piedgogo 发表于 2011-11-1 10:09 ![]()
8 P& g! Z5 _! [+ o: m/ _对啊,只是warning,应该出片了才对。。。你看看assemble的配置有没有问题,有生成过钻孔? ! o7 _# |& ?& p
我没出那个assembly层的,因为有错误就没出,不好意思那个错误表发错了,下面这个是,麻烦您给看看,着急啊!( Y) s# N, V$ X8 {( V# D
)( P- ]5 j* k$ M' T
( ARTWORK LOG )
! b- s2 ~; ~/ { L( )$ t8 M; `. [4 z7 [! S7 x
( Drawing : tju_10_32_2011.mcm )
2 h; [% K# [8 Q [+ R* l3 A5 T3 ~( Software Version : 15.51p003 )" _0 @4 Z$ l7 z8 X
( Date/Time : Tue Nov 01 11:14:07 2011 )
8 [' T9 C \& W6 v0 a( )
4 |: q% `" k) u* a! h(------------------------------------------------------------)
* _1 j! h& o, P& r( c6 g* v8 Z0 m& L1 U% t$ T+ f4 @
. t' ^5 b( B4 ]7 X$ I6 x" }
---- Photoplot outline rectangle not found ... using drawing extents
, s$ c; V& e$ _9 ]6 O
x+ q6 m1 V: }. l& L
' X& o2 }6 g1 p, t( S$ wTue Nov 01 11:14:07 2011 Page 1
% i: z8 K/ o$ u0 Q3 U' v4 R. ^: H7 \4 }" ?
Photoplot log file% v" j) V! ~( \+ X, J% k+ H: P
Results from parameter file ...+ `* K5 F$ k# n
9 V6 g0 w) U1 y. b$ [" A4 A7 ]: |
DEVICE-TYPE GERBER_RS274X
" B# Z; n/ l0 F+ E( C& x" n7 SOUTPUT-UNITS MM$ A+ o- o8 s$ J: F- {( T+ V( \
FILM-SIZE 2400000 1600000& G6 j+ R. H" n1 q# l
FORMAT 5.5
( S* X/ C5 O% Y5 mABORT-ON-ERROR NO
* K1 o$ T, A% D( }7 y4 O* ?SCALE 1
s7 E+ }. @5 t. p. y7 z# LSUPPRESS-LEAD-ZEROES YES
: w% V' h) f5 w, i3 M9 l+ DSUPPRESS-TRAIL-ZEROES NO+ y! d( F' A( ]% D/ j/ s
SUPPRESS-EQUAL YES
$ T% M( k4 `, {UNDEF-APT-CONT NO
% B# h7 x' [' N) y- f8 _. x3 z
g2 N! g* ^3 a6 P8 X2 p9 Y. C, F1 ]0 ?! G& u
================================================================; M1 W- F: h% U2 T o! }; v
PROCESSING FILM < Assembly.art > ...
% N. h, t7 j8 C% B5 N* W================================================================/ o6 B H |, ?
* `2 e. `% B8 I- w& f FILM PARAMETERS :/ t8 S6 @1 ^ c d$ L
---------------------------------------------------------5 S2 G, P9 ]- [) N% o
Undefined line width 10.00
+ I" k( l. ]$ z8 Y/ z Mirror code NONE# V6 ?6 h2 s2 F$ R4 \/ X) h
Rotate angle NONE
# c' `; j4 G% k5 B Offset x: 0.00
8 ?7 Y8 [, \+ m `- C% u. _/ u Offset y: 0.00" {8 D6 a4 O& }7 _: p! Z+ ^2 F7 k
Plot negative NO. @2 P8 R* H" @) s( z# O& O
Suppress unconnected internal pads NO) R: t$ b I; M- Y, _. x
( s$ D* E, o9 Y) V3 w6 `$ R# T
WARNING: Film contains DRC error(s).* E4 L& O3 G, i1 n4 X
WARNING: more than one pin class in film record3 f9 d- x0 g; q- v* K
WARNING: more than one via class in film record7 v# Z! j! G, b. f7 W8 c, d8 U( s9 w$ l# g
WARNING: more than one etch class in film record) M* D3 W3 S% O8 T8 i4 i
WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (-58435.32 -81145.29).
, v/ Y# V! B( z6 ~6 z: Y9 N9 v WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (-58435.32 -78031.29).4 g1 e" Y; B4 n( t
WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (-58435.32 -80107.29).8 U; a( e* |: M+ e0 \" B) b' K
WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (-58435.32 -79069.29).
4 K& ~7 \8 _ j WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (-58462.38 -76935.51).
+ C$ X* {- e1 O; W5 f WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (46233.94 -21963.58).0 I& O+ [+ H8 ^5 y2 S
WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (46233.94 -20925.58).3 |: }4 h6 w! M: n& x. D b7 n" A7 i
WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (47271.94 -23001.58).
0 `, ]9 C2 h) p- R7 i M) A WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (47271.94 -21963.58).: K/ N/ v4 Q- c' l4 S" f$ G
WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (47271.94 -20925.58).: E% f/ h7 O" |
WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (47255.57 -18779.28).
Z: }: |$ b3 D" z, P WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (46220.41 -18778.28).
; u$ v/ v2 g2 C* g: o: L0 s WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (46233.94 -19887.58).1 s( z$ D! p9 m; d5 B2 q$ ?( E
WARNING: Null REGULAR-PAD specified for padstack 13V1016_508_S0M4 at (47269.10 -19888.58).2 F0 }0 E" \. p* b+ E2 Y
WARNING: 0 width line found at (-18000.00 -33000.00)( \7 D \% ]% Z' u0 q" }# J- c
WARNING: ... using undefined line width of 10.00
& D$ d: I, {) w1 [" Q3 v; u
/ x3 ~+ V7 }: v( K! k WARNING: Multiple 0 width lines; all will be treated the same as the first.
3 ?+ U4 F! C3 }% n! B WARNING: ... using undefined line width of 10.00
9 j) z/ q* A: W5 @
( |. n8 h! o! D. ?4 a+ o* p WARNING: Shape at (-15900.00 -15900.00) contains void at (-1000.00 901.00)
$ c6 I$ y7 f1 M. A/ R! s# v1 h2 Y which touches another shape6 Q) F+ M5 g9 G3 f3 T9 j3 _
) U% Y0 B+ G5 F% g5 J' ]- c ERROR: aborting film - artwork will not be generated!0 L! B. S1 L. U- X- m. v
Error in Assembly--halting output. Artwork file not generated.) E' ~ p) h% B6 P4 H. N, `2 v
*** ERROR with Assembly
" [$ H- A- d6 g麻烦看看这是哪的问题,我只要把那层的GND删除,就能出ASSEMBLY层,谢谢您的及时回复!感激不尽。 |
