9 @  {. u( O/ L* w
" x9 w$ x2 g3 d( l6 ]- H
. \2 Q, a! Z# X  F================================================================1 [: e3 H8 {! O
     PROCESSING FILM < SILK_TOP >0 M; W5 f$ J+ o' @2 E
     TO FILE < D:/Documents/Desktop/99/SILK_TOP.art > ...6 j, p; R; K5 p/ A# p& J
================================================================& D$ j4 E  l! o1 @% D) {4 [: B
, z- S! B  w9 c. n3 v
  FILM PARAMETERS :
7 |, ?6 [5 q. {; t1 k  ---------------------------------------------------------
+ |, }) \" w2 b  Undefined line width                5.00
% H0 _# b& G  X# Y, [3 W  Mirror code                         NONE0 B( _6 S: v4 z. x+ Y
  Rotate angle                        NONE
% y7 `- [# e3 ^7 J; [5 Z+ A  Offset x:                           0.00+ X' U) B/ W) T3 R; R9 k
  Offset y:                           0.00
2 B4 ]7 D* V0 m+ q! V  Plot negative                       NO
! _% W, j2 @2 E' w+ `  Suppress unconnected internal pads  NO5 [, D/ `, `% L. P, H& ^- T9 n
9 _1 B8 g, y+ t1 b. `( n! ~; \    WARNING: Segment with same start and end points at
' q' L4 ^9 x/ Z) ~! R        (9516.44 9028.15) will be ignored. Increasing output2 D6 q8 n9 x. l: [- ?
        accuracy may allow segment to be generated.
. ^- u0 k+ S& |# r  D. I& U4 q% e- z/ a8 T0 z/ }/ h
    WARNING: Segment with same start and end points at5 K( o5 G3 B1 O  C$ C8 C
        (9526.69 9029.69) will be ignored. Increasing output
" D. j  a4 }2 M* L4 B+ N        accuracy may allow segment to be generated.
5 A3 Y$ B' i- N. f0 X0 q1 s
$ \7 G- ~, i9 B: a) s6 P6 k: H    WARNING: Segment with same start and end points at
2 s  F1 g1 n; I$ P2 b# ~+ H: a' @        (10127.72 9269.39) will be ignored. Increasing output
: J/ ~: I) I& y6 q        accuracy may allow segment to be generated." t4 D# s: P, |! D( i1 F0 K, n3 }4 D8 k
# |6 Z  l$ Z/ `% j, i: Q3 i6 v
    WARNING: Segment with same start and end points at6 k5 n* ^+ p, S4 X- _" v0 h
        (10141.97 9283.34) will be ignored. Increasing output
2 B  n( C- ]- P        accuracy may allow segment to be generated.
) G  P8 K" |' o, g6 s+ c! {+ i, U( K* c3 O/ m
    WARNING: Segment with same start and end points at- ]1 H; F* d1 N% Y7 k4 ?8 h) X1 _( D
        (10127.72 9298.79) will be ignored. Increasing output
7 v9 M4 g* K( J. r. V( p* Q! E        accuracy may allow segment to be generated.! R. J" r: c" F9 I) G
, |8 |0 x) Q, `: h6 R. z2 E8 d* H% o    WARNING: Segment with same start and end points at; c- p* I( i% F% t2 [
        (10142.84 9284.05) will be ignored. Increasing output0 k5 f4 f! ]- ]# r1 l
        accuracy may allow segment to be generated.! F& ^6 M# L" o& ~+ E& t6 P* \2 `
; p5 Q4 p7 C. Y/ O. U4 V' T    WARNING: Segment with same start and end points at
. ^' ^: i3 y7 B" b6 g% l+ H        (10128.02 9269.09) will be ignored. Increasing output
5 @' e" o- ~% P/ i: p        accuracy may allow segment to be generated.; z9 u8 j  r9 s" X' j/ V8 H6 s
% S3 O# c6 N7 p9 n/ k; j; Q6 J( q) ?    WARNING: Segment with same start and end points at$ g3 v& }9 A$ ?2 S
        (14925.41 7863.94) will be ignored. Increasing output
# r' o- s5 ?+ X        accuracy may allow segment to be generated.3 s" c4 ?- U1 H& f
. Q' P6 n( v7 M* x1 h    WARNING: Segment with same start and end points at7 R  L9 R4 B. Z& c' ?2 E
        (13755.58 7716.52) will be ignored. Increasing output
3 {5 {& L, n; A3 U* ?" |1 b        accuracy may allow segment to be generated.
" E' f+ K1 c! S" n
1 I4 A+ \% q' _4 u- P' E
2 l) `1 ~" h3 A/ w! @" ~" ^) ]* W* W% @+ x2 Y2 P
  APERTURES USED:
& [% V$ a' v& n; l8 v: N5 a; k  ---------------------------------------------------------; |6 Q2 X$ t. ~' }2 k8 M) T
  TYPE       SIZE/NAME                   ROT   MIRROR MODE ) M+ c5 E; b2 L% Q: `6 |) z' s
( n- _- \' r& E  S& I9 @" a6 M  CIRCLE     0.00500                                  DARK
, X) b. M5 Y: R8 D* h) T" b5 g& U1 V  CIRCLE     0.00600                                  DARK
3 N% Z% N. D) P% o6 S- n  CIRCLE     0.00700                                  DARK ( X8 q* a: s0 `2 o2 h+ }5 c
  CIRCLE     0.00800                                  DARK
9 A/ n. M7 b4 L, E+ |: d8 V
8 d, e% w- Z& I1 ~+ Z  o5 V# _     SILK_TOP created with warnings- k5 E/ F  H& {
! N/ t0 [$ {, O4 x; m
, Q; ], ^9 }2 a8 A9 [8 ]# W================================================================7 B  N" ^1 s0 u/ P
     PROCESSING FILM < BOTTOM >
& T* Z/ }9 }% m6 `: }     TO FILE < D:/Documents/Desktop/99/BOTTOM.art > ...' N; f/ n4 m) V1 }
================================================================5 }; y5 Z; b) z3 w& k
" ]2 S) b- u( p  FILM PARAMETERS :2 r4 }- O3 y/ ~1 |- d6 Z: {
! Y# |: P5 B4 ?3 x' V& C5 }3 [  Undefined line width                5.00
7 E& k9 j, N$ [0 c  Mirror code                         NONE/ O& c" Z+ h0 r* U4 w$ L! T8 Z5 T
  Rotate angle                        NONE! J; i5 M1 L0 A0 H6 W2 \: V% B
  Offset x:                           0.00
( X$ q  Y  E4 p6 g( [  Offset y:                           0.00& z- h. |" L* X. O& ?  x( J' \
  Plot negative                       NO8 f! P: b3 x4 \; v$ T
% S- x5 g4 N# f9 |9 {" ~& u  y) g! x, g! F7 R/ `; u' b
8 E5 }6 ], J! Z; B, j: ?2 |) l    ERROR: aborting film - Shape with first seg=(11210.08 7727.26) [layer=BOTTOM]
9 R0 x3 z6 f0 e, V        has a void with extents [(12294.72 7788.51) (12369.76 7959.55)] that touches
8 b. i$ }- {* m- ?, r$ F0 i7 t        another shape with first seg=(11210.08 7727.26). Manually resolve problem.8 s( R: l* c  D" t% j
3 d6 c) g8 a3 h/ J/ u& T    ERROR: aborting film - artwork will not be generated!( v( x: e. g- I( t6 T
Error in BOTTOM--halting output.  Artwork file not generated.1 a2 E0 z3 v8 Q+ t' D
*** ERROR with BOTTOM
5 e0 [7 Z7 r. f' R, g  ~* K2 V& p( E
3 g4 i- y6 s! Z" _; h  b+ `9 t. Q) b1 [8 b0 m9 k3 O
) W8 \: ^' |2 c================================================================
+ U) t4 z6 a/ \. \5 B& v     PROCESSING FILM < GND2 >
3 e' l8 [$ @" D  B     TO FILE < D:/Documents/Desktop/99/GND2.art > ...
# n, Z$ h% w+ u================================================================- Z, V# _& F$ Y+ s$ }# H
" S6 a' {( ]2 s5 }5 u, L& r6 i  FILM PARAMETERS :0 D9 {/ x, S3 q
  ---------------------------------------------------------) C5 c5 X. Q. y: `' r
7 [. e# e9 |& U  v9 a* M  Mirror code                         NONE# h- _% L" L; m$ [# s
  Rotate angle                        NONE
3 _! ?  r. u1 s1 p) j  Offset x:                           0.00
0 b9 c( B1 P( p8 W- U4 D  Offset y:                           0.00
& J: s2 ^$ x( E& @0 ]1 p/ c  Plot negative                       NO
; ?; T: Y. f# `  Suppress unconnected internal pads  NO
% M1 f7 Q# E3 G' S6 O: ^) F) T/ \6 q6 S+ X! A4 ?
6 W) v8 ~& [- @1 O/ Y        (12333.42 8070.95) will be ignored. Increasing output1 k% Y  ~; t, W
6 g% v7 r* O* k8 ]6 x/ \! T2 C$ K, _2 x6 b" C* l! e
3 ]$ r: t' x: t+ U7 i8 q        (13689.30 8070.96) will be ignored. Increasing output% I% K' ~  o9 K
        accuracy may allow segment to be generated.1 M0 T7 s. p  P8 ~/ T1 m2 h5 C' a/ ?6 I
# u, G$ T# N. T/ i" t
# @9 ]7 W6 e) W! A& l! g) E7 c
$ Z6 ?' v+ p( N  APERTURES USED:
8 m5 [: k: x2 W9 C* ?% x0 |# U/ c  ---------------------------------------------------------' N( y8 M1 Z$ l$ e
  TYPE       SIZE/NAME                   ROT   MIRROR MODE 7 N  m/ u% m4 |- ]. G! V* m% Y
  ---------------------------------------------------------+ j* P! Y6 O7 g1 H+ b
  CIRCLE     0.00500                                  DARK ! v/ t& s& g' {5 c; t$ {, n" O
  CIRCLE     0.02000                                  DARK
# H* |5 R) u5 `* j4 q' ?  CIRCLE     0.02400                                  DARK
1 A" i: @5 b& P: I( x8 m  CIRCLE     0.04000                                  DARK ; I( `. O- [: t: `
  CIRCLE     0.04300                                  DARK
3 u3 N$ z% P( @5 G# m  ?  CIRCLE     0.04700                                  DARK
) L* Y' ]- c, H! V+ w" R9 c  CIRCLE     0.05500                                  DARK ! y$ X) o- b+ |0 k
  CIRCLE     0.06000                                  DARK - t2 V# V1 z3 @8 i- Y
  OBLONG     0.05400     x 0.12800       0.000 NO     DARK 8 ]0 P/ B% [/ O
  OBLONG     0.06500     x 0.11300       0.000 NO     DARK , W6 v* k/ ?6 p
  OBLONG     0.06500     x 0.13600       0.000 NO     DARK 9 }) G6 M" b, S+ R" \  C( Q% y: t6 j  s
  OBLONG     0.06900     x 0.12500       0.000 NO     DARK 0 ]. o- n7 ~# p4 y
  B' E2 r# A' K* d0 b  _4 e& E     GND2 created with warnings2 ~6 n+ ^# w# \) `& O# W; D
( w2 E" E: E9 h" W3 F8 S: l" K9 X8 t
================================================================+ R1 i! e; a$ _
     PROCESSING FILM < SIG >2 c$ E  C1 {" \/ r9 q  Z
     TO FILE < D:/Documents/Desktop/99/SIG.art > ...4 B; {& E( F3 U) ]
================================================================; n1 y9 ]: m8 Q! I& \! [
+ r4 a9 U3 r0 C" A$ \8 J
  FILM PARAMETERS :( C! O% a+ s' R* f3 n: Y- L- R
  ---------------------------------------------------------# r3 G8 O& m- E* x- Y& J6 i, A8 h
) h2 b/ K! E) I% U4 X0 v* w! A) T  Mirror code                         NONE
, \) N1 K5 h5 b. L  Rotate angle                        NONE  d( o9 f( x2 P) I1 r8 U, w
  Offset x:                           0.00
( A" n# d+ V( k9 [7 z5 M' G  Offset y:                           0.00
$ L. a- x* n: u. o  Plot negative                       NO& S% ^9 M: S+ S& c
" F% x* c& X) d4 l
" D8 A" u" x  ~; T# o. D    WARNING: Segment with same start and end points at
. V7 l- l$ X- I+ L! M% t6 Y2 V6 l        (10849.82 8267.53) will be ignored. Increasing output
9 b- P0 l" m3 @( K        accuracy may allow segment to be generated.
) X/ [- R5 {8 |! b: P, N9 a- S+ G0 z+ \$ \8 M. T  |4 ]
9 V0 r" R* W- N9 J% ]        (10849.69 8268.11) will be ignored. Increasing output
1 b* ^, Q' W( N        accuracy may allow segment to be generated.6 ^  e0 c- i, m; q0 |  F& x
- ?7 _( R& Y, t$ |! h1 |% T
$ X; g: }2 D: d4 y        (10831.89 8250.31) will be ignored. Increasing output) L5 ]  f( j+ k* t, H0 z- f3 r6 E% t
' c1 \' ~! T+ ^$ z
: K$ O; q# ]7 _/ I& l' n    WARNING: Segment with same start and end points at
, D$ i, I* [2 Y. @0 L        (10831.89 8190.31) will be ignored. Increasing output
* W. H# j/ F0 a1 s& U6 M" ~        accuracy may allow segment to be generated.
# U* O9 l! [; _9 X1 |
2 ?$ h% O$ p! B7 B8 T2 |+ H    WARNING: Segment with same start and end points at
% M' |" c* D) U% l( W, r4 A# A        (10874.89 8009.20) will be ignored. Increasing output( n" B4 e2 ^: v1 L
! l/ z1 O) F. ]# @& {
  ~. G7 k$ z2 m+ a    WARNING: Segment with same start and end points at+ l+ v* y$ C) u, A# _
        (10874.89 8009.19) will be ignored. Increasing output0 v) Z4 x, H) L" C2 u  l
        accuracy may allow segment to be generated.) Q+ F1 p( k+ \  j& r4 Q
6 |' z2 z+ e! ~. o4 }( x
    WARNING: Segment with same start and end points at7 g% R' l% i0 C0 w& p9 t& G9 N
' L/ U% ~4 n  B& L$ f6 d% v        accuracy may allow segment to be generated.* O7 h# \2 Q  z$ d8 m# A% H
  K2 E  g/ I: {& m5 O" ]: w$ |$ u
    WARNING: Segment with same start and end points at! c) p$ T9 M% c5 W5 H- d) c
        (13689.30 8070.96) will be ignored. Increasing output& q5 B2 E2 B& j7 E) U1 j# J
- D# e+ y7 W. k! k% e
- p1 I; Z7 ^. M: j7 D" Y% D    WARNING: Segment with same start and end points at
% n" {# I4 s1 G5 e; N* L# @        (15022.82 7964.66) will be ignored. Increasing output; b& O* U; X2 G
        accuracy may allow segment to be generated., P' |8 r! t3 y" l1 ~5 ]4 E
4 t& i/ k, i# u* y
! V' s1 i! e, ]/ h& D) p8 ~        (10618.75 7691.98) will be ignored. Increasing output
0 h2 Z+ p1 ~2 T8 E        accuracy may allow segment to be generated.+ H6 ]9 B" s; [  Q! w& A
7 y! X" C4 \- r0 M    WARNING: Segment with same start and end points at
- J* I6 K5 }0 |8 i! }+ e        (10562.38 7691.98) will be ignored. Increasing output3 x& x7 k9 I. Q" \: [) A* Z
        accuracy may allow segment to be generated./ o: I- w- n5 W" u
2 ^, \( S- F0 ?" J
1 h( H1 |) P/ L. R9 B: b  Y        (10562.37 7691.98) will be ignored. Increasing output
2 U" _, ~! O: ^2 _0 @        accuracy may allow segment to be generated.
' D  ]9 v( n' X# t+ |# o8 k' V1 }* K: d" u% i2 f7 D* l
. V! ?- k# y5 m  X, k$ D7 v% i        (10159.98 8986.71) will be ignored. Increasing output
, Y7 m' ]/ [% `        accuracy may allow segment to be generated.9 `# Q* @0 P0 v: x$ L8 \
- e# T' u6 p# e
, T% f- b8 W4 S# B3 u9 f. o9 [        (9968.32 9057.48) will be ignored. Increasing output, ^0 E+ R' P' ]* {
. }' X/ O, A9 ~6 p
+ U- \4 O# c3 `# x- F& p- t    WARNING: Segment with same start and end points at
9 {' r# I3 D, ?$ J        (9488.92 8836.26) will be ignored. Increasing output
1 [1 ^3 [. s: o4 ?* z( n        accuracy may allow segment to be generated." D6 ^& j' k4 b( m% N. T
4 Q7 l7 p! v, b% |0 y% F2 E: G    WARNING: Segment with same start and end points at" H+ Q; p2 L9 t$ @- O' V2 ~
        (9508.59 8856.40) will be ignored. Increasing output
: {9 u- [- b4 S        accuracy may allow segment to be generated.( C! |. I$ T1 b8 A. ^3 j" {
: ^0 L( T  a7 V/ |' ^0 W
0 s# [8 n  o  W$ t5 u1 ?4 Y        (9548.59 8866.40) will be ignored. Increasing output
3 ]7 z" G: U! r& k: s7 Y7 W5 `        accuracy may allow segment to be generated.
! @. D; O  m- j! [3 P3 [
# P, s/ V$ _) D6 b- J% f0 {    WARNING: Segment with same start and end points at
9 |# D' ]( U& D: p/ C- y        (10555.87 9195.08) will be ignored. Increasing output4 Z0 G( Z: d8 f& S5 a9 R1 S1 E
  t' V" k8 r9 z) f3 w/ c  X; L: s; \8 w
+ J: R8 P4 z8 p: g& h$ S4 ?        (10498.74 9183.92) will be ignored. Increasing output
  B. X0 \8 w* n        accuracy may allow segment to be generated.
7 ]' A; {* _- v9 D3 l
' }) O) a% k4 T3 a/ a: V, ^    WARNING: Segment with same start and end points at" k$ F+ Z/ `, Q: p& F% Y5 w
        (10456.40 9206.41) will be ignored. Increasing output
2 u' K& D4 h+ i        accuracy may allow segment to be generated.
  |" B* e; G8 v. W4 q" j1 `- r' [* l. z- l/ W- b
    WARNING: Segment with same start and end points at9 R! d. V! o3 l
        (10497.28 7856.12) will be ignored. Increasing output
  z, M$ S* `/ ^8 t        accuracy may allow segment to be generated.0 U, k8 V* X* ~& \# @/ @) N
9 J0 F, N9 k( `, X& f
0 a8 i3 I+ ~* z        (10563.19 7694.00) will be ignored. Increasing output6 C. k$ }8 J7 P9 B7 J8 e" O+ r: N
        accuracy may allow segment to be generated.* _! ~- A& Y' L1 W9 S! D$ a- V4 @
4 R4 M- A$ A4 V8 t6 X    WARNING: Segment with same start and end points at: c  j' p, r( c, ^
        (10563.20 7694.00) will be ignored. Increasing output
: a/ L7 W2 L; a8 R, U4 @; a        accuracy may allow segment to be generated.
+ ^  A0 o: B& p8 R# w1 a2 A* B5 x5 D9 L9 P6 `+ ]
    WARNING: Segment with same start and end points at2 I3 _( O. U% h; s/ ~! p( {1 z  V
        (10617.91 7693.99) will be ignored. Increasing output0 f5 j( [: H9 f' k4 R) I
        accuracy may allow segment to be generated.0 ^% Y2 w% \$ ^) e
( M4 u3 H( ]' Q
    WARNING: Segment with same start and end points at4 a* z; f- X1 y3 [* e7 u: |
        (10595.12 7749.00) will be ignored. Increasing output
* b( w! o( Q8 ^+ x# k        accuracy may allow segment to be generated.
) @* L& t  M- r
, B* o# j! D; R/ |, u( k    WARNING: Segment with same start and end points at: G! O: q0 j1 z1 B0 A4 g1 [! S
        (10586.01 7748.99) will be ignored. Increasing output, w9 n9 R6 N5 I! q- s7 z
        accuracy may allow segment to be generated.6 w- e) ?4 S# G0 `
* H# {4 ~- a$ r) Y, R# ]
    WARNING: Segment with same start and end points at' K- _8 Z5 B  j% H2 [2 \; X  l
        (10586.00 7749.00) will be ignored. Increasing output
- c2 A5 _/ l( |( C; \4 d3 Z        accuracy may allow segment to be generated.
( J/ `& i# h  R9 j0 a- o7 D6 Q1 Y
( @4 \# w4 ]0 K4 _' J' b; u    WARNING: Segment with same start and end points at
, A- f' C/ v+ Z/ {0 ]( f        (10484.27 7850.72) will be ignored. Increasing output0 {( V7 T4 ]. [1 p4 j# n
' s2 h: u5 v1 p
2 T$ O- v& x9 _    WARNING: Segment with same start and end points at: @+ y2 R* V4 m: R7 H
        (10599.68 7738.00) will be ignored. Increasing output
: b- M" g4 c( s7 ^) V        accuracy may allow segment to be generated.
% `* h9 C1 `! ^; M4 s5 R* X- S6 d, D( C1 p, T3 ~) _
! k7 d7 |  q4 c! z' _  E0 @) |        (10581.45 7737.99) will be ignored. Increasing output
0 p$ ]4 M; Z& A& G        accuracy may allow segment to be generated.% y, [5 {4 i2 M
% ~5 d$ X) X, p4 ?* V    WARNING: Segment with same start and end points at- _0 w% x" z9 p, Z
        (10581.44 7738.00) will be ignored. Increasing output% q% `1 B2 D4 g4 F/ w' t
        accuracy may allow segment to be generated.* ^3 r! p2 C) Q+ m/ F. J; }
( U' N' D6 B3 M% M  t0 |    WARNING: Segment with same start and end points at- P, _3 k' ]' q. @% n
        (10613.36 7705.00) will be ignored. Increasing output
) p5 Z+ c; G" \7 B        accuracy may allow segment to be generated.' J; ^0 q$ K' B' t% a- E
( ^, s8 |8 L) h$ S/ `
, X# E5 r+ Z  `; g        (10567.77 7704.99) will be ignored. Increasing output
5 U$ t2 t# |( i        accuracy may allow segment to be generated.
; @9 q) i! h4 a7 S' E1 d" l
% ?1 Z4 N2 d- r* {- G/ K: d* K8 N    WARNING: Segment with same start and end points at
# R, h; d; J0 ], K$ L        (10567.76 7705.00) will be ignored. Increasing output2 }/ c4 P0 ?1 V% T# h& [
        accuracy may allow segment to be generated.9 e+ n$ F$ f$ E/ Z
5 \5 C3 c4 E0 v) ]
    WARNING: Segment with same start and end points at' t6 B5 m* @/ {1 R  [
        (10576.87 7727.00) will be ignored. Increasing output
. D; {: T( ?6 X5 x5 Z' n7 ~4 N. [        accuracy may allow segment to be generated.! W5 j3 s/ e9 Y( Z; a$ A
/ o/ |* v9 H0 D& _5 d2 L, c
    WARNING: Segment with same start and end points at, b% j8 a4 K# Q& e5 k
        (10576.88 7727.00) will be ignored. Increasing output( F" C/ z# U8 _7 b/ N
        accuracy may allow segment to be generated.4 @& ^2 ^" X$ w' F
( D! y7 r1 R5 [- a' N9 s+ J    WARNING: Segment with same start and end points at0 B7 e# J& d3 K
        (10604.23 7726.99) will be ignored. Increasing output- o5 P8 w& |/ Y0 v
% S% `& Q1 A7 z1 N% ?# ^! X! V1 h  N9 G* p, D; G' t( P+ K; J
/ k9 g& _, X1 ?& L/ c0 j        (10572.31 7716.00) will be ignored. Increasing output
) Z8 N4 h1 _$ T- ^7 J' _        accuracy may allow segment to be generated.
' ^+ G+ h6 [& [. @! m, d8 Z
* R9 U- K- o- ?% ^9 @) E! T    WARNING: Segment with same start and end points at
! r% Q$ V' v8 Z( j) P' e% a% Q        (10572.32 7716.00) will be ignored. Increasing output- S8 W' z! {: X" K, s
        accuracy may allow segment to be generated.8 y+ O4 H8 p- E* V
7 s# F% c  T! Q9 E
9 g' u+ U$ J, r# S        (10608.79 7715.99) will be ignored. Increasing output6 v6 ?' ]; L& t) n0 g- o# q1 O
* i3 l/ e: f6 w0 a8 ^. Y4 u* V6 h/ @) l  d! I, w) i; W& B3 e! X0 G1 x
7 N/ S2 ?! C8 L/ [3 J" ?9 K$ v& i$ E/ g% o; [- J2 N0 n& k( X* Y
  APERTURES USED:1 n4 m5 @, U  Y; F) l
  ---------------------------------------------------------/ T7 f5 O& l& ^- E& h
  TYPE       SIZE/NAME                   ROT   MIRROR MODE 1 J: F+ R- W! R3 r6 s1 g) Y* O
; y" D8 l; }" I- C" N9 n6 S  CIRCLE     0.00450                                  DARK : @# v* E5 J$ ^. F6 M( D' a
  CIRCLE     0.00500                                  DARK - i# e9 m; o7 w! v4 m6 C7 c# [& L
  CIRCLE     0.00600                                  DARK
+ J$ Z7 k3 O. ~" t. T: n  CIRCLE     0.00800                                  DARK
3 K/ D4 d: F4 f' ]3 J  CIRCLE     0.01500                                  DARK
: v: n3 G( j5 V% ]& O  CIRCLE     0.02000                                  DARK
( |/ x) y8 J8 A* e8 _7 d  CIRCLE     0.02400                                  DARK % d5 F& R: A' u" [, N
  CIRCLE     0.03000                                  DARK
  I. w/ K! H" C4 @5 I  E  CIRCLE     0.04000                                  DARK
, I1 \: w/ c/ r9 Q+ J7 U* ], Z  CIRCLE     0.04300                                  DARK
; l3 Q: f7 q& {4 y' K5 L/ u/ E  CIRCLE     0.04700                                  DARK 0 a! F+ P  u& d6 E
  CIRCLE     0.05500                                  DARK ' Z2 w7 k$ ^% E5 N  o
  CIRCLE     0.06000                                  DARK
$ W, I2 \7 a( t; M; g. D! U  OBLONG     0.05400     x 0.12800       0.000 NO     DARK
( j" w, J$ j$ v& K! [' a  OBLONG     0.06500     x 0.11300       0.000 NO     DARK
7 _4 D& m" T. _1 A$ Q# ~  OBLONG     0.06500     x 0.13600       0.000 NO     DARK
: ~5 ]7 }1 Q& D0 @3 g+ G6 ]/ r% H  OBLONG     0.06900     x 0.12500       0.000 NO     DARK
: q% `# x: J( ^
3 T0 `3 g/ R  T' }& O. Z9 g% S1 q4 d     SIG created with warnings( M4 l. _! z) p9 F9 s$ j
3 w5 ^! ]# S- x$ {* O" ^- O1 U* O( c
! ^+ W" K9 q2 }$ ?: H" J================================================================
  o) r) W; Q  `5 B  ^8 L. w     PROCESSING FILM < POWER >
, M4 x: m8 K/ E7 y! ]/ I     TO FILE < D:/Documents/Desktop/99/POWER.art > .../ U" z$ A6 p: ~! v$ g% Q+ r8 P
================================================================# D+ k* i( T- D* L
1 r$ B7 p4 I% q: ~1 v8 w4 x) ?# ^+ E
  FILM PARAMETERS :
6 k  ?7 {- w, P) O4 |- }$ S* T2 h2 U6 @1 L  ---------------------------------------------------------# _' u6 |: d: E% b
  Undefined line width                5.001 \0 H4 B! z8 p7 E( t- t6 A
  Mirror code                         NONE
9 `, j8 M" H* w5 z  Rotate angle                        NONE* K  g7 F4 S; y
  Offset x:                           0.00& F* f) \2 k" l0 ~
  Offset y:                           0.00# m9 ]2 n- O# }% c5 d3 x
  Plot negative                       NO
$ ]9 w: t3 V$ B  Suppress unconnected internal pads  NO
. @* u$ h) L  L% Z* k9 d" y; C8 ^7 A) @/ h0 Q. o
' F4 G, f  E$ q+ d$ k; i        (12333.42 8070.95) will be ignored. Increasing output
6 Y" f* Y" l( R" T        accuracy may allow segment to be generated.. W& [- o1 R2 T3 q! x, P9 Z
# K/ F( l4 t; W0 a8 v* b/ E1 e    WARNING: Segment with same start and end points at3 ]6 H9 c; S* @0 W
        (13689.30 8070.96) will be ignored. Increasing output+ h# O8 z7 t9 V2 v" N: B# {! k/ F8 T
7 ^2 p  y3 ?% G  u- S4 l+ ]' z
9 o7 u: C4 I3 ~6 x+ @. [6 {    WARNING: Segment with same start and end points at* J3 J- P. \6 A# r4 C
        (15022.82 7964.66) will be ignored. Increasing output7 a, j) z- J! v  o
! A" C% a7 r/ p1 ]# f. G
0 M6 ~2 F" q& r( e: _- d    WARNING: Segment with same start and end points at
+ j# h0 n0 O/ @" O$ v( P; J8 u        (10229.61 9150.02) will be ignored. Increasing output7 G# W" k3 ~" O) O: j0 k
        accuracy may allow segment to be generated.: w4 D6 J  e$ s9 g+ o* T. y/ e6 P
' z9 H5 Y6 `0 h4 a3 t7 G
1 B2 Q0 S& J8 J* O. i        (10229.64 9150.02) will be ignored. Increasing output2 w8 T4 F- S2 M/ l
; Z7 r2 I, R' ^$ A  O; l' F6 \
8 m# L. X( n, N2 h5 m    WARNING: Segment with same start and end points at
- J* p5 h' ~; ?/ L3 L, r        (10230.36 9150.02) will be ignored. Increasing output
) A) Z& M" W$ W0 I2 W9 @        accuracy may allow segment to be generated.
: f9 j$ Q8 W6 {: o; b
4 ?: [- H" K) V/ c$ B5 T    WARNING: Segment with same start and end points at
1 S8 ]! o8 T, V/ Y1 s8 `2 Y" s- w        (10255.00 9110.73) will be ignored. Increasing output
  g5 y- ~; l, G9 K# ~$ F- j        accuracy may allow segment to be generated., f/ f0 }$ ^7 @% x& d$ |  `
; u+ t# `6 J. f. y* F* D
    WARNING: Segment with same start and end points at# p4 O! ?6 Q2 P, u5 U
        (10255.00 9109.31) will be ignored. Increasing output
6 z. R/ v( M9 V1 e        accuracy may allow segment to be generated.
! T+ W# T( \& W4 o2 A% l0 f
& C  a/ {. c. V- a# z0 }2 b5 r
* u8 A8 q0 N$ q, @& F! Z3 Z; }5 ^6 U5 R8 x2 G6 O) }$ i' }# j
  APERTURES USED:$ m- L, y: o6 n3 x& e2 z5 {6 d8 I% ]
- s5 m4 I9 P$ A/ j  TYPE       SIZE/NAME                   ROT   MIRROR MODE
: X* a# x) S9 m  U, S* ]: l. W  ---------------------------------------------------------
$ D0 l2 C" d0 {, L0 _$ W7 Q  CIRCLE     0.00500                                  DARK
! C$ w; `8 B$ `( E  CIRCLE     0.01000                                  DARK 3 d2 \% v" C  \
  CIRCLE     0.01500                                  DARK
# ?0 q; C# l* j+ \1 }  CIRCLE     0.02000                                  DARK
' ]4 e& S+ L/ p8 I# N+ b! ~  CIRCLE     0.02400                                  DARK
% K0 j! w8 _( ?9 Q$ c* k# M- r  k  CIRCLE     0.04000                                  DARK
3 D1 G. E# j. D  CIRCLE     0.04300                                  DARK : c+ o- R0 v- K: E
  CIRCLE     0.04700                                  DARK
( ]. C4 ?6 a( e2 O" ~  CIRCLE     0.05500                                  DARK
* B( \$ C, u* K/ ]- z' @  CIRCLE     0.06000                                  DARK
6 k7 x  n1 ?6 ~5 b  OBLONG     0.05400     x 0.12800       0.000 NO     DARK
$ g1 G6 P; k/ c6 K) ~& B9 q  OBLONG     0.06500     x 0.11300       0.000 NO     DARK % N# M  l* E+ [* |
  OBLONG     0.06500     x 0.13600       0.000 NO     DARK 5 D; u) q0 o/ ?& V' O* v
7 Q+ z& y+ w2 @9 f" U( V' q* s  ~* b: r; O* Z
     POWER created with warnings% F0 |9 {" m" `& t# d
- f4 d- S3 f1 Y+ [: Q3 u) c* d
0 g" E1 ^" r8 O$ @================================================================: q( ~' u( x+ R/ y6 i+ y* r
     PROCESSING FILM < GND1 >
& P+ z2 U' L6 i6 ]4 S     TO FILE < D:/Documents/Desktop/99/GND1.art > ...; X  E: G/ B& r! i: d9 C( [7 f
: n2 T! ?5 Z8 |& v& C2 P6 V# e
& q( y: n6 I% x% h- T2 b  FILM PARAMETERS :5 L; T  c4 ?$ I3 S' Z# z3 o! a! R, H# Q
3 U- G, Y! ]) `5 q3 q% G' e- _  Undefined line width                5.00: I& \" p* E: p8 \: j! ^  \1 T! b
  Mirror code                         NONE; l) G* V5 d% w% x0 @
  Rotate angle                        NONE. p, X* i! G- \( w2 D" q! r6 Q- M
  Offset x:                           0.00
, D' R0 F' S6 d: C1 F  Offset y:                           0.00' \  w# L, p5 K6 x* v, o' [2 y* S
  Plot negative                       NO
' w& n% L1 t8 O: d' U# z  Suppress unconnected internal pads  NO
- u2 @- z  @8 P2 Q& T& F, j8 J+ \6 L, d8 ~( l/ {
6 l( u7 O" y% @* o, D5 n+ U        (12333.42 8070.95) will be ignored. Increasing output
8 R5 m9 H% j( T$ {        accuracy may allow segment to be generated.2 i% X8 d% ^8 ^$ J8 b6 ]' S7 c
7 w* e+ W6 r$ @9 _; X4 {6 L) @& `9 q    WARNING: Segment with same start and end points at7 x# H, J1 L. n. H9 p
$ t7 v. |% i- L+ _- H$ i        accuracy may allow segment to be generated.9 ]5 w3 x' l2 L$ B0 F* u( l1 b
: _' m9 o; _; D6 o8 u  n  D
8 }8 O8 d) r( R& T0 v7 _" W
  V9 m" A) J& ?( t  APERTURES USED:! c) W) L- G" u
$ j' C; `9 g8 N  TYPE       SIZE/NAME                   ROT   MIRROR MODE ( r; ~0 T2 I' I; t( c1 [
/ V2 [) K9 n$ u9 C8 w  CIRCLE     0.00500                                  DARK
( Q9 i' |0 `. O  a# D' p  CIRCLE     0.02000                                  DARK
9 {( {0 x  s& o  Z* u+ |: @6 Q( u  CIRCLE     0.02400                                  DARK ! j- @* V+ O. g
  CIRCLE     0.04000                                  DARK
' }: o: G- F- i! S! @  CIRCLE     0.04300                                  DARK ! a- t( y3 ^; T$ u. d
  CIRCLE     0.04700                                  DARK . x9 H, f: C$ m( U4 }% q; U
  CIRCLE     0.05500                                  DARK
* k9 Z2 v2 o( ?+ `, R3 K  CIRCLE     0.06000                                  DARK ! b9 ]9 b' j8 _$ x
0 i; B  V) f' P  OBLONG     0.06500     x 0.11300       0.000 NO     DARK
6 ?( X) `0 p4 k- h0 I  OBLONG     0.06500     x 0.13600       0.000 NO     DARK 9 S2 c* S2 L: D4 S
/ [& b( ~( z$ M+ [5 J( @6 |% ]  g; h$ X
     GND1 created with warnings# Q3 r7 [) J  a
$ X* y8 q$ v+ V7 v  Z9 M
- h  y2 O* Y  L+ K================================================================
# [+ M8 z* P* t/ k0 j! s     PROCESSING FILM < TOP >
6 x+ E) z- s! r     TO FILE < D:/Documents/Desktop/99/TOP.art > ..." i* K6 g- i3 Z
================================================================! q1 f0 Z* l7 N5 C
# o" z9 A: H! u  FILM PARAMETERS :( {- |3 a: ], T1 k
6 k  h1 x. t" `* t$ I% r" r  Undefined line width                5.00
6 l6 d* |( P$ q$ Y$ {8 U  Mirror code                         NONE9 S- o1 K& O7 E( z
  Rotate angle                        NONE
8 @0 A3 @4 M* |7 w9 J0 r$ |  Offset x:                           0.005 q: k- w% s6 l9 m- P; R$ d
  Offset y:                           0.009 E/ B9 d7 \- y7 c( @
  Plot negative                       NO
4 Q4 I) R4 ?5 g6 J6 V6 c# h- k2 D# q  Suppress unconnected internal pads  NO
) \! j7 p$ C0 M8 J6 ~5 }
. B# T) G0 m# i    WARNING: Film contains DRC error(s).0 ]. S. _8 i2 x( O& @
    WARNING: Segment with same start and end points at7 p- f  a. ~* t0 T. q3 T1 Z
        (12333.42 8070.95) will be ignored. Increasing output& o' X: m/ @/ F  @; W7 c) Z
        accuracy may allow segment to be generated.2 r8 {7 v3 j5 \4 o4 P
3 O/ d! T% E: T) S
    WARNING: Segment with same start and end points at, N' U8 D+ |0 [- I% @2 b) D! A) _
* k8 ?% C; N  H: p) o2 v7 U( z        accuracy may allow segment to be generated.
2 R0 e. i/ {# }9 O7 {# w2 V; z2 d: c. Y
( Z) x4 @/ F' X+ _' t  K        (10837.53 8279.82) will be ignored. Increasing output
3 ~& S+ v$ R5 J& \        accuracy may allow segment to be generated.
. Y7 X+ c: }; y( e* R& P- V5 Z, D4 t. U, D7 D# k
    WARNING: Segment with same start and end points at" Y/ R& p* m7 c% g- j, z
        (10838.11 8190.31) will be ignored. Increasing output
7 {" C" t2 d; U% I1 h7 N        accuracy may allow segment to be generated.
. D2 @1 f* g# [4 S1 I& {( L" L5 O8 j$ ^8 `: z) ?
  }( b# t$ }9 D3 P8 K% b$ x3 F" D        (10874.76 8008.61) will be ignored. Increasing output3 G/ @( W8 `" l& ^. R
        accuracy may allow segment to be generated.( f4 w& W+ b6 |3 Y6 `9 c/ L
2 U# }8 m& ~) ]. z/ X2 p0 B. ?    WARNING: Segment with same start and end points at/ ~- n9 ~/ u+ a; d
        (10251.89 8270.02) will be ignored. Increasing output
! K9 \; z9 E% k& z7 d3 \- g. i        accuracy may allow segment to be generated.' o; X; K- q' l! R
# [1 P; [! X3 t- d  _6 T" B* `
    WARNING: Segment with same start and end points at1 R. f; N# @# W4 ?  P8 q% Q$ K4 P
        (10252.31 8275.22) will be ignored. Increasing output
7 q' ^9 o3 O5 H; [1 M        accuracy may allow segment to be generated.  v* k* w4 M4 d+ R( S+ V
8 o+ p0 h" ?3 l9 H    WARNING: Segment with same start and end points at& c. t$ S4 U# a% H: Z! F! C
        (10650.26 8947.01) will be ignored. Increasing output
4 S- T& s/ M5 W. z/ C1 T' N+ T        accuracy may allow segment to be generated.
2 X& o. i0 i" y% D; H% P- k# P- `, P& X# T
    WARNING: Segment with same start and end points at# F2 u* a& ?# i5 s$ g. M' ~8 K% |
        (10685.52 8947.45) will be ignored. Increasing output  I+ [( V) g2 R9 r2 E
        accuracy may allow segment to be generated.5 K2 _2 A; \8 J% n. A' U
8 N7 W" h4 x$ D1 Y' n: D    WARNING: Segment with same start and end points at
$ d5 l4 r/ P( e% ^        (9623.74 8638.92) will be ignored. Increasing output+ t9 g1 S8 w! K6 Q: c, K
        accuracy may allow segment to be generated.0 L% [# p! N* E0 @" V: P8 [
. t: {1 l! j# D! {5 t    WARNING: Segment with same start and end points at! f5 b# p* S9 q& X: |1 N+ L- X# U
        (9738.92 8741.26) will be ignored. Increasing output
" e) _- r, t& G9 b7 B2 ?        accuracy may allow segment to be generated.
2 S! g: K4 H6 w' m) y8 [: S4 ]8 L. \& l" e+ ?3 b* Y. q
    WARNING: Segment with same start and end points at7 Y  v3 q" C. k( P# I
        (9799.84 8751.38) will be ignored. Increasing output
. L  w% P% L# A( `9 N4 L        accuracy may allow segment to be generated.7 M" P" F# J4 C7 P0 M
0 f( ]- ]) X9 s- K# h, E8 U
    WARNING: Segment with same start and end points at* z& g- C* o; p% t% ?( y
        (9805.45 8751.25) will be ignored. Increasing output- q1 l, C; G% A& m* K/ N/ V
        accuracy may allow segment to be generated., G+ H$ H" Y1 h; L; m
, a5 \5 G$ a  b! j# i    WARNING: Segment with same start and end points at
. D, R$ U; v2 k( u: j. p  F        (9859.13 8749.92) will be ignored. Increasing output  j$ A% o$ ~6 j. \
        accuracy may allow segment to be generated.2 ]6 W' f7 L- o% T& B4 W
3 e7 ^: b+ l0 A" v( {
0 a! y. T- P; \7 x        (10685.74 8725.29) will be ignored. Increasing output# L& g& @/ N6 Q. O2 c
: F, w- p$ B0 A" ]5 g7 M* U$ G& U( f8 Y4 R
% {) s# p& |1 L        (10650.48 8724.85) will be ignored. Increasing output- L# x- C/ ^% O+ o4 S7 _
# \( u) }6 G' |. w% N, ?- S: [0 Z# G
    WARNING: Segment with same start and end points at6 g+ f+ ~- T$ \% @4 Y  Q
        (10632.02 8770.07) will be ignored. Increasing output$ a4 K: w5 g" z$ V/ j
8 C: Q* ?( g0 }9 O) Z% R
  U7 {5 |& G) ~7 c6 D8 I- o6 g# f    WARNING: Segment with same start and end points at3 c* x4 I$ T4 \1 {6 W  |. d
        (12617.86 7825.24) will be ignored. Increasing output1 [& ?+ Y+ H; g' A- j; u" J2 s5 G
* k% ?2 ?* u# x+ r/ I6 S
8 d, d6 m6 I& h    WARNING: Segment with same start and end points at/ j% }# y& z: H9 T  g5 t
        (12577.55 7825.11) will be ignored. Increasing output' b0 m9 Y4 s' P) N! J
) n" `8 [+ r+ g. F
0 S5 j+ z0 H6 \9 s. O+ u8 J+ u; j    WARNING: Segment with same start and end points at( }: E+ l$ ^4 |' o
        (12416.68 7847.50) will be ignored. Increasing output7 W+ f8 H9 s! Y, A  K! C
) s" y2 j5 n0 l- ^9 r3 o& U6 D% v9 @6 J
    WARNING: Segment with same start and end points at# E) q: M6 ]/ p
        (12611.23 7969.61) will be ignored. Increasing output4 k& I6 D$ u! x' v) B+ Y1 e. P
        accuracy may allow segment to be generated.! t: b/ B% W: h4 M2 Q$ f
$ B$ V, x+ t4 p1 F2 d. Z. W    WARNING: Segment with same start and end points at4 E1 q! f% z- t; ]
        (12685.18 7977.53) will be ignored. Increasing output
/ p2 ]* ^! G& ?3 j6 {5 ~& J        accuracy may allow segment to be generated.
! H! w9 S& I% ~
5 v" z1 W9 E/ m    WARNING: Segment with same start and end points at
$ F' e3 x1 D9 s2 x7 {6 y        (12709.45 7963.32) will be ignored. Increasing output% Q5 n1 c* O; S$ w% ^0 h7 N
+ x( n3 h' T! q: r
2 A( C7 V3 j' t- @  P( _: f    WARNING: Segment with same start and end points at
/ I1 K# r- f5 x& I) X        (12748.31 7968.04) will be ignored. Increasing output
, }: \( I3 _. `        accuracy may allow segment to be generated.
$ ?* m. ~% R7 ]0 n8 F3 e6 N. \+ Q/ Z
6 L) p4 Q: G/ b; b+ |        (13074.14 7942.98) will be ignored. Increasing output: t, R, q' g" i
2 n+ N2 B) ~: K0 M2 M) ?  C
, ~( y7 P; V4 }    WARNING: Segment with same start and end points at
/ v/ i+ R6 I* G* b5 z, J- _' Y2 R        (12413.82 8006.14) will be ignored. Increasing output
$ I4 @8 z- ^5 p! k- |: [9 Y        accuracy may allow segment to be generated.
( n$ a1 a5 N. M# \4 w$ l
# N9 I, r3 f& m( d5 }, B    WARNING: Segment with same start and end points at' q& [0 J# n0 U& w( y! U2 `/ t
        (14482.52 7744.48) will be ignored. Increasing output  N8 o) ]! v; ?  Z6 \6 ]
$ L" B' i- q! b. ~) ?: {3 Y$ {( M
7 W4 N1 r* t* h0 S" l  _1 Q    WARNING: Segment with same start and end points at
( f( N4 Y. C4 o3 `- H0 Y        (10468.74 8894.25) will be ignored. Increasing output7 U# X3 x0 E5 M5 A+ o% b+ m
  R: n2 G% `1 {3 o
1 W- `, @* p# P& [' r  V( e    WARNING: Segment with same start and end points at
, d7 O4 Z& x% E% d! v" a: b        (10444.86 8963.10) will be ignored. Increasing output2 u" m! |: ~: z  Q" Z8 ]! T7 `
  O' T7 h# w- s7 c' ~7 V2 L
* `& r, Q: I" ], W6 @    WARNING: Segment with same start and end points at
- Y' w+ K) P( |  c" l+ h, n        (10193.74 9003.92) will be ignored. Increasing output% m! F1 J& b$ a1 w! E) M
; C8 b$ _! ?  R$ O- c! c: \
" d& I# J9 V$ g6 x' f8 A    WARNING: Segment with same start and end points at
4 G8 b" h1 j6 o2 k        (10168.92 9106.26) will be ignored. Increasing output( r* V1 {3 @  i: z4 ?* v
        accuracy may allow segment to be generated.! H7 j5 r( U" i, b6 L
# l" l9 g# P6 Y
4 e# f: d3 _5 B3 l8 m        (10188.59 9126.40) will be ignored. Increasing output; _$ O! m* Q- ?9 N. S# j0 T
" Q& Q" G9 w. r7 Z& T  h6 F5 _/ N2 C& j+ L
1 ?- @" V4 s  N& C. q7 ]2 J! l    WARNING: Segment with same start and end points at
$ _  X+ n3 g/ k8 u; s$ K% U. _/ c        (10555.87 9195.08) will be ignored. Increasing output$ \- N- E0 ?) b7 W( t, Z
        accuracy may allow segment to be generated.3 D, W% R' L+ v2 D
1 S0 B: Y, E9 u3 h9 M9 K: S
/ m' _' {+ j8 i        (10530.15 9227.84) will be ignored. Increasing output
; i0 K7 U1 j0 ^3 R9 t6 i        accuracy may allow segment to be generated.
# s7 D) o# ~2 y9 c/ g, r  _7 i% B9 C" f* r- Y7 Y! @
% N' v+ y+ K/ F  C& A        (10498.74 9183.92) will be ignored. Increasing output' a# J6 W* D: D  l  o0 u
        accuracy may allow segment to be generated.$ j6 j; U) p- M$ ]1 w0 p) g
0 {: E; F$ ^6 {; m- O    WARNING: Segment with same start and end points at0 h: x# L6 T% B7 o: w
        (10359.89 9160.81) will be ignored. Increasing output
- K7 F0 B4 w& i3 _7 C3 O8 F        accuracy may allow segment to be generated.
+ _- z0 G1 J% {# n0 e
8 ], O$ z+ ~, H+ y& p    WARNING: Segment with same start and end points at
! ?- c% L9 c6 S- z/ G2 W" y9 C. z" |        (10510.77 9126.24) will be ignored. Increasing output& m$ \! {6 a  o" e( K0 Q4 Q7 K
        accuracy may allow segment to be generated.( e$ c- z- I: W; T( s) F
- q5 O/ q% K9 d  L" U6 N' j
    WARNING: Segment with same start and end points at2 F! B/ j# J# l# F, t9 Y+ v* e( Y
        (10515.93 9125.66) will be ignored. Increasing output
' U& p3 h" Y* Z        accuracy may allow segment to be generated.
( {: H  A. R+ v6 f; c
4 }- j9 w, V5 s% x    WARNING: Segment with same start and end points at, f4 B# Z. y. s% g! Q0 G( S# B
        (10626.40 9103.63) will be ignored. Increasing output2 x4 W/ Q& P* `
        accuracy may allow segment to be generated./ c: ?$ Q' b; ]& p& r5 K  N
) Z+ ?! `+ j2 f6 d
) ]1 F( Q6 V* Y3 a( J, `, Z5 q        (10460.32 8999.40) will be ignored. Increasing output! t4 x5 O0 M7 Y& b! t& Q
        accuracy may allow segment to be generated.3 t$ k4 O0 K5 S
; n* e7 H+ f! r6 H! k
    WARNING: Segment with same start and end points at% Q# l* ?# `% e9 V* F
        (10479.86 8979.81) will be ignored. Increasing output
, R& \) ^2 e2 F* U4 ^! \  I        accuracy may allow segment to be generated.5 I# o! z$ u7 K' Q4 u
* u$ F/ f& d) p4 e6 D6 V* B1 t
    WARNING: Segment with same start and end points at2 ~5 G; m; F3 s' J, b3 i
        (10473.90 8893.67) will be ignored. Increasing output
* r0 y; r) H  Q5 Q  s7 N        accuracy may allow segment to be generated.* E7 b: S  C: Y* f/ p6 a/ k/ ~
( M& K$ q! M- K) N' |0 s
7 l7 m  S9 S5 A/ t& A) G        (13641.76 8004.98) will be ignored. Increasing output3 b% q3 {/ @# `* f# ~" x0 V# `* H
        accuracy may allow segment to be generated./ v9 j/ |- r, h( b: j
% M2 ^5 ]4 }, @4 T% t; w1 z
    WARNING: Segment with same start and end points at8 D2 E9 p% A  k  W, a( Z+ q2 \
        (14216.98 7694.64) will be ignored. Increasing output
: L' p# M$ O. z9 {, _7 ^        accuracy may allow segment to be generated.4 r9 m- f( u' v7 @4 @  ]
1 Z2 P9 H% i$ K; Q2 M/ V' v, ?( R
    WARNING: Segment with same start and end points at& S7 [, C( |  N  F
        (12425.47 7835.00) will be ignored. Increasing output
6 d& r' d% x0 g7 E9 K( m6 z        accuracy may allow segment to be generated.
1 k8 z, G, J6 {
4 [5 y7 ^3 ~5 T' Q    WARNING: Segment with same start and end points at% Y) S. }& `* Q$ e; \/ ?7 n; h
        (12775.00 7975.00) will be ignored. Increasing output
- n: J8 X. d# r! W+ e5 M        accuracy may allow segment to be generated.
2 U8 D, ^: x6 S3 M, Z: D- Y; m- F2 f: \- G, j( }% T
6 O5 C6 ]2 w0 \# T( U0 l) Z3 K" G        (10472.50 8970.00) will be ignored. Increasing output
! I( Z) G6 u  ?' \, r        accuracy may allow segment to be generated.
2 y# ?0 j/ L- z* x
( u& g+ Q( E# F! E8 O6 a    WARNING: Segment with same start and end points at" y0 o" t& O% |  |* m$ T' g1 P
        (12443.85 8095.00) will be ignored. Increasing output5 S8 F$ i1 ~, v8 }- O
        accuracy may allow segment to be generated.* h- D$ B" W* r4 A, f& C
5 h7 [* V3 K* x* r  b8 C) J( G3 ]
$ J# V  r' R1 d# l$ n$ d8 V4 @        (12035.24 8025.00) will be ignored. Increasing output
9 X) C; N8 O1 R7 K! N; s6 m5 k+ a9 }        accuracy may allow segment to be generated.7 O) c$ `$ Q6 ?& W7 Q# T
. V. ]; p/ f. N% [2 i. v    WARNING: Segment with same start and end points at
8 j+ k4 h( Q$ p4 A: {& C        (11763.48 7785.01) will be ignored. Increasing output
: T, [& ]5 A0 C' G( T( u        accuracy may allow segment to be generated.2 d) i& \1 i( x2 i
8 C2 X7 y& A3 J2 h* F
    WARNING: Segment with same start and end points at; |5 ]8 v/ z, O
        (11759.32 7795.00) will be ignored. Increasing output- G$ V1 M8 S7 s2 |& r8 I
6 h* B0 S4 o& G4 j, q0 b/ X7 w- `0 |" c- [1 A
: `( m+ `% X2 K+ D# Y( [# E4 E, Y        (12039.38 8035.01) will be ignored. Increasing output+ i6 K$ O3 s. M8 W* F, D
        accuracy may allow segment to be generated.  k6 ?! Q& o! I
% k, k! }5 u) }* R, D# g# r
    WARNING: Segment with same start and end points at9 L) U' x8 x9 o$ W( [" H  j$ N
        (12447.99 8105.01) will be ignored. Increasing output8 O0 \3 @: @' V8 ^6 H, h9 a! B; Y
* u9 M$ T9 H2 T- X
$ S  ^( }- b8 Q    WARNING: Segment with same start and end points at
& _: N5 }; p; W4 m8 Q4 L: U6 ~        (12411.80 8006.96) will be ignored. Increasing output0 a: V# w" ]- `) y, N0 d- J
        accuracy may allow segment to be generated." l, V/ c/ z: k4 }( [
8 x( w5 V3 ^, @    WARNING: Segment with same start and end points at
8 z# {* f: P2 Q6 r8 j* E) D6 t        (13073.68 7956.00) will be ignored. Increasing output
0 Y& Q, S7 ?: \/ F+ s        accuracy may allow segment to be generated.
9 M# z5 }- \( G! o5 N
( o& V; w1 U% ]. T    WARNING: Segment with same start and end points at. X( U: b6 L* s
        (12400.80 8011.53) will be ignored. Increasing output0 i% Y/ _/ r- c8 ~* t) `( P' A: s
        accuracy may allow segment to be generated.! a8 A. A" [# B) X8 X
6 N( M+ n# [" O8 F
0 R6 t& a0 ^) Q3 f! ^        (12378.80 8020.65) will be ignored. Increasing output
* D( K! X5 U6 U' s% b3 v! g        accuracy may allow segment to be generated.; k8 o5 _: E3 a0 K  |1 N; i
& T; O% B7 r2 m! g
    WARNING: Segment with same start and end points at& I2 }, ^9 ]: D% P5 _# _3 d# A2 |( F
        (12389.80 8016.09) will be ignored. Increasing output
5 E; t$ L& w7 j: L, T. ~        accuracy may allow segment to be generated.2 m# m& x8 E6 q0 Q1 d2 u7 p. A
$ L) S) o! E* |. F+ q5 B/ h* a
2 v& D# ?% T; i9 |        (12026.33 8003.50) will be ignored. Increasing output' D$ ]8 ?2 C) N( h# w# O
' u$ A2 I( [% o- m4 _( i
" N1 A! }# [) ]6 o! h, X6 }, f    WARNING: Segment with same start and end points at
, ?/ y# |* x6 V8 f) [        (11772.39 7763.51) will be ignored. Increasing output  b9 i9 |7 e$ ]0 _1 V0 I6 x8 ?
* A: p1 W* v. [. x/ f4 D3 x; u7 x+ a: d# P. h; X" ^8 d" b# _9 c
; e/ X- K! i$ E/ P% u" H, o        (13078.23 7944.99) will be ignored. Increasing output0 I9 [7 G! A1 A, z4 y
        accuracy may allow segment to be generated.% [8 {+ J0 o5 f" b$ ?% ?( {
& L  a6 O7 [0 A8 ~3 }# G5 t
5 T0 H4 Q' B) {- ^        (10381.34 7936.34) will be ignored. Increasing output
3 X6 M  L( U# B& ]+ l        accuracy may allow segment to be generated.
# e1 U* ], Y) E, o$ L5 w7 \( H5 F8 ]) P- f& Q
7 y6 k  i# R, |
$ R6 E% B5 M( a1 E3 j& ]& I
  APERTURES USED:+ e- n' N0 r. X$ T
  ---------------------------------------------------------2 G) n$ S3 @# i# w0 X1 ?
  o, k5 T- r# C- j& o3 }  ---------------------------------------------------------) u7 T, D, O/ n4 m( j' `
  CIRCLE     0.00400                                  DARK
: W4 ~. \$ S' L+ J* _  CIRCLE     0.00450                                  DARK
! E3 j" A/ `  @. m. P  CIRCLE     0.00500                                  DARK 2 K1 J( q4 L( C9 a- H
  CIRCLE     0.00600                                  DARK 1 I- z" u; t" f
  CIRCLE     0.00800                                  DARK
- n" W; U2 K' I! Q. ]  CIRCLE     0.01000                                  DARK
3 e' y1 \4 ~* u7 g  e+ y  CIRCLE     0.01500                                  DARK
/ r; [& `- W1 p# q( w( M# a  CIRCLE     0.02000                                  DARK
* E7 ~+ Q+ [2 ^- B# z  CIRCLE     0.02400                                  DARK - H) ~5 L- L, O& I3 b" n
  CIRCLE     0.04000                                  DARK + W' g+ G: e$ G9 h4 z4 W, y3 `
  CIRCLE     0.04300                                  DARK # m) x9 m+ ]- \6 S5 z
  CIRCLE     0.04700                                  DARK : m4 J8 c  |: V1 \" t  f
  CIRCLE     0.04724                                  DARK
* V! Y0 p! ~% o! s7 w, ?9 x  CIRCLE     0.05500                                  DARK / l. B  @7 U( T4 o- n' E
  SQUARE     0.04000                     0.000 NO     DARK ( e  Q: ~) `/ @0 n4 g
9 q8 h, ]1 K7 P9 t' k  RECTANGLE  0.01100     x 0.10200       0.000 NO     DARK
+ S" m9 j7 g: q! A7 q2 T  \4 Y  RECTANGLE  0.03000     x 0.09800       0.000 NO     DARK 1 b! P6 y6 ], x& e( @- K( z  _
  RECTANGLE  0.03200     x 0.09800       0.000 NO     DARK 8 r4 t1 K( g8 A; m2 ]% j- B2 G
  RECTANGLE  0.04300     x 0.09800       0.000 NO     DARK 9 w- R  Q3 F, o+ S4 y5 t# W
! T/ M8 z5 s# X+ H* ^7 y4 |4 H  RECTANGLE  0.05700     x 0.08300       0.000 NO     DARK
1 k; q3 I: N2 O  w' U, r, `8 v  RECTANGLE  0.05900     x 0.07900       0.000 NO     DARK 1 I0 o+ [6 N3 v
  RECTANGLE  0.06500     x 0.07500       0.000 NO     DARK " R% F  [0 v2 ?
6 a  D' J& Z1 T0 R5 i! u  OBLONG     0.02500     x 0.07500       0.000 NO     DARK 2 [) k9 r! R0 m' D
  OBLONG     0.03500     x 0.07500       0.000 NO     DARK , _% S  j& s1 M9 d8 y; o
6 O- R+ h. p  z3 i6 m( w& S, E  OBLONG     0.06500     x 0.13800       0.000 NO     DARK
4 R" @/ A5 M) z( t  OBLONG     0.06500     x 0.16100       0.000 NO     DARK
. S" ]4 W1 H8 q& A2 V7 P# v) b  OBLONG     0.06900     x 0.15000       0.000 NO     DARK 6 n' J+ d" x0 g5 j% F& b+ O
# l! b" T- [! ?; G8 m  PAD SHAPE  SHAPE20X28                  0.000 NO     DARK
5 R  ?1 ^. c2 U! |+ Z& H  PAD SHAPE  SHAPE20X28                180.000 NO     DARK
7 e' f! A  _3 C2 d) e' f
. u# ^0 o1 @% M1 [/ H/ w     TOP created with warnings
* M- \3 w" P: |6 V5 P
" f0 I7 g1 q) S- u* O# C. _; o/ z! E9 z" T' k
------------------------------------------------------* c0 v+ F) }+ ^) j2 h  _6 e1 M5 X
SUMMARY:- c1 {" W/ F& N' F) T
        drill created with warnings6 F- x7 ?! I6 B1 w; w; C& T0 {4 |
% f8 ^3 [7 w4 P' ?% s% e        solder_top created with warnings3 n0 ?, Y/ R& _
) |5 ~* k0 j" x: u" q        paste_top created with warnings
: {$ P4 z- m4 Z' b        SILK_BOT created with warnings% v$ d1 o7 k% S" Z' ?
! N7 P' f4 D  \# S/ y0 X    *** ERROR with BOTTOM& [$ n( W4 v4 U0 L! t  Z
        GND2 created with warnings5 h' w, q0 F1 i. i
        SIG created with warnings, `9 t$ [/ q' Q. o* @" L
/ U/ Y  O5 ?" S        GND1 created with warnings0 _& |" X& }8 M* O/ m  @4 ?
8 J& u0 f5 g0 a$ s1 I" L ARTWORK Error
    郁闷
    2024-4-23 15:52
  • 签到天数: 57 天
    [LV.5]常住居民I
    发表于 2013-5-17 15:29 | 只看该作者
    ' a2 P& z' i4 D9 v5 i4 n+ g7 v$ I7 X
    点击shape add,画上MAUFACTUING---Photoplot_outline 应该就好了,将整个要出GERBER的PCB和钻孔信息画在里面
    发表于 2013-5-16 23:00 | 只看该作者
    查看出現Error 的資料座標位置是不是發生兩個 sahpe 共搭同一個 Void ?
    % p" N* j4 Y6 N把這兩個 sahpe 何必起來應該就可以了.
    2 e# {, `5 w/ t) F2 t9 m* Q' h) I5 `4 M) `  W$ t
    另外你的 Format 社的應該是有問題 , 系統預設的 5.3 應該是會發生精度不足的問題.
    ' P) ^4 m0 }0 j$ s8 ^請修正為 2.5 或 3.5
    发表于 2013-5-16 21:46 | 只看该作者
    WARNING: DRC OUT OF DATE on this layout.你更新下DRC
    GMT+8, 2025-11-24 16:08 , Processed in 0.265625 second(s), 24 queries , Gzip On.
