查看: 154|回复: 2
6G无线网络研究白皮书:愿景/使能技术与新应用范式
发表于 2022-6-21 10:19 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
前言................................................................................................................................................... I" a3 Y8 \" x" r  {, s3 ?
目录.................................................................................................................................................III5 v/ G# ~8 ~. Y) v0 M
图目录..............................................................................................................................................V
) f4 O, F- r" B& ]表目录.............................................................................................................................................VI
" j% X& X  I/ T1 s( V; @一、6G 无线通信网络的发展背景.................................................................................................1
, E- c9 d( I' r/ P( ?0 J8 o二、6G 性能指标、应用场景和垂直行业应用示例.....................................................................5) y+ y* u3 j# t; ~
2.1 6G 性能指标和应用场景...................................................................................................5
; |7 Z5 P( I6 R0 e+ N. f6 o' V# P2.2 垂直行业应用示例............................................................................................................80 o0 ~& N$ W7 L+ L' i  ]% E
2.2.1 云虚拟现实.............................................................................................................8
5 {0 D9 }* u& z: s) `. J; d6 B2.2.2 物联网工业自动化...............................................................................................10, Y7 f" v" d9 @5 O- q) O2 j( v
2.2.3 蜂窝车联网...........................................................................................................11
7 o! X* c4 D7 c9 U, e2.2.4 数字孪生体域网...................................................................................................13: b0 Y3 c! l) O6 i0 g
2.2.5 高能效无线网络控制与联邦学习系统...............................................................153 ^6 [1 m# G6 {: d$ x; u+ k
三、6G 使能技术...........................................................................................................................17
( [) `' B0 T- b! @7 n# O3.1 6G 空口与传输技术.........................................................................................................17
% r4 y- u' y1 E! L/ q1 _3.1.1 新的波形设计.......................................................................................................17
8 W+ O; i6 ^% u  R3.1.2 多址接入...............................................................................................................199 g3 A3 m. F* d/ R
3.1.3 信道编码...............................................................................................................20( C9 c3 J/ m" N" l0 t
3.1.4 无蜂窝大规模 MIMO ..........................................................................................24
- {+ P6 {' S# E& H3 b3.1.5 动态智能频谱共享与接入...................................................................................25
/ K, ^  h9 P- D3.1.6 基于区块链的无线接入网络...............................................................................26
# n( g  p0 n1 u# ?: T3.1.7 光子定义无线电...................................................................................................27+ d; \- _5 V8 }2 N# _* ?
3.1.8 关键任务 uRLLC..................................................................................................29
6 c  B% A7 M9 U/ y6 n: j2 o% Q+ K8 D3.2 6G 网络架构.....................................................................................................................30; z8 P, H; ?) w1 X) Y( |
3.2.1 软件定义网络/网络功能虚拟化..........................................................................300 A. [2 N) s: G3 o" T7 Y2 o- c
3.2.2 网络切片及其演进...............................................................................................340 O) Y& c3 \% X. x8 Z' _- a
3.2.3 基于服务的网络架构及其演进...........................................................................35
( L, ?0 I2 Z7 Q2 o, T3.2.4 认知服务架构.......................................................................................................363 d7 Y9 u) k: ?9 d
3.2.5 深度边缘节点和网络(DEN2) .........................................................................37/ c9 j5 a9 }6 k; g
3.2.6 无蜂窝架构...........................................................................................................38% u' f0 z% H6 F: y
3.2.7 云/雾/边缘计算.....................................................................................................41
5 M! C8 ]! h  G; {四、6G 新的范式转变...................................................................................................................45& H" b2 i" s; w1 }
4.1 全覆盖:空天地海一体化网络......................................................................................45
5 S" l! y5 y( t- X4.1.1 卫星通信网络.......................................................................................................45/ ]4 l9 [5 j# ^  `: T) I2 d- g
4.1.2 无人机通信网络...................................................................................................465 I7 [3 V) J! F
4.1.3 海洋机器类通信网络...........................................................................................484 C3 x% I8 v: m* N8 I
4.1.4 空天地海一体化网络...........................................................................................50* @8 L4 b1 E( y# Q2 }# {
4.2 全频谱:Sub-6 GHz、毫米波、太赫兹、光频段........................................................53. ]& A, m# P' X: `) @
4.2.1 Sub-6 GHz 频段.....................................................................................................53
9 w# i" K- C" ~4 S& T& ]! v4.2.2 毫米波频段...........................................................................................................54
% P9 ]: I3 ?$ p. J) b" U: R( \4.2.3 太赫兹频段...........................................................................................................55+ P& Y# z" x2 I3 D
4.2.4 光频段...................................................................................................................58
4 @- M' p! f( s3 Q8 g5 s1 i4.2.5 5G 及 5G 之后的信道测量与模型.......................................................................60
) b1 J9 ?( H' z: _9 J. T4 p4.3 全应用:AI 使能的无线通信网络.................................................................................65$ F) c  s. D$ u- {5 h: I" }  t4 C+ I7 V& A
4.3.1 AI 及机器学习技术概述.......................................................................................65
* V2 r. k0 i0 T' e; \4.3.2 物理层应用...........................................................................................................66
: K2 o7 c7 `, i9 y6 g# A: a4.3.3 上层应用...............................................................................................................68
% P/ U  Y. i; [( ~9 o6 x1 }4.3.4 资源分配应用.......................................................................................................696 l, {# t. @; m0 m: X+ S% ~
4.3.5 智能内生网络(IEN)........................................................................................716 U- E% q& k! c' f" P, _
4.3.6 面向 6G 的信息、通信与数据技术融合............................................................72, l3 a( {- O. h" f9 |/ K4 {
4.4 内生安全..........................................................................................................................74
2 U7 t2 {: e5 L, O% s4.4.1 现状和主要问题...................................................................................................74
3 n  F6 T+ u3 F. \* _4.4.2 6G 中的网络安全隐患问题..................................................................................77  l: J% j( A/ g& {# p! Y
4.4.3 6G 网络安全和隐私问题的可能对策..................................................................78# B3 p9 o5 T7 F" A- l% K3 n& L
五、总结与展望.............................................................................................................................81- f- F7 ]+ f  N2 k1 w
六、附录.........................................................................................................................................83
3 ?9 P- @; \- Z6.1 缩略语..............................................................................................................................83! Y% i9 w0 Y% {8 x  ?) U+ }4 h& U
参考文献.........................................................................................................................................925 H2 P$ A& H- n& b% o+ E$ M
) x+ f1 F5 ?4 [$ V5 k: R' O1 P6 g
一、6G 无线通信网络的发展背景, c! U: e: k  s: e8 `& e8 a
自 2020 年起,第五代(5G)无线通信标准化工作进入尾声并开始在全球部署。5G 的三大应用场景包括增强型移动宽带(eMBB)、大规模机器类通信(mMTc)与高可靠低时延通信(uRLLC)。5G 的关键性能指标(KPI)包括 20 Gbps 的峰值速率、0.1 Gbps 的用户体验速率、1 ms 端到端时延、500 km/h 的移动速度支持、每平方千米 100 万设备的连接数密度、10 Mbps/m2 的流量密度、3 倍于第四代(4G)无线通信系统的频效,以及 100 倍于 4G 的能效。业界已提出了多种关键技术来达到 5G 的性能指标,例如毫米波(mmWave)、大规模多输入多输出(MIMO)、超密集网络(UDN)等。
' D9 _8 G; C  {( }7 V0 q2 p# c但是,5G 将不能满足 2030 年之后的未来网络需求。研究人员开始着眼于第六代(6G)无线通信网络的研发。5G 的一个显著特点是低时延,更准确地说是保障/确定性时延,这需要通过确定性网络(DetNet)来保障未来用例需求的准时、准确的端到端时延。6G 对时间和相位同步的精确度提出了更多更高的需求,这是 5G 所不能满足的。除此之外,6G 还将提供接近 100%的全球覆盖、亚厘米级的定位精度和毫秒级的定位更新速率以满足未来应用需求。由于 5G 网络仅局限于一些典型场景,某些偏远地区还不能很好地覆盖,限制了无人驾驶等应用。非陆地网络,特别是卫星通信网络,由于其成本低、无缝接入、泛在服务能力的优势,可以作为陆地网络的有效补充。无人机通信网络由于其快速响应的特点,在严酷艰难的环境中尤为重要。海洋通信网络可以为船只提供高质量的通信服务。5G 毫米波可以提供 Gbps 级的数据传输速率,但对于高质量三维(3D)视频、虚拟现实(VR)、虚拟现实与增强现实(AR)混合等应用,需要 Tbps 级的数据传输速率,太赫兹(THz)和光频段将是可用的候选频段。由于面临大量天线单元、大带宽、新的服务需求产生的海量数据,6G 网络需要借助人工智能(AI)与机器学习(ML)算法,实现一系列智能应用。网络自动化将在多个方面进一步提升网络的性能,例如服务质量(QoS)、用户体验质量(QoE)、安全性、故障管理、能效等方面。
7 a8 C) J7 ]3 Q7 k# c! A+ |( ^/ l3 Y直到 5G 时代,网络流量仍然以视频或流媒体应用为主。除了上面提及的应用和需求,以 5G 触觉互联网应用[2]为代表的类机器人对象的无线网络控制(例如自动驾驶或工厂物流)将成为无线技术新的重要应用领域,但同时面临诸多挑战。当分析由这些应用产生的网络流量时,许多移动终端必须共享传感与控制信息,这给中央式控制系统带来了巨大负担。目前,基于 AI 的分布式控制系统正受到越来越多关注,其中联邦学习被认为是一种可行的方法,数据集相关算法分布于移动终端上,聚合学习在云端完成。这一应用产生了一类全新的网络流量,具有大带宽和极其多样的时延需求。这类应用以及相关的 AI 应用将很有可能主导 6G 的网络流量需求。这是一片未知的探索领域,机遇与挑战并存!与 5G 网络相比,6G 无线通信网络有望提供更高的频谱/能量/成本效率、更高的传输速率(Tbps 级)、10 倍以上的更低时延、100 倍以上的连接数密度、全自动的更高智能化水平、亚厘米级的定位精度、接近 100%的覆盖率,以及亚毫秒级的时间同步。新的空口与传输技术对于获得高频效和高能效十分必要,这包括新的波形设计、多址接入方式、信道编码方案、多天线技术,以及这些技术的有机结合。同时,需要设计新的网络架构,例如软件定义网络(SDN)/网络功能虚拟化(NFV)、动态网络切片、基于服务的网络架构(SBA)、认知服务架构(CSA)以及无蜂窝架构等。( a/ g6 U6 q* c% u, R; i8 o9 _
另一方面,软件化伴随着相应的代价,正如我们从 5G 部署所得知的一样。商用现成品(COTS)服务器的使用与虚拟化无线接入网(RAN)中的特定领域芯片带来了能量消耗的大幅增加,由此需要更为高能效的新对策。虽然 5G 网络消耗的能量多于 4G 网络,但是提供了更大的带宽,从而使得 5G 传输单位数据使用的能耗小于 4G。因此,新一代无线网络的能耗不应超过上一代的能量需求。为此,6G 需要新的计算范式来获得软件化的所有优点而不增加总体能量消耗。以云计算、雾计算、边缘计算为代表的计算技术对于保障网络韧性、分布式计算与处理能力、低时延与时间同步十分重要。为了解决 5G 包括短包缺陷在内的限制,提供高可靠性、低时延、高传输速率服务、系统覆盖率、万物互联(IoE),满足 2030 年及之后的移动通信需求,6G 网络必须将以人为中心作为发展愿景,而非以机器、应用或数据为中心。为了满足这些需求,6G 无线通信网络将会产生新的范式转换。我们对于 6G 网络的发展愿景如图 1 所示。首先,6G 无线通信网络将会是空天地海一体化网络,用于提供深度全球覆盖。卫星通信、无人机通信、海洋通信将极大扩展无线通信网络的覆盖范围。为了提供更高的数据传输速率,包括 sub-6 GHz 频段、毫米波、太赫兹、光频段在内的全频谱资源将会被充分挖掘。为了实现全应用愿景,AI 与机器学习技术将与 6G 无线通信网络高效融合以实现更好地网络管理与自动化。此外 AI 技术可以实现网络、缓存、计算资源的动态调配以提高下一代网络的性能。还有一个重要趋势是强安全或内生安全,包括物理层与网络层安全,这在构建网络之初就要考虑。垂直行业应用,诸如云虚拟现实、物联网工业自动化、蜂窝车联网(C-V2X)、数字孪生体域网,以及高能效无线网络控制与联邦学习系统将极大促进 6G 无线通信网络的发展。6G 无线通信网络概述如图 2 所示,图中给出了 6G 的各种性能指标、应用场景、使能技术、新的范式转换,以及垂直行业应用。6 a* e( Q- `) S% c  A
2 q4 R  n: u* R0 L; R3 `# s( E
( ^3 \' w$ ]0 f9 ?* i. ]
6G研究白皮书.pdf
6.46 MB, 下载次数: 0, 下载积分: 威望 -5
发表于 2022-6-21 14:35 | 只看该作者
学一学。\(^o^)/~
发表于 2022-6-21 11:10 | 只看该作者
看一看,学一学。\(^o^)/~
GMT+8, 2025-11-22 07:22 , Processed in 0.156250 second(s), 28 queries , Gzip On.
