用的是28335, 想通过外部总线功能实现一个并行液晶的功能,液晶驱动器是ST7567。XINTF配置没啥问题,但是液晶还是实现不了,所以想请教一下是不是时序无法匹配呢,还是其他原因( G9 _" t! i- h& I! o6 X
这是液晶的时序图
% @9 P& V! {) O+ X4 @2 |
- t1 H: Y* A: c0 v& N: U
3 ^! \" f3 p; {0 |XINTF的配置; K" l- N& k3 N5 m4 U7 O. r$ r
4 S: s( {2 M% d! S! |+ x: M r
6 v! C. U2 T E( @) n* `2 \* i2 [. D
void InitZone0(void)0 A0 I# b4 m) v$ o j6 B
{+ y' I. g7 j/ c3 l6 b& {
SysCtrlRegs.PCLKCR3.bit.XINTFENCLK = 1; //使能XINTF模块时钟& }9 \: a3 |/ H3 f |0 K
; V( d& J* I7 j1 ]0 B: z- ? InitXintf16Gpio(); //XD0-16 XA0-19 XREDAY XRNW XWE0 XZCS
/ g/ X; S' |. y0 y! m+ w3 `( X% i I/ ~4 E( W6 R( W
EALLOW;) b4 C* J8 g' Z& c' ?3 g( w- P' |; p
XintfRegs.XINTCNF2.bit.XtiMCLK = 1; //配置XTIMCLK = SYSCLKOUT/2 6.67*2 = 13.34ns6 m8 p9 \1 W" s! D& E
XintfRegs.XINTCNF2.bit.WRBUFF = 0; //不使用写缓冲+ U" L! ^% w% w* R. F3 J
XintfRegs.XINTCNF2.bit.CLKOFF = 1; //关闭XCLKOUT+ s* o# j2 `$ s1 c5 |" H
//时序) f% w/ \, l3 s1 m3 Y+ c2 a
XintfRegs.XTIMING0.bit.X2TIMING = 1; //比例因子为2
/ g# X+ R3 ]: |. m
( V4 x- G- i; X, N XintfRegs.XTIMING0.bit.XRDLEAD = 1; //前导 3x2x13.34 = 80 ns
( U6 v, z8 _& c+ x6 D* Q3 K3 ^ XintfRegs.XTIMING0.bit.XRDACTIVE = 7; //有效 (7x2 + 1) x 13.34 = 200 ns
3 r4 q5 S1 B9 Q* O XintfRegs.XTIMING0.bit.XRDTRAIL = 3; //结束 3x2x13.34 = 80 ns
( `( y; y. l9 ?% t" ]' I$ a6 p* t% F3 j) v& z% h2 z
XintfRegs.XTIMING0.bit.XWRLEAD = 1; //前导 3x2x13.34 = 80 ns9 D" @& a* n, M+ Z
XintfRegs.XTIMING0.bit.XWRACTIVE = 7; //有效 (7x2 + 1) x 13.34 = 200 ns
4 {% W+ K, d l# A N- l XintfRegs.XTIMING0.bit.XWRTRAIL = 3; //结束 3x2x13.34 = 80 ns
& G/ E V. R% _. i7 k$ v9 r9 {1 j2 N. L. G& ^' @
XintfRegs.XTIMING0.bit.USEREADY = 0; //不使能XREADY信号
) {7 F7 t9 M, X/ A( q t XintfRegs.XTIMING0.bit.XSIZE = 3; //16位数据线8 p% C: H! m$ U5 ?
EDIS;% Q! a1 I! B/ v0 A4 U
& [& Q1 Q; s% H; ^& a7 h
asm(" RPT #7 || NOP");
: |& l% U: b" ]7 G}
0 N# l' O6 I3 a4 P2 f9 c$ A: Q4 ^% X7 P; G) o: h2 I5 ^
- r" {. N0 S; T: U
3 d" h" B* Y5 V0 ?+ e/ ^4 a
' M! {+ i4 J( s7 T5 f
