TA的每日心情 | 开心 2021-5-25 15:04 |
签到天数: 37 天 [LV.5]常住居民I
偶是第一次 capture,生成网络表的时候的时候出现如下错误0 w2 |& j2 B* |
E:\CANDENCE\练习\allegro% `2 |( U: q8 ~8 p: a3 ?% I6 d4 o
Configuration File:
2 U$ A5 O& o1 G1 ~C:\cadence\SPB_15.5\tools\capture\allegro.cfg
9 U) L! y+ V( Q) ?$ |Spawning... "C:\Cadence\SPB_15.5\tools\capture\pstswp.exe" -pst -d "E:\candence\练习\2440mornitoring.dsn" -n "E:\CANDENCE\练习\ALLEGRO" -c "C:\Cadence\SPB_15.5\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
, p; W I7 k4 X! e5 l+ j/ _#1 Warning [ALG0047] "No_connect" property on Pin "P1.8" ignored for P1: SCHEMATIC1, 13)URAT (7.90, 1.20). Connecting pin to net "N16811229".
, l$ k! @; Q- l1 t3 g0 j0 @#2 Warning [ALG0047] "No_connect" property on Pin "P2.7" ignored for P2: SCHEMATIC1, 13)URAT (7.90, 3.60). Connecting pin to net "N16811584".
3 G1 C' W9 r/ t) u+ j5 t#3 Warning [ALG0047] "No_connect" property on Pin "P1.7" ignored for P1: SCHEMATIC1, 13)URAT (7.90, 1.20). Connecting pin to net "N16811225".
6 e$ I0 N {, v4 \. T3 g#4 Warning [ALG0047] "No_connect" property on Pin "P2.8" ignored for P2: SCHEMATIC1, 13)URAT (7.90, 3.60). Connecting pin to net "N16811590".
( l2 n9 U! k2 I8 e0 j#5 Warning [ALG0016] Part Name "CAP PN_C100UP-6.3V-SMT-S_100UF/6.3V" is renamed to "CAP PN_C100UP-6.3V-SMT-S_100UF/".
3 G% o3 ] M9 ~) u: _#6 Warning [ALG0016] Part Name "CAP PN_C100UP-6.3V-SMT-S_10UF/10V" is renamed to "CAP PN_C100UP-6.3V-SMT-S_10UF/1".
, e' J7 ^* c5 n: M+ ?) _#7 Warning [ALG0016] Part Name "CAP PN_C100UP-6.3V-SMT-S_100U/6.3V" is renamed to "CAP PN_C100UP-6.3V-SMT-S_100U/6".: R" ]4 C+ r7 n& w
#8 Warning [ALG0016] Part Name "CAP PN_C100UP-6.3V-SMT-S_220UF/4V" is renamed to "CAP PN_C100UP-6.
3 q* @% x. m) S) R: m1 X3V-SMT-S_220UF/".
) l5 B! H# \9 n6 x/ {#9 Warning [ALG0016] Part Name "SINGLE_PORTS_COMBO_0_RJ-45B_HR901103A" is renamed to "SINGLE_PORTS_COMBO_0_RJ-45B_HR9".2 i+ H4 y& R. W; p
#10 Warning [ALG0016] Part Name "UCDRAGON LCD CONNECTOR_0_SIDC50_IDC50-2.00MM" is renamed to "UCDRAGON LCD CONNECTOR_0_SIDC50".
" \# U9 K8 E! n1 W1 `. s#11 Warning [ALG0016] Part Name "CON IDE44-2MM_0_SIDC44_IDC44-2MM" is renamed to "CON IDE44-2MM_0_SIDC44_IDC44-2M".' c f9 f# a/ f8 L
#12 Warning [ALG0016] Part Name "CON_USB_B_0_USB-B2_USB_HOST_PORT" is renamed to "CON_USB_B_0_USB-B2_USB_HOST_POR".
/ U0 F! u6 \8 B#13 Warning [ALG0016] Part Name "USBPORT_1_USB-B1_USB_DEVICE_PORT" is renamed to "USBPORT_1_USB-B1_USB_DEVICE_POR"." O0 r' n5 m3 N; K8 d( V/ U
#14 Warning [ALG0016] Part Name "IDC20 MULTI-ICE_0_20PIN2_IDC20-2.54MM" is renamed to "IDC20 MULTI-ICE_0_20PIN2_IDC20-".
0 q& k. _# b9 y% p7 x#15 Warning [ALG0016] Part Name "DIODE SCHOTTKY_1_MBRS340_MBRS340" is renamed to "DIODE SCHOTTKY_1_MBRS340_MBRS34".2 B) w3 }. P' f
#16 Warning [ALG0016] Part Name "HEADER 20_0_SIDC20_CAMERA_EXTEND" is renamed to "HEADER 20_0_SIDC20_CAMERA_EXTEN".
* }+ p( N+ ^0 I1 J#17 Warning [ALG0016] Part Name "PHONEJACK STERE1 _& X: R+ z! J5 W7 a
O SW_EARPHONE2_MICROPHONE_CN" is renamed to "PHONEJACK STEREO SW_EARPHONE2_M". A# {2 V( y% t$ r
#18 Warning [ALG0016] Part Name "PHONEJACK STEREO SW_EARPHONE2_EARJACK" is renamed to "PHONEJACK STEREO SW_EARPHONE2_E".6 v( [3 o% l! B8 M1 N- [* f
#19 Warning [ALG0016] Part Name "MAX232_1_MAX3232ESA-SO16_MAX3232C" is renamed to "MAX232_1_MAX3232ESA-SO16_MAX323".
- k6 @+ s+ `5 i# R#20 Warning [ALG0016] Part Name "IRMS6452 VISHAY_IRMS6452_IRMS6452" is renamed to "IRMS6452 VISHAY_IRMS6452_IRMS64".
. z4 T s F+ D$ t/ Y& E# Y' h#21 Warning [ALG0016] Part Name "DM9000A LQFP48_0_DM9161E-QFP48_DM9000AE" is renamed to "DM9000A LQFP48_0_DM9161E-QFP48_".# o5 V& [1 Z/ g
#22 Warning [ALG0016] Part Name "74ALVC164245_8_TSSOP48_74LVCH162245" is renamed to "74ALVC164245_8_TSSOP48_74LVCH16".( W9 }# C1 `3 A- c2 K5 D g( j# Q
#23 Warning [ALG0016] Part Name "74ALVC164245_1_74LVTH162245-TSSOP48_74LVCH162245" is renamed to "74ALVC164245_1_74LVTH162245-TSS".3 V k7 ?( g6 M+ v; A9 C
#24 Warning [ALG0016] Part Name "MIC5207BM5_MIC_LDO_5_MIC5207-2.5BM5" is renamed to "MIC5207BM5_MIC_LDO_5_MIC5207-2.".
& | K2 U0 ^' c# ]4 G: F#25 Warning [ALG0016] Part Name "MIC5207BM5_MIC_LDO_5_MIC5207-1.8BM5" is renamed to "MIC5
2 O. W) }) b; i# x0 Q207BM5_MIC_LDO_5_MIC5207-1.".0 ^3 P x2 z5 t( m* ]! m
#26 Warning [ALG0016] Part Name "UDA1341TS_UDA1341TS-SSOP28_UDA1341TS" is renamed to "UDA1341TS_UDA1341TS-SSOP28_UDA1".
4 j5 H( P! J" v% L2 n: h#27 Warning [ALG0016] Part Name "LP3965ES-ADJ_0_TO263-5_MIC29152BU" is renamed to "LP3965ES-ADJ_0_TO263-5_MIC29152".; U9 S3 p5 u" I0 I5 t6 X. F
#28 Warning [ALG0016] Part Name "74ALVC164245_8_74LVTH162245-TSSOP48_74LVCH162245" is renamed to "74ALVC164245_8_74LVTH162245-TSS".
# g8 R' T9 X8 p6 {#29 Warning [ALG0016] Part Name "EZ1117X/SOT223_0_LD-2.5V-SOT23_LM1117-ADJ" is renamed to "EZ1117X/SOT223_0_LD-2.5V-SOT23_".5 }# |2 z7 V5 _
#30 Warning [ALG0016] Part Name "K4S561632C_0_K4S561632E-TSOP54_K4S561632C-TC75 (32MB)" is renamed to "K4S561632C_0_K4S561632E-TSOP54_".2 b) h$ ~4 x- M2 I' T
#31 Warning [ALG0016] Part Name "K9F2808/1208_0_SST39VF1601-TSOP48A_K9F2808/5608/1208" is renamed to "K9F2808/1208_0_SST39VF1601-TSOP".$ o7 R" V( _) p! `7 b! k2 W( k
#32 Warning [ALG0016] Part Name "XTAL-SMD2_XTAL_HC49SMT_25.000MHZ" is renamed to "XTAL-SMD2_XTAL_HC49SMT_25.000MH".
! B n+ o. i" s& KScanning netlist files ...6 L0 V0 I* l+ b0 N) L
Loading... E:\CANDENCE\练习\ALLEGRO/pstchip.dat& c! V! |# N7 s2 t
Loading... E:\CANDENCE\练1 \. I0 e+ X, @6 G# X
癨ALLEGRO/pstchip.dat
$ L! I6 e) z1 tLoading... E" q/ Y" }/ z! ^$ {
:\CANDENCE\练习\ALLEGRO/pstxprt.dat# J) \, e. ?& I" F4 n! P' g
Loading... E:\CANDENCE\练习\ALLEGRO/pstxnet.dat8 D: p# E% l/ q4 f" p
Error: Line 443 in file E:\CANDENCE\练习\ALLEGRO/pstxnet.dat:
; t- O7 Y, U. W* g Could not create new pin inst <logicalPinName> , S" b/ l* ^8 D& k2 T# a
Detected in function: pstReadNodeSec 3 c, O7 p$ ~2 l: i
Error: Line 443 in file E:\CANDENCE\练习\ALLEGRO/pstxnet.dat:6 c# A8 T( N2 n4 V$ h+ z
Error loading the net list file
- d3 u5 m$ } |) z$ O+ { Detected in function: ddbLoadPstXFiles
" T- q) s- E5 {* e" R7 f5 O2 \#33 Error [ALG0036] Unable to read logical netlist data.
2 n6 G, D3 E. }0 fExiting... "C:\Cadence\SPB_15.5\tools\capture\pstswp.exe" -pst -d "E:\candence\练习\2440mornitoring.dsn" -n "E:\CANDENCE\练习\ALLEGRO" -c "C:\Cadence\SPB_15.5\tools\capture\allegro.cfg |
