安装ansoftlink4.1后 , 原先allegro中的 FPM skill程序菜单不见了:
: K9 ^) C; x2 z7 }1 B原因:allegro的menupath 变量值被修改为:d:\Ansoft\integrate4/cdsmenus1635 V2 e0 o' y$ w% f$ l
在此目录下 编辑allegro.men文件 添加代码如下:$ \- h+ e7 k( T* N3 x
// FPM_BEGIN. d$ U5 I R- ?. S
POPUP "F&PM"
8 J' T- Z5 d! }6 LBEGIN& Q' ?( s3 m9 C
MENUITEM "Quick &Grid","grids"5 V. \5 |( `6 @5 l
MENUITEM "Quick &View","qview"% }# W; e. {. `4 v2 ~+ B
MENUITEM "check_dir","check_dir"
( m1 X- j; E. d) d) _/ O# JMENUITEM "check_no_refdes","check_no_refdes"& z6 y( H5 Y9 Y. f" h T
MENUITEM "ch_nc_via","ch_nc_via"
! M( F( Y( N' S( dMENUITEM "ch_text_overlap","ch_text_overlap"
9 \' i8 ^. {2 c9 C: P* v; QMENUITEM "colorset","colorset"
4 m' F9 u7 A; l- v' QMENUITEM "cot","cot" f) d1 k% @+ X. i" ^: y. M! u5 N5 D
MENUITEM "DeleteDanglingLines","DeleteDanglingLines"
) G! T; Q2 | @# L/ CMENUITEM "drc walk","drc walk"6 @. O$ B; g; s4 R' o
MENUITEM "hl_null_pin","hl_null_pin"
6 D: Z) a6 }6 b* J# JMENUITEM "MoveRefDestoBodyCenter","r2c"
. D$ e% I! m; S% }MENUITEM "OrphanNet","OrphanNet"
6 ~& z5 s( O7 V4 f3 L$ ~MENUITEM "ref_rot","ref_rot"
& u$ d) y' w0 t! I5 b" ~. F3 \MENUITEM "StackVias","StackVias"( s5 m( i% k9 I$ Q2 ?# O& m
MENUITEM "uc shape","uc shape"+ ]5 N+ B" q. z) a
MENUITEM "auto balance","auto balance"7 H7 W) f7 \6 v% `; o- a
MENUITEM "align_sym","align_sym"* u8 ~* }* ~7 y# |
MENUITEM "boundaryview","boundaryview"1 S6 f# z" _( k5 \+ d: z, o9 q0 u
MENUITEM "conv","conv"
4 J/ Y8 I: y/ D8 T5 L4 ~6 _/ z+ O SMENUITEM "hlvia","hlvia"" w4 H0 [) ^1 L: h* D% C! G! F# b
MENUITEM "scalpel","scalpel"
+ W4 m2 @% ?$ ~( L. vEND9 \6 Z( G/ E2 x' P" ^4 t
// FPM_END$ [% M, b9 `: ~5 K+ U; O
此段代码为FPM添加allegro菜单时 自动生成的 / o# z2 g& N4 b, w- ?
保存文件 重启 问题解决!!! |
