查看: 307|回复: 1
优化跨分割检查代码
    2025-6-25 15:43
  • 签到天数: 33 天
    [LV.5]常住居民I
     楼主| 发表于 2025-4-8 15:02 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
    1. defun( select_layername ()
    2. prog( (numa numb changdu)
    3.     etchparam = axlGetParam("paramLayerGroup:ETCH")
    4.     l_layers = etchparam->groupMembers
    5.     etchlist = nil
    6.     planelist = nil
    7.     /**********
    8.     foreach(nlayer l_layers
    9.     layerlista = strcat("ETCH/" nlayer )
    10.     when(axlDBGetLayerType(layerlista)=="PLANE"
    11.         planelist = cons(layerlista planelist)
    12.         );end when 结束when PLANE判断
    13.     when(axlDBGetLayerType(layerlista)=="CONDUCTOR"
    14.         etchlist = cons(layerlista etchlist)
    15.         ) ;end when 结束when CONDUCTOR判断
    16.       );foreach  结束foreach判断
    17.     *********/
    18.     changdu=length(l_layers)/2
    19.     if((mod(length(l_layers) 2)==0) then
    20.                     numa=1
    21.                     for(i 1 changdu layerlista = strcat("ETCH/" nthelem(numa l_layers)) etchlist = cons(layerlista etchlist) numa=numa+2)
    22.                     etchlist = reverse(etchlist)
    23.                     numb=2
    24.                     for(i 1 changdu layerlistb = strcat("ETCH/" nthelem(numb l_layers)) planelist = cons(layerlistb planelist) numb=numb+2)
    25.                     planelist =reverse(planelist)
    26.
    27.                     else
    28.
    29.                     numa=1
    30.                     for(i 1 changdu+1 layerlista = strcat("ETCH/" nthelem(numa l_layers)) etchlist = cons(layerlista etchlist) numa=numa+2)
    31.                     etchlist = reverse(etchlist)
    32.                     numb=2
    33.                     for(i 1 changdu layerlistb = strcat("ETCH/" nthelem(numb l_layers)) planelist = cons(layerlistb planelist) numb=numb+2)
    34.                     planelist =reverse(planelist)
    35.
    36.                     )
    37.
    38.       axlFormSetField( form "etch_list" etchlist)
    39.       axlFormSetField( form "Plane_list" planelist)
    40.
    41.   );prog
    42. );defun
    复制代码
    可以检查奇数层叠,可以不设置plane层
    etch_cross_planeZ.rar
    1.93 KB, 下载次数: 3, 下载积分: 贡献 -30 , 威望 -10
    发表于 2025-4-8 15:41 | 只看该作者
    谢谢楼主的分享
    GMT+8, 2025-11-22 02:55 , Processed in 0.187500 second(s), 28 queries , Gzip On.
