1. 作品用途:君正Iot物联网邮票孔核心板
2. 软件版本:allegro16.6
3. 层数:8层
4. 用到的主要芯片:X1000+EA3036+BCM43438
5. PCB尺寸:异形
| Bill of Material Report (Condensed) | | | | | |
| 名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
| 1N5817A | 1N5817A | SS14(1N5819) | DISCRETE | 6 | D3; D7; D26; D27; D37; D50 |
| 1N5817A | 1N5817A | 1N5817(SS14)/NC | DISCRETE | 1 | D41 |
| 1N5817A | 1N5817A | SMAJ33CA_DO214AC(SMA) | DISCRETE | 4 | TVS1; TVS2; TVS3; TVS4 |
| 2N7002B | 2N7002B | AO3414/SOT23 | DISCRETE | 10 | Q8; Q16; Q25; Q34; Q35; Q66; Q68; Q82; Q101; Q104 |
| 2N7002B | 2N7002B | 2N7002/SOT23 | DISCRETE | 37 | Q12; Q18; Q20; Q21; Q45; Q46; Q47; Q48; Q49; Q50; Q51; Q52; Q53; Q54; Q55; Q56; Q57; Q58; Q59; Q60; Q61; Q62; Q64; Q65; Q67; Q69; Q70; Q71; Q73; Q74; Q79; Q84; Q99; Q100; Q105; Q116; Q119 |
| 2N7002B | 2N7002B | 2N7002/SOT23/NC | DISCRETE | 3 | Q24; Q63; Q78 |
| 2N7002B | 2N7002B | AO3414/SOT23/NC | DISCRETE | 1 | Q83 |
| 2N7002B | 2N7002B | AM2324N-T1-TRG_SOT23 | DISCRETE | 4 | Q102; Q103; Q107; Q108 |
| 5EHDRM-03P_5MM | 5EHDRM-03P_5MM | 5EHDRM-03P_D90 | IC | 2 | DC-IN1; DC_IN1 |
| A694B | A694B | LED HOLDER(GREEN/YELLOW)_3MM_D90 | IC | 2 | LED1; LED2 |
| AJ_424-05211T02_D90 | AJ_424-05211T02_D90 | PHONEJACK STEREO SW(GREEN) | IC | 2 | AUDIO_IN2; SPK_OUT1 |
| AJ_424-05211T02_D90 | AJ_424-05211T02_D90 | PHONEJACK STEREO SW(PINK) | IC | 1 | MIC_IN1 |
| APL1108P-2R0M | APL1108P-2R0M | 2.0UH/20A_APL1108P-2R0M_D180/NC | IC | 2 | L2; L7 |
| BAT54C_132 | BAT54C_132 | BAS21A_SOT23 | DISCRETE | 2 | D15; D18 |
| BAT54C_132 | BAT54C_132 | BAT54C_SOT23 | DISCRETE | 1 | D19 |
| BAT54S_132 | BAT54S_132 | BAV99_SOT23 | DISCRETE | 8 | D22; D42; D43; D44; D45; D47; D48; D49 |
| BAT54_132 | BAT54_132 | BZX84C5V6_SOT23 | DISCRETE | 6 | D1; D5; D8; D10; D13; D21 |
| BAT54_132 | BAT54_132 | BZX84C51_SOT23 | DISCRETE | 6 | D16; D31; D33; D35; D36; D38 |
| BAT54_132 | BAT54_132 | BZX84C51_SOT23/NC | DISCRETE | 1 | D17 |
| BAT54_132 | BAT54_132 | BZX84C5V6_SOT23/NC | DISCRETE | 1 | D20 |
| BH800-9_S180 | BH800-9_S180 | BATTERY HOLDER CR2032L | IC | 1 | BAT1 |
| BZ_250 | BZ_250 | BUZER | IC | 1 | BZ1 |
| CFAST_S90_PP-1 | CFAST_S90_PP-1 | CFAST SOCKET_H=8.35MM | IC | 1 | CFAST1 |
| CM315D | CM315D | 32.768KHZ/SMD | IC | 1 | X2 |
| CON2_B | CON2_B | WAFER 1X2_2.0MM_D180 | IC | 6 | PWR_SW1; PWR_SW2; SPK_L1; SPK_L2; SPK_R1; SPK_R2 |
| CON6_B | CON6_B | WAFER 1X6_2.0MM_D180 | IC | 2 | TS1; TS2 |
| CON10_B | CON10_B | WAFER 1X10_2.0MM_D180 | IC | 2 | INV1; INV2 |
| CON20X2_1D25_01036 | CON20X2_1D25_01036 | WAFER 2X20_1.25MM_S180 | IC | 2 | LVDS_P1; LVDS_P2 |
| COPPER_1 | COPPER_1 | COPPER/NC | IC | 9 | S2; S3; S4; S5; S7; S8; S9; S11; S12 |
| COPPER_2 | COPPER_2 | COPPER/NC | IC | 3 | S1; S6; S10 |
| CPCI_F5X11_D90 | CPCI_F5X11_D90 | CPCI FEMALE CON 5X11_D90 | IC | 2 | LVDS_OUT1; LVDS_OUT2 |
| CPCI_M5X11_D180 | CPCI_M5X11_D180 | CPCI MALE CON 5X11_D180 | IC | 2 | LVDS_IN1; LVDS_IN2 |
| DCON9F | DCON9F | COM9F_D90 | IC | 1 | COM_IN2 |
| DCON9M-T | DCON9M-T | COM9M_THIN_D90 | IC | 2 | COM1_1; COM2_1 |
| DDR3_SODIMM_S90_HL | DDR3_SODIMM_S90_HL | DDR3 SODIMM 204P 1.5V 9.2MM_S90 | IC | 1 | SODIMM1 |
| DFN2X3-6T | DFN2X3-6T | LTC4357CDCB_DFN2X3-6T | IC | 2 | U34; U37 |
| DFN3X3-10T | DFN3X3-10T | AN6033-ADD_DFN3X3-10T | IC | 1 | U16 |
| DFN4120P10E | DFN4120P10E | AZ1065-06F_DFN4120P10E | IC | 1 | ESD1 |
| DHS-102LMTC | DHS-102LMTC | SW1X2_S180(DHS-102LMTC) | IC | 4 | SW1; SW2; SW3; SW4 |
| DIP2A-300 | DIP2A-300 | SW1X1_D180(EDS101SZ) | IC | 1 | CLR_CMOS1 |
| DIP20_2D54 | DIP20_2D54 | TPA6021A4_DIP20_2D54 | IC | 1 | U17 |
| DP_WDPE20_D90 | DP_WDPE20_D90 | DISPLAYPORT_20H_D90 | IC | 2 | DP1; DP_IN2 |
| DSUB-15P-RD-8P8M | DSUB-15P-RD-8P8M | VGA CONNECTOR_3D08 | IC | 1 | VGA_IN2 |
| DVI30A | DVI30A | DVI-D | DISCRETE | 1 | DVI_IN2 |
| ECH350R-10P | ECH350R-10P | ECH350R-10P_D90 | IC | 1 | DIO1 |
| EL357N-G | EL357N-G | EL357N(C)(TA)-G | IC | 8 | U23; U48; U50; U54; U56; U57; U59; U60 |
| FCBGA1170 | FCBGA1170 | E3845_FCBGA1170 | IC | 1 | U21 |
| FUSE_0456 | FUSE_0456 | BRICK 125V/20A_SMD | IC | 2 | FS1; FS5 |
| FUSE_SMD | FUSE_SMD | FUSE_13V/2.6A | IC | 1 | FS2 |
| FUSE_SMD | FUSE_SMD | FUSE_16V/1.25A | IC | 4 | FS3; FS4; FS6; FS7 |
| H264P4-MTH_MT | H264P4-MTH_MT | NUT_M2_9.2MM | IC | 2 | NUT1; NUT2 |
| JH2X4-HD | JH2X4-HD | PIN HEADER 2X4_2.54MM_D180 | IC | 1 | JP1 |
| KDCON5X2_2M | KDCON5X2_2M | PIN HEADER 2X5_2.0MM_D180 | IC | 1 | COM12_SEL1 |
| KDCON7X2_2M | KDCON7X2_2M | PIN HEADER 2X7_2.0MM_D180 | IC | 1 | DEBUG1 |
| KDJACK_POWER | KDJACK_POWER | POWER_JACK 2X2PIN/NC | DISCRETE | 2 | DC-IN2; DC_IN2 |
| LQFP48 | LQFP48 | ALC886-GR_LQFP48 | IC | 1 | U38 |
| LQFP128_14X14 | LQFP128_14X14 | NT68856_LQFP128_14X14 | IC | 1 | U24 |
| LQFP128_14X14 | LQFP128_14X14 | F81866AD_LQFP128_14X14 | IC | 1 | U67 |
| MINIPCIE_52 | MINIPCIE_52 | MINI-PCIE_9.2MM | IC | 1 | MINIPCIE1 |
| MSOP8 | MSOP8 | F75909M_MSOP8 | IC | 7 | U1; U25; U28; U29; U33; U43; U47 |
| MTH276_138 | MTH276_138 | 138 DRILL / 276PAD | IC | 20 | H1; H2; H3; H4; H5; H6; H7; H8; H9; H10; H11; H12; H13; H14; H15; H16; H17; H18; H19; H20 |
| MYEC100_250 | MYEC100_250 | 820UF/2.5V | IC | 4 | SC28; SC30; SC31; SC34 |
| MYEC138_350 | MYEC138_350 | 270UF/16V | IC | 27 | SC1; SC2; SC3; SC4; SC5; SC6; SC7; SC8; SC9; SC11; SC12; SC13; SC14; SC15; SC16; SC17; SC18; SC19; SC20; SC21; SC23; SC24; SC25; SC26; SC29; SC32; SC33 |
| MYEC200_400 | MYEC200_400 | 470UF/16V | DISCRETE | 4 | SC10; SC22; SC27; SC35 |
| MYFAN_L_4_D90 | MYFAN_L_4_D90 | PWR_SMALL 4P_CONN_2.54MM_D90 | IC | 1 | POWER1 |
| MYSMDTO252_GDS | MYSMDTO252_GDS | AP6679GH_TO252 | DISCRETE | 7 | Q1; Q2; Q4; Q11; Q23; Q72; Q86 |
| OSC-5X3 | OSC-5X3 | OSC-48MHZ_4P/SMD | IC | 1 | OSC1 |
| POWER33 | POWER33 | FDMC4435BZ_POWER33 | IC | 4 | Q120; Q121; Q123; Q125 |
| POWER56 | POWER56 | FDMS8820_POWER56 | IC | 2 | Q6; Q32 |
| POWER56 | POWER56 | FDMS7682_POWER56 | IC | 2 | Q7; Q33 |
| POWER56 | POWER56 | FDMS7694_POWER56 | IC | 9 | Q9; Q10; Q19; Q75; Q76; Q77; Q85; Q96; Q97 |
| POWER56 | POWER56 | FDMS7694_POWER56/NC | IC | 2 | Q14; Q15 |
| POWER56 | POWER56 | FDMS8333L_POWER56 | IC | 5 | Q36; Q37; Q42; Q112; Q113 |
| POWER56 | POWER56 | FDMS86103L_POWER56 | IC | 5 | Q38; Q40; Q109; Q110; Q111 |
| POWER56 | POWER56 | FDMS86300DC_POWER56 | IC | 3 | Q44; Q114; Q115 |
| POWER56 | POWER56 | FDMS0312S_POWER56 | IC | 1 | Q89 |
| POWER56-2T | POWER56-2T | FDMS3664S_POWER56-2T/NC | IC | 2 | Q81; Q94 |
| POWER56-2T | POWER56-2T | FDMS3664S_POWER56-2T | IC | 6 | Q87; Q91; Q92; Q93; Q95; Q98 |
| PQFN34-3T_5D5X5 | PQFN34-3T_5D5X5 | FAN2356MPX_PQFN34-3T_5D5X5 | IC | 2 | U2; U3 |
| QFN36-T_6X6 | QFN36-T_6X6 | USB2514BI-AEZ_QFN36-T_6X6 | IC | 1 | U32 |
| QFN40-T_5X5 | QFN40-T_5X5 | ISL95837HRZ-HF_QFN40-T_5X5 | IC | 1 | U18 |
| QFN40-T_6X6 | QFN40-T_6X6 | SP339EER1-L_QFN40-T_6X6 | IC | 2 | U66; U71 |
| QFN64-T_9X9 | QFN64-T_9X9 | I210-AT_QFN64-T | IC | 2 | U35; U36 |
| QFN68_8X8 | QFN68_8X8 | CH7511B-BFI_QFN68_8X8 | IC | 1 | U8 |
| RJ45_RT7-174AAM1A | RJ45_RT7-174AAM1A | RJ45+TRANSFORMERLED | IC | 2 | LAN1; LAN2 |
| RN8SMDA | RN8SMDA | 4.7K(8P4R) | DISCRETE | 1 | RN1 |
| RN8SMDA | RN8SMDA | 4.7K(8P4R)/NC | DISCRETE | 1 | RN2 |
| SATA22P_F_9D1_S90 | SATA22P_F_9D1_S90 | SATA CONN 7+15PIN_S90 | IC | 1 | SATA1 |
| SC_10D3X10D3_SMD | SC_10D3X10D3_SMD | 82UF/50V_S180 | IC | 3 | SC36; SC37; SC38 |
| SER1360 | SER1360 | 1.8UH/19A_SER1360-182KLD_S180 | IC | 5 | L1; L5; L6; L8; L10 |
| SER1360 | SER1360 | 0.33UH/31A_SER1360-331KLD_S180 | IC | 4 | L3; L4; L12; L19 |
| SER2900 | SER2900 | SER2915L-103KL_S180 | IC | 2 | L20; L25 |
| SIM_CON_PP | SIM_CON_PP | SIM CARD SOCKET 6P_SMD | IC | 1 | SIM1 |
| SK12D02_D90 | SK12D02_D90 | SLIDE SWITCH 1P2T_D90 | IC | 1 | AT_ATX1 |
| SLPG1307 | SLPG1307 | SLPG1307A-100M_S180/NC | IC | 2 | L21; L26 |
| SM0603C | SM0603C | 0.1UF/50V | DISCRETE | 260 | C3; C4; C5; C6; C7; C12; C26; C28; C35; C36; C37; C38; C44; C46; C50; C55; C61; C62; C64; C68; C75; C78; C81; C82; C85; C92; C93; C95; C96; C97; C98; C104; C105; C106; C114; C120; C121; C122; C126; C130; C139; C141; C142; C143; C150; C157; C160; C170; C174; C175; C176; C179; C185; C186; C189; C190; C191; C192; C193; C195; C197; C198; C199; C200; C201; C203; C204; C205; C206; C207; C208; C209; C210; C212; C215; C216; C217; C218; C220; C221; C222; C225; C226; C227; C228; C229; C234; C235; C236; C237; C238; C239; C248; C250; C251; C258; C259; C261; C262; C263; C264; C266; C269; C270; C275; C278; C293; C300; C301; C318; C323; C330; C331; C341; C348; C349; C351; C352; C353; C357; C358; C361; C363; C364; C365; C366; C368; C375; C376; C378; C381; C382; C383; C384; C389; C395; C399; C400; C401; C402; C404; C407; C410; C414; C415; C416; C417; C421; C429; C435; C437; C442; C443; C445; C448; C450; C457; C459; C464; C466; C467; C474; C482; C484; C485; C486; C487; C496; C497; C500; C509; C512; C513; C514; C515; C516; C518; C523; C546; C548; C554; C561; C567; C569; C570; C572; C575; C578; C581; C582; C589; C591; C595; C596; C597; C599; C600; C604; C605; C606; C608; C609; C611; C612; C614; C616; C619; C621; C622; C624; C625; C626; C628; C631; C632; C634; C638; C639; C640; C641; C642; C645; C647; C649; C651; C652; C655; C657; C658; C659; C660; C661; C662; C665; C666; C670; C673; C675; C677; C678; C679; C687; C688; C689; C693; C694; C697; C698; C700; C702; C703; C705; C706; C707; C708; C713; C714; C715; C716; C725 |
| SM0603C | SM0603C | 0.01UF/50V | DISCRETE | 32 | C8; C16; C23; C29; C56; C69; C72; C90; C113; C124; C133; C168; C182; C224; C253; C372; C390; C391; C392; C393; C420; C427; C440; C446; C521; C535; C537; C585; C586; C587; C588; C617 |
| SM0603C | SM0603C | 0.015UF/50V | DISCRETE | 2 | C10; C13 |
| SM0603C | SM0603C | 100PF/50V | DISCRETE | 31 | C11; C14; C252; C316; C317; C338; C339; C340; C350; C377; C583; C584; C590; C603; C610; C620; C629; C635; C650; C656; C672; C695; C709; C710; C711; C712; C717; C719; C720; C721; C722 |
| SM0603C | SM0603C | 10PF/50V | DISCRETE | 18 | C15; C107; C312; C313; C314; C315; C325; C326; C327; C332; C333; C334; C335; C336; C337; C342; C343; C644 |
| SM0603C | SM0603C | NC | DISCRETE | 12 | C19; C20; C32; C33; C57; C65; C67; C439; R26; R43; R112; R116 |
| SM0603C | SM0603C | 1000PF/50V | DISCRETE | 28 | C24; C39; C58; C80; C109; C112; C119; C123; C135; C154; C166; C184; C223; C254; C265; C367; C374; C408; C413; C419; C428; C438; C449; C462; C520; C528; C544; C601 |
| SM0603C | SM0603C | 22PF/50V | DISCRETE | 9 | C47; C63; C118; C246; C247; C291; C302; C646; C669 |
| SM0603C | SM0603C | 1UF/16V/NC | DISCRETE | 2 | C51; C431 |
| SM0603C | SM0603C | 10PF/50V/NC | DISCRETE | 7 | C60; C76; C296; C297; C298; C425; C452 |
| SM0603C | SM0603C | 0.1UF/50V/NC | DISCRETE | 14 | C66; C70; C91; C101; C115; C136; C171; C307; C422; C426; C430; C441; C607; C633 |
| SM0603C | SM0603C | 1UF/16V | DISCRETE | 57 | C73; C74; C140; C155; C156; C158; C159; C161; C183; C249; C319; C320; C324; C346; C354; C355; C403; C433; C444; C447; C455; C458; C477; C478; C488; C489; C492; C493; C502; C504; C506; C517; C527; C530; C533; C534; C538; C545; C549; C553; C556; C559; C560; C563; C564; C568; C574; C623; C636; C637; C648; C653; C674; C676; C685; C691; C701 |
| SM0603C | SM0603C | 100PF/50V/NC | DISCRETE | 7 | C79; C167; C173; C180; C273; C310; C311 |
| SM0603C | SM0603C | 18PF/50V | DISCRETE | 6 | C83; C87; C279; C280; C468; C469 |
| SM0603C | SM0603C | 0.022UF/50V/NC | DISCRETE | 1 | C86 |
| SM0603C | SM0603C | 220PF/50V | DISCRETE | 2 | C99; C461 |
| SM0603C | SM0603C | 680PF/50V | DISCRETE | 1 | C100 |
| SM0603C | SM0603C | 82PF/50V | DISCRETE | 1 | C108 |
| SM0603C | SM0603C | 0.01UF/50V/NC | DISCRETE | 2 | C128; C271 |
| SM0603C | SM0603C | 470PF/50V | DISCRETE | 5 | C129; C453; C463; C476; C479 |
| SM0603C | SM0603C | 0.033UF/50V | DISCRETE | 3 | C131; C181; C272 |
| SM0603C | SM0603C | 0.22UF/50V | DISCRETE | 6 | C146; C151; C164; C165; C472; C481 |
| SM0603C | SM0603C | 330PF/50V/NC | DISCRETE | 1 | C147 |
| SM0603C | SM0603C | 4.7UF/10V | DISCRETE | 26 | C187; C214; C305; C423; C473; C495; C498; C499; C505; C510; C511; C519; C524; C525; C526; C529; C531; C539; C540; C541; C542; C547; C551; C566; C579; C580 |
| SM0603C | SM0603C | 1000PF/50V/NC | DISCRETE | 6 | C255; C260; C718; C723; C724; C726 |
| SM0603C | SM0603C | 0.039UF/50V | DISCRETE | 2 | C268; C274 |
| SM0603C | SM0603C | 0.047UF/50V | DISCRETE | 6 | C282; C283; C284; C285; C286; C287 |
| SM0603C | SM0603C | 33PF/50V/NC | DISCRETE | 2 | C288; C289 |
| SM0603C | SM0603C | 33PF/50V | DISCRETE | 2 | C299; C308 |
| SM0603C | SM0603C | 0.022UF/50V | DISCRETE | 5 | C380; C398; C418; C536; C573 |
| SM0603C | SM0603C | 68PF/50V | DISCRETE | 1 | C460 |
| SM0603C | SM0603C | 1500PF/50V | DISCRETE | 1 | C480 |
| SM0603C | SM0603C | 0.068UF/50V | DISCRETE | 1 | C491 |
| SM0603C | SM0603C | 220PF/50V/NC | DISCRETE | 1 | C508 |
| SM0603L | SM0603L | BEAD 30 | IC | 13 | L27; L28; L29; L30; L31; L33; L34; L35; L37; L38; L39; L40; L41 |
| SM0603R | SM0603R | 2.2K | DISCRETE | 50 | R1; R2; R4; R243; R252; R301; R306; R310; R312; R323; R328; R330; R346; R351; R355; R357; R362; R371; R438; R448; R480; R493; R527; R558; R564; R574; R575; R576; R585; R586; R638; R639; R640; R678; R679; R712; R713; R715; R743; R745; R747; R749; R754; R757; R770; R814; R944; R945; R954; R982 |
| SM0603R | SM0603R | 0 | DISCRETE | 148 | R3; R54; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R75; R78; R83; R87; R91; R99; R148; R151; R156; R158; R164; R180; R185; R188; R199; R206; R208; R212; R216; R220; R221; R223; R224; R230; R232; R245; R246; R261; R268; R274; R283; R293; R295; R296; R326; R340; R350; R354; R363; R378; R397; R404; R441; R449; R450; R452; R458; R464; R466; R470; R471; R477; R481; R482; R484; R485; R513; R514; R515; R516; R517; R546; R553; R555; R557; R571; R572; R573; R584; R592; R598; R599; R600; R613; R618; R623; R627; R628; R648; R652; R655; R661; R667; R668; R669; R670; R671; R672; R673; R674; R675; R676; R719; R725; R734; R739; R748; R759; R773; R780; R783; R795; R819; R834; R838; R867; R868; R875; R878; R879; R891; R894; R895; R896; R897; R899; R900; R933; R956; R974; R985; R986; R991; R992; R994; R996; R997; R1003; R1005; R1008; R1011 |
| SM0603R | SM0603R | 1.5K | DISCRETE | 2 | R5; R7 |
| SM0603R | SM0603R | 10K | DISCRETE | 131 | R6; R12; R13; R37; R40; R53; R57; R96; R98; R104; R105; R107; R121; R122; R123; R124; R130; R133; R135; R139; R169; R170; R186; R189; R191; R192; R195; R201; R225; R226; R244; R256; R259; R260; R262; R269; R273; R275; R309; R314; R318; R352; R353; R359; R369; R381; R417; R418; R419; R431; R440; R446; R467; R473; R478; R486; R491; R492; R496; R503; R504; R543; R544; R570; R580; R581; R590; R601; R602; R625; R633; R635; R647; R653; R654; R681; R682; R684; R687; R688; R689; R691; R695; R699; R700; R704; R711; R722; R746; R752; R778; R779; R791; R793; R798; R799; R803; R804; R821; R827; R829; R831; R842; R844; R845; R849; R853; R855; R856; R865; R870; R902; R906; R907; R917; R920; R921; R924; R935; R942; R946; R958; R962; R964; R965; R970; R973; R979; R999; R1015; R1018 |
| SM0603R | SM0603R | 54.9K,1% | DISCRETE | 2 | R8; R16 |
| SM0603R | SM0603R | 4.7K | DISCRETE | 81 | R9; R10; R17; R32; R41; R93; R120; R126; R137; R147; R194; R251; R267; R284; R286; R303; R322; R356; R360; R410; R411; R445; R459; R462; R465; R469; R474; R475; R476; R487; R488; R489; R490; R501; R502; R505; R507; R508; R509; R510; R518; R519; R520; R539; R540; R561; R562; R563; R591; R692; R696; R697; R702; R706; R707; R784; R800; R808; R818; R825; R832; R836; R843; R847; R852; R859; R860; R869; R871; R873; R876; R882; R883; R912; R918; R923; R925; R934; R968; R983; R995 |
| SM0603R | SM0603R | 6.65K,1% | DISCRETE | 1 | R11 |
| SM0603R | SM0603R | 10K/NC | DISCRETE | 30 | R14; R15; R44; R76; R81; R97; R111; R115; R118; R152; R153; R155; R171; R202; R213; R319; R641; R644; R645; R690; R698; R710; R726; R729; R736; R805; R817; R848; R929; R978 |
| SM0603R | SM0603R | 4.7K/NC | DISCRETE | 36 | R18; R86; R132; R138; R149; R150; R166; R238; R258; R302; R334; R347; R396; R398; R399; R400; R401; R412; R413; R430; R463; R500; R506; R718; R751; R811; R812; R820; R837; R840; R864; R877; R881; R969; R971; R984 |
| SM0603R | SM0603R | 20K,1% | DISCRETE | 17 | R19; R193; R382; R415; R619; R872; R874; R959; R967; R1019; R1020; R1021; R1022; R1023; R1024; R1025; R1026 |
| SM0603R | SM0603R | 1K | DISCRETE | 72 | R20; R30; R36; R47; R89; R101; R106; R109; R142; R143; R146; R160; R161; R165; R168; R174; R197; R215; R217; R241; R253; R264; R266; R279; R280; R281; R282; R297; R315; R333; R341; R342; R345; R385; R395; R420; R422; R423; R424; R426; R427; R428; R429; R437; R497; R512; R547; R551; R569; R629; R637; R646; R683; R694; R721; R742; R781; R810; R857; R866; R886; R887; R890; R905; R908; R915; R926; R932; R963; R972; R1013; R1016 |
| SM0603R | SM0603R | 15K/NC | DISCRETE | 3 | R21; R23; R634 |
| SM0603R | SM0603R | 10 | DISCRETE | 23 | R22; R136; R200; R214; R307; R308; R316; R321; R409; R531; R532; R533; R534; R535; R536; R537; R538; R577; R578; R626; R901; R910; R977 |
| SM0603R | SM0603R | 1.65K,1% | DISCRETE | 2 | R24; R643 |
| SM0603R | SM0603R | NC | DISCRETE | 8 | R25; R29; R35; R45; R90; R113; R693; R727 |
| SM0603R | SM0603R | 15K | DISCRETE | 9 | R27; R42; R110; R114; R129; R656; R730; R893; R998 |
| SM0603R | SM0603R | 3.24K,1% | DISCRETE | 2 | R28; R46 |
| SM0603R | SM0603R | 2.2 | DISCRETE | 6 | R31; R74; R117; R141; R939; R980 |
| SM0603R | SM0603R | 330 | DISCRETE | 8 | R33; R39; R658; R660; R1001; R1002; R1004; R1006 |
| SM0603R | SM0603R | 100 | DISCRETE | 46 | R34; R38; R95; R131; R227; R277; R278; R285; R287; R298; R313; R327; R483; R494; R495; R498; R521; R522; R523; R524; R525; R526; R529; R559; R560; R565; R566; R568; R607; R608; R609; R610; R611; R612; R614; R615; R616; R621; R622; R631; R632; R651; R738; R766; R771; R931 |
| SM0603R | SM0603R | 220/NC | DISCRETE | 10 | R48; R49; R50; R51; R52; R662; R663; R664; R665; R666 |
| SM0603R | SM0603R | 1.8K | DISCRETE | 2 | R55; R1009 |
| SM0603R | SM0603R | 3.3K | DISCRETE | 2 | R56; R1012 |
| SM0603R | SM0603R | 2.2K/NC | DISCRETE | 10 | R77; R242; R361; R386; R461; R468; R596; R714; R760; R772 |
| SM0603R | SM0603R | 0/NC | DISCRETE | 33 | R79; R80; R102; R108; R119; R144; R145; R187; R219; R344; R366; R389; R414; R434; R545; R583; R597; R617; R716; R737; R753; R775; R835; R862; R898; R922; R927; R955; R975; R976; R981; R1007; R1010 |
| SM0603R | SM0603R | 1.21K,1%/NC | DISCRETE | 1 | R82 |
| SM0603R | SM0603R | 100K | DISCRETE | 34 | R84; R92; R103; R125; R128; R134; R154; R305; R311; R320; R338; R380; R391; R394; R416; R436; R442; R457; R472; R587; R588; R605; R620; R649; R816; R823; R833; R863; R884; R911; R937; R938; R1014; R1017 |
| SM0603R | SM0603R | 1K/NC | DISCRETE | 27 | R85; R167; R343; R383; R421; R425; R443; R460; R624; R636; R659; R677; R680; R685; R686; R701; R792; R801; R809; R854; R888; R903; R916; R947; R948; R951; R952 |
| SM0603R | SM0603R | 5.36K,1% | DISCRETE | 2 | R88; R705 |
| SM0603R | SM0603R | 301,1% | DISCRETE | 1 | R94 |
| SM0603R | SM0603R | 1M/NC | DISCRETE | 3 | R100; R337; R379 |
| SM0603R | SM0603R | 5.1K | DISCRETE | 6 | R127; R196; R265; R291; R454; R957 |
| SM0603R | SM0603R | 5.6K | DISCRETE | 2 | R140; R236 |
| SM0603R | SM0603R | 150K | DISCRETE | 1 | R157 |
| SM0603R | SM0603R | 45.3,1% | DISCRETE | 2 | R159; R708 |
| SM0603R | SM0603R | 2K/NC | DISCRETE | 1 | R162 |
| SM0603R | SM0603R | 10M | DISCRETE | 2 | R163; R444 |
| SM0603R | SM0603R | 4.02K,1% | DISCRETE | 2 | R172; R254 |
| SM0603R | SM0603R | 1.87K,1% | DISCRETE | 1 | R173 |
| SM0603R | SM0603R | 1.33K,1% | DISCRETE | 1 | R175 |
| SM0603R | SM0603R | 2.21K,1% | DISCRETE | 1 | R176 |
| SM0603R | SM0603R | 49.9K,1% | DISCRETE | 1 | R177 |
| SM0603R | SM0603R | 2K | DISCRETE | 7 | R178; R179; R184; R439; R589; R765; R936 |
| SM0603R | SM0603R | 73.2,1% | DISCRETE | 3 | R181; R182; R183 |
| SM0603R | SM0603R | 51 | DISCRETE | 7 | R190; R368; R373; R731; R732; R735; R744 |
| SM0603R | SM0603R | 47.5,1% | DISCRETE | 1 | R198 |
| SM0603R | SM0603R | 287K,1% | DISCRETE | 1 | R203 |
| SM0603R | SM0603R | 27.4K,1% | DISCRETE | 4 | R204; R657; R733; R788 |
| SM0603R | SM0603R | 33 | DISCRETE | 21 | R205; R317; R331; R335; R348; R402; R403; R405; R406; R407; R408; R885; R889; R892; R904; R909; R913; R914; R919; R928; R993 |
| SM0603R | SM0603R | 20,1% | DISCRETE | 2 | R207; R233 |
| SM0603R | SM0603R | 16.9,1% | DISCRETE | 2 | R209; R237 |
| SM0603R | SM0603R | 6.98K,1% | DISCRETE | 2 | R210; R231 |
| SM0603R | SM0603R | 2.37K,1% | DISCRETE | 1 | R211 |
| SM0603R | SM0603R | 866,1% | DISCRETE | 2 | R218; R782 |
| SM0603R | SM0603R | 2.2/NC | DISCRETE | 1 | R222 |
| SM0603R | SM0603R | 2.61K,1% | DISCRETE | 2 | R228; R750 |
| SM0603R | SM0603R | 33/NC | DISCRETE | 1 | R229 |
| SM0603R | SM0603R | 6.8K | DISCRETE | 2 | R234; R802 |
| SM0603R | SM0603R | 5.1 | DISCRETE | 1 | R235 |
| SM0603R | SM0603R | 1.1,1% | DISCRETE | 2 | R239; R263 |
| SM0603R | SM0603R | 402,1% | DISCRETE | 4 | R240; R785; R790; R794 |
| SM0603R | SM0603R | 182,1% | DISCRETE | 1 | R247 |
| SM0603R | SM0603R | 100/NC | DISCRETE | 8 | R250; R336; R349; R603; R604; R630; R717; R796 |
| SM0603R | SM0603R | 619K,1% | DISCRETE | 1 | R257 |
| SM0603R | SM0603R | 57.6K,1% | DISCRETE | 2 | R288; R433 |
| SM0603R | SM0603R | 12.7K,1% | DISCRETE | 2 | R289; R456 |
| SM0603R | SM0603R | 115K,1% | DISCRETE | 2 | R290; R455 |
| SM0603R | SM0603R | 147K,1% | DISCRETE | 2 | R292; R453 |
| SM0603R | SM0603R | 200K | DISCRETE | 6 | R294; R364; R365; R376; R377; R451 |
| SM0603R | SM0603R | 49.9,1% | DISCRETE | 5 | R324; R325; R329; R786; R807 |
| SM0603R | SM0603R | 470 | DISCRETE | 1 | R332 |
| SM0603R | SM0603R | 51K/NC | DISCRETE | 2 | R339; R393 |
| SM0603R | SM0603R | 300K | DISCRETE | 1 | R358 |
| SM0603R | SM0603R | 1M | DISCRETE | 7 | R367; R392; R432; R479; R528; R530; R756 |
| SM0603R | SM0603R | 576K,1% | DISCRETE | 2 | R374; R387 |
| SM0603R | SM0603R | 866K,1% | DISCRETE | 2 | R375; R388 |
| SM0603R | SM0603R | 27K/NC | DISCRETE | 1 | R384 |
| SM0603R | SM0603R | 100K/NC | DISCRETE | 9 | R447; R606; R650; R709; R880; R987; R988; R989; R990 |
| SM0603R | SM0603R | 47K | DISCRETE | 4 | R499; R567; R579; R582 |
| SM0603R | SM0603R | 4.99K,1% | DISCRETE | 2 | R511; R548 |
| SM0603R | SM0603R | 3.3K/NC | DISCRETE | 6 | R541; R542; R949; R950; R953; R960 |
| SM0603R | SM0603R | 560/NC | DISCRETE | 3 | R549; R550; R961 |
| SM0603R | SM0603R | 75 | DISCRETE | 3 | R552; R554; R556 |
| SM0603R | SM0603R | 150 | DISCRETE | 7 | R593; R594; R595; R761; R767; R768; R769 |
| SM0603R | SM0603R | 20K,1%/NC | DISCRETE | 2 | R703; R724 |
| SM0603R | SM0603R | 7.5K/NC | DISCRETE | 1 | R720 |
| SM0603R | SM0603R | 1.24K,1% | DISCRETE | 1 | R723 |
| SM0603R | SM0603R | 301K,1% | DISCRETE | 2 | R728; R755 |
| SM0603R | SM0603R | 3.83K,1% | DISCRETE | 2 | R740; R797 |
| SM0603R | SM0603R | 220 | DISCRETE | 5 | R741; R826; R830; R846; R861 |
| SM0603R | SM0603R | 51K | DISCRETE | 1 | R758 |
| SM0603R | SM0603R | 2.55K,1% | DISCRETE | 1 | R762 |
| SM0603R | SM0603R | 3.83K,1%/NC | DISCRETE | 1 | R787 |
| SM0603R | SM0603R | 357,1% | DISCRETE | 1 | R789 |
| SM0603R | SM0603R | 23.2,1% | DISCRETE | 1 | R813 |
| SM0603R | SM0603R | 6.8K/NC | DISCRETE | 1 | R815 |
| SM0603R | SM0603R | 162,1% | DISCRETE | 1 | R824 |
| SM0603R | SM0603R | 29.4,1% | DISCRETE | 1 | R828 |
| SM0603R | SM0603R | 12K,1% | DISCRETE | 1 | R930 |
| SM0603R | SM0603R | 560 | DISCRETE | 2 | R943; R966 |
| SM0603R | SM0603R | 100K,5% THRM/NC | DISCRETE | 2 | RT1; RT5 |
| SM0603R | SM0603R | 10K,5% THRM | DISCRETE | 4 | RT2; RT3; RT4; RT6 |
| SM0805C | SM0805C | 22UF/6.3V(0805) | IC | 28 | C9; C30; C84; C144; C152; C196; C359; C370; C371; C394; C396; C397; C411; C412; C424; C434; C436; C454; C483; C490; C494; C501; C507; C543; C550; C555; C557; C690 |
| SM0805C | SM0805C | 10UF/10V(0805) | IC | 91 | C21; C22; C31; C40; C41; C45; C48; C49; C54; C89; C94; C102; C110; C111; C116; C117; C125; C127; C134; C137; C138; C145; C148; C153; C162; C169; C172; C177; C178; C188; C194; C211; C213; C219; C240; C241; C242; C243; C244; C245; C256; C290; C292; C306; C309; C328; C329; C344; C369; C373; C409; C432; C465; C470; C471; C475; C503; C522; C532; C552; C558; C565; C571; C593; C594; C613; C615; C627; C630; C663; C664; C667; C668; C680; C681; C686; C692; C696; C699; C728; C729; C730; C731; C732; C733; C734; C735; C736; C737; C738; C739 |
| SM0805C | SM0805C | 10UF/10V(0805)/NC | IC | 1 | C53 |
| SM0805C | SM0805C | 22UF/6.3V(0805)/NC | IC | 3 | C59; C405; C406 |
| SM0805C | SM0805C | 0.47UF/50V(0805) | IC | 4 | C202; C230; C232; C598 |
| SM0805L | SM0805L | BEAD 30(0805) | IC | 12 | L11; L13; L14; L15; L16; L17; L18; L22; L23; L24; L32; L36 |
| SM0805R | SM0805R | 2.2(0805) | IC | 5 | R248; R270; R272; R276; R764 |
| SM0805R | SM0805R | 0(0805) | IC | 5 | R271; R763; R774; R776; R1000 |
| SM0805R | SM0805R | 1(0805) | IC | 1 | R777 |
| SM1206C | SM1206C | 0.001UF/2KV(1206) | DISCRETE | 12 | C1; C2; C17; C257; C294; C295; C303; C304; C347; C360; C379; C727 |
| SM1206C | SM1206C | 10UF/16V(1206) | DISCRETE | 37 | C18; C25; C27; C34; C42; C43; C52; C71; C77; C88; C103; C132; C149; C163; C233; C277; C321; C322; C345; C356; C362; C385; C386; C387; C388; C451; C456; C562; C577; C592; C618; C643; C671; C682; C683; C684; C704 |
| SM1206D_AC | SM1206D_AC | 1N4148W | DISCRETE | 13 | D2; D6; D11; D12; D23; D24; D25; D28; D29; D30; D32; D39; D46 |
| SM1206D_AC | SM1206D_AC | 1N4148W/NC | DISCRETE | 1 | D4 |
| SM1206R | SM1206R | 0(1206)/NC | DISCRETE | 1 | R58 |
| SM1206R | SM1206R | 1K(1206) | DISCRETE | 2 | R255; R839 |
| SM1206R | SM1206R | 2.49K,1%(1206) | DISCRETE | 4 | R299; R300; R304; R806 |
| SM1206R | SM1206R | 0(1206) | DISCRETE | 3 | R370; R642; R858 |
| SM1206R | SM1206R | 5.1K(1206) | DISCRETE | 4 | R822; R841; R850; R851 |
| SM1210C | SM1210C | 2.2UF/100V(1210) | DISCRETE | 7 | C231; C267; C276; C281; C576; C602; C654 |
| SM2512R | SM2512R | 0.002,1%(2512) | DISCRETE | 6 | R249; R372; R390; R435; R940; R941 |
| SMA-LS | SMA-LS | FM1100LS | IC | 4 | D9; D14; D34; D40 |
| SMC | SMC | SMDJ58CA_SMC | IC | 2 | TVS5; TVS6 |
| SOIC8 | SOIC8 | APW7120KE-TRL_SOIC8 | DISCRETE | 4 | U4; U7; U12; U13 |
| SOIC8 | SOIC8 | HT24LC16-A_SOIC8 | DISCRETE | 1 | U20 |
| SOIC8 | SOIC8 | R1EX25008ASAS0A_SOIC8 | DISCRETE | 1 | U26 |
| SOIC8 | SOIC8 | HT24LC02_SOIC8 | DISCRETE | 2 | U40; U42 |
| SOIC8 | SOIC8 | HT24LC64-A_SOIC8 | DISCRETE | 1 | U45 |
| SOP8B-209 | SOP8B-209 | W25Q64FWSSIG-HF_SOIC8-209 | DISCRETE | 1 | U41 |
| SOP8B-209 | SOP8B-209 | W25Q16DVSSIG-HF_SOIC8-209 | DISCRETE | 2 | U63; U64 |
| SOP14B-300 | SOP14B-300 | LM1877M-9_SOP14B-300 | IC | 1 | U39 |
| SOT23-5 | SOT23-5 | LM8261M5/NOP5_SOT23-5 | IC | 2 | U5; U72 |
| SOT23-5 | SOT23-5 | SN74AHC1G08DBVR_SOT23-5 | IC | 1 | U10 |
| SOT23-5 | SOT23-5 | SN74LVC1G32DBVR_SOT23-5 | IC | 2 | U11; U15 |
| SOT23-5 | SOT23-5 | SN74AHC1G08DBVR_SOT23-5/NC | IC | 3 | U14; U31; U61 |
| SOT23-5 | SOT23-5 | SN74LVC1G14DBVR_SOT23-5 | IC | 10 | U22; U49; U51; U52; U53; U55; U58; U62; U65; U70 |
| SOT23-5 | SOT23-5 | SN74AHCT1G125DBVR_SOT23-5 | IC | 2 | U68; U69 |
| SOT23-6 | SOT23-6 | SESD099-04AT1_SOT23-6 | DISCRETE | 16 | ESD2; ESD3; ESD4; ESD5; ESD6; ESD7; ESD8; ESD9; ESD10; ESD11; ESD12; ESD13; ESD14; ESD15; ESD16; ESD17 |
| SOT23-6 | SOT23-6 | RT9194_SOT23-6/NC | DISCRETE | 1 | U6 |
| SOT23-6 | SOT23-6 | RT9194_SOT23-6 | DISCRETE | 2 | U9; U46 |
| SOT23_QA | SOT23_QA | 2N3906/SOT23 | DISCRETE | 2 | Q3; Q5 |
| SOT23_QA | SOT23_QA | 2N3904/SOT23 | DISCRETE | 16 | Q13; Q17; Q26; Q27; Q29; Q30; Q31; Q39; Q41; Q80; Q90; Q106; Q117; Q118; Q122; Q124 |
| SOT23_QA | SOT23_QA | 2N3904/SOT23/NC | DISCRETE | 4 | Q22; Q28; Q43; Q88 |
| TAND_7343 | TAND_7343 | 150UF/6.3V | IC | 10 | TC1; TC2; TC5; TC9; TC10; TC12; TC14; TC15; TC19; TC20 |
| TAND_7343 | TAND_7343 | 330UF/2V | IC | 9 | TC3; TC4; TC6; TC7; TC8; TC11; TC16; TC17; TC18 |
| TAND_7343 | TAND_7343 | 150UF/6.3V/NC | IC | 1 | TC13 |
| TP20 | TP20 | N/A | IC | 83 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP51; TP52; TP53; TP54; TP55; TP56; TP57; TP58; TP59; TP60; TP61; TP62; TP63; TP64; TP65; TP66; TP67; TP68; TP69; TP70; TP71; TP72; TP73; TP74; TP75; TP76; TP77; TP78; TP79; TP80; TP81; TP82; TP83 |
| TS-004A | TS-004A | TACT SWITCH_TS-004A | IC | 9 | AUTO2; BL_DN1; BL_DN2; BL_PWR1; BL_PWR2; BL_UP1; BL_UP2; MENU2; RESET1 |
| TSSOP28 | TSSOP28 | SP3243EUEY-L_TSSOP28 | DISCRETE | 1 | U44 |
| TSSOP38-T | TSSOP38-T | LT3791-1_TSSOP38-T | IC | 2 | U27; U30 |
| USB | USB | USBX2_9_2.77MM_D90 | IC | 1 | USB1_2_1 |
| USB2_L_UA04FWS-AC | USB2_L_UA04FWS-AC | USB2.0_S90 | IC | 2 | USB3_1; USB_IN2 |
| USB3_1L_S90 | USB3_1L_S90 | USB3.0_S90 | IC | 1 | USB4_1 |
| VGACON15_S_KD-T | VGACON15_S_KD-T | DSUB15_VGA_PORT(BLUE/THIN) | IC | 1 | VGA1 |
| WQFN-20L-T_3X3 | WQFN-20L-T_3X3 | RT8207MZQW_WQFN-20L-T_3X3 | IC | 1 | U19 |
| XTL_4P_5X3D2_S180 | XTL_4P_5X3D2_S180 | 27MHZ_4P/SMD | IC | 1 | X1 |
| XTL_4P_5X3D2_S180 | XTL_4P_5X3D2_S180 | 12MHZ_4P/SMD | IC | 1 | X3 |
| XTL_4P_5X3D2_S180 | XTL_4P_5X3D2_S180 | 24MHZ_4P/SMD | IC | 1 | X4 |
| XTL_4P_5X3D2_S180 | XTL_4P_5X3D2_S180 | 25MHZ_4P/SMD | IC | 3 | X5; X6; X7 |
| ZAD-4030 | ZAD-4030 | 2.2UH/4.9A_ZAD-4030MES-2R2N_S180 | IC | 1 | L9 |
