查看: 719|回复: 2
請問如何用skill統計unconnect數目
    2019-11-19 15:32
    发表于 2020-10-22 10:21 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
    請問如何用skill統計unconnect數目?
    Skill > miss=length(setof(net axlDBGetDesign()->nets net->unconnected>0))
    但是net被設為NO_RAT 就會不統計該條net 尚未拉完線
    Net: SOCNDTRA_R has been selected.
    Property NO_RAT added to 1 element(s).
    0
    目前是暫用 report sum.rpt 然後讀sum.rpt 的Missing Connections
    謝謝
    2019-11-19 15:32
     楼主| 发表于 2020-10-29 09:58 | 只看该作者
    謝謝你
    昨日上 candence 網站去請教 已解決:
    To check a complete design check for all net->branches with more than 2 entries.
    So something like this:
    miss=length(setof(net axlDBGetDesign()->nets cadr(net->branches)))
    A branch is:
    Is the set of all the etch objects—ppins, etch paths, shapes, and vias—associated with a particular signal name. Every net has a name which is its signal name. A net contains one or
    more branches. Each branch is a list of the etch objects that are physically connected among themselves. A branch can include ppins, etch paths, shapes, and vias. The number of branches in
    a net varies as Allegro PCB Editor connects or disconnects parts of the net. A completely connected net consists of one and only one branch.
    发表于 2020-10-26 09:42 | 只看该作者
    来帮你顶一下
    謝謝你 昨日上 candence 網站去請教 已解決: To check a complete design check for all net->branches with more than 2 entries.So something like this:miss=length(setof(net axlDBGetDesign()->nets cadr(n  详情 回复 发表于 2020-10-29 09:58
    GMT+8, 2025-11-22 08:39 , Processed in 0.156250 second(s), 26 queries , Gzip On.
