查看: 502|回复: 3
GUI 表格增删报错???求助
发表于 2020-9-18 18:35 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
function one4_OpeningFcn(hObject, eventdata, handles, varargin)9 E* C4 w. X# g& p$ T
% This function has no output args, see OutputFcn.
- g1 c; _# F4 K  Y% hObject    handle to figure
+ S$ F6 L. b7 r3 b+ A% eventdata  reserved - to be defined in a future version of MATLAB
4 H" ]! F# @2 A) p6 ~% handles    structure with handles and user data (see GUIDATA)/ K4 F, }7 d% T2 ^  t
% varargin   command line arguments to one4 (see VARARGIN)
" Z9 Z$ F: Z! u/ G8 s3 Nload('newdata.mat');8 D( n5 O9 i) W1 f/ H0 y
set(handles.uitable1,'Data',newdata);) ?7 O, A% h$ V9 j/ `( f
% Choose default command line output for one46 V: K! k3 T* r7 F5 ^* t
handles.output = hObject;
! r2 o+ I. Y4 ?: C8 }# ^) |) j1 C8 o* C1 _8 m! a# T% d8 G
% Update handles structure& o* t3 j3 H$ c9 U' v/ M+ y# Y
guidata(hObject, handles);5 p7 N. w- U3 P0 O
! W( O8 Y( p0 N+ P: \( E5 {
% UIWAIT makes one4 wait for user response (see UIRESUME); ~1 W0 h- q: l* {3 w
% uiwait(handles.figure1);+ G) a, I' c# t: G' B" `
4 E" u9 P3 y6 {
% j% {8 t$ u, b9 V8 t! e/ P1 x8 f% --- Outputs from this function are returned to the command line.
+ ?0 w  Q, C' \% Rfunction varargout = one4_OutputFcn(hObject, eventdata, handles)
5 q$ J9 I' F, T6 \0 z' f+ ]( F% varargout  cell array for returning output args (see VARARGOUT);
# J6 K/ {; ^# b& ], W' J- `% hObject    handle to figure/ k5 W# v; C1 \$ E' j
/ V$ p8 e8 J0 }0 u* M% handles    structure with handles and user data (see GUIDATA)
9 {2 V0 I. s4 ~* I3 p3 F. I' m7 N2 k. V5 I7 r+ M8 i% e; L1 z
% Get default command line output from handles structure( n- F0 W; P* R& l3 U3 T9 I
代码5 G) d  Y5 O8 f- |( D+ u7 U% b
varargout{1} = handles.output;
+ ~$ s! D# `. [% G! i7 R* y  d$ e1 x6 `& D9 j
4 r+ w# Q  F& R; {; H4 X4 n9 R; p3 I% --- Executes on button press in pb1.
% E! y7 t0 w% `" Rfunction pb1_Callback(hObject, eventdata, handles)
- R1 _) X# X/ A8 i. R4 e2 V$ B% hObject    handle to pb1 (see GCBO)
' Z" h0 w( V5 b) w% eventdata  reserved - to be defined in a future version of MATLAB
! v" b* a5 X) U& X4 u( I3 A7 x! \% handles    structure with handles and user data (see GUIDATA)
* ]6 c2 T& I2 G3 |tab=inputdlg({"基本尺寸","公差等级","上偏差","下偏差",},"减环基本值");0 l* V/ q8 @' V
newrow1=str2num(tab{1});' q/ X- A7 @- f. w
newrow2=str2num(tab{2});) k5 Z1 L2 J. Q* o
newrow3=str2num(tab{3});
' Q( ]: y  m7 z7 L) ?  unewrow4=str2num(tab{4});
% j/ m4 L9 a3 I# S5 S: p9 {0 xnewarray={newrow1,newrow2,newrow3,newrow4};
$ m( c4 B% @  g! d' Polddata=get(handles.uitable1,'Data');( k6 {, q2 \9 ^/ w3 ^* p
newdata=[olddata,newarray];6 {7 S7 a) h: k: Y, J
set(handles.uitable1,'Data',newdata);+ R* k& t" V2 ?! Y
handles.tabale=newdata;/ Y  z  Y4 r' {0 b) B( `+ T8 o  u4 J
save('newdata.mat','newData');& d$ J- f9 X; m8 K+ |* G( e
错误信息
2 ^$ E/ f1 m6 S( G0 u
* K0 O. P, C. G2 @& ~错误使用 inputdlg (line 108)
# j6 i, ?1 r9 v( F  G4 ~1 ?NumLines 大小错误。& J1 p: K. ^- Z7 T6 w
1 j. ]0 d4 x& J1 A$ c9 G* v出错 o3>add1_Callback (line 108)
: \! f" S" ?: etab=inputdlg(prompt,title,lines);4 ]( ?5 g% ?  A! G3 n
- T2 ?; ]8 o1 Z7 A- @出错 gui_maiNFCn (line 95), z) i% M0 n! I/ ]! Z
        feval(varargin{:});
6 p9 p: f" v6 Y' _5 x7 F7 _. k0 |9 K! l
出错 o3 (line 42)
+ A$ H; e% U$ a, I    gui_mainfcn(gui_State, varargin{:});
& F% K' H3 [) I' }: u4 E2 r$ K8 ~! v+ T
出错) o3 {' K6 h% L, Y# D7 S  a) e$ ~
matlab.graphics.internal.figfile.FigFile/read>@(hObject,eventdata)o3('add1_Callback',hObject,eventdata,guidata(hObject))
  Y  C4 k9 |; M. K7 k' \7 S$ [( r' V计算 UIControl Callback 时出错。1 A' i1 T+ x6 y
发表于 2020-9-18 19:15 | 只看该作者
不是应该help吗
发表于 2020-9-18 19:14 | 只看该作者
看来是大神啊
    慵懒
    2020-6-13 15:46
    发表于 2020-9-18 19:05 | 只看该作者
    路过,看一下
    GMT+8, 2025-11-24 11:52 , Processed in 0.171875 second(s), 24 queries , Gzip On.
