现在的库(原理图库和PCB封装库)是从DXP导进pads里面的,但在用的时候出了一些问题其中有几个问题我弄了两个晚上了还没有搞定,还请各位大虾帮忙指点指点,谢谢咯~! , L! p3 u- K3 L% z
问题如下: }) Q3 Z5 P+ B' \4 M
Part Type EC10QS04_3 has the following gate pins that do not match to the Library part:; ^% ?+ D9 F @& v- |& `' l2 S
Design to Library Part Consistency Check: E. d9 T# ~0 M. s$ Y
---------------------------------------- f0 U. K: b. X y4 O
问题1、Part Type EC10QS04_3 has the following gate pins that do not match to the Library part:4 R* v% o% E& x# E
(ANODE 1) (CATHODE 2).9 \, y& A% ^) m8 \
Non matching Part Type EC10QS04_3 is used by the following parts:
+ x- X5 [4 T) W4 q% ^& P6 K9 v D1.(D1是个二极管)3 L# Q! q9 y# I
问题2、Part Type EC10QS04_2 has the following pins not found in PCB Decal SMA_/_DO-214AC_EC10QS04(PRIMARY):
. {' U- K N% b9 V" }, b3 t9 Q1(ANODE) 2(CATHODE)
8 {/ U6 @6 d j/ Y; c$ V- a; G0 {/ aNon matching PCB Decal SMA_/_DO-214AC_EC10QS04(PRIMARY) affects the following parts:, q# K" M* H1 d! V
D3 D4 D2.(D2.D3.D4是二极管) |
