TA的每日心情 | 怒 2019-11-20 15:22 |
签到天数: 2 天 [LV.1]初来乍到
本帖最后由 mutougeda 于 2021-8-5 10:14 编辑 - O z, R$ Z: W4 L, S% J- S
# A/ J. Q* n; D- X0 d \这篇 blog 介绍 I2C 的学习了,首先要在我们的 or1200_soc 上添加进来 I2C Controller ,到 opencores 社区上面找到 i2c_latest.tar.gz 这个工程包。
6 a# q7 T& Q1 o9 \, q$ Z 解压得到如下文件目录:
. S* k8 S: r$ n/ a1 M( f1 S4 p/ d8 a6 P8 e$ T
+ N. e( M. F. E8 }& ^9 w Z; p) V5 b- K* ~. B+ Q+ G
! ~. w" x; z, k
注意啦,这里的i2c_top.v的顶层文件需要自己编写,因为需要在工程的更顶层将i2c_master_top.v里的输入输出信号组织成三态信号。
n3 M1 m6 k" u9 u5 m
; ]% _; m, q# r
+ y9 @4 v6 f- ?2 n. x- module i2c_top(
- //wishbone inteRFaces
- wb_clk_i, wb_rst_i, arst_i,
- wb_adr_i, wb_dat_i, wb_dat_o,
- wb_we_i, wb_stb_i, wb_cyc_i, wb_ack_o, wb_inta_o,
- i2c_scl, i2c_sda
- // wishbone signals
- input wb_clk_i; // master clock input
- input wb_rst_i; // synchronous active high reset
- input arst_i; // asynchronous reset
- input [2:0] wb_adr_i; // lower address bits
- input [7:0] wb_dat_i; // databus input
- output [7:0] wb_dat_o; // databus output
- input wb_we_i; // write enable input
- input wb_stb_i; // stobe/core select signal
- input wb_cyc_i; // valid bus cycle input
- output wb_ack_o; // bus cycle acknowledge output
- output wb_inta_o; // interrupt request signal output
- // i2c signals
- inout i2c_scl; //i2c clock signal
- inout i2c_sda; //i2c data signal
- i2c_master_top i2c_master_top(
- //wishbone interfaces
- .wb_clk_i(wb_clk_i),
- .wb_rst_i(wb_rst_i),
- .arst_i(arst_i),
- .wb_adr_i(wb_adr_i),
- .wb_dat_i(wb_dat_i),
- .wb_dat_o(wb_dat_o),
- .wb_we_i(wb_we_i),
- .wb_stb_i(wb_stb_i),
- .wb_cyc_i(wb_cyc_i),
- .wb_ack_o(wb_ack_o),
- .wb_inta_o(wb_inta_o),
- .scl_pad_i(scl_pad_i),
- .scl_pad_o(scl_pad_o),
- .scl_padoen_o(scl_padoen_o),
- .sda_pad_i(sda_pad_i),
- .sda_pad_o(sda_pad_o),
- .sda_padoen_o(sda_padoen_o)
- assign i2c_scl = scl_padoen_o ? 1'bz : scl_pad_o;
- assign i2c_sda = sda_padoen_o ? 1'bz : sda_pad_o;
- assign scl_pad_i = i2c_scl;
- assign sda_pad_i = i2c_sda;
- endmodule
6 Y1 W+ `+ l4 K7 ^/ C) ]
* {8 ]% K8 q' b8 Q; e/ Z) g2 o- M* }0 b4 s
详细可以看看在改工程目录下的/doc说明文档,当中有改ipcore的使用说明。
1 k6 q$ H1 a- {$ k# f
8 y% z7 i, y6 Z- k: m' s5 f0 r 接着在or1200_soc中例化改ipcore,然后添加到wishbone总线上,再定义好使用的中断号。
. C# ] K! P+ ^7 y* e8 W7 ?$ u" H: n. X4 b' i% w$ u. R" P. o
例化代码:
8 \; W2 E, y1 a2 g) V
5 N# b0 e$ T, B5 H5 T2 `- `ifdef I2C
- wire [2:0] wb_i2c_adr_i;
- wire [7:0] wb_i2c_dat_i;
- wire [7:0] wb_i2c_dat_o;
- wire [31:0] wb_i2c_dat32_i;
- wire [31:0] wb_i2c_dat32_o;
- wire [3:0] wb_i2c_sel_i;
- wire wb_i2c_stb_i;
- wire wb_i2c_we_i;
- wire wb_i2c_ack_o;
- wire wb_i2c_cyc_i;
- wire wb_i2c_inta_o;
- .wb_clk_i(clk_cpu_40),
- .wb_rst_i(wb_rst_pad_i),
- .arst_i(1'b1),
- .wb_adr_i(wb_i2c_adr_i),
- .wb_dat_i(wb_i2c_dat_i),
- .wb_dat_o(wb_i2c_dat_o),
- .wb_we_i(wb_i2c_we_i),
- .wb_stb_i(wb_i2c_stb_i),
- .wb_cyc_i(wb_i2c_cyc_i),
- .wb_ack_o(wb_i2c_ack_o),
- .wb_inta_o(pic_ints[`APP_INT_I2C]),
- //i2c interface
- assign wb_i2c_dat32_o[7:0] = (wb_i2c_sel_i[0] == 1'b1) ? wb_i2c_dat_o : 8'h0;
- assign wb_i2c_dat32_o[15:8] = (wb_i2c_sel_i[1] == 1'b1) ? wb_i2c_dat_o : 8'h0;
- assign wb_i2c_dat32_o[23:16] = (wb_i2c_sel_i[2] == 1'b1) ? wb_i2c_dat_o : 8'h0;
- assign wb_i2c_dat32_o[31:24] = (wb_i2c_sel_i[3] == 1'b1) ? wb_i2c_dat_o : 8'h0;
- assign wb_i2c_dat_i = wb_i2c_dat32_i[7:0];
- `else
- assign pic_ints[`APP_INT_I2C] = 'b0;
- `endif/*endif I2C*/
- /* the comment section below just instance for wb_conbus module */
- `ifdef I2C
- .s5_dat_i (wb_i2c_dat32_o),
- .s5_dat_o (wb_i2c_dat32_i),
- .s5_adr_o (wb_i2c_adr_i),
- .s5_sel_o (wb_i2c_sel_i),
- .s5_we_o (wb_i2c_we_i),
- .s5_cyc_o (wb_i2c_cyc_i),
- .s5_stb_o (wb_i2c_stb_i),
- .s5_ack_i (wb_i2c_ack_o),
- .s5_err_i (1'b0),
- .s5_rty_i (1'b0),
- // .s5_cab_i (),
- for switch cross bus :
- // .slave5_sel_addr ( `I2C_BASE_ADDR ),
- .wbs5_adr_i( wb_i2c_adr_i ),
- .wbs5_bte_i( ),
- .wbs5_cti_i( ),
- .wbs5_cyc_i( wb_i2c_cyc_i ),
- .wbs5_dat_i( wb_i2c_dat32_i ),
- .wbs5_sel_i( wb_i2c_sel_i ),
- .wbs5_stb_i( wb_i2c_stb_i ),
- .wbs5_we_i( wb_i2c_we_i ),
- .wbs5_ack_o( wb_i2c_ack_o ),
- .wbs5_err_o( 'b0 ),
- .wbs5_rty_o( 'b0 ),
- .wbs5_dat_o( wb_i2c_dat32_o ),
- */$ j2 d; a! V1 \
9 W' P9 P$ R& A* V
! T$ }% e# y$ S 中断号和地址:" k+ p; p$ q& b1 W; z. j2 T1 O
/ z: s+ J( z" A/ H% `1 A9 S+ C- /* Interrupts */
- `define APP_INT_RES1 1:0
- `define APP_INT_UART 2
- `define APP_INT_KEY 3
- `define APP_INT_ETH 4
- `define APP_INT_I2C 5
- `define APP_INT_VGA_LCD 6
- `define APP_INT_RES 19:7
- /* Peripheral Addr ,modify by manual */
- `define FLASH_BASE_ADDR 4'hf //slave X address ,connect to FLASH
- `define SDRAM_BASE_ADDR 4'h0 //slave X address ,connect to DDR_SDRAM
- `define UART_BASE_ADDR 8'h90 //slave X address ,connect to UART
- `define GPIO_BASE_ADDR 8'h91 //slave X address
- `define ETH_BASE_ADDR 8'h92 //slave X address ,connect to ETH
- `define VGA_BASE_ADDR 8'h95 //slave X address, connect to VGA/LCD
- `define DMA_BASE_ADDR 8'hxx //slave X address,
- `define SRAM_BASE_ADDR 8'hxx //slave X address ,connect to SRAM
- `define SD_CARD_BASE_ADDR 8'h94 //slave X address ,connect to sd_card
- `define I2C_BASE_ADDR 8'h93 //slave X address ,connect to i2c device
/ {& x; R5 Z0 [$ {' k , o* C4 [& R$ p1 C6 L4 ?7 c
; X5 {. t; g5 D6 z
. F' M8 X# W* U7 L! [% _/ {
添加到wishbone总线:
+ v) Y- l; G1 W1 l' @
% J/ ~4 W, z( s! a8 t2 K8 f, I+ |9 G4 g7 h+ c8 `
- wb_switch_b3 #(
- .slave0_sel_addr ( `FLASH_BASE_ADDR ),
- .slave1_sel_addr ( `SDRAM_BASE_ADDR ),
- .slave2_sel_addr ( `UART_BASE_ADDR ),
- .slave3_sel_addr ( `ETH_BASE_ADDR ),
- .slave4_sel_addr ( `GPIO_BASE_ADDR ),
- .slave5_sel_addr ( `I2C_BASE_ADDR ),
- .slave6_sel_addr ( 'hfffffffe ),
- .slave7_sel_addr ( 'hfffffffe )
- wb_switch_b3(
- // Clocks, resets
- .wb_clk(clk_cpu_40),
- .wb_rst(wb_rst_pad_i),
- // Slave 5 Interface ,connect to simple_i2c
- .wbs5_bte_i( ),
- .wbs5_cti_i( ),
1 s6 t; i) l/ T: y" e 5 U( h( h4 e( b) H
4 G3 M- P" p7 b+ O$ ]- a
4 }4 j- j N6 F2 T8 F7 j OK,synthesize之,注意稍微看看时序够不够即可。6 E& @4 P$ y& l- n; Z
$ ?. y; h7 k+ n( i4 n6 p0 t& ~& E" e5 K. j
