| Bill of Material Report (Condensed) |
| SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
| 名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
| 15-24-4742 | H1X4-200_15-24-4742 | H-1X4-200 | IC | 1 | J15 |
| 22-11-2032 | KEYED_HDR3 | KEYED_H-1X3 | IC | 1 | J31 |
| 32K10K-400 | SMA_32K10K-400 | 32K10K-400E3 | IC | 8 | J10; J11; J12; J13; J42; J43; J44; J45 |
| 102-1261-EV | 102-1261-EV | SPDT | IC | 1 | SW1 |
| 0201_012SQ_023SP | C0201_001UF_63V_0201_012SQ_02 | 0.01uF | IC | 2 | Z1; Z2 |
| 402 | 0_01UF_0402 | 0.01UF | DISCRETE | 39 | C1; C2; C10; C31; C68; C75; C76; C77; C79; C84; C85; C86; C87; C104; C137; C199; C204; C205; C211; C212; C213; C214; C215; C216; C217; C218; C219; C220; C221; C222; C223; C224; C225; C420; C421; C422; C423; C424; C425 |
| 402 | 120PF_0402 | 120PF | DISCRETE | 2 | C3; C32 |
| 402 | 0_1UF_0402 | 0.1UF | DISCRETE | 115 | C12; C14; C18; C19; C24; C25; C27; C28; C29; C30; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C47; C49; C50; C51; C52; C55; C56; C57; C60; C61; C62; C90; C91; C92; C94; C95; C97; C100; C106; C110; C122; C131; C132; C133; C139; C143; C144; C146; C147; C148; C150; C155; C158; C159; C166; C170; C171; C172; C173; C174; C175; C176; C178; C181; C182; C186; C190; C191; C193; C198; C202; C203; C209; C210; C231; C232; C235; C237; C238; C241; C245; C246; C249; C301; C302; C304; C306; C307; C309; C311; C316; C350; C351; C352; C353; C354; C364; C365; C366; C367; C368; C369; C373; C374; C380; C381; C382; C383; C384; C385; C410; C411; C426; C430; C431 |
| 402 | 22PF_0402 | 22PF | DISCRETE | 14 | C20; C21; C22; C23; C111; C112; C113; C115; C116; C118; C119; C121; C200; C201 |
| 402 | 5_0PF_0402 | 5.0PF | DISCRETE | 2 | C66; C67 |
| 402 | 33PF_0402 | 33PF | DISCRETE | 5 | C114; C117; C120; C207; C208 |
| 402 | 270PF_0402 | 270PF | DISCRETE | 6 | C123; C124; C151; C152; C153; C154 |
| 402 | 82000PF_0402 | 82000PF | DISCRETE | 1 | C125 |
| 402 | 8200PF_0402 | 8200PF | DISCRETE | 1 | C126 |
| 402 | 0_047UF_0402 | 0.047UF | DISCRETE | 3 | C127; C128; C130 |
| 402 | 0_22UF_0402 | 0.22UF | DISCRETE | 17 | C256; C330; C331; C332; C333; C334; C335; C336; C337; C338; C339; C340; C341; C342; C343; C344; C345 |
| 402 | NS_0402 | DNP | DISCRETE | 17 | R1; R5; R7; R9; R56; R57; R61; R63; R67; R68; R87; R89; R103; R132; R171; R175; R211 |
| 402 | 332_0402 | 332 | DISCRETE | 2 | R2; R91 |
| 402 | 1_21K_0402 | 1.21K | DISCRETE | 12 | R3; R52; R53; R64; R120; R130; R131; R191; R196; R204; R205; R206 |
| 402 | 4_75K_0402 | 4.75K | DISCRETE | 30 | R4; R6; R8; R33; R71; R83; R84; R88; R95; R96; R97; R100; R101; R116; R117; R135; R136; R137; R138; R142; R143; R152; R153; R154; R155; R157; R158; R165; R166; R197 |
| 402 | 140_0402 | 140 | DISCRETE | 6 | R10; R17; R50; R51; R114; R173 |
| 402 | 0_0402 | 0 | DISCRETE | 16 | R16; R49; R58; R62; R70; R79; R80; R82; R90; R104; R139; R167; R168; R194; R212; R224 |
| 402 | 49_9_0402 | 49.9 | DISCRETE | 26 | R20; R21; R22; R23; R24; R25; R26; R27; R35; R36; R37; R38; R60; R65; R160; R161; R162; R163; R170; R172; R228; R229; R230; R231; R232; R233 |
| 402 | 100_0402 | 100 | DISCRETE | 6 | R30; R31; R111; R147; R226; R227 |
| 402 | 1_54K_0402 | 1.54K | DISCRETE | 2 | R32; R127 |
| 402 | 113_0402 | 113 | DISCRETE | 1 | R55 |
| 402 | 84_5_0402 | 84.5 | DISCRETE | 3 | R59; R220; R222 |
| 402 | 27_4_0402 | 27.4 | DISCRETE | 10 | R69; R72; R73; R74; R75; R76; R77; R81; R148; R149 |
| 402 | 6_81K_0402 | 6.81K | DISCRETE | 2 | R85; R190 |
| 402 | 4_99K_0402 | 4.99K | DISCRETE | 3 | R102; R177; R185 |
| 402 | 2_43K_0402 | 2.43K | DISCRETE | 8 | R110; R112; R113; R115; R118; R119; R176; R184 |
| 402 | 75_0_0402 | 75 | DISCRETE | 9 | R121; R122; R123; R124; R125; R126; R144; R145; R146 |
| 402 | 7_87K_0402 | 7.87K | DISCRETE | 2 | R128; R129 |
| 402 | 3_01K_0402 | 3.01K | DISCRETE | 2 | R140; R141 |
| 402 | 20_5K_0402 | 20.5K | DISCRETE | 2 | R150; R195 |
| 402 | 49_9K_0402 | 49.9K | DISCRETE | 2 | R151; R156 |
| 402 | 1_13K_0402 | 1.13K | DISCRETE | 1 | R178 |
| 402 | 4_53K_0402 | 4.53K | DISCRETE | 1 | R179 |
| 402 | 1_00M_0402 | 1.00M | DISCRETE | 1 | R198 |
| 402 | 562_0402 | 562 | DISCRETE | 1 | R199 |
| 402 | 3_57K_0402 | 3.57K | DISCRETE | 2 | R200; R202 |
| 402 | 1_69K_0402 | 1.69K | DISCRETE | 2 | R201; R203 |
| 402 | 124_0402 | 124 | DISCRETE | 2 | R221; R223 |
| 603 | 1UF_0603 | 1UF | DISCRETE | 20 | C11; C13; C102; C134; C136; C140; C142; C149; C157; C160; C161; C164; C165; C230; C236; C244; C300; C305; C310; C315 |
| 603 | 470PF_0603 | 470PF | DISCRETE | 5 | C43; C44; C45; C46; C276 |
| 603 | NS_0603 | DNP | DISCRETE | 1 | C48 |
| 603 | 1000PF_0603 | 1000PF | DISCRETE | 11 | C71; C72; C74; C82; C83; C129; C233; C239; C247; C320; C321 |
| 603 | 220PF_0603 | 220PF | DISCRETE | 1 | C275 |
| 603 | FERRITE-220_0603 | FERRITE-220 | DISCRETE | 49 | FB5; FB6; FB7; FB8; FB10; FB11; FB12; FB13; FB14; FB20; FB21; FB30; FB31; FB32; FB33; FB34; FB40; FB41; FB48; FB49; FB50; FB51; FB52; FB55; FB60; FB61; FB70; FB71; FB72; FB73; FB74; FB75; FB76; FB77; FB78; FB79; FB80; FB81; FB82; FB83; FB84; FB85; FB90; FB91; FB92; FB93; FB94; FB95; FB96 |
| 0603-A4 | RP4_7K_0603X4 | 4.7K | DISCRETE | 2 | RP7; RP8 |
| 0603-A4 | 47X4_0603X4 | 47 | DISCRETE | 17 | RP9; RP25; RP26; RP27; RP28; RP29; RP30; RP32; RP33; RP52; RP53; RP54; RP55; RP56; RP57; RP58; RP59 |
| 0603-A4 | RP22_0603X4 | 22 | IC | 1 | RP38 |
| 805 | 10UF_0805 | 10UF | DISCRETE | 63 | C26; C53; C58; C63; C70; C73; C80; C81; C93; C96; C98; C101; C135; C141; C145; C156; C180; C185; C187; C192; C194; C206; C226; C234; C240; C248; C261; C262; C263; C267; C281; C282; C283; C288; C291; C292; C293; C297; C303; C308; C312; C313; C314; C317; C318; C319; C357; C358; C359; C360; C361; C362; C363; C377; C378; C387; C388; C390; C391; C392; C412; C413; C432 |
| 805 | NS_0805 | DNP | DISCRETE | 2 | C103; C138 |
| 805 | HZ0805E601R-10_0805 | HZ0805E601R-10 | DISCRETE | 3 | FB1; FB2; FB3 |
| 805 | 82NH_0805 | 82NH | DISCRETE | 6 | FB42; FB43; FB44; FB45; FB46; FB47 |
| 805 | 10_0805 | 10 | DISCRETE | 4 | R66; R78; R210; R213 |
| 0805-A4 | 0_1UF_0805 | 0.1UF | DISCRETE | 38 | CP1; CP2; CP3; CP10; CP11; CP12; CP13; CP20; CP30; CP31; CP32; CP34; CP35; CP36; CP38; CP39; CP40; CP50; CP51; CP60; CP61; CP70; CP71; CP75; CP80; CP81; CP90; CP100; CP101; CP102; CP103; CP110; CP121; CP122; CP128; CP129; CP130; CP131 |
| 0805-A4 | 0_01UF_0805 | 0.01UF | DISCRETE | 3 | CP21; CP52; CP53 |
| 3352W | 2K_POT-3352W | 0-2K | DISCRETE | 1 | R86 |
| 67800-8005 | SATA-67800-8005 | SATA | IC | 2 | J40; J41 |
| 87832-1420 | MOLEX-87832-1420 | 87832-1420 | IC | 1 | J1 |
| 1108800 | SK_DIP8_4 | 110880 | IC | 2 | X1; X5 |
| 1367073-1 | SFP-1367073-1 | SFP_CONN_CASE | IC | 1 | P19 |
| ABLS | ABLS-25_000MHZ-B2F-T | 25MHZ | DISCRETE | 1 | X2 |
| ABLS | ABLS-25_000MHZ-B2F-T | 25.5625MHZ | DISCRETE | 1 | X3 |
| ABLS | ABLS-25_000MHZ-B2F-T | 19.44MHZ | DISCRETE | 1 | X4 |
| ABLS | ABLS-25_000MHZ-B2F-T | 25.000MHZ | DISCRETE | 2 | X6; X7 |
| AT-1220-TT-2-R | 665-AT-1220TT2R | PIEZO_AT-1220-TT-2-R | IC | 1 | SP1 |
| EVQ-WK4001 | PEC11-4020F-S0024 | ROTARY_ENCODER | IC | 1 | SW2 |
| EXBE-1608 | RP4_7K_EXBE-1608 | 4.7K | DISCRETE | 15 | RP1; RP2; RP5; RP12; RP13; RP21; RP22; RP31; RP34; RP41; RP50; RP51; RP60; RP61; RP70 |
| EXBE-1608 | RP10K_EXBE-1608 | 10K | DISCRETE | 3 | RP6; RP15; RP20 |
| EXBE-1608 | RP120_EXBE-1608 | 120 | DISCRETE | 1 | RP10 |
| EXBE-1608 | RP150_EXBE-1608 | 150 | DISCRETE | 3 | RP11; RP14; RP35 |
| FMC_15 | FMC_15 | | IC | 4 | J70; J71; J76; J77 |
| HDR-1X1 | CON1 | H-1X1 | IC | 10 | MH6; MH7; TP1; TP10; TP11; TP12; TP13; TP20; TP21; TP22 |
| HDR-1X2 | HRD_1X2 | H-1X2 | IC | 10 | J14; J18; J19; J24; J32; J33; J54; J56; J80; J82 |
| HDR-1X3 | HRD_1X3 | H-1X3 | IC | 7 | J17; J21; J22; J23; J62; J63; J81 |
| HDR-1X5 | HRD_1X5 | H-1X5 | IC | 3 | J25; J26; J83 |
| HDR-1X6 | H-1X6_HDR_1X6 | H-1X6 | IC | 1 | J3 |
| HDR-1X7 | H-1X7_HDR_1X7 | H-1X7 | IC | 1 | J2 |
| HDR-1X32 | HRD_1X32 | H-1X32 | IC | 2 | J5; J7 |
| HDR-2X3 | HDR_2X3 | H-2X3 | IC | 1 | J20 |
| HDR-2X5 | HDR_2X5 | H-2X5 | IC | 4 | J9; J28; J60; J61 |
| HDR-2X7 | H-2X7_HDR-7X2 | H-2X7 | IC | 1 | J8 |
| HDR-2X8 | HDR_2X8 | J15 | IC | 1 | J51 |
| HDR-2X32 | H-2X32_HRD_2X32 | H-2X32 | IC | 2 | J4; J6 |
| K31X-E9P-NJ | DB9_K31-E9P-NJ | DB9M | IC | 1 | P3 |
| K66X-E15S-N | DB15_VGA_K66X-E15S-N | K66X-E15S-N | IC | 1 | P8 |
| KMDRX-6S-BS | PS2_KMDRX-6S-BS | MINIDIN6 | IC | 2 | P4; P5 |
| KUSBX-SLAS1N-B | USB_A_KUSBX-SLAS1N-B | USB_A_VERT_TH | IC | 1 | P18 |
| KUSBX-SMT-BS1N-W | USB_B_KUSBX-SMT-BS1N-W | USB_B_PERI_SMT | IC | 1 | P17 |
| KVIX-DA29S-N-W | DVI_KVIX-DA29S-N-W | DVI_CONN | IC | 1 | P7 |
| LED-0603 | LED-GRN-SMT_LED_0603 | LED-GRN-SMT | IC | 24 | DS1; DS2; DS3; DS10; DS11; DS12; DS13; DS14; DS15; DS16; DS17; DS20; DS21; DS22; DS23; DS24; DS30; DS31; DS32; DS33; DS34; DS35; DS40; DS41 |
| LED-0603 | LED-RED-SMT_LED_0603 | LED-RED-SMT | IC | 3 | DS4; DS5; DS6 |
| LQFP50P900X900-48 | AD1981B_LQFP-48 | AC97 | IC | 1 | U22 |
| MH_125_250 | HOLE_MH_125_250 | MH_125_250 | IC | 6 | MH1; MH2; MH3; MH4; MH5; MH8 |
| MICTOR38P_RECP | MICTR38P_REC_MICTOR38P_RECP | MICTR38P_REC | IC | 1 | P22 |
| ML621S_F9DE | ML621S_F9DE | BATTERY_ML621S | IC | 1 | B1 |
| MM50-200B2-1E | DDR_184_DIMM184 | DDR2-SO-DIMM | IC | 1 | P2 |
| MSOP50P500X300-11 | TPS51100DGQ_MSOP8 | TPS51100DGQ | IC | 2 | U42; U43 |
| N7E50-7516PG-20 | N7E50-7516PG-20_CF-50PIN | N7E50-7516PG-20 | IC | 1 | P1 |
| PCI-E-FINGER-1X | PCI-E-FINGER-1X | PCI_E-FINGER-1X | IC | 1 | P21 |
| PJ-002AH | CUI_PJ-002AH | PWR_JACK | IC | 1 | P20 |
| PQFP50P1720X2320-128R | M88E1111_PQFP128R | M88E1111 | IC | 1 | U16 |
| PTH08T220W | PTH08T220 | PTH08T220W | IC | 1 | U37 |
| PTH08T240W | PTH08T240 | PTH08T240W | IC | 2 | U35; U38 |
| QFN50P300X300-17 | ICS85401_VFQFN16 | ICS85401 | IC | 1 | U12 |
| QFN65P500X500-21 | TPS74401_QFN20 | TPS74401 | IC | 5 | U30; U31; U33; U40; U41 |
| QFP50P1200X1200-64 | CH7301C_LQFP64 | CH7301C-TF | IC | 1 | U17 |
| QFP65P1600X1600-80 | AD9980_LQFP80 | AD9980 | IC | 1 | U19 |
| RCA-572 | RCA_572 | RCA_JACK | IC | 1 | P14 |
| RJ45_HFJ11-1G01E | RJ45_HFJ11-1G01E | RJ45 | IC | 1 | P6 |
| SC70 | ADR03_SC70 | ADR03_SC70 | IC | 1 | U9 |
| SDMX-8-X | SWDIP_SW-16_SDMX-8-X | SDMX-8-X | IC | 3 | SW3; SW6; SW8 |
| SG-BGA-6046 | SG-BGA-6046 | SG-BGA-6046 | IC | 1 | U1 |
| SO127P600X865-14 | CD4069_SOIC-14 | CD4069 | IC | 1 | U39 |
| SO127P1030X1030-16 | M25P16_SO-16 | M25P16-VMF6P | IC | 1 | U6 |
| SO-8 | M25P80_SO-8 | M25P80 | IC | 1 | U6B |
| SOFTTOUCH_PRO | SOFTTOUCH_PRO | | IC | 1 | J16 |
| SOP63P866X600-24 | ADT7476_SOP-24 | ADT7476 | IC | 1 | U14 |
| SOP127P500X600-8 | MIC2025-2B_SOP8 | MIC2025 | IC | 1 | U24 |
| SOT23-5 | SN74LVC1G126_SOT23-5 | SN74LVC1G126 | IC | 2 | U7; U45 |
| SOT23-5 | TPS73633_SOT23-5 | TPS73633DBVT | IC | 2 | U18; U21 |
| SOT23-5 | TPS73118_SOT23-5 | TPS73118 | IC | 1 | U20 |
| SOT223-4 | SOT223_SOT223-4 | NDT3055L | IC | 1 | Q10 |
| SOT-23 | BAV40-04_SOT23 | BAS40-04 | IC | 9 | D1; D10; D11; D12; D13; D14; D15; D16; D17 |
| SOT-23 | BZX84-C3V3_SOT23 | BZX84C15 | IC | 1 | D5 |
| SOT-23 | NDS331N_SOT23 | NDS331N | IC | 20 | Q1; Q2; Q3; Q4; Q5; Q8; Q9; Q11; Q12; Q13; Q14; Q15; Q16; Q17; Q18; Q20; Q21; Q40; Q41; Q42 |
| STX-3150-3N | 3P5MM_STX-3150-3N | STEREO_JACK_TH | IC | 4 | P10; P11; P12; P13 |
| TANT-B | 330UF_TANT_B | 33UF | DISCRETE | 1 | C375 |
| TANT-B | 47UF_TANT_B | 47UF | DISCRETE | 15 | C394; C395; C396; C397; C398; C399; C400; C401; C414; C415; C416; C417; C428; C433; C434 |
| TANT-B | NS_TANT_B | NS | IC | 2 | C402; C403 |
| TANT-C | 150UF_TANT_C | 150UF | DISCRETE | 3 | C162; C163; C177 |
| TANT-D | 330UF_TANT_V | 330UF | DISCRETE | 3 | C64; C371; C372 |
| TANT-D | 470UF_TANT_D | 470UF | DISCRETE | 4 | C260; C279; C280; C290 |
| TANT-D | 680UF_TANT_D | 680UF | DISCRETE | 1 | C264 |
| TANT-D | NS_TANT_D | NS | DISCRETE | 3 | C265; C286; C295 |
| TANT-D | 1000UF_TANT_D | 1000UF | DISCRETE | 3 | C284; C285; C294 |
| THTL3301EF100QG | PUSHBUTTON_4 | TL3301EF100QG | IC | 8 | SW4; SW5; SW7; SW10; SW11; SW12; SW13; SW14 |
| TQFP50P1600X1600-100 | XC95144XL_TQFP100C | XC95144XL_10TQ100C | IC | 1 | U3 |
| TQFP50P1600X1600-100 | CY7C67300-TQFP100 | CYP_USB_HOST | IC | 1 | U23 |
| TQFP65P1600X2200-100 | CY7C1354B_TQFP100R | SRAM_ZBT_256KX36 | IC | 1 | U26 |
| TQFP80P900X900-32 | IDT5V9885_TQFP-32 | IDT5V9885 | IC | 1 | U8 |
| TQFP144 | XCCACE-TQ144I_TQFP144 | XCCACE-TQ144I | IC | 1 | U2 |
| TSOP50P2000X1200-48 | XCF32P_VOG48 | XCF32P-VOG48 | IC | 2 | U4; U5 |
| TSOP50P2000X1400-56 | JS28F256P30_TSOP56 | FLASH_256MBIT | IC | 1 | U27 |
| TSOP65P640X500-16 | ADM3202ARU_TSSOP16 | ADM3202ARUZ | IC | 1 | U13 |
| TSSOP65P640X300-8 | M24C08-WDW6TP | M24C08-WDW6TP | IC | 1 | U15 |
| TSSOP65P640X300-8 | M24128-BWDW6TP | M24128-BWDW6TP | IC | 1 | U25 |
| TSSOP65P640X300-8 | ICS844021I_TSSOP8 | ICS844021I | IC | 1 | U29 |
| TSSOP65P640X300-8 | ICS844071I_TSSOP8 | ICS844071I | IC | 1 | U44 |
| TSSOP65P650X640-20 | ICS8543_TSSOP20 | ICS8543 | IC | 1 | U11 |
| TSSOP65P780X640-24 | ICS843001-21_TSSOP24 | ICS843001-21 | IC | 1 | U10 |
| ZTB350D | 350KHZ_ZTB350D | 350KHZ | DISCRETE | 1 | X8 |
