: e3 B; V( q8 p3 l; x( ), \! T; H5 D8 h$ Y" ?
( allegro Netrev Import Logic )
( g X- Z: T" a( )
2 p, n" e$ E6 y( Drawing : JH-7206A.brd )* _2 @% Y2 g% ?
( Software Version : 16.5P002 )
5 l6 F7 W. D* `- ^/ M( Date/time : Sat Dec 14 16:26:17 2013 )1 d& r1 P4 V" J9 J( Q, U
( )8 l! g( j) a- z5 t. e. k! i5 I
" r4 w, N+ A3 Z. j. N) G0 A5 M
, D- J/ ^; o, C% V7 \/ J2 r* p, ?6 A, a( ~5 C' f) V0 L
------ Directives ------2 ^- r( ] n7 ]! }
- _( {+ g7 d$ N# [; a oRIPUP_ETCH FALSE;; q7 z G/ @0 m/ k& R8 S
RIPUP_DELETE_FIRST_SEGMENT FALSE;
1 X$ _! z& x9 v7 m, d( m9 a9 IRIPUP_RETAIN_BONDWIRE FALSE;
" O/ v1 i0 k: ~5 ^7 I! \+ u5 mRIPUP_SYMBOLS ALWAYS;2 a4 X: Z: e2 O6 u$ Q* e6 @ Q% ^/ L
Missing symbol has error FALSE;
' y1 o/ {# x9 s! s0 ~, q* G/ WSCHEMATIC_DIRECTORY '.';
+ Z; E9 i- E/ l1 ~5 PBOARD_DIRECTORY '';$ y8 u0 n% T% }0 N
OLD_BOARD_NAME 'F:/LIAN XI/cadence/JH-7206A/JH-7206A.brd';
' n* G, Y% ?/ G, h+ {6 JNEW_BOARD_NAME 'F:/LIAN XI/cadence/JH-7206A/JH-7206A.brd';
# k" O- n: E) e3 X- c3 r# [( U
% @0 ^3 p! Q& D x" u. C! \4 d$ QCmdLine: netrev -$ -i . -y 1 F:/LIAN XI/cadence/JH-7206A/#Taaaaaa06548.tmp4 m. b4 Y7 F7 B/ h( M7 m0 b
! @ X" S w4 H6 v/ J. e1 c------ Preparing to read pst files ------
* B/ E8 C' b: q. I' w3 p$ D. s, E' v, }( P
# X _+ x) q7 \ b& L) k& i/ F3 A
#1 ERROR(24) File not found
3 R! ] O! |2 x, ] Packager files not found
5 N4 a( b: v6 H3 g9 {2 X- v! r% ~
" \; d1 T6 S, l2 J c; T% i1 Q" _#2 ERROR(102) Run stopped because errors were detected6 [0 p( x0 H) `; c, K! V
9 V- K2 Z" h% O2 G+ k
netrev run on Dec 14 16:26:17 2013
! [. Y( [" L* L8 }* q+ e5 k* @3 c, j. I3 G" k0 H: a$ T. ~
COMPILE 'logic'
3 L6 e' @- D8 c& V CHECK_PIN_NAMES OFF
) {" ] _, ~2 M5 D* z CROSS_REFERENCE OFF- D4 E" j6 Y& g% r3 g
FEEDBACK OFF
" m3 N: t( {) y INCREMENTAL OFF
' x/ Y) U8 a# ^+ I; r INTERFACE_TYPE PHYSICAL
3 z1 K( P8 \) T MAX_ERRORS 500
9 [3 }1 }3 O4 [6 Y% h' G1 A MERGE_MINIMUM 56 ~/ {" L! C+ V4 _: K
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'4 G* T0 q6 f7 D' c6 X3 g
NET_NAME_LENGTH 240 i2 a6 N( S1 [. j
OVERSIGHTS ON
: H M7 S& y* ~' D. D* K REPLACE_CHECK OFF6 O( T y2 ^. L, L3 b2 {, s
SINGLE_NODE_NETS ON
3 [( C5 `1 a3 T SPLIT_MINIMUM 0. w, j7 Z& G. E9 F
SUPPRESS 20+ O7 Q+ ^0 l. E% Y$ \( ^
WARNINGS ON
1 s6 l9 c8 d" h( { x5 O1 T6 V! I% j5 _/ k! `! v0 H
2 errors detected" I+ z5 j2 \/ T: j) }! X* o5 a8 |0 ]
No oversight detected
, p p6 m3 G! L1 w! t No warning detected
8 W: @! K7 _7 u5 t& r& K" S7 s: u+ ?4 M/ _# e( K* t4 }% h: Y7 z
cpu time 0:00:50; l$ Y, y1 P! ^4 d* ]8 U1 X2 v
elapsed time 0:00:00
9 V* K' R) E: g+ w
' i" G: ^4 k2 e. c6 g* P2 I5 Y1 ~0 X
; X, b* c/ E3 N4 b' Z) L" s
: T; [2 \) s: V |
