查看: 400|回复: 1
請問要怎麼改成所有的白漆層 (有原碼)
    慵懒
    2019-11-18 15:01
    发表于 2022-1-3 11:09 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
    原本功能是via會有top的shpae覆蓋
    想要改成所有的via挖掉白漆shape
    請問高手該怎麼改?
    謝謝!
    axlCmdRegister("gsd" 'gnd_shape)
    defun(gnd_shape ()
    let((via_p via_net shape_Radius via_drill via_Broad Geometry/Silkscreen_top poly_via)
            axlClearSelSet()
            axlSetFindFilter( ?enabled '( "NOALL" "vias") ?onButtons '("vias"))
            LCBpopup = axlUIPopupDefine( nil (list
        (list "Done" "axlFinishEnteRFun()")
        (list "Cancel" "axlCancelEnterFun()")
            axlUIPopupSet(LCBpopup)
        while(axlSelect(?prompt "Please select via")
        foreach(via axlGetSelSet()
                via_drill = via->definition->drillDiameter/2
                via_net = via->net->name
                via_p = via->xy
                foreach(pad via->pads
                when(pad->layer == "via_Broad Geometry/Silkscreen_top" && pad->type == "REGULAR"
                        via_Broad Geometry/Silkscreen_top_pad = caadr(pad->bBox)
                );end foreach
                shape_Radius = (via_Broad Geometry/Silkscreen_top_pad - via_drill)/2 + via_drill
                poly_via = axlPathStartCircle(list(via_p shape_Radius) 0)
            axlDBCreateShape(poly_via,t,strcat("via_Broad Geometry/Silkscreen_top"),via_net)
        );foreach
        );while
    );end let
    );defun
    发表于 2022-1-4 09:29 | 只看该作者
    看看其他人怎么说
    GMT+8, 2025-11-23 11:37 , Processed in 0.140625 second(s), 24 queries , Gzip On.
