作品名:[allegro16.6][2层]Hi3518EV300DMEB(MLF88-035-0909L)PCB&原理图源文件 $ o. s: Y% M0 V& Z9 ~2 V6 R
文件描述 1. 作品用途:Hi3518EV300DMEB 2. 软件版本:Allegro 16.6 3. 层数:2层 4. 用到的主要芯片:MLF88-035-0909L+MLF56-050-1105 5. PCB尺寸:6105MIL*4530MIL
9 v/ L' B% O1 I) h作品截图如下:
+ }* }1 Q. X& A5 {0 a3 Z7 ?顶层截图:
. E2 g2 u7 [: K2 M
底层截图: 5 l8 J$ R. s5 @2 n( n- j
全部截图:
9 }* [8 Z q. Q' h' \
PCB&SCH 2 `$ E+ z$ F7 {' t7 b/ Q U
5 @% D! ?6 c& K
BOM
2 j2 B$ E6 s5 t& i# y9 X$ x
| SYM_NAME | COMP_DEVICE_TYPE | REFDES | | BATT3-3R70-SM | BATT3-3R70-SM | J12 | | DB9-2RM | DB9-2RM | J10 | | DF17_7MH-60DP_P05 | DF17_7MH-60DP_P05 | J1;J19 | | HEAD0101-T-B | HEAD0101-T-B | J5;J6 | | HSC0402 | HSC0402 | C23;C25;C26;C555 | | HSC0402-HDTA | HSC0402-HDTA | C145;C153 | | HSC0402-HDTA | HSC0402-HDTA | R174 | | HSC0402-TA | HSC0402-TA | C10;C14 | | HSD0603-LED | HSD0603-LED | D24 | | HSDC10-1614B | HSDC10-1614B | J2 | | HSL1008 | HSL1008 | L1;L2;L4;L6 | | HSL1008 | HSL1008 | L5 | | HSL1008C | HSL1008C | L11 | | HSOD882 | HSOD882 | D3;D6 | | HSOD882 | HSOD882 | D4;D8;D9;D18;D21 | | HSR0402-TA | HSR0402-TA | R221 | | HSX2-0302 | HSX2-0302 | X3 | | HSX4-0302 | HSX4-0302 | X1 | | ID-BOARD | ID-BOARD | ID1;ID2;ID3;ID4;ID5;ID6 | | IDC20-DTM1-A | IDC20-DTM1-A | J8 | | LGA12-0202C | LGA12-0202C | U2 | | MLF16B-050-0303L | MLF16B-050-0303L | U17 | | MLF56-050-1105 | MLF56-050-1105 | U41 | | MLF88-035-0909L | MLF88-035-0909L | U4 | | MTH_C6MMD3P2MM | MTH_C6MMD3P2MM | M1;M2;M3;M4;M13;M14;M15;M16;M17;M18;M19;M20;M21;M22 | | PSW3-RA | PSW3-RA | S8 | | PWC0103-M-N | PWC0103-M-N | J9 | | SC0402 | SC0402 | C11;C13;C15;C20;C29;C30;C32;C40;C41;C42;C43;C44;C47;C49;C51;C54;C55;C58;C59;C60;C61;( U3 H0 `) M1 h: N3 R
C62;C63;C64;C65;C66;C68;C73;C76;C77;C78;C79;C83;C92;C97;C103;C202;C203;C229;C230;C332;
7 r$ n% T4 D3 W7 x6 B4 G" z+ A) {C543;C544;C545;C546;C547;C548;C549;C561;C564;C565;C566;C567;C568 | | SC0402 | SC0402 | C12;C24;C48;C50;C56;C57;C108;C109;C111;C112;C156;C550 | | SC0402 | SC0402 | C21 | | SC0402 | SC0402 | C31;C38;C556;C557;C558 | | SC0402 | SC0402 | C115;C116;C123 | | SC0402 | SC0402 | C117 | | SC0402 | SC0402 | C126 | | SC0402 | SC0402 | C129;C569 | | SC0402 | SC0402 | C139 | | SC0402 | SC0402 | C143;C146;C147;C148 | | SC0402 | SC0402 | C173;C174 | | SC0402 | SC0402 | C463;C464 | | SC0402 | SC0402 | C465;C466 | | SC0402 | SC0402 | C542 | | SC0402-PC | SC0402-PC | C33;C37;C551 | | SC0402-PD | SC0402-PD | C7;C80;C93 | | SC0402-PD | SC0402-PD | C16;C19;C134 | | SC0402-PD | SC0402-PD | C81;C82;C87;C88;C96;C100 | | SC0603 | SC0603 | C6 | | SC0603 | SC0603 | C17;C18 | | SC0603 | SC0603 | C27;C52 | | SC0603 | SC0603 | C45;C46;C128;C131;C137;C149;C152;C408;C415;C552 | | SC0603 | SC0603 | C84;C85;C86;C89;C90;C101;C102;C104;C110;C142;C163 | | SC0603 | SC0603 | C127 | | SC0603 | SC0603 | C141 | | SC0603 | SC0603 | C150 | | SC0805 | SC0805 | C4;C223 | | SC1206 | SC1206 | C5;C122;C133 | | SC1206 | SC1206 | C22 | | SC1206 | SC1206 | C118;C121;C135;C334 | | SC1206 | SC1206 | C120;C136;C460 | | SC1210B | SC1210B | C99;C181;C182;C183 | | SCAPC2-280-327 | SCAPC2-280-327 | C314 | | SD1710A | SD1710A | D22 | | SED60-16F-A | SED60-16F-A | J3 | | SF6127 | SF6127 | F1 | | SGM8903 | SGM8903 | U8 | | SHEAD-3P | SHEAD-3P | J56 | | SHEAD-4P-49 | SHEAD-4P-49 | J11;J23;J54;J55 | | SHEAD-8P-49 | SHEAD-8P-49 | J25;J26 | | SIP-2P | SIP-2P | J13;J14 | | SL0402 | SL0402 | LB1;LB4;LB7;LB8;LB9;LB13 | | SL0805 | SL0805 | LB14 | | SL1008H | SL1008H | L9 | | SOP8-20-91 | SOP8-20-91 | U42 | | SOP10-20-124A | SOP10-20-124A | U6;U14;U15;U34;U40 | | SOP16-26-208-255 | SOP16-26-208-255 | U13 | | SOP16-50-300A | SOP16-50-300A | U1 | | SOT23 | SOT23 | D1;D2;D23 | | SOT23 | SOT23 | Q2 | | SOT23-5 | SOT23-5 | U22 | | SOT23-6 | SOT23-6 | U3 | | SOT23-6 | SOT23-6 | U7;U9;U10;U16 | | SPL0404L | SPL0404L | L3 | | SR0402 | SR0402 | R2;R4;R21;R22;R23;R24;R25;R35;R41;R44;R46;R47;R48;R50;R52;R134;R135;R150;R161;R166;- ]0 k* j) E$ |0 g* p- Q6 }8 _1 w
R167;R168;R171;R176;R178;R283;R284;R285;R444;R445;R446;R461;R462;R463;R514;R568;R569;
% ~' y7 _! p/ rR571;R595;R597;R598;R599 | | SR0402 | SR0402 | R5;R9;R14;R15;R16;R43 | | SR0402 | SR0402 | R17 | | SR0402 | SR0402 | R19 | | SR0402 | SR0402 | R30;R31;R191;R192;R193;R194;R230;R231;R240;R241 | | SR0402 | SR0402 | R32;R618 | | SR0402 | SR0402 | R33;R34;R54;R71;R72;R82;R116;R118;R120;R123;R164;R181;R182;R183;R199;R200;R201;R202;' A5 r1 I3 s( r8 L4 B5 E
R203;R204;R207;R257;R550;R575;R576;R586;R610;R615;R616;RT1 | | SR0402 | SR0402 | R42;R45;R49;R51;R53;R175;R177;R565;R566;R567;R570;R573;R596;R604;R605;R606;R607;
5 {* I6 p$ U; U' l8 Z# X) g" RR608;R609 | | SR0402 | SR0402 | R55;R247 | | SR0402 | SR0402 | R64;R124 | | SR0402 | SR0402 | R65;R66;R67;R68;R70;R91;R223;R229;R232;R233;R254;R366;R451;R611;R612;R621;R622 | | SR0402 | SR0402 | R69;R189 | | SR0402 | SR0402 | R73;R234 | | SR0402 | SR0402 | R75;R162;R163;R165;R198;R228;R235;R236;R237;R256;R578;R579;R580;R588;R589;R613 | | SR0402 | SR0402 | R76 | | SR0402 | SR0402 | R80;R103 | | SR0402 | SR0402 | R90;R196;R197;R577 | | SR0402 | SR0402 | R92;R170;R212;R243;R413 | | SR0402 | SR0402 | R121;R592;R593;R594;R624 | | SR0402 | SR0402 | R127 | | SR0402 | SR0402 | R128;R129;R130;R131;R133 | | SR0402 | SR0402 | R156 | | SR0402 | SR0402 | R179 | | SR0402 | SR0402 | R185 | | SR0402 | SR0402 | R186 | | SR0402 | SR0402 | R187 | | SR0402 | SR0402 | R188 | | SR0402 | SR0402 | R219 | | SR0402 | SR0402 | R220 | | SR0402 | SR0402 | R226 | | SR0402 | SR0402 | R227 | | SR0402 | SR0402 | R242 | | SR0402 | SR0402 | R471 | | SR0402 | SR0402 | R600 | | SR0402 | SR0402 | R601;R603 | | SR0402 | SR0402 | R602 | | SR0402 | SR0402 | R614 | | SR0603 | SR0603 | R26;R27;R238;R239;R317;R406;R564;R583 | | SR0603 | SR0603 | R58;R59 | | SR0603 | SR0603 | R77 | | SR0603 | SR0603 | R132;R584 | | SR0603 | SR0603 | R208;R209;R210;R211;R213;R214;R215;R216 | | SR0603 | SR0603 | R217 | | SR0603 | SR0603 | R245 | | SR0603 | SR0603 | R258 | | SR0603 | SR0603 | R617 | | SR0603 | SR0603 | R623 | | SR1206 | SR1206 | R94 | | SR2512C | SR2512C | R20;R40;R57;R79;R502 | | SSW-PUSH | SSW-PUSH | S1;S4;S7;S9;S10;S11;S12 | | STC3528 | STC3528 | C125;C319 | | STC3528 | STC3528 | C318 | | STC7343 | STC7343 | C151 | | TDFN_8_0_5 | TDFN_8_0_5 | U11 | | USB4-200-1907 | USB4-200-1907 | J53 | | VAF6-1406E | VAF6-1406E | J15;J16 | | WSON8-MX25L12835ZN | WSON8-MX25L12835ZN | U33 |
0 ?+ k; C/ I& x& N- y |
