TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
3.3V/8A Synchronous Step-down Converter
5 k5 r8 r& G6 b: w, vThe ZCC7008B operates at high efficiency over a wideoutput current load range with fixed 3.3V output voltageand capable of delivering 8A load current. lt supports awide range input voltage from 4.5V to 23V.AdaptiveConstant-On-Time (COT) control mode provides fasttransient response, eases loop stabilization, andoperates with a low-cost electrolytic capacitorZCC7008B also integrate a 100mA LDO and bypassswitch for efficiency improving.ZCC7008B provides complete enable control, under/overvoltage protect, short circuit protect, valley current limit,thermal shutdown function features.ZCC7008B provides compact solution for TCON powersystem! j4 j {" X( V& _
Features
" `. ~ T1 V3 n4.5V ~ 23V Input Voltage Range; F+ L1 |4 x' D5 L& ~
Fixed 3.3V output voltage
9 q6 g% v( j4 X( I' w* x. q vSupports 8-A continuous output current
9 b! o. T% L! r8 VIntegrated 20mQ High side FET and 10m0 low side FET3.3V LDO capable ofsourcing 100mA
+ Q: z `/ J- Q; l+ I- \Internal +1% reference voltage at 25°C# F _+ F1 }, W# B+ Z
Integrated bypass switch, typical Ron is 1.50
& |4 `+ L" V, a0 ?3 y. h3 `Internal 0.6ms soft-start
' s( D$ ^. ^; y {$ {1 v! OMax switching frequency up to 500kHz% X7 z+ I6 n8 w T
fast transient response with COT control mode
2 {/ B4 Q2 K) G& p$ h6 ePower good indicator& v8 p9 T& Z1 b( x, D6 @
Ultrasonic Mode
6 W) o7 K7 F+ P1 IIntegrated protections for Uv, Ov, OT, and OCP40°C to +150°C operating junction temperature
* n1 c- ?. B) bAQFN3X3-12 FC Package# Q+ N7 U. ^/ J* C0 t
Applications
' o3 b: C! w1 `! c- M, E0 M$ jNotebook Computers
4 C" q% @% g+ u0 X" J/ c3 K. BNotebook, Tablet Computers& d3 ]+ A* S# s, J; f
General power supply for 3.3V output1 ~3 t; ~7 M U! I% B
