基本用法: legend({'str1','str2','strn'}); 高级用法1:指定legend显示的位置: legend({'str1','str2','strn'},1); legend({'str1','str2','strn'},2); legend({'str1','str2','strn'},'Location','SouthEast'); 可选的位置很多: North:Inside plot box near top/ H' N: Q0 |, q& f
South:Inside bottom1 s% Y* E1 Y& {. A
EastI:nside right
' v, x! w' Y/ R$ q( C8 D' vWest:Inside left
3 T; m L2 c7 C" L0 qNorthEast:Inside top right (default)
% B a$ ~# [+ H1 `NorthWest:Inside top left
& s- `( i" T* D6 [! X. ?. d9 KSouthEast:Inside bottom right' N( z; V- s- Y& o6 U
SouthWest:Inside bottom left
; T1 h2 R/ K' J. `# p- s1 o* I* @5 aNorthOutside:Outside plot box near top5 V2 V5 Y- I% X
SouthOutside:Outside bottom6 r* w2 c: |$ `# x& q
EastOutside:Outsideright( P) q( T' t6 p% h
WestOutside:Outside left: V/ k& O3 {% X& m7 ]8 B6 X, e
NorthEastOutside:Outside top right
5 g3 E5 y1 o1 q( A2 VNorthWestOutside:Outside top left
2 X) {2 l% H: @8 B5 @; H$ }SouthEastOutside:Outside bottom right* Z9 T) G" y: K* I0 Q- U
SouthWestOutside:Outside bottom left5 N, U! p5 M% x$ O6 T8 Z, {7 d$ N
Best:Least conflict with data in plot' C& o- N- j+ z
BestOutside:Least unused space outside plot 通常,用'Best‘比较不错 高级用法2:指定显示某几条曲线的legend: 方法1:复杂到吐血 例如你有25条曲线,想显示其中1,6,11,16,21的legend,则 for i = [2:5 7:10 12:15 17:20 22:25]' d1 }. @. Y8 w k; S1 J
set(get(get(H(i),'Annotation'),'LegendInformation'),'IconDisplayStyle','off');) q& x; E( b' I. {+ D1 E7 z
end
4 z7 r0 C: R l3 w/ M) M6 T% ~legend('1','6','11','16','21'); 方法2:简单到郁闷 H = plot(data);+ @! U; Z; a. w7 Z/ t
legend(H([1 6 11 16 21],'1,'6','11’,'16','21'); 高级用法3:legend横排 hl = legend(H([1 6 11 16 21],'1,'6','11’,'16','21');
1 ^1 A5 b6 u# x0 @set(hl,'Orientation','horizon') 高级用法4:不显示方框: hl = legend(H([1 6 11 16 21],'1,'6','11’,'16','21');! C' B# L; l1 W
set(hl,'Box','off'); 5 w0 T5 D7 q, @6 F6 C/ |
Y: U4 j' a* r
* e- I" v) f2 w5 L/ f |
