查看: 4946|回复: 37
【Skill分享/提取】导入BMP图片LOGO的Skill 【源码】
    慵懒
    2020-12-22 15:45
  • 签到天数: 9 天
    [LV.3]偶尔看看II
    发表于 2022-1-19 17:56 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
    提取自GTallegroOpen开源项目https://github.com/whh5118/GTOpen
    • BMP文件需要是单色位图,用Windows画图软件另存成单位色图即可
    • gtopen_Logo.form文件存放至目录 cadence\SPB_16.6\share\local\pcb\forms中
    • 命令:gtopen_Logo
    下载:
    gtopen_Logo.zip (3.01 KB, 下载次数: 73)
    慵懒
    2020-12-22 15:45
  • 签到天数: 9 天
    [LV.3]偶尔看看II
    来自 37#
     楼主| 发表于 2022-1-27 11:43 | 只看该作者
    gtopen_Logo.il:
    1. ;--------导入LOGO--------
    2. ;
    3. ;---------------
    4. axlCmdRegister("gtopen_Logo" 'gtopen_Logo ?cmdType "interactive")
    5. procedure( gtopen_Logo()
    6. let((form)
    7.
    8.         axlShell("noappmode")
    9.         form = gtopen_Logo_Createform()
    10.         gtopen_Logo_Int_Var(form)
    11.         gtopen_Logo_Update_form(form)
    12. )
    13. )
    14. procedure( gtopen_Logo_Createform()
    15. let((file form)
    16.         file = "gtopen_Logo.form"
    17.         when('gtopen_Logoform && boundp('gtopen_Logoform)
    18.                 when(axlIsFormType(eval('gtopen_Logoform))
    19.                         axlFormClose(eval('gtopen_Logoform))
    20.                 )
    21.         )
    22.
    23.         form = axlFormCreate('gtopen_Logoform file nil 'gtopen_Logo_CB t)
    24.
    25.         form
    26. )
    27. )
    28. procedure( gtopen_Logo_Int_Var(form)
    29. let((_getFontList)
    30.         form->pop = ncons(nil)
    31.         form->pop->layerclass = list("BOARD GEOMETRY" "PACKAGE GEOMETRY" "MANUFACTURING" "ETCH" "DRAWING FORMAT")
    32.
    33.         form->var = ncons(nil)
    34.         form->var->layerclass = "PACKAGE GEOMETRY"
    35.         form->var->layersubclass = "SILKSCREEN_TOP"
    36.         form->var->pic_size = 1
    37.         form->var->neg = nil
    38. )
    39. )
    40. procedure( gtopen_Logo_CB(form)
    41. prog((tt bmp_show Blockw Blockh width height pixel_size box pick)
    42.         case(form->curField
    43.                 ("layerclass"
    44.                         form->var->layerclass = form->curValue
    45.                         form->var->layersubclass = car(axlSubclasses(form->var->layerclass))
    46.                 )
    47.                 ("layersubclass" | "neg" | "pic_size"
    48.                         evalstring(sprintf(nil "form->var->%s = form->curValue" form->curField))
    49.                 )
    50.                 ("vis"
    51.                         if(form->curValue then
    52.                                 axlVisibleLayer(strcat(form->var->layerclass "/" form->var->layersubclass) t)
    53.                         else
    54.                                 axlVisibleLayer(strcat(form->var->layerclass "/" form->var->layersubclass) nil)
    55.                         )
    56.                         axlVisibleUpdate(t)
    57.                 )
    58.                 ("load"
    59.                         tt = axlDMFileBrowse("\321\241\324\361\315\274\306\254" nil ?optFilters "BMP Files(*.bmp)|*.bmp")
    60.                         when(tt
    61.                                 if(isFile(tt) && member(upperCase(lastelem(axlDMFileParts(tt))) list("BMP")) then
    62.                                         form->var->bmpinput = tt
    63.                                 else
    64.                                         printf(">>\262\273\326\247\263\326\315\274\306\254\270\361\312\275\n")
    65.                                 )
    66.                         )
    67.                 )
    68.                 ("place"
    69.                         when(form->bmpdate
    70.                                 tt = axlGetParam(sprintf(nil "paramTextBlock:%d" form->var->pic_size))
    71.                                 Blockw = tt->width
    72.                                 Blockh = tt->height
    73.                                 width = (form->bmpdate[21] << 24) + (form->bmpdate[20] << 16) + (form->bmpdate[19] << 8) + form->bmpdate[18]
    74.                                 height = (form->bmpdate[25] << 24) + (form->bmpdate[24] << 16) + (form->bmpdate[23] << 8) + form->bmpdate[22]
    75.                                 pixel_size = max(Blockw/width Blockh/height)
    76.                                 box = list(list(0 0) list(width*pixel_size height*pixel_size))
    77.                                 axlClearDynamics()
    78.                                 axlAddSimpleMoveDynamics(0:0 axlPathStart(box) "box" ?ref_point 0:0)
    79.                                 pick = axlEnterPoint()
    80.                                 axlClearDynamics()
    81.                                 when(pick
    82.                                         axlDBCloak(gtopen_Logo_addshape(form pick) 'shape)
    83.                                 )
    84.                         )
    85.                 )
    86.                 ("textset"
    87.                         axlShell("define text")
    88.                 )
    89.                 (t
    90.                         return(t)
    91.                 )
    92.         )
    93.         gtopen_Logo_Update_form(form)
    94. )
    95. )
    96. procedure( gtopen_Logo_Update_form(form)
    97. let((tt port bmpdate)
    98.         form->pop->layersubclass = nil
    99.         foreach(n0 axlSubclasses(form->var->layerclass)
    100.                 when(axlIsLayer(buildString(list(form->var->layerclass n0) "/"))
    101.                         form->pop->layersubclass = cons(list(n0 n0 axlLayerGet(buildString(list(form->var->layerclass n0) "/"))->color) form->pop->layersubclass)
    102.                 )
    103.         )
    104.         tt = axlLayerGet(strcat(form->var->layerclass "/" form->var->layersubclass))
    105.         if(tt->visible then
    106.                 form->var->vis = tt->color
    107.                 axlFormSetField(form "vis" t)
    108.         else
    109.                 form->var->vis = 0
    110.                 axlFormSetField(form "vis" nil)
    111.         )
    112.
    113.         foreach(n0 form->pop->?
    114.                 tt = member(n0 form->pop)
    115.                 axlFormBuildPopup(form symbolToString(car(tt)) cadr(tt))
    116.         )
    117.         foreach(n0 form->var->?
    118.                 tt = member(n0 form->var)
    119.                 axlFormSetField(form symbolToString(car(tt)) cadr(tt))
    120.         )
    121.         when(form->curField == "load" && form->var->bmpinput
    122.                 form->bmpsize = fileLength(form->var->bmpinput)
    123.                 axlFormSetField(form "bmp_show" form->var->bmpinput)
    124.                 port = infile(form->var->bmpinput)
    125.                 declare(bmpdate[form->bmpsize])
    126.                 for(i 0 form->bmpsize-1
    127.                         bmpdate[i] = charToInt(getc(port))
    128.                 )
    129.                 close(port)
    130.                 form->bmpdate = bmpdate
    131.         )
    132.         if(form->var->bmpinput then
    133.                 axlFormSetFieldEditable(form "place" t)
    134.         else
    135.                 axlFormSetFieldEditable(form "place" nil)
    136.         )
    137.         axlFormAutoResize(form)
    138.         axlFormDisplay(form)
    139. )
    140. )
    141. procedure( gtopen_Logo_addshape(form pickxy)
    142. prog((tt Blockw Blockh number num row max_column column max_w bit x y offset width height Grid imagesize path polys symbolid)
    143.         tt = axlGetParam(sprintf(nil "paramTextBlock:%d" form->var->pic_size))
    144.         Blockw = tt->width
    145.         Blockh = tt->height
    146.
    147.         offset = (form->bmpdate[13] << 24) + (form->bmpdate[12] << 16) + (form->bmpdate[11] << 8) + form->bmpdate[10]
    148.         width = (form->bmpdate[21] << 24) + (form->bmpdate[20] << 16) + (form->bmpdate[19] << 8) + form->bmpdate[18]
    149.         height = (form->bmpdate[25] << 24) + (form->bmpdate[24] << 16) + (form->bmpdate[23] << 8) + form->bmpdate[22]
    150.         imagesize = form->bmpsize - offset
    151.
    152.         max_column = (imagesize / height) << 3
    153.         max_w = (imagesize / width) << 3
    154.         number = offset + imagesize - 1
    155.         Grid = 1/min(width/Blockw height/Blockh)
    156.         column = 0
    157.         polys = '()
    158.         if(!axlSelectByName("SYMTYPE" "GTLogo") then
    159.     axlDBCreateSymDefSkeleton(list("GTLogo" "mechanical") list(list(0 0) list(width height)))
    160.         else
    161.           axlClearSelSet()
    162.         )
    163.         symbolid = car(axlDBCreateSymbolSkeleton(list("GTLogo" "mechanical") pickxy nil 0.0 nil))
    164.         axlMeterCreate("\275\370\263\314\326\320" "" t)
    165.         for(i offset number
    166.                 tt = fix((50*i) / (imagesize-1))
    167.                 when(tt == 12 || tt == 25 || tt == 37 || tt == 50
    168.                         axlMeterUpdate(tt sprintf(nil "\315\352\263\311\266\310 :%d / %d" (i-offset) (imagesize-1)))
    169.                 )
    170.
    171.                 y = Grid * fix((i - offset) / (max_column >> 3)) + cadr(pickxy)
    172.                 for(j 0 7
    173.             bit = bitfield1(form->bmpdate[i] (7 - j))
    174.             when(form->var->neg
    175.                     bit = abs(bit-1)
    176.             )
    177.             x = Grid * column + car(pickxy)
    178.                         when(zerop(bit) && (column < width)
    179.                                 path = axlPathStart(list(x:y))
    180.                                 axlPathLine(path 0.0 x:(y+1.1*Grid))
    181.                                 axlPathLine(path 0.0 (x+1.1*Grid):(y+1.1*Grid))
    182.                                 axlPathLine(path 0.0 (x+1.1*Grid):y)
    183.                                 axlPathLine(path 0.0 x:y)
    184.                                 polys = append(axlPolyFromDB(path) polys)
    185.                         )
    186.             column++
    187.                 )
    188.                 when(column == max_column
    189.             column = 0
    190.                 )
    191.         )
    192.         polys = axlPolyOperation(car(polys) cdr(polys) 'OR)
    193.         num = 1
    194.         foreach(n0 polys
    195.                 tt = fix((50*num) / length(polys)) + 50
    196.                 when(tt == 62 || tt == 75 || tt == 87 || tt == 100
    197.                         axlMeterUpdate(tt sprintf(nil "\315\352\263\311\266\310 :%d / %d" num length(polys)))
    198.                 )
    199.                 tt = axlDBCreateShape(n0 t strcat(form->var->layerclass "/" form->var->layersubclass) nil symbolid)
    200.                 axlCustomColorObject(car(tt) 0)
    201.                 num++
    202.         )
    203.         axlMeterDestroy()
    204.         axlVisibleUpdate(t)
    205.
    206. )
    207. )
    208. /*
    209. axlCmdRegister("gtopen_Logo" 'gtopen_Cline2Shape ?cmdType "interactive")
    210. procedure( gtopen_Cline2Shape()
    211. let((form)
    212.
    213. ;        axlShell("noappmode")
    214.         form = gtopen_Cline2Shape_Createform()
    215.         gtopen_Cline2Shape_Int_Var(form)
    216.         gtopen_Cline2Shape_Update_form(form)
    217. )
    218. )
    219. procedure( gtopen_Cline2Shape_Createform()
    220. let((file form)
    221.         file = "gtopen_Cline2Shape.form"
    222.         when('gtopen_Logoform && boundp('gtopen_Cline2Shapeform)
    223.                 when(axlIsFormType(eval('gtopen_Cline2Shapeform))
    224.                         axlFormClose(eval('gtopen_Cline2Shapeform))
    225.                 )
    226.         )
    227.
    228.         form = axlFormCreate('gtopen_Cline2Shapeform file nil 'gtopen_Cline2Shape_CB t)
    229.
    230. )
    231. )
    232. procedure( gtopen_Cline2Shape_CB(form)
    233. let(()
    234.         println(form->curField)
    235.         case(form->curField
    236.                 (
    237.
    238.                 )
    239.         )
    240. )
    241. )
    242. */
    复制代码
    gtopen_Logo.form:
    1. FILE_TYPE=FORM_DEFN VERSION=2
    2. FORM AUTOGREYTEXT
    3. FIXED
    4. PORT 69 10
    5. HEADER "BMP Logo导入"
    6. POPUP <fontlist_pop>""""
    7. POPUP <layerclass_pop>""""
    8. POPUP <layersubclass_pop>""""
    9. POPUP <brushmode>""""
    10. TILE
    11. GROUP "预览"
    12. GLOC 1 1
    13. GSIZE 40 22
    14. ENDGROUP
    15. FIELD bmp_show
    16. THUMBNAIL
    17. FLOC 3 5
    18. FSIZE 37 16
    19. ENDFIELD
    20. GROUP "参数"
    21. GLOC 43 1
    22. GSIZE 26 22
    23. ENDGROUP
    24. FIELD layerclass
    25. FLOC 47 4
    26. ENUMSET 18 1
    27. POP layerclass_pop
    28. OPTIONS prettyprint
    29. ENDFIELD
    30. FIELD vis
    31. FLOC 44 7
    32. COLOR 2 1
    33. ENDFIELD
    34. FIELD layersubclass
    35. FLOC 47 7
    36. ENUMSET 18 1
    37. OPTIONS ownerdrawn prettyprint
    38. POP layersubclass_pop
    39. ENDFIELD
    40. TEXT "大小"
    41. TLOC 44 10
    42. ENDTEXT
    43. FIELD pic_size
    44. FLOC 50 10
    45. INTSLIDEBAR 4 2
    46. MIN 1
    47. MAX 50
    48. ENDFIELD
    49. FIELD textset
    50. FLOC 60 10
    51. MENUBUTTON "设置" 3 3
    52. ENDFIELD
    53. TEXT "类型"
    54. TLOC 44 13
    55. ENDTEXT
    56. FIELD neg
    57. FLOC 50 13
    58. CHECKLIST "负片"
    59. ENDFIELD
    60. TEXT
    61. FLOC 1 25
    62. INFO bmpinput 100
    63. FSIZE 45 2
    64. ENDTEXT
    65. FIELD load
    66. FLOC 45 24
    67. MENUBUTTON "1.导入" 9 4
    68. ENDFIELD
    69. FIELD place
    70. FLOC 58 24
    71. MENUBUTTON "2.摆放" 9 4
    72. ENDFIELD
    73. ENDTILE
    74. ENDFORM
    复制代码
    慵懒
    2020-12-22 15:45
  • 签到天数: 9 天
    [LV.3]偶尔看看II
     楼主| 发表于 2022-3-9 11:01 | 只看该作者
    小池养大鱼 发表于 2022-3-8 16:59
    我下载的全是乱码,图片导入之后也不显示
    16.6版本测试没问题,你的是17.x版本吗,我知道的是17.x以后的不支持中文显示会乱码另外可以不用下载附件了,下载扣贡献,我有把代码贴上来,复制就行了
    慵懒
    2020-12-22 15:45
  • 签到天数: 9 天
    [LV.3]偶尔看看II
     楼主| 发表于 2022-7-6 10:47 | 只看该作者
    myhome43 发表于 2022-7-5 17:44
    想問一下 .form這檔案需要放在哪~ 謝謝分享
    帖子里有写
    • 命令:gtopen_Logo
    阿...謝謝板主提醒,眼盲了  详情 回复 发表于 2022-7-7 00:28
    32#
    发表于 2025-3-24 21:41 | 只看该作者
    正真的好心人,爱了
    奋斗
    2025-2-28 15:32
  • 签到天数: 6 天
    [LV.2]偶尔看看I
    31#
    发表于 2025-3-22 14:06 | 只看该作者
    大佬,我的弹出first arg must be either symbol, list, defstruct or user type - nil这是哪里出问题了吗?谢谢
    30#
    发表于 2025-3-22 14:05 | 只看该作者
    感谢分享了,支持学习了.
    慵懒
    2025-2-10 15:39
  • 签到天数: 16 天
    [LV.4]偶尔看看III
    26#
    发表于 2025-1-15 11:46 | 只看该作者
    感謝分享~好用
    25#
    发表于 2024-10-9 10:54 | 只看该作者
    好用,在16.6上可以用就够了。
    24#
    发表于 2024-10-9 10:18 | 只看该作者
    再次下载试一下。感觉威望都快用光了
    2025-11-21 15:06
  • 签到天数: 94 天
    [LV.6]常住居民II
    23#
    发表于 2024-7-29 15:53 | 只看该作者
    学习一下学习一下
    22#
    发表于 2024-7-29 14:21 | 只看该作者
    感谢分享 666666
    21#
    发表于 2023-7-15 23:39 | 只看该作者
    666666 感谢分享
    2024-11-22 15:19
  • 签到天数: 101 天
    [LV.6]常住居民II
    20#
    发表于 2022-8-5 14:35 | 只看该作者
    哇塞~~~ 這東西超方便 謝謝分享!!!!
    2022-8-15 15:41
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    19#
    发表于 2022-8-5 11:46 | 只看该作者
    顯示E- *Error* putprop: first arg must be either symbol, list, defstruct or user type - nil
    GMT+8, 2025-11-22 03:24 , Processed in 0.203125 second(s), 33 queries , Gzip On.
