cadence Design Systems, Inc. netrev 15.7 Mon Apr 18 16:19:13 2011" a+ p$ h" X. b! [0 n' G; P* T- H8 W
(C) Copyright 2002 Cadence Design Systems, Inc. T, R2 Q/ ^$ A4 M7 D. _2 q4 W0 c
------ Directives ------
0 i5 S# e, I+ a# W; o* rRIPUP_ETCH FALSE;3 M3 b: w) @+ x9 [, n
RIPUP_SYMBOLS ALWAYS;
& `0 a+ ?3 _5 K' R! z$ sMISSING SYMBOL AS ERROR FALSE;
5 j- z2 H) T- p5 V1 _; DSCHEMATIC_DIRECTORY 'F:/allegro157/SFP_RJ45/allegro';2 G- y2 _; Q9 n, r
BOARD_DIRECTORY '';
# o; s; ?6 N( \& n3 E+ ^OLD_BOARD_NAME 'F:/allegro157/SFP_RJ45/SFP_RJ45.brd';
5 i- {% P9 F2 Y; ?; {) p+ ZNEW_BOARD_NAME 'F:/allegro157/SFP_RJ45/SFP_RJ45.brd';
0 e# w2 }, m1 c1 @/ CCmdLine: netrev -$ -5 -i F:/ALLEGRO157/SFP_RJ45/allegro -y 1 F:/allegro157/SFP_RJ45/#Taaaaaa03144.tmp
1 r1 y# }" s. F------ Preparing to read pst files ------1 p! r# ?9 H, ^" a' B8 n4 i( Y
Starting to read F:/ALLEGRO157/SFP_RJ45/allegro/pstchip.dat
, p1 ~* B Z5 I Finished reading F:/ALLEGRO157/SFP_RJ45/allegro/pstchip.dat (00:00:00.00)
K J- j7 g; w1 p* k! H# b jStarting to read F:/ALLEGRO157/SFP_RJ45/allegro/pstxprt.dat 3 p% J- [! X: H; M8 z6 U5 i) o) a3 I- s
Finished reading F:/ALLEGRO157/SFP_RJ45/allegro/pstxprt.dat (00:00:00.00)
! E) Z. z) Q. n9 }- K2 i+ q0 zStarting to read F:/ALLEGRO157/SFP_RJ45/allegro/pstxnet.dat / ?* ^; ~) {( c
Finished reading F:/ALLEGRO157/SFP_RJ45/allegro/pstxnet.dat (00:00:00.00)
, x0 d& H6 Q6 ] v+ Y9 ^, `------ Oversights/Warnings/Errors ------# P" N) ~4 x0 V
: m o9 w& e+ w! b' B. p5 G3 O
Illegal character(s) present in name or value., Z5 w) W4 P8 i9 [7 ]0 w6 n( C# k2 |
------ Summary Statistics ------
2 ^. [2 S) x, K0 p. C
- E9 z @# X1 j* ]#1 ERROR(102) Run stopped because errors were detected
. O8 P4 i2 S/ v+ Z- x- Q# K1 h, ]0 M. @netrev run on Apr 18 16:19:13 2011
! U( M/ L6 ?. _9 X7 V DESIGN NAME : '光口转铜口'* |# m6 Z4 \' ^/ R
PACKAGING ON May 28 2006 22:05:31
2 |( J& g/ b7 b COMPILE 'logic'- q/ s7 H" G6 [4 I p" d- u3 l
CHECK_PIN_NAMES OFF
7 {1 k$ S3 C6 o0 R6 E% K* R CROSS_REFERENCE OFF: u4 q6 A, d; ~& f8 j) k. B- \
FEEDBACK OFF$ w- H9 I- E6 |3 n1 M }
INCREMENTAL OFF
x. y( ]" T( K; P INTERFACE_TYPE PHYSICAL% i( c* ^' {8 m5 B# V
MAX_ERRORS 5005 u C0 k8 x+ f2 |2 b
MERGE_MINIMUM 51 F# M# E% h/ E- Z9 i' A7 ?& m: {
