请各位大侠帮我看一下这个ibis模型怎么了,这是我从TI官网上下载的,在编译的时候报错:
4 Y- m4 a% Q* @5 }ERROR - Model Model67: The [Rising Waveform]
$ j2 x, o7 n |8 T2 t# R with [R_fixture]=50 Ohms and [V_fixture]=0V
: O( M9 A! n0 p: W( t has TYP column DC endpoints of 0.00V and 1.19v, but
& W: y1 ~! ~+ a" C* ^' ^ an equivalent load applied to the model's I-V tables yields+ A) e5 Y' F; K" X. B
different voltages ( 0.00V and 0.98V),
# S* H% ~) t; I* s, ] a difference of 0.00% and 21.94%, respectively.) g/ u# a9 l9 D7 T, b9 @
ERROR - Model Model67: The [Falling Waveform] ( j! E7 h% Q9 y
with [R_fixture]=50 Ohms and [V_fixture]=1.8V* l" S8 [. l* o2 l4 a
has TYP column DC endpoints of 0.63V and 1.80v, but
' B, d3 ~0 F! {4 q: t; Y2 \! ? an equivalent load applied to the model's I-V tables yields
: n* z9 r, n) n1 ~! t different voltages ( 0.88V and 1.80V),
) Q- a% ^3 N$ B+ r. F! f' Y3 H; K a difference of 27.06% and 0.00%, respectively.+ z/ p. A2 V" r. S
WARNING - Model Model67 Pulldown Minimum data is non-monotonic: Z2 f7 Q5 s) A4 w
WARNING - Model Model67 Pullup Maximum data is non-monotonic9 a# \1 B: B3 P1 M
ERROR - Model Model67: The [Rising Waveform] ! K0 {2 M. ~$ x q0 H7 a! ], F' @) Y
with [R_fixture]=50 Ohms and [V_fixture_max]=0V
" W$ t" ~+ J6 L has MAX column DC endpoints of 0.00V and 1.38v, but
2 J/ O, L) N+ @( C, V an equivalent load applied to the model's I-V tables yields
! ?5 C) o* _; |0 V& }) d different voltages ( 0.00V and 1.15V),7 \2 @+ j/ h: G# r; k9 o2 ^7 h3 B
a difference of 0.00% and 20.19%, respectively.
% S- u2 z0 H7 vERROR - Model Model67: The [Falling Waveform] % B2 q# a4 j4 ?0 o1 ^- y) C
with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V
# `+ H3 \- {! M i has MAX column DC endpoints of 0.53V and 1.89v, but
1 g- i# Q; l- K! v' w U an equivalent load applied to the model's I-V tables yields3 ~' {5 c( i) }
different voltages ( 0.84V and 1.89V),
" j7 Q0 V* B; b5 j8 {) z a difference of 29.38% and 0.00%, respectively.7 W% e3 c4 ?8 T2 T9 z* @( j2 W5 D) W
: b1 E4 O* I7 N' @$ B9 e' W哪位大侠知道的帮帮忙啊,不知道的也帮我分析分析吧。
I( {& u6 w3 {9 X3 W% G我这有一段解释:This happens because the function acdc_VI_Given_VIC_VR() in acdc.c improperly
* G/ e5 c" M8 R) J2 ^reports the I-V/V-t intersection whenever it lies above the highest voltage in , E/ n! U* N5 h$ Y
the I-V characteristic. This defect is likely to show itself in models lacking1 ?$ b1 E& K( `; l* R
clamp tables and in which either the [Pullup] or [Pulldown] table does not cover
, U+ [$ L2 x! F0 [+ v& f$ \: W" x7 p1 q9 Qthe range from -Vcc to 2*Vcc. Any open drain or open source model which lacks
9 N, P7 E& _ Mclamp tables is likely to meet these conditions because it is likely to lack 7 @. S/ p, n4 ~0 t$ h
either the [Pullup] or [Pulldown] table. In this test case, IBISCHK generates / q0 d" O# r" G
error messages only for the MIN data because the highest voltage in the high-, k1 n# E+ l' ?- R1 `6 S
state I-V characteristic for the minimum corner lies below the 1.8 V V-T / e. G/ h% n# l1 e) G
operating voltage.
5 i' w' N g: T: M8 L3 C+ V! b4 A/ k$ e; l+ T( r# `
但是缺少该怎么做啊 |
