allegro从placement -> placement list ->module instances中调用模块,报以下出错,是什么问题啊。
9 X6 s6 H' N2 W
2 N& Y. G& w3 v6 o7 X0 f2 YW- Component not found for symbol C1206 at (116412.02 22096.18), reuse id 5.
6 p" q1 B: b) L3 C' fW- Logic synchronization failed. Continuing.0 I1 \1 B7 _; J u8 S: I4 ^
W- Component not found for symbol C1206 at (116412.02 22096.18), reuse id 7., ^! Z4 v% f3 X9 \
$ j& ^# D# M- r1 E# l; Q# }W- Component not found for symbol C0603 at (116410.00 22260.00), reuse id 12.& r& M) @. I" V2 B* Z, T' c
W- Logic synchronization failed. Continuing.. N# _$ T; S/ Z/ s
W- Component not found for symbol C0603 at (116735.00 22095.00), reuse id 10.
$ {9 E/ F* c! Z5 Y jW- Logic synchronization failed. Continuing.
5 `0 p. ]# w! h0 X- rW- Component not found for symbol C0603 at (116735.00 22040.00), reuse id 2., X/ }; x$ _9 A C) t+ u
1 c1 g6 \% A; Y; s! N# m" VW- Component not found for symbol C0603 at (116735.00 21985.00), reuse id 11.
. W& m, q# d, ~$ z0 @2 [ v; AW- Logic synchronization failed. Continuing.7 a( {7 |! D1 O1 z2 l& i- m4 K: `
5 i6 R, r6 z2 u. ^4 e: G; i
4 E# I3 R4 c1 o/ R% [9 }
