2 s4 p! \; M+ M3 Z( [2 X# f% m3 ~1 [. o
fpc(1) Free Pascal Compiler fpc(1) NAME fpc - Free Pascal Compiler (FPC) binary SYNOPSIS fpc [options] [sourcefile] DESCRIPTION This binary is the main binary of the Free Pascal Compiler (FPC) whichis a Turbo Pascal and Delphi (7.0) compatible standalone (non GCC frontend)multitarget Pascal compiler. The compiler uses LD(1) and can use AS(1) (see parameter -Aas), but alsohas its own binary object writer. The current main targets are Go32V2 (Dos DJGPP extender), Freebsd, Linux,MacOS, MacOSX, MorphOS, Netware, OS/2 and Win32. The other targets (M68Kcompilers for Atari and Amiga) are either based on older versions of the compiler orare still in development. This manpage is meant for quick-reference only. FPC comes with a great(2000+ pages) manual, which is updated constantly, while this man page can beout of date. Version number Starting with release 1.0, a new versioning system has been implemented.If the last number is even (1.0, 1.0.2), it is stable, and if the last numberis odd it is a daily changing development version.(1.0.5, 1.1) just like the linuxkernel.
) {3 x# W$ [& t+ O2 O# v
- c8 ]- v9 Y6 X3 B( f5 D% H# ]
; N5 f* Y2 F1 m5 G" h
