查看: 606|回复: 10
[allegro16.6][8层]联想服务器上的控制器 LSI SAS3004(CNTLR896P+HDR36P+TAB64P)...
发表于 2020-3-4 17:00 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
[allegro16.6][8层]联想服务器上的控制器 LSI SAS3004(CNTLR896P+HDR36P+TAB64P)原理图和pcb文件
文件描述:
1. 作品用途:联想服务器上的控制器 LSI SAS3004
2. 软件版本:allegro16.6
3. 层数:8层
4. 用到的主要芯片:CNTLR896P+HDR36P+TAB64P
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
名称类型属性类别数量位号
0201RDC1NF_16_X7R_10_2011NDISCRETE17C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C244
0201RDC100NF_10_X5R_10_201100NDISCRETE138C52; C53; C54; C55; C56; C57; C58; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173; C174; C175; C176; C177; C178; C179; C180; C181; C182; C183; C184; C185; C186; C187; C188; C189; C190; C191; C192; C193; C194; C195; C196; C197; C198; C199; C200; C201; C202; C203; C204; C205; C206; C207; C208; C209; C210; C211; C212; C213; C214; C215; C216; C217; C218; C219; C220; C221; C222; C223; C224; C225; C226; C227; C228; C229; C290; C291; C309; C310; C311; C321; C322; C323; C324; C334; C342; C343; C344; C345; C346; C347; C348; C349; C350; C351; C352; C358; C359; C360; C361; C362; C363; C364; C365; C366; C372
0201RDC220NF_4_X5R_20_201220NDISCRETE8C87; C88; C89; C90; C91; C92; C93; C94
0201RDC10NF_10_X7R_10_20110NDISCRETE16C231; C232; C233; C234; C235; C236; C237; C238; C312; C313; C314; C315; C316; C317; C318; C319
402C330NF_6P3_X5R_10_402330NDISCRETE1C1
402C100PF_50_C0G_5_402100PDISCRETE1C14
402C100NF_25_X5R_10_402100NDISCRETE36C31; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C70; C71; C72; C73; C74; C75; C86; C300; C301; C302; C303; C304; C335; C336; C339; C353; C354; C355; C357; C367; C368; C369; C370
402C100NF_16_X7R_10_402100NDISCRETE22C60; C62; C64; C65; C66; C67; C69; C292; C293; C294; C295; C296; C297; C299; C320; C331; C332; C333; C340; C371; C373; C374
402C1_8NF_50_X7R_10_4021.8NDISCRETE1C124
402C12PF_50_C0G_5_40212PDISCRETE2C125; C126
402C5_6NF_25_X7R_10_4025.6NDISCRETE1C230
402C10NF_25_X7R_10_40210NDISCRETE3C242; C243; C327
402C1UF_16_X5R_10_4021UDISCRETE22C245; C246; C247; C248; C249; C250; C251; C252; C253; C254; C255; C256; C257; C258; C259; C260; C261; C262; C263; C264; C265; C266
402C1NF_50_X7R_10_4021NDISCRETE1C289
402C1UF_25_X5R_10_4021UDISCRETE3C307; C308; C341
402C3_3NF_50_X7R_10_4023.3NDISCRETE1C325
402C5_6PF_50_C0G_4P464_4025.6PDISCRETE3C328; C329; C330
402R1K_1_4021KDISCRETE36R1; R2; R3; R70; R72; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R112; R113; R123; R127; R138; R139; R140; R142; R180; R181; R198; R200; R201; R202; R203; R272; R273; R274; R275; R291; R312
402R51R1_1_40251.1DISCRETE3R4; R5; R6
402R107K_1_402107KDISCRETE1R7
402R1M_5_4021MEGDISCRETE1R8
402R330R_1_402330DISCRETE7R9; R11; R12; R13; R14; R15; R261
402R75K_1_40275KDISCRETE2R16; R160
402R3K01_1_4023.01KDISCRETE2R17; R59
402R36K5_1_40236.5KDISCRETE1R18
402R84K5_1_40284.5KDISCRETE1R19
402R4K7_1_4024.7KDISCRETE61R20; R21; R26; R27; R28; R29; R30; R31; R32; R33; R34; R37; R38; R101; R102; R103; R105; R109; R119; R120; R121; R122; R124; R128; R148; R153; R154; R155; R156; R157; R162; R163; R164; R165; R167; R168; R170; R171; R177; R178; R179; R182; R183; R197; R199; R205; R206; R263; R264; R265; R266; R268; R276; R279; R280; R307; R308; R309; R310; R311; R313
402R200K_1_402200KDISCRETE3R35; R134; R317
402R10R_1_40210DISCRETE8R40; R41; R42; R43; R44; R45; R46; R315
402R2K_1_4022KDISCRETE27R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R73; R74; R75; R76; R77; R78; R132; R133; R137; R141; R144; R145; R147; R277; R278
402R100K_1_402100KDISCRETE3R62; R63; R269
402R158R_1_402158DISCRETE1R65
402R158K_1_402158KDISCRETE1R66
402R681R_1_402681DISCRETE3R117; R118; R214
402R10K_1_40210KDISCRETE3R169; R207; R210
402R0R_05O_4020DISCRETE27R217; R218; R219; R220; R221; R222; R223; R224; R231; R240; R243; R282; R283; R284; R285; R286; R289; R292; R296; R297; R298; R299; R300; R302; R303; R304; R306
402R100R_1_402100DISCRETE2R238; R318
402R2K2_1_4022.2KDISCRETE4R249; R250; R251; R252
402R180K_1_402180KDISCRETE1R253
402R0R51_1_4020.51DISCRETE3R257; R258; R259
402R33K_1_40233KDISCRETE1R271
402R20K_1_40220KDISCRETE2R281; R295
402R22R_1_40222DISCRETE3R290; R314; R316
402R6K81_1_4026.81KDISCRETE1R293
402R4K99_1_4024.99KDISCRETE1R294
402R34K8_1_40234.8KDISCRETE1R301
402R20R_1_40220DISCRETE1R305
603C10UF_6P3_X5R_20_60310UDISCRETE13C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114
603R34K_1_60334KDISCRETE1R61
603R24K_1_60324KDISCRETE1R150
603R0R_05O_6030DISCRETE1R247
805C47UF_6P3_X5R_20_80547UDISCRETE8C32; C33; C34; C35; C36; C37; C38; C39
805C10UF_25_X5R_10_80510UDISCRETE2C81; C100
805C22UF_6P3_X5R_20_80522UDISCRETE12C96; C97; C267; C268; C269; C270; C271; C272; C273; C274; C275; C276
805C22UF_16_X5R_20_80522UDISCRETE6C127; C128; C277; C278; C283; C284
805IND2P_FE_MPZ2012S601AT000600DISCRETE7L1; L2; L3; L4; L5; L6; L7
805IND2P_MPZ2012S300AT30DISCRETE3L12; L13; L14
1206C100UF_6P3_X5R_20_1206100UDISCRETE4C3; C4; C5; C6
1206C22UF_25_X5R_10_120622UDISCRETE9C95; C98; C99; C117; C119; C120; C121; C122; C123
BERG1X4_TSM-104-01-X-SV-PBERG1X4_TSM-104-01-S-SV-P-TRIO2J6; J8
BERG16P_TSM-108-01-X-DV-PBERG16P_TSM-108-01-T-DV-P-TRIO1J5
FBGA48P_6X8_REV03MRAM_MR0D08BMA45R_DUALIC1U15
FBGA64P_8X8FEPROM_S29GL256P11FFIV20IC1U16
FPBGA896P_30X30CNTLR896P_LSISAS3004_500020662IC1U20
FUSE2P_0603FUSE2P_0467_4A_32V4IC1F1
FUSE2P_0603FUSE2P_0467_750NR0.75IC2F2; F93
FUSE2P_0603FUSE2P_0467_375NR0.375IC2F5; F14
HDR2P_87898-02XXHDR2P_87898-0204IO1J10
HDR3P_ASP-154559-02HDR3P_ASP-154559-02IO1J9
HDR36P_76867-00X1HDR36P_76867-0011_CONTROLLERIO1J4
HEATSINK_ECB-00327-02-HFCONN1X2_HSIC1J7
IND2P_SMT_SPM6530IND2P_SPM6530T-R25M2300.22DISCRETE1L8
LED2P_SML-51XLED2P_19-213UYC_S530-A3_TR820IC5CR2; CR3; CR4; CR5; CR6
LED2P_SML-51XLED2P_SML-512MW_GRN20IC2CR7; CR8
PAD126NP4VPAD126NP4VIO2H1; H2
PQFN33_IRPWRCTLR33P_IR3847MTRPBF21IC1U8
QFN20_MPSCNTLR20P_MPM3610AGQV-Z5IC3U17; U18; U19
SC70_3TRANS_MMBT3904WT1GIC2Q2; Q4
SC70_5LVC1G07_SC70_5IC4U22; U24; U25; U31
SC70_5LVC1G17_SC70_5IC3U27; U32; U33
SC70_5LVC1G06_SC70_5IC1U28
SC70_6LVC2G07_SC70_6_1IC5U10; U12; U23; U29; U30
SO8NEEPROM_M24512-WMN6TPIC1U3
SO8NEEPROM_AT24C64D-SSHM-TIC1U14
SOT23_6SUPVR6P_TPS3808G18DBVRG41.8IC1U21
SOT563_TIFET2PAK_NTZD3154DT1GIC1Q3
SSOP8_65MMBIDIBUFR8P_PCA9306DCTRG45IC3U1; U2; U34
TAB64P_PCIE_10018784TAB64P_PCIE_NAIO1J2
TDFN6_MAXIMEEPROM_DS28E02Q-W01_5TIC1U9
XTAL4P_FA238XTAL2P_FA-238-25M-50PPM-12PF25IC1Y1
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
: P3 w5 e2 F9 ^7 }3 A
    2025-11-26 15:28
  • 签到天数: 884 天
    [LV.10]以坛为家III
    发表于 2023-1-12 15:10 | 只看该作者
    骗子,没有原理图
    2025-11-26 15:28
  • 签到天数: 884 天
    [LV.10]以坛为家III
    发表于 2023-1-12 15:09 | 只看该作者
    DDDDDDDDDDDDDDDDDDDDDD: H# X, C* x/ I% m" p1 q8 f- y
    发表于 2021-11-2 14:42 | 只看该作者
    文档打不开呢,加密了??
    发表于 2021-11-2 14:38 | 只看该作者
    有LSI SAS3004的设计资料吗??求分享1 J/ A' J) @3 t# h4 k
    2020-1-8 15:27
    发表于 2021-10-11 17:31 | 只看该作者
    学习一下,多谢分享!!!!!
    发表于 2021-10-10 22:55 | 只看该作者
    看看666666666666666666666
    4 m9 H0 V" d' i5 Q. Y! i
    2024-8-26 15:16
    发表于 2021-9-24 11:50 | 只看该作者
    下载看看怎样& L3 u" G! H/ @: g2 ^
    奋斗
    2025-11-25 15:27
  • 签到天数: 139 天
    [LV.7]常住居民III
    发表于 2021-9-24 10:15 | 只看该作者
    好东西,学习
    GMT+8, 2025-11-27 04:56 , Processed in 0.187500 second(s), 28 queries , Gzip On.
