查看: 313|回复: 2
基于matlab FCM和改进的FCM脑部CT图像聚类
    2019-11-20 15:22
    发表于 2021-4-22 13:24 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
    8 R2 f8 K$ i8 H/ U一、源代码. y2 M; G! ^' ^3 C0 t; }# I
    • function varargout = CT_image_FCM(varargin)
    • % CT_IMAGE_FCM MATLAB code for CT_image_FCM.fig
    • %      CT_IMAGE_FCM, by itself, creates a new CT_IMAGE_FCM or raises the existing
    • %      singleton*.
    • %      H = CT_IMAGE_FCM returns the handle to a new CT_IMAGE_FCM or the handle to
    • %      the existing singleton*.
    • %      CT_IMAGE_FCM('CALLBACK',hObject,eventData,handles,...) calls the local
    • %      function named CALLBACK in CT_IMAGE_FCM.M with the given input arguments.
    • %      CT_IMAGE_FCM('Property','Value',...) creates a new CT_IMAGE_FCM or raises the
    • %      existing singleton*.  Starting from the left, property value pairs are
    • %      applied to the GUI before CT_image_FCM_OpeningFcn gets called.  An
    • %      unrecognized property name or invalid value makes property application
    • %      stop.  All inputs are passed to CT_image_FCM_OpeningFcn via varargin.
    • %      *See GUI Options on GUIDE's Tools menu.  Choose "GUI allows only one
    • %      instance to run (singleton)".
    • % See also: GUIDE, GUIDATA, GUIHANDLES
    • 3 D: x; f' b2 m- i& j
    • % Edit the above text to modify the response to help CT_image_FCM
    • # _. F$ u5 e* m" p0 W
    • % Last Modified by GUIDE v2.5 17-Apr-2020 00:06:23
    •   v9 N' E* c6 G5 S
    • % Begin initialization code - DO NOT EDIT
    • gui_Singleton = 1;
    • gui_State = struct('gui_Name',       mfilename, ...
    •                    'gui_Singleton',  gui_Singleton, ...
    •                    'gui_OpeningFcn', @CT_image_FCM_OpeningFcn, ...
    •                    'gui_OutputFcn',  @CT_image_FCM_OutputFcn, ...
    •                    'gui_LayoutFcn',  [] , ...
    •                    'gui_Callback',   []);
    • if nargin && ischar(varargin{1})
    •     gui_State.gui_Callback = str2func(varargin{1});
    • end
    • 9 w! o; l& k( z& _
    • if nargout
    •     [varargout{1:nargout}] = gui_maiNFCn(gui_State, varargin{:});
    • else
    •     gui_mainfcn(gui_State, varargin{:});
    • end
    • % End initialization code - DO NOT EDIT
    • 7 z) \" I# b* v& d+ M
    • - Q$ o8 e6 a' {% o- L1 Y
    • % --- Executes just before CT_image_FCM is made visible.
    • function CT_image_FCM_OpeningFcn(hObject, eventdata, handles, varargin)
    • % This function has no output args, see OutputFcn.
    • % hObject    handle to figure
    • % eventdata  reserved - to be defined in a future version of MATLAB
    • % handles    structure with handles and user data (see GUIDATA)
    • % varargin   command line arguments to CT_image_FCM (see VARARGIN)
    • 3 O( y& X) L1 B( W+ i* \
    • % Choose default command line output for CT_image_FCM
    • handles.output = hObject;
    • / c7 w2 i8 I" ~4 u) v7 n( e5 a
    • % Update handles structure
    • guidata(hObject, handles);
    • 4 H" L( b; Z8 U: A  H$ |! V" y  g
    • % UIWAIT makes CT_image_FCM wait for user response (see UIRESUME)
    • % uiwait(handles.figure1);
    • 3 h: n0 U" N9 n2 K4 a9 N
    • 5 ?; X3 @4 ?* K1 y, ~2 e
    • % --- Outputs from this function are returned to the command line.
    • function varargout = CT_image_FCM_OutputFcn(hObject, eventdata, handles)
    • % varargout  cell array for returning output args (see VARARGOUT);
    • 9 q( w! n' q# O
    • % Get default command line output from handles structure
    • varargout{1} = handles.output;
    • 4 E2 F0 d3 r' t" c( @
    • % f) G1 K8 w* |# B, t) e
    • % --- Executes on button press in pushbutton1.
    • function pushbutton1_Callback(hObject, eventdata, handles)
    • % hObject    handle to pushbutton1 (see GCBO)
    • global I
    • [filename, pathname]= ...
    •     uigetfile({'*.*';'*.bmp';'*.tif';'*.png';'*.jpg'},'select picture');
    • str= [pathname filename];
    • I= imread(str);
    • axes(handles.axes1);
    • imshow(I);
    • title('原图');
    •   j0 ~2 i. H/ ?, q) u
    • % --- Executes on button press in pushbutton2.
    • function pushbutton2_Callback(hObject, eventdata, handles)
    • % hObject    handle to pushbutton2 (see GCBO)
    •   ]% R% b0 I# f1 }( X8 e
    • 6 y% U$ T+ ]) I) C9 t
    • % --- Executes on button press in pushbutton3.
    • function pushbutton3_Callback(hObject, eventdata, handles)
    • % hObject    handle to pushbutton3 (see GCBO)
    • global I I0 A
    • [I2,clusterResult] = FCM1(I, 4,[0 80 160 255],2,150,1e-5);
    • axes(handles.axes3);
    • imshow(I2)
    • I0=I2;
    • A=unique(I0);
    • # x: y5 _9 x0 B; K: D
    • 3 ?* R+ J9 i3 w) k" v7 \
    • % --- Executes on button press in pushbutton4.
    • function pushbutton4_Callback(hObject, eventdata, handles)
    • % hObject    handle to pushbutton4 (see GCBO)
    • global I0 A
    • I0_2=zeros(size(I0,1),size(I0,2));
    • for i=1:size(I0,1)
    •      for j=1:size(I0,2)
    •          if I0(i,j)==A(2)
    •              I0_2(i,j)=255;
    •          else I0_2(i,j)=0;
    •          end
    •      end
    • end
    • I0_2=uint8(I0_2);
    • axes(handles.axes4);
    • imshow(I0_2);
    • # _/ F; `+ T/ B( L% \
    • 0 y8 s- V0 x. q9 c" B. d! h' H( A
    • % --- Executes on button press in pushbutton5.
    • function pushbutton5_Callback(hObject, eventdata, handles)
    • % hObject    handle to pushbutton5 (see GCBO)
    • global I0 A
    • I0_3=zeros(size(I0,1),size(I0,2));
    •          if I0(i,j)==A(3)
    •              I0_3(i,j)=255;
    •          else I0_3(i,j)=0;
    •          end
    •      end
    • end
    • I0_3=uint8(I0_3);
    • axes(handles.axes5);
    • imshow(I0_3);
    • . u) z4 B! I4 c8 n# D/ U) m& g
    • ' W5 D6 Z; }3 q6 L; {1 g
    • % --- Executes on button press in pushbutton6.
    • function pushbutton6_Callback(hObject, eventdata, handles)
    • % hObject    handle to pushbutton6 (see GCBO)
    • global I0 A
    • I0_4=zeros(size(I0,1),size(I0,2));
    •          if I0(i,j)==A(4)
    •              I0_4(i,j)=255;
    •          else I0_4(i,j)=0;
    •          end
    •      end
    • end
    • I0_4=uint8(I0_4);
    • axes(handles.axes6);
    • imshow(I0_4);
      ) w2 y* m3 V0 ^
                           7 F% M2 ]  r9 f! p8 ^7 I! I
    0 ~6 u) q! M, O1 v  r! ]0 x# Z# u8 h
    5 \3 i4 S  K. V( V) o  L. ]4 G4 F; e
    • function varargout = CT_image_GFCM(varargin)
    • % CT_IMAGE_GFCM MATLAB code for CT_image_GFCM.fig
    • %      CT_IMAGE_GFCM, by itself, creates a new CT_IMAGE_GFCM or raises the existing
    • %      singleton*.
    • %      H = CT_IMAGE_GFCM returns the handle to a new CT_IMAGE_GFCM or the handle to
    • %      CT_IMAGE_GFCM('CALLBACK',hObject,eventData,handles,...) calls the local
    • %      function named CALLBACK in CT_IMAGE_GFCM.M with the given input arguments.
    • %      CT_IMAGE_GFCM('Property','Value',...) creates a new CT_IMAGE_GFCM or raises the
    • %      applied to the GUI before CT_image_GFCM_OpeningFcn gets called.  An
    • %      stop.  All inputs are passed to CT_image_GFCM_OpeningFcn via varargin.
    • 7 u! |" T6 @8 h3 a1 _: }
    • % Edit the above text to modify the response to help CT_image_GFCM
    • - t/ A/ M4 n8 D8 b) e3 p% ?
    • % Last Modified by GUIDE v2.5 13-Apr-2020 21:47:11
    • - ~9 _& h/ _) ~# n$ B7 O
    •                    'gui_OpeningFcn', @CT_image_GFCM_OpeningFcn, ...
    •                    'gui_OutputFcn',  @CT_image_GFCM_OutputFcn, ...
    • end
    • % N9 K; ]" p! {' U
    • if nargout
    •     [varargout{1:nargout}] = gui_mainfcn(gui_State, varargin{:});
    • else
    • end
    • 3 _# _" }5 J- U; i9 o
    • " @+ F1 f$ u4 z1 g$ I
    • % --- Executes just before CT_image_GFCM is made visible.
    • function CT_image_GFCM_OpeningFcn(hObject, eventdata, handles, varargin)
    • % varargin   command line arguments to CT_image_GFCM (see VARARGIN)
    • % n' u$ g% C& E% N* L% X4 [
    • % Choose default command line output for CT_image_GFCM
    • ' ^3 L! B7 I: K' }7 s! ]  G
    • ( j; U1 j# [. F$ H5 x
    • % UIWAIT makes CT_image_GFCM wait for user response (see UIRESUME)
    • 2 d5 b- J+ j" b7 A
    • 4 x3 e. F2 a' L
    • function varargout = CT_image_GFCM_OutputFcn(hObject, eventdata, handles)
    • + S$ ]: N2 P; d" D# B
    • / H1 a! w. g8 L; D
    • + T% Z8 R8 q1 i% D! [7 |
    • global I
    • I= imread(str);
    • imshow(I);
    • title('原图');
    •   q1 F& `8 O9 s4 F" s
    • global I
    • I=medfilt2(I,[3,3]);
    • axes(handles.axes2);
    • imshow(I)
    •   I5 S- `/ x) X( u7 M2 ^
    • : `$ b6 i* n. v6 p
    • global I r c U
    • [r,c] = size(I);
    • data = zeros(r*c,1);
    • for i = 1:r
    •     for j = 1:c
    •         data((i-1)*c+j,1) = double(I(i,j));
    •     end
    • end
    • [center, U, obj_fcn] = GFCM(data,4,0.9);
    •   T% C6 o2 w) w9 M$ p: G
    • for i = 1 : r
    •     for j = 1 : c
    •         temp = (double(I(i, j)) - center) .^ 2;
    •         [fmin pos] = min(temp);
    •         I(i, j) = uint8(pos * 255 / 4);
    •     end
    • end
    • imshow(I)
    • " D! B+ V2 b  N
    • global I r c U
    • I_seg2 = I*0;
    • for i = 1:r
    •     for j = 1:c
    •         if U(1,(i-1)*c+j)<U(2,(i-1)*c+j)
    •             I_seg2(i,j) =0 ;
    •         else
    •             I_seg2(i,j) =255;
    •         end
    •     end
    • end
    • imshow(I_seg2)
    • & {/ L; b" s! ?/ X8 x5 L$ v
    • global I r c U
    • I_seg3 = I*0;
    • for i = 1:r
    •     for j = 1:c
    •         if U(1,(i-1)*c+j)<U(3,(i-1)*c+j)
    •             I_seg3(i,j) =0 ;
    •         else
    •             I_seg3(i,j) =255;
    •         end
    •     end
    • end
    • imshow(I_seg3)
    • ! \& \5 _2 e5 r* B: k
    • global I r c U
    • I_seg4 = I*0;
    • for i = 1:r
    •     for j = 1:c
    •         if U(1,(i-1)*c+j)<U(4,(i-1)*c+j)
    •             I_seg4(i,j) =0 ;
    •         else
    •             I_seg4(i,j) =255;
    •         end
    •     end
    • end
    • imshow(I_seg4)0 `- U1 D0 d2 c" J
    ! f1 e, O6 x, i9 d, ]
    9 _: |8 S- b4 k; p5 q7 x: O' W3 R4 K
    二、运行结果
    6 L# m. r" |4 Q5 e5 B* Y8 \% r. q% \+ I2 Y% E7 ^0 D5 P9 e4 F
    4 D; y6 [9 V6 V# w0 Q; l; h% |
    # z/ e8 P9 U) @) m" J, B
    " J; o; D+ U( q! y. }& W0 y
    发表于 2021-4-25 17:05 | 只看该作者
    收藏到源代码库# ?& O$ P: F+ z
    发表于 2021-4-22 14:50 | 只看该作者
    GMT+8, 2025-11-23 20:47 , Processed in 0.171875 second(s), 28 queries , Gzip On.
