查看: 653|回复: 1
为啥am437更换内核后就无法启动了?
发表于 2020-3-16 10:41 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
9 B5 C4 V' P6 a3 s; Z* @$ A
采用内核4.19.59编译完内核、模块、设备树后,将新编译产生的文件替换SD启动卡中rootfs分区对应文件,并安装模块到rootfs分区,系统启动卡在mmcblk1: p1 p2。请问各位大神这是什么原因?
; a6 T; a& [) s! |  u0 [; P, ]+ i启动信息如下:
1 H) @! P+ W  Q. \$ WU-Boot 2014.07-00115-g6c69db3 (Jan 30 2016 - 17:32:22)
- I0 u/ \, N& t  m
& k! C: w9 o" _5 i# l8 x
4 p8 i' _* k" o- @4 Z( XI2C:   ready0 a8 X( g& b$ I$ f2 d$ K
DRAM:  1 GiB1 |, N7 p. M% {" p, r' O
NAND:  512 MiB4 n* z- d# H. w7 o& D% ^2 E) g6 x# m
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1$ {  @3 I8 l% F* ^( j- O
reading uboot.env
' {7 H6 N) V& L* V3 W: m. v) XCould not probe the EEPROM at 0x50% {1 R- @" r% Z- B& q7 V2 n. |8 L3 P
Could not get board ID.
6 [7 N1 {8 O/ QNet:   cpsw, usb_ether
+ z0 J) ~. ~% R4 M3 ~; U; J  jHit any key to stop autoboot:  0
% Q2 X8 q$ X! _1 Z& ?: nswitch to partitions #0, OK
" ]5 _  w! y0 g0 w' {% jmmc0 is current device0 ]! U4 x: r/ P4 I8 ]
SD/MMC found on device 0
4 X" W: j8 ~3 E4 K7 x2 wreading uEnv.txt
9 |7 @7 q  y4 }9 V" K$ ?/ V** Unable to read file uEnv.txt **
* `* W6 s% \6 b# l4133376 bytes read in 195 ms (20.2 MiB/s)
6 j$ @* F, u5 [47121 bytes read in 9 ms (5 MiB/s)2 {* _' n  H- ~& l5 K
Booting from mmc0 ...
+ X+ D1 n6 @; U7 a- ]! eKernel image @ 0x82000000 [ 0x000000 - 0x3f1200 ]! q! \' v% N5 C7 T4 ~8 e% {5 {
## Flattened Device Tree blob at 88000000
6 p! M" C4 ]( P" c9 I7 f   Booting using the fdt blob at 0x88000000; Q$ a$ Z/ P" u  w, y" [0 f4 w
   Loading Device Tree to 8fff1000, end 8ffff810 ... OK
, P0 X; k5 I; q# u/ [# k$ ^2 N! L& O2 J7 D
! E" @+ K- Y; z7 q5 c/ ZStarting kernel ...- Y% [' z: V' s4 K) P
4 t% I/ |. q( q4 C
; M  \" n5 f4 Y2 h[    0.000000] Booting Linux on physical CPU 0x0
; Z5 H) F# M1 p# e[    0.000000] Linux version 4.19.59 (nan@nan-virtual-machine) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (ARM-rel-8.36))) #1 PREEMPT Fri Jan 10 10:12:38 HKT 2020
+ u. P+ e+ b2 d! w[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
/ r+ P9 p- ~5 ~# n[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache! K" s, C/ J9 i7 {( J
[    0.000000] OF: fdt: Machine model: TI AM437x GP EVM
5 h+ O+ s- ?6 l& F$ Y; ^* @" Y3 }[    0.000000] Memory policy: Data cache writeback
6 r1 }2 r, f( K2 ~: U6 N* ?! C[    0.000000] efi: Getting EFI parameters from FDT:
7 i( h/ C( e; Y6 Q7 Y, R& F8 M[    0.000000] efi: UEFI not found.+ m2 X! p9 [7 U+ I* V
[    0.000000] cma: Reserved 48 MiB at 0xbd000000
2 A. l. K) u9 |" G[    0.000000] CPU: All CPU(s) started in SVC mode.% O" K1 s4 f! C+ B5 z1 Z% a0 R6 g. u
[    0.000000] AM437x ES1.2 (sgx neon)
3 a) C& C8 G# M* w# H[    0.000000] random: get_random_bytes calLED from start_kernel+0xa4/0x434 with crng_init=0" Q7 s* l7 y! i
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260416
9 I- q) E! Q$ ]9 W3 A1 W[    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
% g+ `: g( L( v- X8 u2 M7 [[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes); N; j# H" n# x% O; k
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)% l# x% w! C1 h% Q/ O
[    0.000000] Memory: 976328K/1048576K available (8192K kernel code, 310K rwdata, 2612K rodata, 1024K init, 254K bss, 23096K reserved, 49152K cma-reserved, 212992K highmem)* |. }# w. Q( d, i8 c
[    0.000000] Virtual kernel memory layout:5 f- B( W; Z' i1 P7 {% e
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
4 I4 X& f7 ]: n[    0.000000]     fixmap  : 0xFFC00000 - 0xfff00000   (3072 kB): @' Z& q: \. g. z$ Z5 p
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)6 S. C) {' z7 f+ l' c
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
* r) I( L9 y9 N1 E[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
! v% L, T; t" G[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)- W8 C0 Z3 F& J8 L; C4 B
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)$ B8 U9 I! P  P2 B# Y' A
[    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)! I5 S. N) {  a- @2 P8 }
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 311 kB)/ X5 L4 G8 n9 h: l
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 255 kB)
3 K8 t6 D. q0 n  j) f5 c3 b9 F% P[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
3 A8 x/ w& ]; d/ Q! m[    0.000000] rcu: Preemptible hierarchical RCU implementation.# u4 S7 T* x, M, I
[    0.000000]  Tasks RCU enabled.$ ?% N8 v( ~4 O: Y$ o
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
) k! `8 |; _3 B/ q[    0.000000] L2C: platform modIFies aux control register: 0x0e030000 -> 0x3e430000
) M4 H  _# Q, k2 w" p# k[    0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
4 W# T  L7 A" L3 x$ x! H& }[    0.000000] L2C-310 enabling early BRESP for Cortex-A9" R4 ~, C1 Y' h; G
[    0.000000] OMAP L2C310: ROM does not support power control setting0 l9 ?3 ?6 e9 r" e- B3 S8 N
[    0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled* @6 X' N0 t6 W
[    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB  E! }* P  R5 F
[    0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
) ~, _" u' b5 [) Y[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
; X+ M. U7 U- |. {[    0.000013] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns5 e) M3 t6 Q& e6 X4 E/ R4 {: l( G- h
[    0.000030] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
! G$ M, Z3 Y5 b1 m' c& A2 o[    0.000039] OMAP clocksource: timer1 at 24000000 Hz3 X/ G# X8 ~+ f
[    0.000408] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
. \$ x& ~+ m8 c. v/ E, j[    0.000419] OMAP clocksource: 32k_counter at 32768 Hz3 `" i) r  B! i  a
[    0.000783] Console: colour dummy device 80x30
, J) L/ ^% j% T% i[    0.000810] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'2 l( L) Q& V7 c# x7 T6 \% q) h
[    0.000815] This ensures that you still see kernel messages. Please
( F0 V6 x' c& ]! \( \/ ?[    0.000820] update your kernel commandline.
* e: R$ |8 ?4 g( B3 y[    0.000864] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)' g  o$ _9 s. e, C5 i
[    0.060185] pid_max: default: 32768 minimum: 301
* a$ Y, a9 ~% v% [4 ?. y6 |[    0.060372] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
9 I( `! V. t' v3 Y1 a[    0.060396] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)9 t3 m  g8 {0 @/ b2 n  i
[    0.061139] CPU: Testing write buffer coherency: ok+ ~4 N2 C# B" Q
[    0.061205] CPU0: Spectre v2: using BPIALL workaround+ K) p. p$ Z) b- O# D
[    0.062055] Setting up static identity map for 0x80100000 - 0x801000605 N1 U5 k2 m  |
[    0.062198] rcu: Hierarchical SRCU implementation.0 @4 w- U% W+ u: y$ Z
[    0.062533] EFI services will not be available.
) L. Z8 W" e; @* V[    0.063443] devtmpfs: initialized
1 d2 B% N; w& I[    0.071741] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4' D7 t' }0 o+ Z# z+ }& Q+ v- j* D4 j- p
[    0.072128] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
4 l2 k& p, _- v; `$ K" a[    0.072151] futex hash table entries: 256 (order: -1, 3072 bytes)1 j8 Y- V) z' f' P0 \
[    0.075293] pinctrl core: initialized pinctrl subsystem$ k; N! o/ j6 x
[    0.075984] DMI not present or invalid.
& Q. u9 N+ G" Z& g# K# _[    0.076400] NET: Registered protocol family 16
3 f5 u& g7 E8 y# h[    0.078066] DMA: preallocated 256 KiB pool for atomic coherent allocations, z0 y! }+ S; T: z' x0 _
[    0.156038] l4_per_cm:clk:0240:0: failed to disable
* j. d8 G+ w4 y) x- f[    0.157707] cpuidle: using governor ladder
) v4 k3 F) @- N& N# J[    0.157741] cpuidle: using governor menu) p: b8 f4 @" B- a% v) q
[    0.159410] omap_l3_noc 44000000.ocp: L3 debug error: target 8 mod:0 (unclearable)/ ~2 G* `  P: v( ?
[    0.159482] omap_l3_noc 44000000.ocp: L3 application error: target 8 mod:0 (unclearable)
( U. b# j9 I% A; t- l[    0.164906] OMAP GPIO hardware version 0.15 p/ w6 m& P( J8 ~9 Q  S
[    0.173772] No ATAGs?  ]& \" ]. d6 x* W0 Y+ A3 W3 D. l
[    0.173796] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
/ b, i4 l! T+ U6 z& F; g[    0.173812] hw-breakpoint: maximum watchpoint size is 4 bytes.
1 `8 [# }% E$ f7 m7 |8 S3 r[    0.186941] edma 49000000.edma: TI EDMA DMA engine driver
% R7 ]! X4 d2 S- X2 a4 q. {: k[    0.190805] SCSI subsystem initialized
6 U/ E0 N8 @& f6 B; C9 F[    0.191324] media: Linux media inteRFace: v0.109 Z5 e& u! U. j, [" j7 I
[    0.191366] videodev: Linux video capture interface: v2.00
8 l: H1 x# m$ W, ?[    0.191479] pps_core: LinuxPPS API ver. 1 registered/ m! @4 P/ h/ o3 n5 ?
[    0.191487] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
7 ], X4 o* q, t3 z2 A8 k[    0.191509] PTP clock support registered: F: }6 r6 y( d. ^
[    0.191543] EDAC MC: Ver: 3.0.0
! q, [7 I( f! ^[    0.192488] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400; ]. j; F+ u1 k
[    0.193094] Advanced Linux Sound Architecture Driver Initialized.% |1 T4 C9 X8 z4 x4 {/ ~8 e
[    0.194183] clocksource: Switched to clocksource timer1# {# h8 x; N3 p0 Q4 u
[    0.201777] NET: Registered protocol family 24 U! o0 I& f9 K$ m  B& F
[    0.202518] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
) Z0 O0 t+ k6 n* ~5 _[    0.202553] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
# C6 g2 N3 ]) k[    0.202613] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
& w: {! @- K$ z2 |0 Z; `3 e2 j[    0.202686] TCP: Hash tables configured (established 8192 bind 8192)7 R3 o- u$ K# [' [( V/ T. ?
[    0.202863] UDP hash table entries: 512 (order: 1, 8192 bytes)7 K% U. Q0 y# p8 y# |' j
[    0.202887] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)# A+ g- R9 o& U3 f; n2 Z. x# L5 h4 e
[    0.203030] NET: Registered protocol family 1. `+ A3 \" @3 g6 }
[    0.203571] RPC: Registered named UNIX socket transport module.! j. |* i9 |$ z
[    0.203584] RPC: Registered udp transport module." u6 `9 u' A8 c( ^. S' W. z5 _
[    0.203589] RPC: Registered tcp transport module.9 Q" {) z* ]3 Q% g/ G# u
[    0.203595] RPC: Registered tcp NFSv4.1 backchannel transport module.: d8 L& h. _' `. t7 i, I  I: {4 b: k
[    0.206658] Initialise system trusted keyrings  s$ a% V5 J5 b* d
[    0.206983] workingset: timestamp_bits=14 max_order=18 bucket_order=4- q, A+ G9 V6 t; Y# f
[    0.211092] squashfs: version 4.0 (2009/01/31) Phillip Lougher
' F3 P( T; b( I) M& T[    0.211812] NFS: Registering the id_resolver key type. u) Q8 t% H% l2 q5 ~  [
[    0.211844] Key type id_resolver registered$ U$ P8 M8 G( }' G
[    0.211851] Key type id_legacy registered
/ m. e' q% z- k! s1 X4 x[    0.211888] ntfs: driver 2.1.32 [Flags: R/O].
' \4 C! p8 ]1 p' {3 K+ w[    0.214074] Key type asymmetric registered
! h% I4 l+ ]. N& G8 \3 b[    0.214090] Asymmetric key parser 'x509' registered
# l" L- |# ?) j  O8 F! ^7 ^[    0.214153] bounce: pool size: 64 pages- x3 J: n5 d6 d6 `: L, {7 O
[    0.214303] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
& c! e; ^$ U. K3 l. G6 {[    0.214315] io scheduler noop registered
. M! Z% m. G. \  @' N[    0.214322] io scheduler deadline registered
- @% J/ v8 p; w; Q[    0.214561] io scheduler cfq registered (default)
6 S2 q8 K+ L! X2 K* W[    0.214573] io scheduler mq-deadline registered
% ?; b" ~" d1 M; p- S/ N' v[    0.214580] io scheduler kyber registered
6 c9 r8 ^$ u1 q- k  e. C[    0.217064] pinctrl-single 44e10800.pinmux: 199 pins, size 796" o. a5 T# c/ Q" Q  k
[    0.219985] pwm-backlight backlight: backlight supply power not found, using dummy regulator8 d& V! T; r" ?( E9 U3 V3 E2 k  {
[    0.220083] pwm-backlight backlight: Linked as a consumer to regulator.0
* [5 _, A: V2 v, `[    0.262527] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
3 b1 y! `7 H/ w: j7 b[    0.265721] omap8250 44e09000.serial: No clock speed specified: using default: 480000008 n0 m" z8 r# ^$ _- I( V! k
[    0.266430] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 31, base_baud = 3000000) is a 8250
3 J( n' O1 I$ r8 C2 T' X3 G[    0.974441] console [ttyS0] enabled3 @/ X2 y) w9 @' u$ U2 i
[    0.978495] omap8250 481a6000.serial: No clock speed specified: using default: 48000000/ S7 m7 C+ P% ~! d
[    0.987295] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 32, base_baud = 3000000) is a 8250
* z" m/ @, G5 B  `9 Y8 b[    0.998227] omap_rng 48310000.rng: Random Number Generator ver. 20/ J2 z+ U  r, P1 t3 O4 o
[    1.004672] random: fast init done$ r3 S7 H# m/ M! z
[    1.008295] random: crng init done$ A7 z, ?9 I; s. _
[    1.013538] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator; d& i0 J. [& ^
[    1.023064] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0! \4 e, o1 B3 O' G  P+ ~4 W
[    1.029983] DSS: OMAP DSS rev 2.0
. A+ j1 [% B' G/ e' h[    1.034040] omapdss_dss 4832a000.dss: bound 4832a400.dispc (ops dispc_component_ops)
3 [- `8 [3 q0 @% C+ d[    1.055520] brd: module loaded
0 g2 q: C6 ?, Q4 J[    1.067137] loop: module loaded4 O4 r& a9 o1 P% O
[    1.072834] libphy: Fixed MDIO Bus: probed( |* U! t$ Y; d& F
[    1.144242] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
# {7 b2 r; X9 U. n' k% B[    1.151944] davinci_mdio 4a101000.mdio: detected phy mask ffffffcf
% I. X: b% A' _6 w9 B! X7 m[    1.160099] libphy: 4a101000.mdio: probed- w( o5 I: ?: J. L
[    1.164146] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver Micrel KSZ9031 Gigabit PHY8 f3 `0 Z6 L7 G! y0 p% g% S  U
[    1.173930] davinci_mdio 4a101000.mdio: phy[5]: device 4a101000.mdio:05, driver Micrel KSZ9031 Gigabit PHY
# t: }/ J- o7 H[    1.184613] cpsw 4a100000.ethernet: Detected MACID = 60:64:05:67:74:a9
3 B# ]2 R% y8 v' g* ?8 Q! b$ m[    1.191281] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4# }  A0 p/ U# d$ g: H" H
[    1.197745] cpsw 4a100000.ethernet: ALE Table size 1024
) d3 v; ?! O9 v. e  H9 `) N[    1.203022] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)* X1 D% x# {" F- m3 h0 t
[    1.211556] i2c /dev entries driver0 B- Z0 U3 B& N$ S# R( ?3 ?, m
[    1.217409] sdhci: Secure Digital Host Controller Interface driver
% H: o5 v# }; m0 E: ^( U[    1.223622] sdhci: Copyright(c) Pierre Ossman3 X0 L; v/ O2 k) C& z
[    1.229292] omap_hsmmc 47810000.mmc: Linked as a consumer to regulator.2: k% k$ F* t2 j2 l, W1 s4 Y
[    1.261850] sdhci-pltfm: SDHCI platform and OF driver helper
9 n. U! j" T! ^. i1 R[    1.268640] ledtrig-cpu: registered to indicate activity on CPUs
  n8 O  F+ ^" X' c0 k[    1.277666] NET: Registered protocol family 10
$ O  {' R' Y1 O( Q' r2 c4 P[    1.283483] Segment Routing with IPv6
1 `; T  {2 q# ]2 f% J7 n[    1.287416] sit: IPv6, ipv4 and MPLS over IPv4 tunneling driver! _2 u1 d8 N" M  ?# ~! N# l" W
[    1.294255] NET: Registered protocol family 17  e# A* B) w9 w; Q- V, I* m
[    1.299082] Key type dns_resolver registered
( W2 C5 Z" r7 i/ M. r- {" w, i[    1.303592] omap_voltage_late_init: Voltage driver support not added' r. T" |4 h6 h. I
[    1.310927] Loading compiled-in X.509 certificates$ L1 Z& Y. p# l- }' P
[    1.326082] GPIO line 119 (SelEMMCorNAND) hogged as output/low
- n- f. z( x' G% _& ~; g[    1.332715] GPIO line 136 (SelLCDorHDMI) hogged as output/high. n+ u6 U( Y' X4 ?' n0 {
[    1.339299] omap-gpmc 50000000.gpmc: GPMC revision 6.01 |# m/ y# X8 v% z" [( v0 C
[    1.344548] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000- S: ^) b- U( i) j. w2 h/ ^
[    1.352027] nand: device found, Manufacturer ID: 0x01, Chip ID: 0xdc
! ?2 O% K1 n0 M/ A) |[    1.358468] nand: AMD/spansion S34ML04G24 k' k! h7 f6 m, H8 w# q# \
[    1.362412] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 128
9 {$ n0 a7 h! {& {3 t[    1.370186] Using OMAP_ECC_BCH16_CODE_HW ECC scheme7 ]. c1 \5 w$ u: S
[    1.375191] 10 fixed-partitions partitions found on MTD device omap2-nand.0
0 D' a) u7 k6 k6 G) P. E# _7 A- R. Q[    1.382183] Creating 10 MTD partitions on "omap2-nand.0":; ?. o2 D# w; g* W* Z  c! t
[    1.387628] 0x000000000000-0x000000040000 : "NAND.SPL"6 s# P, o6 y  c9 t9 V0 h) J
[    1.393878] 0x000000040000-0x000000080000 : "NAND.SPL.backup1"
0 R! k+ \9 M+ t5 q7 G! [! F/ F[    1.400739] 0x000000080000-0x0000000c0000 : "NAND.SPL.backup2"
* }5 V6 Y, S/ [; w2 Y[    1.407517] 0x0000000c0000-0x000000100000 : "NAND.SPL.backup3"3 O! S$ u, N0 O2 ]; X0 j
[    1.414311] 0x000000100000-0x000000180000 : "NAND.u-boot-spl-os"
# Z; o% r& S' c0 `[    1.421356] 0x000000180000-0x000000280000 : "NAND.u-boot") U8 z* w3 P! T  X
[    1.428107] 0x000000280000-0x0000002c0000 : "NAND.u-boot-env". F* ]* }1 |6 [# w  H
[    1.434785] 0x0000002c0000-0x000000300000 : "NAND.u-boot-env.backup1"' o$ a4 B  I8 P
[    1.442156] 0x000000300000-0x000000a00000 : "NAND.kernel"
4 Q! V' o- m& o- S, H$ M! V8 U[    1.452172] 0x000000a00000-0x000020000000 : "NAND.file-system"
+ b/ A& d9 n. e[    1.770019] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz- }' h6 I- s4 t, F: ]
[    1.777328] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 100 kHz
7 j& Z) x) n& [[    1.783306] cpu cpu0: Linked as a consumer to regulator.5
& q1 ?7 M, \  D8 H* I' b[    1.788843] cpu cpu0: Dropping the link to regulator.5
. i7 l7 }# ~+ J[    1.794169] cpu cpu0: Linked as a consumer to regulator.5
/ [; L) E) L& s1 o) n[    1.800959] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)# Q% n0 P2 G" |; H' Y' A: R
[    1.809823] omap_hsmmc 48060000.mmc: Got CD GPIO
- a% O2 M- t5 A) ]: o% z[    1.814946] omap_hsmmc 48060000.mmc: Linked as a consumer to regulator.1: S# d7 z; o6 I
[    1.849465] hctosys: unable to open rtc device (rtc0)
$ f, `5 j3 g; r. [: Y8 _[    1.861265] l4_per_cm:clk:0300:0: failed to disable
( r7 h9 T. x5 i& s# j3 q[    1.866796] vmmcwl_fixed: disabling, ?3 ~1 ^4 z4 W
[    1.870531] ALSA device list:5 B* E7 S$ y& K, ]/ t2 f& [, I
[    1.873681]   No soundcards found.: V. ^" g) M" ?
[    1.878787] Waiting for root device /dev/mmcblk0p2...
2 C- H8 C" M; i/ v6 U# o& P1 [[    1.939410] mmc1: host does not support reading read-only switch, assuming write-enable
/ }4 C5 E1 [8 T' c$ @/ B0 g[    1.953780] mmc1: new high speed SDHC card at address aaaa7 e$ j5 u/ {% \" p
[    1.961863] mmcblk1: mmc1:aaaa SS08G 7.40 GiB % G3 g2 B/ S" ?# j3 Q3 V; M
[    1.972476]  mmcblk1: p1 p2
    2019-11-29 15:37
    发表于 2020-3-16 16:01 | 只看该作者
    Could not probe the EEPROM at 0x504 K# l& P, u5 m
    Could not get board ID! r5 X% ^, {4 B$ i2 U+ D: E
    Unable to read file uEnv.txt 1 A" b$ e4 @# i9 n
    先解决这些问题吧
    GMT+8, 2025-11-25 22:19 , Processed in 0.171875 second(s), 25 queries , Gzip On.
