查看: 2943|回复: 45
[allegro16.6][16层]XILINX的VC707,高速DDR3布线经典(ddr3+DNP+M88E1111)原理图...
发表于 2020-3-2 16:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][16层]XILINX的VC707,高速DDR3布线经典(ddr3+DNP+M88E1111)原理图和pcb文件
文件描述:
1. 作品用途:XILINX的VC707,高速DDR3布线经典
2. 软件版本:allegro16.6
3. 层数:16层
4. 用到的主要芯片:ddr3+DNP+M88E1111
5. PCB尺寸:10500*4999 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
名称类型属性类别数量位号
32K10K_400_NEWSMA_32K10K-40032K10K-400L5IC10J25; J26; J27; J28; J29; J30; J31; J32; J33; J34
20149_9_020149.9IC2R88; R89
4020_1UF_04020.1UFIC137C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C44; C45; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C100; C102; C103; C104; C105; C347; C348; C349; C350; C351; C352; C353; C354; C355; C356; C357; C358; C359; C360; C361; C362; C363; C364; C365; C366; C367; C393; C394; C395; C396; C397; C398; C416; C417; C423; C424; C461; C462; C463; C490; C491; C492
4020_022UF_04020.022UFIC22C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C153; C154; C425; C426; C427; C428; C429; C430; C431; C432; C433; C434
4020_01UF_04020.01UFIC29C187; C188; C189; C190; C191; C192; C193; C194; C195; C196; C197; C198; C199; C200; C201; C202; C203; C204; C205; C206; C207; C208; C209; C210; C211; C213; C214; C215; C375
402DNP_C_0402DNPIC2C217; C218
4020_22UF_04020.22UFIC16C231; C232; C233; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C245; C246
4020_068UF_04020.068UFIC15C253; C254; C255; C256; C257; C258; C259; C260; C261; C262; C378; C379; C380; C381; C382
4021000PF_04021000PFIC9C263; C264; C265; C266; C267; C268; C269; C270; C271
402820PF_0402820PFIC12C292; C293; C294; C295; C296; C297; C298; C299; C387; C388; C389; C390
40218PF_040218PFIC6C300; C301; C302; C303; C304; C305
4020_47UF_04020.47UFIC16C308; C309; C310; C311; C312; C313; C314; C315; C449; C450; C451; C452; C453; C454; C455; C456
4024_7UF_04024.7UFIC12C493; C494; C495; C496; C497; C498; C499; C500; C501; C502; C503; C504
40227_4_040227.4IC1R2
4024_7K_04024.7KIC78R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R32; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R83; R244; R391; R392; R397; R398; R421; R443; R444; R445; R446; R447; R448
402DNP_R_0402DNPIC24R56; R233; R234; R235; R236; R237; R238; R241; R242; R243; R245; R246; R247; R248; R249; R250; R357; R358; R439; R440; R441; R442; R455; R456
4024_22K_04024.22KIC12R74; R75; R76; R77; R78; R79; R80; R81; R342; R343; R344; R345
402249_0402249IC3R84; R86; R87
402787_0402787IC7R90; R91; R92; R93; R346; R347; R348
40215_040215IC4R94; R95; R96; R97
402887_0402887IC1R102
40227_4K_040227.4KIC1R103
4022_43K_04022.43KIC5R104; R105; R106; R107; R108
4025_62K_04025.62KIC1R117
4026_81K_04026.81KIC1R118
40230_040230IC41R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137; R138; R139; R140; R141; R401; R402; R403; R404; R405; R406; R407; R408; R409; R410; R411; R412; R413; R414; R415; R416; R417; R418
4028_06K_04028.06KIC1R142
4021_07K_04021.07KIC1R144
40286_6K_040286.6KIC1R145
40249_9_040249.9IC8R147; R148; R149; R150; R151; R152; R153; R154
4023_48K_04023.48KIC1R155
40280_6_040280.6IC6R159; R160; R161; R162; R163; R164
402100_0402100IC35R165; R166; R167; R168; R169; R170; R171; R172; R173; R174; R175; R176; R177; R178; R179; R180; R181; R182; R183; R184; R185; R186; R187; R188; R189; R389; R390; R419; R420; R449; R450; R451; R452; R453; R454
40210_0K_040210.0KIC39R192; R193; R195; R196; R197; R199; R200; R201; R202; R203; R204; R205; R206; R207; R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R349; R350; R351; R352; R353; R354; R355; R356; R399
4021_00K_04021.00KIC31R198; R276; R277; R278; R279; R280; R281; R282; R283; R284; R285; R286; R287; R288; R289; R291; R369; R370; R371; R372; R373; R374; R375; R376; R377; R378; R379; R380; R381; R382; R400
402220_0402220IC2R226; R227
402140_0402140IC6R253; R254; R255; R256; R257; R258
402100K_0402100KIC2R259; R359
4020_04020IC17R260; R261; R262; R263; R264; R265; R272; R273; R360; R361; R362; R363; R364; R365; R366; R367; R368
4022_7K_04022.7KIC1R293
4022_00K_04022.00KIC10R294; R295; R296; R299; R300; R301; R302; R303; R383; R436
402261_0402261IC4R306; R307; R395; R396
40251_1K_040251.1KIC12R308; R309; R310; R311; R312; R313; R314; R315; R316; R317; R318; R319
4021_0M_04021.0MIC3R320; R321; R323
4024_99K_04024.99KIC1R332
40275K_040275KIC4R333; R334; R335; R388
4021_21K_04021.21KIC5R337; R338; R339; R340; R341
6031UF_06031UFIC30C167; C168; C169; C170; C171; C172; C173; C174; C175; C176; C177; C179; C180; C181; C182; C183; C185; C437; C438; C439; C440; C441; C471; C472; C473; C474; C475; C476; C477; C478
6032_2UF_06032.2UFIC1C282
603FERRITE-220_0603FERRITE-220IC21L8; L9; L10; L11; L12; L13; L14; L15; L16; L17; L18; L19; L20; L21; L22; L23; L24; L25; L26; L27; L28
60347_060347IC8R109; R110; R111; R112; R113; R114; R115; R116
0603_SHORT0603_SHORT0603_SHORTIC13Z1; Z2; Z3; Z4; Z5; Z6; Z7; Z8; Z9; Z10; Z11; Z12; Z13
80510UF_080510UFIC2C65; C252
8054_7UF_08054.7UFIC17C219; C220; C221; C222; C224; C225; C226; C227; C228; C230; C376; C377; C443; C444; C445; C446; C447
80510UF_080510UFIC3C249; C250; C251
805100PF_0805100PFIC4C486; C487; C488; C489
805FERRITE-600FERRITE-600IC5L1; L2; L3; L4; L5
80510_080510IC1R156
0805_A40_1UF_0805_CPACK0.1UFIC13CP1; CP2; CP3; CP4; CP5; CP6; CP7; CP8; CP9; CP10; CP11; CP12; CP13
120622UF_120622UFIC9C114; C115; C116; C117; C118; C119; C120; C368; C369
120647UF_120647UFIC14C123; C125; C126; C127; C128; C129; C130; C131; C132; C165; C370; C371; C372; C373
1206100UF_1206100UFIC22C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C166; C399; C400; C401; C402; C403; C404; C418; C419; C420; C421; C422
12065_6UF_12065.6UFIC1C247
120610UF_120610UFIC17C328; C329; C330; C331; C332; C333; C334; C335; C336; C337; C338; C339; C340; C341; C342; C343; C344
121010UF_121010UFIC13C133; C134; C135; C136; C138; C374; C464; C465; C466; C467; C468; C469; C470
1224_SMTLVK25R005FER0.005IC11R325; R326; R327; R328; R329; R330; R331; R384; R385; R386; R387
87832_1420MOLEX-87832-142087832-1420IC1J4
27730214472773021447FERRITE-78IC7L29; L30; L31; L32; L33; L34; L35
ASP_134486_01ASP_134486_01ASP_134486_01IC2J35; J37
BNX016-01BNX016-0150MOHMIC1U73
CAP_F330UF_8_3MMX8_3MM330UFIC8C320; C321; C322; C323; C324; C325; C391; C392
CON23_MOLEX_HDMI_RA500254_1927500254-1927IC1P2
CONN_USB_MINI_B_THCONN_USB_MINI_B_THCONN_USB_MINI_B_THIC2J2; J17
CON_MOLEX_SD_6784067840-800167840-8001IC1U29
CON_MOL_20P_74441_001074441-001074441-0010IC1P3
CON_MOL_5569_6P39-30-1060_JACK_500X54039-30-1060IC1J18
DDR3_SO-DIMM_SHIELDEDDDR3_SO-DIMMDDR3_SO-DIMM_SHIELDEDIC1J1
DIGILENT_USB_JTAGDIGILENT_USB_JTAGDIGILENT_USB_JTAGIC1U26
DIO_DFS1150_7DFLS1150DFLS1150IC1D5
EFS_R_PDSS_T22PTD08D210WPTD08D210WACIC5U20; U21; U22; U62; U63
EGP_R_PDSS_T12PTD08A020WPTD08A020WIC1U25
EGS_R_PDSS_T12PTD08A010WPTD08A010WIC1U12
HDR_1X1HDR_1X1HDR_1X1IC3J20; J21; J22
HDR_1X2HDR_1X2HDR_1X2IC11J6; J9; J10; J11; J12; J13; J14; J50; J51; J52; J53
HDR_1X3HDR_1X3HDR_1X3IC7J38; J39; J42; J43; J44; J45; J54
HDR_1X3_LOCK_MOLEXWM2701-ND22_11_2032IC1J48
HDR_2X3HDR_2X3HDR_2X3IC1J49
HDR_2X7HDR_2X7_265HDR_2X7IC1J23
HDR_BOX_2X5HDR-2X5-SHR_HDR-2X5-SHRHDR_BOX_2X5IC1J5
HSMF_C15XHSMF-C155LED-GRN-REDIC1DS1
IND_IHLP2020BZ_ERINDUCTOR_0_4_7UH4.7UHIC2L6; L7
LED_0603LED-GRN-SMT_LED_0603LED-GRN-SMTIC9DS2; DS3; DS4; DS5; DS6; DS7; DS8; DS9; DS10
LED_0603LED-GREEN-SMT_LED_0603LED-GRN-SMTIC4DS14; DS16; DS17; DS18
LED_GRN_SMALL_DUAL_STACKLED_GRN_SMALL_DUAL_STACKLED-GRN-DUAL-STACKIC3DS11; DS12; DS13
LQFP100_14X14ADV7511ADV7511IC1U48
MH_135H110HOLE_MH_110_135MH_110_135IC3MH7; MH8; MH9
MH_250H125HOLE_MH_125_250MH_125_250IC6MH1; MH2; MH3; MH4; MH5; MH6
MINIMELFDL4148DL4148IC1D1
MSOP_8INA333_MSOP-8INA333IC12U53; U54; U55; U56; U57; U58; U59; U60; U65; U66; U67; U68
OSCON_C616SVPF180M180UFIC7C479; C480; C481; C482; C483; C484; C485
OSC_EG2121CA_6PSIT9102200MHZIC1U51
OSC_SIT8102_PKG2SIT810212.00000MHZIC1U41
OSC_SIT8103_PKG2SIT810380.00000MHZIC1U40
PC28F00AG18FEPC28F00AG18FEPC28F00AG18FEIC1U3
PCIE_8LANE_EDGEPCIE_8LANE_EDGEPCIE_8LANE_EDGEIC1P1
PFC_S_PQFP_G80UCD9248PFC_QFP50P14X14-80UCD9248PFCIC3U42; U43; U64
POT_3352W2K_POT-3352W2KIC1R232
QFN36_6X6MMSI5324C-C-GMSI5324C-C-GMIC1U24
QFN_24PCA9548ARGER_QFN24PCA9548ARGERIC1U52
QFN_28CP2103GM_MLP-28CP2103GMIC1U44
QFN_RSV_16SN74AVC4T245SN74AVC4T245IC3U37; U38; U39
QFN_RSW_10SN74AVC2T245SN74AVC2T245IC1U7
RCLAMP0524PRCLAMP0524PRCLAMP0524PIC4DP1; DP2; DP3; DP4
RES_WSL3637WSL36370.005IC1R82
RJ45_HFJ11_1G01ERJ45_HFJ11-1G01ERJ45IC1P4
SAMTEC_TST_110_XX_X_DSAMTEC_TST_110_XX_X_DTST-110-01-G-DIC1J19
SC70_5NC7SZ66NC7SZ66P5XIC2U27; U28
SC70_6SN74AVC1T45SN74AVC1T45IC5U45; U46; U47; U69; U72
SI570570BAB000544DG_5X710MHZ-810MHZIC1U34
SMT_CRYS_224MHZ_HC49SD24.000MHZIC1X1
SOC_IRONWOOD_FHG1761SOC_IRONWOOD_FHG1761DNPIC1U1
SOD_123DDZ9678_SOD_123DDZ9678IC1D2
SOD_123BZX84C4V7_SOT23BZT52C5V1-TPIC3D3; D4; D7
SON10_TPS51200TPS51200DRCTTPS51200DRCTIC1U23
SOT23_3REF3012AIDBZT_SOT23_3REF3012AIDBZTIC1U35
SOT143SP0503BAHT_SOT143SP0503BAHTGIC1X5
SOT_23BAS40_04_SOT23BAS40-04IC1D6
SOT_23SI2300DS_SOT23SI2300DSIC1Q1
SOT_23NDS331N_SOT23NDS331NIC10Q2; Q4; Q5; Q6; Q7; Q8; Q10; Q15; Q16; Q17
SOT_89FCX491A_SOT_89FCX491AIC3Q11; Q12; Q13
SW6P_EVQ_WK4001EVQ-WK4001EVQ-WK4001IC1SW10
SW_450_5001201M2S3ABE2_SLIDE_2POS1201M2S3AQE2IC1SW12
SW_SDA_10PSDA05H1SBDSDA05H1SBDIC1SW11
SW_SDA_16PSDA08H1SBDSDA08H1SBDIC1SW2
SW_TL3301_G_4PTL3301EF100QG-NDTL3301EF100QGIC7SW3; SW4; SW5; SW6; SW7; SW8; SW9
T-18_AXIAL1N5335BRLG1N5335BRLGIC5D8; D9; D10; D11; D12
TANT_C150UF_TANT_C150UFIC1C272
TANT_CDNP_TANT_CDNPIC1C326
TANT_D330UF_TANT_D330UFIC2C280; C281
TANT_D330UF_LOW_ESR330UFIC12C284; C285; C286; C287; C288; C289; C290; C291; C383; C384; C385; C386
TANT_E680UF_TANT_E680UFIC5C279; C407; C408; C409; C410
TFBGA_117M88E1111_BAB1C000M88E1111IC1U50
TO_PMOD_7LMZ12002LMZ12002IC1U36
TPS2051B_DBVTPS2051B_DBVTPS2051BIC1U17
TS518FE_FL35ETS518FE_FL35ETS518FE-FL35EIC1B1
TSOT_5ADP123ADP123IC1U10
TSSOP8_65P440X300MMICS844021I_TSSOP8ICS844021IIC1U2
TSSOP8_65P440X300MMM24C08-WDW6TPM24C08-WDW6TPIC1U6
TSSOP_16CD74HC4051_TSSOP-16CD74HC4051IC3U4; U5; U61
TSSOP_20SN74LV541APWRSN74LV541APWRIC1U19
TSSOP_20TXB0108TXB0108IC1U31
TSSOP_20TXS0108ETXS0108EIC3U32; U33; U70
USB3320_QFN32USB3320_QFN32USB3320IC1U8
XTAL_ABM8XTAL_ABM825.00MHZIC2X3; X4
XTAL_CS_023_125X98XTAL_CS_023_125X98114.285MHZIC1X6
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
5 I+ A  M9 ]! g# O
发表于 2021-12-23 10:07 | 只看该作者
原理图在哪呢 请不要忽悠大家
    2023-8-4 15:22
    发表于 2021-12-21 11:02 | 只看该作者
                             好   资料
    发表于 2022-1-5 16:39 | 只看该作者
    thanks
    4 s( m  _7 x# b5 ~6 Y
    2025-11-26 15:07
  • 签到天数: 1280 天
    [LV.10]以坛为家III
    发表于 2020-10-14 06:31 | 只看该作者
    谢谢分享
    “来自电巢APP”
    发表于 2020-10-22 14:03 | 只看该作者
    :victory::victory::victory::victory::victory:kankan
    擦汗
    2021-9-6 15:33
  • 签到天数: 68 天
    [LV.6]常住居民II
    发表于 2020-12-22 11:10 | 只看该作者
    学习一下,谢谢分享。
    2021-8-19 15:42
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    发表于 2021-1-27 20:46 | 只看该作者
    allegro16.6可以打开
    发表于 2021-2-1 11:41 | 只看该作者
    谢谢分享谢谢分享
    : C1 j3 F: L8 ?6 O7 R0 k2 ?: F
    14#
    发表于 2021-2-25 23:32 | 只看该作者
    ; {1 v9 J8 P! u% [; R5 w学习一下,谢谢分享。
    16#
    发表于 2021-6-1 15:14 | 只看该作者
    学习一下,谢谢分享。
    GMT+8, 2025-11-26 23:50 , Processed in 0.218750 second(s), 28 queries , Gzip On.
