查看: 1435|回复: 11
Matlab辅助激光光学分析与应用(2014年 第三版)
发表于 2020-10-12 09:51 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
Matlab辅助激光光学分析与应用(2014年 第三版)( m$ K% M2 L, K1 h2 a$ S* P* W1 x
8 ^. k0 q/ x* `  E& W  {目 录
1 M8 }% n0 ?1 l$ w' K' fMATLAB辅助激光光学分析与应用....................................................................................................I
$ u& {7 W/ G, Z& E  f6 vMATLAB辅助激光光学分析与应用...................................................................................................II
6 I6 s6 f% E+ Q. e' C作 者:刘良清..............................................................................................................................II8 t( A. j+ ]  e8 a6 \" A/ m: ?
第一章 光的波动性和衍射............................................................................................................... 1
1 k8 o8 r6 t' M- s3 ^1.1 MAXWELL方程组和电磁波........................................................................................................1
! q! D* i& v$ w' y3 |$ z1.2 波动方程.......................................................................................................................................4
- {7 d5 g9 F6 _7 j1.3 衍射...............................................................................................................................................58 b- Y- a% j) s
1.3.1 小孔衍射................................................................................................................................6
" b/ _  W+ u; t1.3.2 双缝衍射..............................................................................................................................14
8 I% t! ^6 U) [+ }7 B1.4 波前畸变.....................................................................................................................................17
" H: W- T* D' C6 u7 e1 i' ?( H1.4.1 Zernike多项式......................................................................................................................17
/ X6 V: H1 F1 l/ P  f3 y1.4.2 畸变光束的衍射..................................................................................................................20* l; l0 l( _7 Q& T; w% i
1.5 光束通过光学元件的变换.........................................................................................................24& r! a+ {5 ^1 `
1.5.1 平行光束通过透镜的聚焦..................................................................................................24
0 e! O$ F# J# t5 W- F5 P1.5.2 高斯光束通过透镜的聚焦..................................................................................................30
/ J- N& Q5 X8 [  U/ v, p4 O1.5.3 自聚焦透镜..........................................................................................................................32
+ O2 y: N8 V' L, X  y1.6 高斯光束.....................................................................................................................................36
, s2 K% x7 H9 |& V  u+ g1.6.1 高阶高斯光束......................................................................................................................36
4 O8 U/ ^8 a( p5 F5 ~1.6.2 高斯光束的传输变换..........................................................................................................412 J9 S5 h. d: Q
1.6.3 高斯光束的干涉..................................................................................................................458 p$ {* V5 c) w' y1 i' b
第二章 激光谐振腔......................................................................................................................... 60
, a9 }7 _" g! o2.1 激光谐振腔的本征方程.............................................................................................................60
9 C2 G  c- S8 w9 ~4 _7 I2.2 无源腔的FOX-LI迭代方法.......................................................................................................60" E0 Q* U- R7 o/ C! l* X6 ]4 T( ~# r. h
2.3 无源腔的矩阵特征向量方法.....................................................................................................66$ K& U3 _0 E& G' c( `- t5 i. Q! [
2.3.1 平行平面腔..........................................................................................................................67- G7 Z& D/ a# L: n( V. Q: d2 X  {
2.3.2 双凹腔..................................................................................................................................71
" N. _- B  ?' e& \7 V# I1 }2.4 基模谐振腔.................................................................................................................................78- x- n( n( D( i: B# g; s% D
2.4.1 高斯光束的ABCD定律与谐振腔.......................................................................................804 b* n- h, ~4 Y
2.4.2 基模谐振腔的稳定性..........................................................................................................91
( o; n$ a% ]9 U; p# r, U+ R2.4.3 基模谐振腔设计实例..........................................................................................................97  {8 T0 P' I- v/ V3 h
2.4.4 基模谐振腔设计的逆向方法............................................................................................107! t9 H" N, O" M/ N
第三章 激光工程设计................................................................................................................... 118. P1 L6 Q! H0 R$ R  i' W
3.1 速率方程的求解....................................................................................................................... 1186 H, T7 D# W9 y# \
3.1.1 主动调Q速率方程的求解................................................................................................. 118" z, l- t7 L8 }2 t$ B
3.1.2 被动调Q速率方程的求解.................................................................................................125! A3 I' w. n7 o" L0 ~2 x5 s: p
3.1.3 脉冲泵浦速率方程的求解................................................................................................132) \0 u# I& N! }$ z+ d. Y  Z
3.2 非线性激光光学.......................................................................................................................136( k' o7 j& s1 Z1 W! \/ Q3 N! z& H
3.2.1 非线性晶体........................................................................................................................136
* v$ R" a5 |8 s, V3.2.2 非线性晶体相位匹配........................................................................................................1613 ^  U% G/ e: I& h1 z
第四章 MATLAB数据与图像处理............................................................................................... 1718 G8 E1 G8 d0 f
4.1 MATLAB图像处理应用...........................................................................................................171
; C. Z: c: W$ {4.1.1 自制特殊图形....................................................................................................................171
3 F+ I: ^) h; N1 q( [. E$ @4.1.2 图像数据处理....................................................................................................................179
" \' g  R) F6 G, R: c4.2 MATLAB数据处理应用...........................................................................................................197
4 N% ?) I, c: `0 B$ O- b( q4.2.1 批量数据处理....................................................................................................................197
- X& \$ P$ G1 K' x7 ~# c3 Y4.3 MATLAB方程求解应用...........................................................................................................211: v2 d- e7 a2 E6 ]! Z
4.3.1 含参数非线性方程组的求解.............................................................................................211
5 ]8 t4 I( B) z' L
游客,如果您要查看本帖隐藏内容请回复
参与人数 1威望 +1 收起 理由
grand + 1
发表于 2021-11-17 16:39 | 只看该作者
年烦烦烦烦烦烦烦烦烦烦烦烦烦烦烦烦烦烦
1 R5 q- g/ C0 i
发表于 2021-10-6 14:14 | 只看该作者
谢谢楼主分享
发表于 2021-10-5 22:32 | 只看该作者
thxxxxxxxxxx1 Z. u" }# G1 i* |$ m, E! \
    难过
    2021-4-9 15:31
    发表于 2021-7-13 14:40 | 只看该作者
    感謝大大無私分享
    发表于 2021-7-13 03:03 | 只看该作者
    谢谢 学习学习
    发表于 2021-6-16 22:15 | 只看该作者
    多谢,值得一看
    发表于 2021-6-7 12:09 | 只看该作者
    Matlab辅助激光光学分析与应用(2014年 第三版) [[url=]修改[/url]
    ) u: _" D, q! N  V
    发表于 2021-5-20 14:23 | 只看该作者
    谢谢分享,非常需要,感谢楼主
    发表于 2020-10-12 15:09 | 只看该作者
    谢谢楼主分享!!!!4 u& [. J) r% F0 {6 [
    发表于 2020-10-12 11:25 | 只看该作者
    Matlab辅助激光光学分析与应用,收藏了。
    GMT+8, 2025-11-23 19:32 , Processed in 0.187500 second(s), 29 queries , Gzip On.
