查看: 470|回复: 6
已知含有9个微分的微分方程组,带参数,根据已知数据,拟合曲线,得参数最优解
    2019-11-19 15:29
    发表于 2020-12-8 11:21 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
    % syms s(t) e(t) i1(t) p(t) h(t) f(t) iph(t) %定义符号变量! q7 v  T# i# A: J1 m( `+ y6 y
    % syms Beta IoTa Beta_2 Kappa Rho_1 Rho_2 Gamma_a Gamma_i Gamma_r Delta_i Delta_p Delta_h 希腊字母参数; o% X; _  h9 x+ y
    N = 11000000/250;
    ) U; Y& q5 P8 n%dS/dt
    ! D, l; I' s# U6 _; ]; ldy(1)=-Beta*(y(3)/N)*y(1)-Iota*Beta*(y(6)/N)*y(1)-Beta_2*(y(4)/N)*y(1);
    7 ?$ T0 u! i1 i%dE/dt$ M9 @6 O" L& ?# B
    dy(2)=Beta*(y(3)/N)*y(1)+Iota*Beta*(y(6)/N)*y(1)+Beta_2*(y(4)/N)*y(1)-Kappa*y(2);
    & w" F6 J% S0 y( i7 i%dI/dt
    4 N& \9 J1 F, j3 Cdy(3)=Kappa*Rho_1*y(2)-(Gamma_a+Gamma_i)*y(3)-Delta_i*y(3);
    1 N% s3 ^! I: N6 C1 K* |%dP/dt; ^* @$ G+ G8 H) s( x+ J( \% ~
    dy(4)=Kappa*Rho_2*y(2)-(Gamma_a+Gamma_i)*y(4)-Delta_p*y(4);4 s) h0 Z! C% d- ]: h
    %dA/dt% C8 w; \  H; k5 w' \' h6 O
    dy(5)=Kappa*(1-Rho_1-Rho_2)*y(2);8 J* z4 O6 j/ c9 ^
    %dH/dt; T; g; E) N2 m" g! W
    dy(6)=Gamma_a*(y(3)+y(4))-Gamma_r*y(6)-Delta_h*y(6);
    $ G/ R6 E3 K( b# G1 H0 Z" O8 F%dR/dt' d' s# N5 g3 @. A( M
    dy(7)=Gamma_i*(y(3)+y(4))+Gamma_r*y(6);; F# ], E' v% J! L9 @: y
    %dF/dt
    % S& N. T" D% X! U7 P  Fdy(8)=Delta_i*y(3)+Delta_p*y(4)+Delta_h*y(6);%
    * P1 [! m4 S8 T. H8 C%d(I+P+H)/dt8 X3 ~& h! s, {. z4 i* H$ @
    dy(9)=dy(3)+dy(4)+dy(6);. y( H, k3 h* l+ {/ O
    %y(9)数据0 z4 F/ Q6 ^9 B1 q5 g% }6 j
    y9data1 = [6,  12,  19,  25,  31,  38,  44,  60,  80,  131,  131,  259,  467,  688,  776 ...,
    ' X( g1 [" O/ \: B* J! Q- H         1776,  1460,  1739,  1984,  2101,  2590,  2827,  3233,  3892,  3697,  3151 ...,
    6 C/ r- e7 W9 A0 t         3387,  2653,  2984,  2473,  2022,  1820,  1998,  1506,  1278,  2051,  1772 ...,8 f1 Y* C* K" Q" t$ ]
             1891,  399,  894,  397,  650,  415,  518,  412,  439,  441,  435,  579,  206 ...,
    8 N3 R' A! C( q9 z8 ]( h         130,  120,  143,  146,  102,  46,  45,  20,  31,  26,  11,  18,  27,  29,  39,  39];
    & [$ r8 v9 Z6 I%y(8)数据5 J0 y( ]: ?# a. c7 o$ k, b
    y8data1= [0,  0,  0,  0,  0,  0,  0,  0,  4,  4,  4,  8,  15,  15,  25,  26,  26 ...,
    5 I7 \/ l& I6 T' W    38,  43,  46,  45,  57,  64,  66,  73,  73,  86,  89,  97,  108,  97,  254 ...,. o5 w# {# [3 @7 _& Y
        121,  121,  142,  106,  106,  98,  115,  118,  109,  97,  150,  71,  52,  29 ...,2 `7 [: L: X$ r3 @  u/ A
        44,  37,  35,  42,  31,  38,  31,  30,  28,  27,  23,  17,  22,  11,  7,  14 ...,
    * `$ G; u  o5 X    10,  14,  13,  13];
    9 _1 g% J! d, w4 L3 W+ L
    发表于 2020-12-8 14:10 | 只看该作者
    adogpp 发表于 2020-12-8 14:08) F! I! t8 Q( w6 a3 K
    是的,t=1:1:66.我在网上收了很多相关数据,目前找到很多拟合的方法,但就对这个微分方程组难处理
    $ O+ j; A4 R' Z3 a8 N/ f/ h
    用1stOpt试试,应该可以解决
    ; D" w- i1 Q; i+ O) J5 a
    2019-11-19 15:29
     楼主| 发表于 2020-12-8 14:08 | 只看该作者
    pulbieup 发表于 2020-12-8 13:48. \( h4 Q& u( w; Y
    你这个看着应该属于微分方程拟合问题吧,不知道t数据在哪儿?
    ! k' r) z, ~5 l5 R. i& h9 [是的,t=1:1:66.我在网上收了很多相关数据,目前找到很多拟合的方法,但就对这个微分方程组难处理
    2 X# P6 |+ O9 s$ e: P1 ]( w* H
    用1stOpt试试,应该可以解决  详情 回复 发表于 2020-12-8 14:10
    发表于 2020-12-8 13:48 | 只看该作者
    是的,t=1:1:66.我在网上收了很多相关数据,目前找到很多拟合的方法,但就对这个微分方程组难处理  详情 回复 发表于 2020-12-8 14:08
    发表于 2020-12-8 13:47 | 只看该作者
    这是让我们看你写的程序呀
    2022-6-1 15:04
  • 签到天数: 81 天
    [LV.6]常住居民II
    发表于 2020-12-8 12:37 | 只看该作者
    不怎么了解,有待学习
    GMT+8, 2025-11-24 12:46 , Processed in 0.171875 second(s), 26 queries , Gzip On.
