查看: 2674|回复: 27
[allegro15.5][4层] 电脑主板(FPGA+DDR+USB)原理图和pcb文件
发表于 2020-5-28 18:32 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
3 f8 Y  h/ V, k5 w# u# G) f# _. P. m[allegro15.5][4层] 电脑主板(FPGA+DDR+USB)原理图和pcb文件) }. Q5 t, y. b% @
. f" c; P/ t- R% |文件描述:* U5 z$ o+ B# i* d( k2 `$ `
- q: S2 j2 n# }
1. 作品用途:电脑主板
! O3 P8 D0 o1 z) M! X2. 软件版本:allegro15.5
/ K5 j* \* p4 x3. 层数:4层
+ H" K; R: s: g! J( I4. 用到的主要芯片:FPGA+DDR+USB
0 y1 b: E- C3 q  U5. pcb尺寸:9600*7480 MIL
  y# ~8 D4 T: G! |) L9 O5 @4 q( I; V: `0 U7 a
作品截图如下:
5 B4 L/ N% L, y: h
2 t4 V$ r* a( ]# N/ b4 h顶层截图:* n; b  G5 @: D4 G5 b( s
5 R: X/ ^  F' B% d0 s7 M底层截图:2 N  U5 i. |+ u/ z  |- d
; l# c% p" t, J, d
' f5 d5 H9 G$ E1 i8 H* K. X全层截图:: I" a/ w* @, J$ p0 `$ h
" z5 I* v: k+ n3 R
+ s: G5 w) x# ?: Y4 E
2 q3 J$ b) Q; E% {6 b3 PBOM:5 G: J- F. L5 m- X
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
8P4R_06038P4R_0603DISCRETE4RN16; RN28; RN31; RN32
ATXPWR_24PATXPWR_24PIO1ATXPWR
AUDIO_CODECAUDIO_CODECIC1AUDIO
BAT_2PBAT_2PIC1BAT
BGA652_FANBGA652_FANICH7/[10HB1-032801-M1R]IC1U3
BGA1226BGA1226IC1U2
C0402C0402IC138AC39; C26; C27; C28; C32; C37; C39; C43; C58; C61; C62; C65; C73; C74; C75; C79; C80; C83; C84; C85; C89; C95; C103; C104; C105; C108; C109; C113; C117; C118; C119; C121; C123; C124; C125; C126; C127; C128; C129; C134; C135; C136; C137; C138; C147; C148; C149; C154; C155; C156; C157; C158; C167; C168; C169; C217; C218; C219; C220; C221; C222; C224; C246; C247; C251; C252; C253; C254; C255; C256; C257; C259; C260; C261; C268; C270; C273; C274; C275; C276; C280; C292; C294; C295; C307; C308; C309; C311; C313; C314; C315; C316; C317; C320; C322; C323; C324; C325; C326; C328; C329; C330; C331; C333; C335; C336; C337; C338; C340; C349; C350; C368; C371; C373; C374; C376; C377; C385; C387; C388; C389; C390; C391; C405; C414; C417; C418; C458; C459; CB5; CB7; CB9; LC4; SC1; SC2; SC3; SC4; SC11
C0603C06030.01UFIC213BC1; C17; C18; C19; C20; C29; C31; C33; C34; C35; C36; C38; C41; C42; C44; C45; C46; C47; C50; C51; C52; C53; C54; C55; C56; C57; C59; C60; C63; C64; C66; C67; C68; C70; C71; C72; C78; C82; C87; C94; C96; C98; C99; C100; C101; C102; C106; C107; C120; C122; C141; C142; C143; C144; C161; C162; C163; C164; C171; C172; C173; C174; C175; C176; C177; C178; C179; C180; C181; C182; C183; C184; C185; C186; C187; C188; C189; C190; C191; C192; C193; C194; C195; C196; C197; C198; C199; C200; C201; C202; C206; C207; C208; C209; C210; C211; C212; C213; C214; C216; C223; C225; C226; C227; C228; C229; C230; C231; C232; C233; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C245; C248; C249; C250; C262; C264; C265; C266; C267; C272; C277; C281; C284; C285; C288; C289; C290; C291; C293; C302; C303; C310; C312; C327; C332; C334; C339; C341; C342; C343; C344; C345; C348; C361; C362; C367; C369; C370; C375; C378; C379; C380; C383; C384; C406; C410; C411; C412; C413; C415; C416; C419; C420; C424; C446; C456; C460; C735; CB1; CB2; CB3; CB4; CB6; CB8; CB60; CB61; CB62; CB63; CB67; CB70; CB71; CB72; CB73; CB74; LC5; LC6; LC15; LC16; LC18; LC19; PC34; PC35; SC8; SC10; SC12; SC13; SC14; SC15; SC17; SC18; SC20; SC21
C0805C08054.7UFIC22C40; C48; C49; C81; C86; C88; C90; C91; C92; C93; C97; C110; C111; C112; C114; C115; C215; C269; C372; C382; C393; CB287
C1206C120610UFIC14C1; C2; C3; C4; C5; C6; C7; C9; C10; C11; C30; C76; C77; SC22
CAP6D3X7CAP6D3X7IC7CE8; CE23; CE26; CE34; CE38; CE55; CE57
CAP8X9CAP8X9DISCRETE6PCE1; PCE2; PCE3; PCE4; PCE5; PCE6
CAP8X12CAP8X121000UFIC24CE1; CE3; CE7; CE10; CE11; CE12; CE13; CE14; CE15; CE16; CE17; CE18; CE19; CE20; CE21; CE22; CE24; CE25; CE28; CE30; CE31; CE32; CE33; CE52
CAP10X20CAP10X20DISCRETE3PCE14; PCE15; PCE16
CAPN_300CAPN_3001000PFIC1LHC1
COIL_334COIL_334IC5L8; L10; L23; L24; L25
COMCOMIC1COM
DB15M_VGADB15M_VGADISCRETE1VGA
DB25M_LPTDB25M_LPTIC1LPT
DDR2DDR2IC2DIMM1; DIMM2
DIP8_300DIP8_300IC1U14
DLL34DLL34IC1D10
DRILL_150_PAD_300DRILL_150_PAD_300IC5MH7; MH9; MH10; MH11; MH12
DTRAN12_100_300DTRAN12_100_300IC1LT1
FAN3PFAN3PIC1SYS_FAN
FAN4PFAN4PLGA775_FANIC1CPU_FAN
FB0603FB0603DISCRETE9FB20; FB21; FB22; FB28; FB29; FB30; FB31; FB32; FB33
FB0805FB08051UHIC17FB1; FB2; FB3; FB4; FB5; FB6; FB7; FB8; FB9; FB10; FB12; FB13; FB40; FB58; L4; L6; L11
FB1206FB120610UHIC3L1; L2; L3
FLOPPY_34PFLOPPY_34PDISCRETE1FDD
FMARKCFMARKCIC6FD1; FD2; FD3; FD4; FD5; FD6
H2X5_USBH2X5_USBIO1JUSB
H2X8_PANELH2X8_PANELIC1F_PANEL
IDE40P_2D54IDE40P_2D54IC1IDE
IND7D5_10IND7D5_10IC3L7; L9; PL4
J2J210K,5%IC1SRT1
J3J3IC2CLR_CMOS; KB_PWR
L0805L080510UHIC1L5
L1210L1210IC1R500
LGA775DIPLGA775DIPIC1U1
PCI164APCI164APCI-E/16X-164P/BK/RIGHT PUSHIC1PCIE_16X
PCISLOT_120PPCISLOT_120PDISCRETE2PCI1; PCI2
PIN2X5_2D54_NC8PIN2X5_2D54_NC8IC1F_AUDIO
PS2_KBPS2_KBIC1PS/2
PWR_4PPWR_4PIO1ATX12V
QFNS48_0D5_1GQFNS48_0D5_1GISL6312CRIC1U10
QFNS64_0D5_1GQFNS64_0D5_1GRTL8111B/8111C/8101EIC1U13
QFPR128_0D5_3D3QFPR128_0D5_3D3IC1U11
QFPS48_0D5_1D6QFPS48_0D5_1D6ALC880IC1AU2
R0603R06031.69K,1%IC497AR27; LR5; LR6; LR9; LR10; LR11; LR12; LR13; LR14; LR15; LR16; LR17; LR18; LR22; LR23; PR43; PR44; PR45; PR46; PR47; PR48; R1; R2; R3; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R17; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R46; R47; R48; R49; R50; R52; R53; R54; R55; R56; R57; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R87; R88; R89; R90; R91; R92; R93; R94; R95; R96; R99; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137; R138; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R157; R158; R159; R160; R161; R162; R163; R164; R165; R166; R167; R168; R169; R170; R171; R172; R173; R174; R175; R176; R177; R178; R179; R180; R181; R182; R183; R184; R185; R186; R187; R188; R189; R190; R191; R193; R195; R196; R198; R199; R200; R201; R202; R203; R204; R205; R209; R210; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R231; R232; R233; R234; R235; R236; R237; R238; R239; R240; R241; R242; R243; R244; R245; R246; R247; R248; R249; R250; R251; R252; R253; R254; R255; R256; R257; R258; R259; R260; R261; R262; R263; R264; R265; R266; R267; R268; R269; R270; R272; R274; R275; R276; R277; R278; R279; R280; R281; R282; R283; R285; R286; R289; R290; R292; R293; R294; R295; R298; R299; R300; R301; R302; R303; R304; R305; R306; R307; R308; R309; R310; R311; R312; R313; R314; R315; R316; R317; R318; R319; R320; R321; R323; R324; R326; R327; R328; R329; R332; R333; R334; R335; R336; R337; R340; R341; R342; R343; R346; R347; R349; R350; R351; R353; R355; R356; R357; R358; R359; R360; R362; R363; R365; R367; R368; R369; R370; R371; R372; R373; R374; R375; R376; R377; R378; R379; R380; R381; R382; R383; R384; R385; R386; R387; R388; R389; R390; R391; R392; R399; R411; R412; R415; R418; R419; R420; R421; R422; R423; R424; R425; R426; R428; R429; R430; R431; R432; R433; R434; R435; R436; R437; R438; R439; R440; R441; R442; R443; R444; R445; R446; R447; R448; R449; R450; R451; R452; R453; R454; R455; R456; R457; R458; R459; R460; R464; R465; R466; R467; R468; R469; R470; R472; R473; R477; R479; R480; R481; R482; R483; R484; R485; R486; R487; R488; R489; R490; R491; R492; R493; R499; R502; R503; R504; R505; R506; R507; R508; R509; R510; R511; R512; R513; R514; R515; R516; R518; R519; R521; R522; R523; R524; R525; R526; R527; R528; R529; R530; R531; R556; R563; R566; R567; R568; R569; R570; R571; R572; R576; R577; R595; R596; R599; R1206; SR13; SR14; SR17; SR18; SR27; SR36; SR38; SR45; SR56; SR57
R0805R08050,5%IC23R192; R194; R197; R206; R207; R208; R211; R287; R291; R296; R338; R339; R344; R345; R348; R352; R354; R361; R364; R366; R501; R517; R520
R1206R12060,5%IC1R86
RA0603_8RA0603_82.7K,5%IC23RN2; RN7; RN8; RN9; RN10; RN12; RN13; RN15; RN17; RN18; RN19; RN20; RN21; RN22; RN23; RN24; RN25; RN26; RN33; RN34; RN35; RN36; SRN2
SATA_D_VSATA_D_VIC4SATA1; SATA2; SATA3; SATA4
SDMMELFSDMMELF1N4148IC5D2; D3; D4; D5; D7
SO8_50_150SO8_50_150IS93C46A-3GRLIIC4U5; U6; U9; U12
SO14_50_150SO14_50_150LM324IC2SU2; U8
SOP20_0D65_4D4SOP20_0D65_4D4IC1SU3
SOT23_123SOT23_123DISCRETE21D1; D6; D8; PQ10; PQ11; Q7; Q8; Q10; Q11; Q13; Q20; Q21; Q23; Q24; Q28; Q29; Q30; Q32; Q36; Q38; Q39
SOT223SOT223L1117IC1U7
SSOP56SSOP56ck410_cy28410/ics954101/rev:bIC1U4
TO252TO252AOD452IC16PQ1; PQ2; PQ3; PQ4; PQ5; PQ6; PQ7; PQ8; PQ9; Q14; Q15; Q16; Q18; Q19; Q22; Q25
TRAN24_50_490TRAN24_50_490H24102MKIC1LU3
USB8P_RUSB8P_RIC1USB
USB_RJ45LEDUSB_RJ45LEDIC1LAN_USB
VIAVIAVIAIC19VIA2; VIA3; VIA4; VIA5; VIA6; VIA7; VIA8; VIA9; VIA10; VIA11; VIA12; VIA13; VIA14; VIA15; VIA16; VIA17; VIA18; VIA19; VIA20
XD2XD214.318MHzIC2X3; Y1
XD4_RXD4_RIC1X1
附件:0 l6 q5 h2 w( g0 e( G5 e0 i
原理图和PCB文件如下:
5 n6 J7 H/ u3 p
游客,如果您要查看本帖隐藏内容请回复
+ Z& M1 F0 D! _
! b2 V0 F) m/ k# c) @
    2023-8-30 15:37
  • 签到天数: 30 天
    [LV.5]常住居民I
    发表于 2020-5-29 14:32 | 只看该作者
    学习学习
    : u0 {' U; c: `7 k" ^- X, C4 D
    发表于 2024-3-16 17:51 | 只看该作者
    学习学习
    发表于 2023-12-1 22:59 | 只看该作者
    Good! I wante to go download!
    & ?6 R  H3 |: k
    慵懒
    2025-11-26 15:02
  • 签到天数: 148 天
    [LV.7]常住居民III
    23#
    发表于 2024-3-24 21:53 | 只看该作者
    看上去,还不错啊.
    22#
    发表于 2024-3-21 16:12 | 只看该作者
    GANXIE LOUZHU FENGXIANG- X7 R0 h) Z6 q# G+ C8 f9 C" M  h3 e
    慵懒
    2025-11-26 15:02
  • 签到天数: 148 天
    [LV.7]常住居民III
    21#
    发表于 2024-3-20 17:31 | 只看该作者
    感谢楼主分享
    20#
    发表于 2024-3-20 09:40 | 只看该作者
    学习学习学
    7 i! a- H. T) L' A9 X3 [* E2 m9 T
    19#
    发表于 2024-3-19 19:19 | 只看该作者
    bu cuo,bu cuo..
    18#
    发表于 2023-12-14 11:28 | 只看该作者
    谢谢分享谢谢分享
    奋斗
    2025-11-25 15:27
  • 签到天数: 139 天
    [LV.7]常住居民III
    16#
    发表于 2021-11-25 00:04 | 只看该作者
    好东西,学习一下
    + ~! Z0 J( P% A8 ]- o
    2021-9-17 15:06
    15#
    发表于 2021-9-17 14:57 | 只看该作者
    谢谢分享,来学习一下
    ' D: X+ D5 r1 m9 y& n
    2025-11-25 15:06
  • 签到天数: 369 天
    [LV.9]以坛为家II
    14#
    发表于 2021-9-17 12:46 | 只看该作者
    学习一下,看看电脑主板
    发表于 2021-5-24 21:26 | 只看该作者
    多谢楼主无私分享3
    9 R- d" q; e. d3 {) `; ]
    郁闷
    2020-3-10 15:59
    发表于 2021-5-24 17:58 | 只看该作者
    好东东必须顶。
    GMT+8, 2025-11-26 23:33 , Processed in 0.203125 second(s), 30 queries , Gzip On.
