APPLICATIONS INFORMATION( w* x5 r1 M) x5 R
Figure 24 shows the AD608 configured for operation in a digital system at a 10.7 MHz IF. The input and output impedance of the filter are parallel terminated using 330 Ω resistors, and the conversion gain is 24 dB. The RF port is terminated in 50 Ω; in a typical application, the input is matched to a SAW filter using the impedance data provided in Table 5.
( `: [3 c' T! \6 r+ }3 e# }9 K% I. @0 u
從應用原理圖來看,是有市售現成的 SAW Filter 器件能購買。: T# H e& S" i# { U: @
' v4 r# _) D$ k# B + A9 r4 O: _% L' ]0 y
* t- m2 K3 L) l; T. m" W. M2 o# l7 e* R" z+ f
$ G7 l% p) D/ r3 T# F |
