查看: 332|回复: 2
模拟MDIO协议,读到数据都是1,大有人模拟过吗,求解答?
发表于 2020-11-23 11:20 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
) d1 H8 O# k4 E5 A2 ~( @void delay(void)
9 Q0 ], }' J: y) z+ S" _5 ?{
2 X" j! H0 f: Q  A" O. m- wdelay_us(1);
4 a( U- M6 u2 E9 _# h; b+ U+ y* X}( V4 |# C! o  x5 d+ b9 W3 {  G
1 t' e" l! N0 P! r0 e6 `0 F$ Mvoid mdio_init(void)
1 C1 P& `$ x, ~5 K8 G* K{3 Y0 t8 ]1 ~% ~, P% V6 m: c
rcu_periph_clock_enable(RCU_GPIOA);
  K7 j9 R7 c$ A9 C# w    rcu_periph_clock_enable(RCU_GPIOC);
& k9 h9 o# B- v+ N//开漏输出
2 N: V% o$ ]3 ?2 P% z: g( s//MDIO---PA2   MDC---PC14 I, t" m8 D" k$ n# i! ?  j! r% L
    gpio_mode_set(GPIOA, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_2);* K$ Z+ @5 M7 o5 J* \9 e
    gpio_output_options_set(GPIOA, GPIO_OTYPE_OD, GPIO_OSPEED_200MHZ,GPIO_PIN_2);
: U5 C6 w  d  G& ^1 J( Y# R" {% c  X$ G" G. R6 q1 A; x. j( Y
gpio_mode_set(GPIOC, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_1);$ X: [* q0 ~, X; H
    gpio_output_options_set(GPIOC, GPIO_OTYPE_OD, GPIO_OSPEED_200MHZ,GPIO_PIN_1);# |( z  Z# }0 p6 R; `
" Z  w8 s. ~" L* e# ]* [
2 Q; r, w) w5 P5 J1 T  B
/* BCMMDIO_EN---PB14*/
  x, D( j! d% V8 m    rcu_periph_clock_enable(RCU_GPIOB);
2 G: H  C  w/ T4 ~) ~    gpio_mode_set(GPIOB, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_14);9 u- n/ k6 S, g1 V5 {8 e) a
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_200MHZ,GPIO_PIN_14);
8 g. B7 B1 x( }" R//on---1, off---0
5 t. X/ X0 f* K) sgpio_bit_set(GPIOB, GPIO_PIN_14);   {* {: X# b+ M2 L0 f% d( E
}' K: `6 V. Y, w/ J6 q
#if 01 i4 d3 A( ^+ y, B) ]1 x. M
- J. d9 A+ y0 M. m4 q{
$ K# u8 R) T/ c& Q( C  Yrcu_periph_clock_enable(RCU_GPIOA);# f4 T, O. P( G- q
    rcu_periph_clock_enable(RCU_GPIOC);& {8 W9 i3 }+ E
" N2 ^; `. V8 s* O  r2 H    /* PA2: ETH_MDIO */
9 H* Z$ y& S9 B    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_2);! g1 q' Q" k  S6 K+ m6 ?) Q( u0 p- y8 X
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_200MHZ,GPIO_PIN_2);/ V4 x8 ~" r9 k* }# u5 A
    gpio_af_set(GPIOA, GPIO_AF_11, GPIO_PIN_2);
- s* ~! n$ y# e) k/* PC1: ETH_MDC */2 E! H, q0 }  @( I+ q
    gpio_mode_set(GPIOC, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_1);& _; V, r! w5 S4 A& b4 ~
    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_200MHZ,GPIO_PIN_1);
, d% p4 [0 b, n* ]$ t    gpio_af_set(GPIOC, GPIO_AF_11, GPIO_PIN_1);% r7 n& D/ i* V/ h/ D4 z0 M
* V$ ^6 U. |( b/* BCMMDIO_EN */# t0 O9 f6 `5 f9 |) A, y
3 q) Q+ o+ Y& W6 G    gpio_mode_set(GPIOB, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_14);
- I! f4 b" b0 R% `0 L9 s2 m    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_14);
! G5 z7 |0 z2 I" m/ Q) b6 Y/ E//on---0, off---10 j3 q( A( j3 {2 a% E/ x9 H4 Z  j
gpio_bit_reset(GPIOB, GPIO_PIN_14); 9 C1 E- a- e1 L2 j
}( f) u% [6 D+ N
#endif
7 p, j+ K! [, B, j
# C  ~' G% _, h" v1 ?6 F& o/* 设置MDC为输出引脚,在MDC输出时钟之前设置 */, i3 `6 T) z7 m+ `; Y% U
static void MDC_OUT(void)
- {1 Y2 l+ i" n{4 g9 @3 B/ C! D0 g. _! I
gpio_mode_set(GPIOC, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_1);5 J. y3 t' b# e9 y. r% K4 L3 p
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_200MHZ,GPIO_PIN_1);0 w& g* ~  ?2 ]- `/ _" d; r0 Q
}  p7 K# e; @% I8 M" F* Q
/* 设置MDIO引脚为输出模式 */
) }: A  M6 a0 h) m& d2 ?static void mdio_output(void)' ?' L) d+ k; Y
; M6 _! W8 X$ \: ~/ |' vMDC_L();: k- V) |! S& ^/ X, I
7 K% @+ }* P4 E$ a& _: A/* PA2 MDIO */
# M9 j$ |, |7 R2 K/ Lgpio_mode_set(GPIOA, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_2);
1 Z$ d/ E% t+ cgpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_200MHZ, GPIO_PIN_2);
) a& K% k( s/ X* J7 _
1 t# O6 w1 Z. ], B; w+ K: F0 Bdelay_us(1);    ) R! {2 J) r- }% ~# X& w: f1 ~% z, p
8 E$ P- l( p) s' c8 }1 A3 R
MDC_H();
) k* q/ b' {4 Ldelay_us(1);
9 z( Q, {5 T0 `0 {/ }7 s! a4 G. D}. F! `4 {7 h! |. v) c' l
/* 设置MDIO引脚为输入模式 */9 l/ c/ y# Y# V
static void mdio_input(void)# A! x  Y0 C% F1 L' a6 @! M3 C
{7 Q2 o8 y, J$ m. e' W% G
MDC_L();9 i$ o* `- J! x" i" Q( }8 @
/* PA2 MDIO */8 \3 G5 e3 P, g4 M1 f4 d
gpio_mode_set(GPIOA, GPIO_MODE_INPUT, GPIO_PUPD_NONE, GPIO_PIN_2);
! W5 ^5 ^, z; j* f/ e9 f( bdelay_us(1);      Z( u$ N$ e- P6 L, l
4 I2 b6 U  p/ j; g5 j2 m
MDC_H();' L- T8 S+ h! l* ^4 ~" x
delay_us(1);
6 W) J1 b, C4 g  e# \% Q& a
$ q2 m, o- i/ r( k, s( x1 O}0 w6 j- K. t$ F7 d7 r$ f+ g2 x
//set MDC CLK
" m1 m% E* ^- _. a. |3 x6 r3 Uvoid set_mdc_val()8 s4 d; U  q# m4 K- v
{' f/ X8 n  R( J  \
MDC_L();# X& t" ]- D) Y: a* h  @0 m
delay_us(1);. x3 ?9 c" W. P
    MDC_H();2 m9 x% I' s6 v2 m
delay_us(1);1 j, O' R4 U3 T' D2 N
* o5 z# O1 t& I, r& e, Z& c; A0 @: {) _//set MDIO val
0 H- q8 p* J+ h+ Cvoid set_mdio_val_bit(uint8_t val)4 H- b, s  p- B6 ?- P& ~# O0 B3 Z; `
3 i/ s" d& J7 T3 {7 f) m1 {if( (val&0x1) == 0)
# m: Z- A+ z6 E1 k2 _, j9 x  gpio_bit_reset(GPIOA, GPIO_PIN_2); 6 T  u+ s. h9 |8 N' B; o! y
else
* v$ c1 q8 @0 Z  C5 b  gpio_bit_set(GPIOA, GPIO_PIN_2);
3 i6 d/ v/ L* s; z' w}
8 A! U3 v& h/ G' C0 w% N: T- Y" d1 h
#if 14 K" s. r4 W+ q
/* MDIO发送一个bit的数据,MDIO必须已经被配置为输出 */9 G' W7 e: T5 O1 _  ?6 V& w
static void mdio_bb_send_bit(uint8_t val)
" S; K8 ~4 I6 F/ w{ ! U$ S) f6 G' h, z9 H
MDC_L();
9 X5 ]) P: o3 G2 O" U
: }5 w1 P3 v8 c) V% W4 z4 Cset_mdio_val_bit(val);
7 @2 X+ v7 n/ m" N/ adelay_us(1);
) i1 P9 U) x6 m% F& z+ A. |) x% r, W6 v7 g
    MDC_H();0 w( v- E' W" |+ T/ ?( L. L, J& ?6 L
delay_us(1);
4 @- D6 E5 m+ A: E
% |9 \/ K: r1 l2 J; }, t9 \// set_mdc_val();
' r0 k+ d  D" n1 g9 ?3 ?0 s}
. r. R, ^- ~* l/ S/*  6 M+ @4 W" g/ Z; K" \( w1 m# O0 s. I+ Q& Y
*  MDIO发送一个数据,MDIO 必须被配置为输出模式. 6 w0 j8 g1 _! ^# s
*  value:要发送的数据
4 R" J' {+ `9 T; x*  bits:数据的位数! J& m; I  @7 _8 Q7 r2 c
*/  " L. a. F) S4 I
static void mdio_bb_send_num(unsigned int value ,int bits)/ `/ I; r$ g: o! I+ I, H
* m* H( @5 h: O# F' F    int i;: H: x+ e7 F& I' e
1 j6 U& a+ g6 c) g+ ~9 A    for(i = bits - 1; i >= 0; i--)
2 R7 U$ M6 u# [8 A8 T2 n& C        mdio_bb_send_bit((value >> i) & 1);
* J. t6 Y5 A! N; u9 n( j}
1 w( [  c: m# U5 Q4 X: Y; b. p3 U0 @/*  MDIO 获取一个bit的数据,MDIO必须已经被配置为输入. */
7 k- h5 c4 `: ?/ dstatic int mdio_bb_get_bit(void)* @9 _3 x) x: W4 z9 `1 S/ K
7 ?0 d, `' T6 r    int value;! y, ]4 u+ N3 ~% ^3 Y
) b$ a+ p- i8 n- D) }! ~, ^5 E
// set_mdc_val(); ! {  k* [" C6 K8 V( o: w; O* }" x
MDC_L();; `; Q( v8 O5 H. w
) m3 g3 v3 h' t0 t: {( |. {8 Ddelay_us(1);/ |4 w% F! P; T" |
value = GET_MDIO();
' r, Y4 a; r4 D9 M2 X8 F/ I! h+ Z3 O
6 U7 e( \/ M% D6 O% I; Z: l- n; D( r    MDC_H();
. i- z! Z  H$ `# f' Zdelay_us(1);) N5 j3 L$ i$ q( }: k  }  [8 {; Y
    return value;8 w) o7 S" Q" n- I
}* E% o/ q! ^* C6 s- X: e
. G/ a. }+ v5 M% P; c  Y* L*  MDIO获取一个数据,MDIO 必须被配置为输入模式. ' O% S0 ?8 Y- z2 [4 B3 Q/ @5 z  c& V
*  bits:获取数据的位数/ D4 |# K4 k3 z5 k# [
*  * c  H8 K2 |6 F  z: U) u
*/3 ]! q8 Q/ k" P, P$ q, c
static int mdio_bb_get_num(int bits)
  q+ }; ?3 E: F5 Z5 O! c{+ F$ N# _1 e" n  ~: X
    int i;, W* X) p; \# U3 T6 E6 K- U/ u
    int ret = 0;
, a1 e( X/ p+ U- D+ |. b4 h* o* X    for(i = bits - 1; i >= 0; i--)' c) p  ]8 ^) b& s8 v1 G
    {- L3 f0 b- {; R+ q0 S
        ret <<= 1;5 l6 B8 X; ^8 J# G
        ret |= mdio_bb_get_bit();
/ S' h# n. o& F! Y  }7 O2 F    }5 o. h/ J' \" H3 @1 O
    return ret;
. I: g( W9 E/ R) q: ~& J4 j/ E9 I}1 `7 W6 ~: i$ }( c' D. s- I5 X4 `* M! l8 p
- b& J1 N  J5 l& Z6 Y2 WMDIO frame format definitions are shown below:
8 F: p1 H7 b& i* u+ C+ S. PPreamble = 32-bit 1's (optional)
9 b1 M9 p5 [. K7 ^2 {& \START = Start of Frame indicated by 00 pattern% K. U0 I+ I# M8 m
OP = Opcode (access type)5 F& b' ^4 [; k: B  k1 I
– 00: Address
. S0 f6 e7 R/ e– 01: Write
/ D( P% I# j( l– 11: Read
& K' R7 }8 U7 M. l– 10: Post read increment address2 _& A' M1 s9 W0 Y- H( a
TA = Turnaround
# Q5 _+ b% M6 F1 ^  q2 G– Z0: Read
- M  b4 R  `. ?# B8 R  T– 01: Write
- @1 X3 U) ^) a2 M4 ~* s0 h5 pPRTAD = Physical Address (hardwired)5 B' q7 F  W" ^
DEVAD = Device Address . e( P* Z: l3 k
– 00001: PMA/PMD; D' D' v% m" H5 O7 l" [7 B
– 00111: AN
4 H; }* i: {5 V: mAddress/Data = 16-bit Address or Data
/ M+ x' [; `4 p3 F8 F*/
+ O; `; H* |, w, |4 D/*
- K* w4 f  p0 _% ~  lread:
3 S, U. n  w# }" w- tFrame 1: Address (Opcode = 00, PRTAD = 0, Device Address = 1, Address/Data field = 0x8200)' F- g, s4 D- N$ J! H
Frame 2: Read (Opcode = 11 or 10, PRTAD = 0, Device Address = 1, Address/Data field = data read back from 0x8200)
5 T; u) T% y( P- D. d% t3 b*/
0 L2 a) E0 X2 C* Q, O7 suint16_t read_data(uint8_t phy, uint8_t dev, uint16_t reg)
+ o+ C% x7 [0 ]/ d. I6 X{+ u: k! Z, f" G5 Q" m) T
int ret = 0, i = 0;4 I7 v& m/ ?- C: s  S, E' x
mdio_output();% J7 P+ a; V6 U" x* K* z
) O' [0 Z& @* X  q//第一帧数据,先发地址! [/ R0 B$ {* Z. v
/*发送32bit的1,这个帧前缀域不是必须的,某些物理层芯片的MDIO操作就没有这个域*/
3 a6 g6 _, \1 F/ jfor(i = 0; i < 32; i++)( L" U/ z& _# D3 a1 p# D
  mdio_bb_send_bit(1);
* Y" s' E  D; R7 f# g' Q: w9 ^6 ~( h+ N+ W
//start 00
/ K  x# P$ P6 Imdio_bb_send_num(0x0, 2);
- V: C  c# c- C5 N3 j4 i//Opcode = 00
; [, |. q7 {* R1 X) Imdio_bb_send_num(0x0, 2);5 g* L2 ~7 Z7 J3 x5 D9 c, }
//PRTAD---5bit
: l; U; ?0 I" J0 ^& Pmdio_bb_send_num(phy,5);$ b0 S) {: S# h2 c+ G3 J! Q# y
//Device---5bit
0 o+ r3 W( }4 h' i1 P" \) }mdio_bb_send_num(dev,5);2 o' s9 M* u) W4 e* i
//TA---0x01-write---2bit
) p& P% i; @' e3 v1 ~- r( Imdio_bb_send_num(0x1, 2);
" k* q6 z+ z& X/ g" C//Address---16bit# u+ L2 l. I, H! j; R
mdio_bb_send_num(reg,16);
" y, y4 f! @. n6 P, p6 U" ?, E2 W& `: _
//第二帧数据6 z; V8 x$ I/ W! K
/*发送32bit的1,这个帧前缀域不是必须的,某些物理层芯片的MDIO操作就没有这个域*/8 z4 j5 r% y0 |4 G, f% ?+ P
2 _9 ]7 r! M! c" ]5 T' M) z  mdio_bb_send_bit(1);
3 D9 N6 u2 w, |9 n, \+ R7 j% h# i, n% \5 C
//start 00 & H" D* B9 q+ M% v2 M% A) A
' J$ B# n3 o5 F//Opcode = 10
/ J: N) E, ]0 z' W  d) J+ |4 o. Pmdio_bb_send_num(0x10, 2);
! L2 i& k+ \% [! e2 _% m//PRTAD---5bit
+ E$ q9 d8 x# Q. L3 Cmdio_bb_send_num(phy,5);
3 H5 Z, ]6 g4 I% z7 h" N2 q, i//Device---5bit
2 S6 e* f$ T  A- ~/ g+ x5 R  i* nmdio_bb_send_num(dev,5);$ z9 O: Y$ v: Z
. o' B% M$ }& w5 C- I) l
mdio_input();
8 A4 s8 V& l. }1 z% k9 i// //TA---0x00-read---2bit
5 H% y7 a/ M. @. q8 u* ?; ^// mdio_bb_send_num(0x2, 2);
* ]" L4 b9 w7 A6 Mset_mdc_val();8 m" F' k+ r; S- m# K6 O* w4 E
; ^! _" Z2 b4 N$ \
//get data! a4 q0 ~4 @: h4 `" h. |
ret = mdio_bb_get_num(16);
( G, O% ]8 F7 L5 f
7 v  s8 U# c4 r: pmdio_output();* d+ e3 p. y7 L3 |
// //高阻态
5 T8 A+ f3 R! d' X* I// for(i = 0; i < 32; i++)2 o4 r( O+ W6 k5 u/ S7 C
//  mdio_bb_send_bit(1);; U0 w% r: S/ y
4 f5 T' M; @5 y0 ~; c. m3 M% Z7 K9 J. p
return ret;
( _; U* o/ {& v9 [( L}9 g7 g! O/ j% _" e
发表于 2020-11-23 13:21 | 只看该作者
是不是管脚定义错了啊
GMT+8, 2025-11-25 02:09 , Processed in 0.187500 second(s), 25 queries , Gzip On.
