查看: 1230|回复: 2
帮忙把这个程序做成一个可执行的skill吧
发表于 2011-11-2 10:53 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
defun( _Create_Thermal ( od, id, spoke, n, ang)
prog(( PI, r, x, y, arc, slice, a, b, c, p)
  PI = 3.141593
  axlDBControl('activeLayer "etch/top")
  r = ( od + id)/4, x = ( od - id)/4 + spoke/2, y = sqrt( r*r - x*x )
  spoke = asin( x/r)*2, slice = 2*PI/n, arc = slice - spoke
  a = -x:y, b = _CTRotatePt( a, arc)
  if( ang != 0 then ang = ang*PI/180.0, a = _CTRotatePt( a, ang), b = _CTRotatePt( b, ang))
  for( i 1 n
       c = caar( axlDBCreatePath( axlPathArcCenter( axlPathStart( list( a)), ( od - id)/2, b, nil, 0:0)))
       p = axlPolyFromDB( c ?endCapType 'ROUND)
       axlDeleteObject( c)
       axlDBCreateShape( car( p) t)
       a = _CTRotatePt( a, slice), b = _CTRotatePt( b, slice)
    );end-for
);end-prog
);end-defun
QUOTE:
defun( _CTRotatePt ( pt, ang)
prog(( x, y, nx, ny)
  x = car( pt)
  y = cadr( pt)
  nx = x*cos( ang) - y*sin( ang)
  ny = x*sin( ang) + y*cos( ang)
  return( nx:ny)
);end-prog
);end-defun
 楼主| 发表于 2011-11-15 23:31 | 只看该作者
upupupupupup
 楼主| 发表于 2011-11-2 10:56 | 只看该作者
http://www.pcbbbs.com/viewthread.php?tid=105660&extra=&highlight=skill&page=2
原帖地址
GMT+8, 2025-11-22 08:56 , Processed in 0.156250 second(s), 25 queries , Gzip On.
