查看: 326|回复: 1
u-boot移植时出现inline function 'coloured_LED_init' cannot b
发表于 2020-11-2 13:18 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
, h# W( B1 i2 M7 e" Zboard.c:127: error: inline function 'coloured_LED_init' cannot be declared weak
. ]4 B8 L3 n7 z- i. N6 j+ ]board.c:129: error: inline function 'red_LED_on' cannot be declared weak6 r+ V( f2 d0 w
board.c:131: error: inline function 'red_LED_off' cannot be declared weak
5 q& K" ]7 [# k" l& W" Dboard.c:133: error: inline function 'green_LED_on' cannot be declared weak# x+ Y1 w' j  Z
board.c:135: error: inline function 'green_LED_off' cannot be declared weak
2 X# ^/ G8 `; Q+ i  wboard.c:137: error: inline function 'yellow_LED_on' cannot be declared weak- \+ C  F: G. v
board.c:139: error: inline function 'yellow_LED_off' cannot be declared weak
7 i  {7 h, e1 {+ h: ]board.c:141: error: inline function 'blue_LED_on' cannot be declared weak
$ O. W6 M( y) P# H- |( bboard.c:143: error: inline function 'blue_LED_off' cannot be declared weak" o  @. U5 r3 I; u2 c
make[1]: *** [board.o] 错误 1' b9 E/ ^- G9 w  @& }/ p+ e# h! f
make[1]: Leaving directory `/root/workspace/u-boot-2009.08/lib_ARM'
) @0 ^9 H6 ]/ J, Kmake: *** [lib_arm/libarm.a] 错误 2
4 p: G; k/ q0 `( }6 y8 }& f[root@localhost u-boot-2009.08]#' Z- a' W: l) j, b' T
4 T: X/ S$ }. @% r  J1 R出现错误,内嵌函数不能被声明为weak属性,打开lib_arm/board.c,定位到127行开始,将其注释掉,修改后结果如下:0 k0 d( V' \7 b" E7 r% `! G
5 q1 O, F/ ~# r/ h" P3 c# l' c$ O- J
void inline __coloured_LED_init (void) {}8 v0 L5 U6 E, R+ _$ j) |
//void inline coloured_LED_init (void) __attribute__((weak, alias("__coloured_LED_init")));
/ o4 a+ S! a; S( _5 evoid inline __red_LED_on (void) {}6 k, C7 V5 L& t+ [' K
//void inline red_LED_on (void) __attribute__((weak, alias("__red_LED_on")));. W" k, F9 t- P) H/ M$ S
void inline __red_LED_off(void) {}: }- Q9 G; T( D$ L7 V. ^* F
//void inline red_LED_off(void) __attribute__((weak, alias("__red_LED_off")));% O6 I( y5 }6 Z5 {) y% s4 S  t. Q
void inline __green_LED_on(void) {}, c9 o  N& a' @
//void inline green_LED_on(void) __attribute__((weak, alias("__green_LED_on")));* q# r) A( b4 A- ?7 [3 r- e: F! ~
void inline __green_LED_off(void) {}
4 e  C0 N' h+ `; C//void inline green_LED_off(void)__attribute__((weak, alias("__green_LED_off")));
, z. o( ]+ _# x* z# Y8 Lvoid inline __yellow_LED_on(void) {}  T6 E* s/ V  h9 i0 t2 P
//void inline yellow_LED_on(void)__attribute__((weak, alias("__yellow_LED_on")));
/ t* O" B8 r/ }. Q4 e  e% bvoid inline __yellow_LED_off(void) {}
5 `2 w6 s" a% c/ w5 F& l3 Y//void inline yellow_LED_off(void)__attribute__((weak, alias("__yellow_LED_off")));
$ K% y5 ~* c- w6 A, {) E1 B. avoid inline __blue_LED_on(void) {}
3 I- [! D6 W" i3 U' U//void inline blue_LED_on(void)__attribute__((weak, alias("__blue_LED_on")));( V; S- D9 L3 z6 @- F4 S  g
void inline __blue_LED_off(void) {}+ n8 d$ q( k# y
//void inline blue_LED_off(void)__attribute__((weak, alias("__blue_LED_off")));
( x: B8 h1 s/ _: ]1 n' W. j
) U7 u" C* a. Q$ F! d) K' Q! c[root@localhost u-boot-2009.08]# make clean% o6 ?; q! m! O3 u) S4 _/ H7 c
1 G+ V" ~3 d0 E( W& X& ?[root@localhost u-boot-2009.08]# make
    2019-11-29 15:37
    发表于 2020-11-2 14:18 | 只看该作者
    GMT+8, 2025-11-25 00:47 , Processed in 0.156250 second(s), 24 queries , Gzip On.
