作品名字:[pads VX.2.4][2层]IW2691 5V 2A 苹果IPAD充电器(BAV70+SPU02N60C3)原理图+PCB文件分享下载9 l. r3 |+ x- k! V# M
4 S0 c& o' O+ q1 B
文件描述; S3 u0 k6 r1 b( s6 E- _
7 E" b! y- A7 I; \3 Z1.功能描述:苹果IPAD充电器
4 @* C1 T1 Y( c/ `( G. x7 ^6 b
0 ^5 F) U1 } ?) V9 U: n( x2.软件版本:PADS VX.2.4
% g4 `* ], B# `5 Y7 M" g
; e& P8 }/ H: B7 v5 p3.层数:2层板
0 A9 L/ ^; L( O+ O& g3 f. t( B
# Q. a4 Y4 A- Q2 {8 R0 t( J4.用到的主要芯片:SPU02N60C3 + q/ J, S) z: y5 u# \; m' s
5.PCB板尺寸:42.5mm*22mm
; s1 [) F5 d$ F, x, J# A 6 A! S* G3 S% X" j$ f2 _! b
作品截图如下: & r* c9 h9 R W/ J' W. J: O. C1 c
; Z D9 c; S2 R# ]/ ?8 d( C" P( [3 O! F# D顶层截图:
( a# M5 V4 d7 E" w
- R3 z* a. W# R/ R
底层截图:
8 z" N4 P% V+ D" Y
9 Z- V! y9 | x( S. H, x
全层截图:
, ^8 {/ n9 a P
7 @( O: g+ C1 e
5 ^5 [1 E. |' ^* r) s叠层截图:
4 x5 u! C: P- G% OBOM: | REFDES | COMP_DEVICE_TYPE | COMP_VALUE | | 位号 | 类型 | 属性 | | A | PADS1A | L | | B | PADS1A | L | | BR1 | BS-106-00-PCBA | | | C1 | CE-D10XL10-P5-1-PCBAAAAAAA | 10uF/200V | | C2 | CE-D10-P5-PCB | 15uF/400V | | C3 | CS-1206-PCB | 10pF | | C4 | R-S0805 | 1nF | | C6 | CS-0402-PCB | 100pF | | C7 | CS-0402-PCB | 10pF | | C8 | CS-0402-PCB | 470pF | | C9 | CS-0805-PCB | 0.1uF | | C10 | CS-0805-PCBA | 0.1uF | | C11 | CS-0402-PCB | 22pF | | C12 | CS-0603-PCB | 1nF | | C13 | CE-D8-P3.5-PCBA | 680uF/16V | | C14 | CE-D6.3-P2.5-PCB | 100uF/16V | | C15 | CS-1206-PCB | 1nF | | C16 | CS-0402-PCB | 10pF | | CY1 | CY-222-3.5X8-P7-1-PCBA | | | D1 | DS-S1ALS1ML-PCBAA | 1N4148 | | D2 | DS-S1ALS1ML-PCBAA | 1N4148 | | D3 | DS-S1ALS1ML-PCBAA | 1N4148 | | D4 | DS-S1ALS1ML-PCBAA | 1N4148 | | D5 | BAV70-SOT23 | BAV70 | | D6 | DS-S1ALS1ML-PCBAA | 1N4148 | | D7 | DIODE-0805B | 1N4148 | | D8 | TO-252-231-PCBA | | | F1 | FUSE-2P1AA | 10R | | IC1 | IC-SO8-OPT | iW1691-03 | | L1 | LE-8.3-01-PCBA | 8.5mH | | L2 | LC-0410V-PCBAAAAAAAAAAAAAAAAAAAA | 470uH | | N | PADS1 | L | | NTC1 | R-S0603A | 100K | | Q1 | TO-251-123-PCBAA | SPU02N60C3 | | R1 | RS-0402-PCB | | | R4 | R-S1206 | 3M | | R5 | R-S1206A | 10R | | R6 | R-S1206BAA | 220K | | R7 | R-S0805 | 10R | | R8 | R-S1206 | 1.4R | | R9 | RS-0402-PCB | | | R10 | RS-0402-PCB | | | R11 | RS-0402-PCB | | | R12 | RS-0402-PCB | | | R13 | RS-0402-PCB | | | R14 | RS-0402-PCB | | | R15 | RS-0402-PCB | | | R16 | RS-0402-PCB | | | R17 | RS-0402-PCB | | | R18 | RS-0402-PCB | | | R19 | RS-0402-PCB | | | R20 | R-S0603 | | | R21 | R-S0805 | 2K | | R22 | SMD0402 | | | R23 | SMD0402 | | | R24 | SMD0402 | | | R25 | SMD0402 | | | T1 | TH-EPC17N-02-PCBAAAAAAA | EPC17 | | USB1 | JU-DF17-PCBAA | | ) Z! v( Z1 u2 s
O9 L* _/ ]& P2 L5 Q" m' I
) M3 o* U2 o0 \5 M1 ^
# K$ g2 F9 ]6 s附件: ( }0 M* P) z8 ?7 q; q0 V, |
