代码如下:; }. _/ ]6 j+ O9 L# n
clear all;
8 W* u: H2 d: V Gclc;
, G* Y6 Y" @. m' g) M" zrandn('state',0);
9 R% Q5 q. {( ^6 Nrand('state',0);, u" l0 v, e# N* f9 t5 A, E
dt = 0.005;
1 ~2 x3 n1 H% t6 P1 c; HJ = 1000000;
, {: C* M+ f. P5 xfor h = 1:100+ J. z2 J6 I7 g9 i I! C4 V
x = normrnd(43.68,39.85,[1,J]);%设定分布:正态分布,Avoided fertilizers application
8 v! O7 O3 S% K7 n5 O6 k" c x1 = find(x>0);
T' G2 ?" h1 I$ p8 m& ~ x2 = x(x1);
- C" ~8 P' v# {: \' h$ P4 p5 w$ | X(h, = x2;# w( W$ C. [. p2 y1 X
A(h, = mean(X(h, );1 W1 a; B$ c" C" Q' {8 w1 ^( [
B(h,:) = std(X(h,:));
0 H3 Y; g9 Y5 I$ H( z5 l+ f y1 = X(:);5 {$ G. @; @" N5 t3 D# a
Y1 = sort(y1);
& u; y- n& t2 { W = length(x1);3 m) }% c0 c0 a& S+ Q9 e( O( L
if rem(W,2)==0. V8 ]; I6 z ?1 G8 J, Z
W1 = W;
7 i2 t t4 x0 h# S else. _) N% T% @& F
W1 = W+1;
/ @+ [, w9 ]- z5 }" Y& w( ~. u9 | end
9 h, H1 i9 w& H r" s; j/ E for r = 1:W1 * 5/100
8 V5 @# Z. z0 }6 q k9 z* a W2(:,r) = X(W1 * 95/100 + r) - X(r);
# r- Z3 f @( I6 H* Q6 c end; R( |8 w7 R+ k& O e4 W1 P
n1 = find(W2 == min(W2));
3 O- D5 o8 Y6 r4 Q C(h,:) = Y1(n1);2 c2 D; ]) Y8 v" H
D(h,:) = Y1(J * 95/100 + n1);
4 k* p; X, I, k/ Y if h > 1$ ?6 E1 ]6 F! f% S3 A, q7 x
A1 = 2 * std(A)/sqrt(h);7 v; h H& t1 ~+ K+ F5 ]
B1 = 2 * std(B)/sqrt(h);
0 I) C7 @8 F6 p C" W% j C1 = 2 * std(C)/sqrt(h);
/ t, L5 [& u3 [ \5 g D1 = 2 * std(D)/sqrt(h);4 s' w6 ?' U+ Y- i: ?* E2 k3 e9 y# J
if (A1<=dt&B1<=dt&C1<=dt&D1<=dt) == 1
9 x# v6 @/ Y, {' @ break
& ~) D" W+ E: U9 A( x, |! ` end
) @: M4 c9 [ x2 D* {( c end' F4 y& I) Y! h; z
end7 k* [- P) s$ s& p5 A
4 z" A) y" R8 \$ T
1 A* U3 t" J3 @# t* S" D4 `, D _/ S/ m+ G5 o
; y: d f8 c9 c6 V; Z! |
/ U, r4 a" C. Q1 U3 |( }上述代码运行后出现“下标索引必须为正整数类型或逻辑类型。” 为什么
; W$ A* d6 W: |8 C! J0 R |
