8 S1 B! A/ I1 I1 H3 u. U* a
1 X1 d/ T+ r. [/ @. G, h, T5 B" O作品名字:[pads VX.2.4][2层]CT316S-Z机顶盒(9701+HY57V641620HG+S25FL004+FMS6143+LD1117A+XS3045B)原理图+PCB) s. v; n$ }* d( w4 r5 |' u
5 e7 a- q3 }' ^, D% n3 ~. }文件描述
, s1 J: E& K' m6 B" P8 b
* o1 I1 x5 g! G; @1.功能描述:机顶盒# Y" k4 \& \$ q* K
$ U* T W6 ]2 @' z2.软件版本:PADS VX.2.4
, y/ I. g; ^% @* ^ - N! {7 H4 B$ W* }: X: A- D
3.层数:2层板
# m$ d( U5 B& V! Y- a3 d3 d' c
& B* `; d6 E4 }; f; d4 H3 Q4.用到的主要芯片:HY57V641620HG+S25FL004+FMS6143
+ e3 Q" h- K8 g$ n) ]5.PCB板尺寸:115mm*105mm' P0 z3 ~. f' n
: P; _7 E8 W/ x: n0 j% r4 N; q
作品截图如下:
/ d. _4 i+ L( |) |$ u: o + j' F7 \/ h# @3 k) @+ y! x
顶层截图:
$ W+ e4 C5 L$ Q
; }9 r. F2 `4 M/ r$ d) T- L底层截图:
. }# e+ d6 u3 Q' L# N- D0 }9 ]3 j
- A0 s3 i4 ?7 m' g+ Q) m {6 H
全层截图:4 E+ U4 Y1 r0 H
" Y9 s+ h1 s ~: E5 V! H叠层截图:
3 x0 D c, R! x5 t- f4 f8 eBOM: | REFDES | COMP_DEVICE_TYPE | COMP_VALUE | | 位号 | 类型 | 属性 | | C1 | CAP0603 | 473 | | C2 | CAP0603 | 0.1UF | | C3 | CAP0603 | 270pF | | C4 | CAP0603 | 270pF | | C5 | CAP0603 | 0.1uF | | C6 | CAP0603 | 104 | | C7 | CAP0603 | 104 | | C8 | CAP0603 | 0.1UF | | C9 | CAP0603 | 103pF | | C10 | CAP0603 | 0.1UF | | C11 | CAP0603 | 0.1UF | | C12 | CAP0603 | 0.1UF | | C13 | CAP0603 | 0.1uF | | C14 | CAP0805 | 4.7uf | | C15 | CAP0805 | 4.7uf | | C16 | CAP0805 | 10uF | | C17 | CAP0805 | 10uF | | C18 | CAP0805 | 10uF | | C19 | CAP0603 | 1nF | | C20 | CAP0603 | 0.1UF | | C21 | CAP0603 | 104 | | C22 | CAP0603 | 104 | | C23 | CAP0603 | 104 | | C24 | CAP0603 | 104 | | C25 | CAP0603 | 104 | | C26 | CAP0603 | 104 | | C27 | CAP0603 | 104 | | C28 | CAP0603 | 104 | | C29 | CAP0603 | 104 | | C30 | CAP0603 | 27P | | C31 | CAP0603 | 27P | | C32 | CAP0603 | 104 | | C33 | CAP0603 | 102 | | C34 | CAP0603 | 104 | | C35 | CAP0603 | 102 | | C36 | CAP0603 | 104 | | C37 | CAP0603 | 104 | | C38 | CAP0603 | 104 | | C39 | CAP0603 | 0.1uF | | C40 | CAP0603 | 104 | | C41 | CAP0603 | 104 | | C42 | CAP0805 | 10uF | | C43 | CAP0603 | 104 | | C44 | CAP0805 | 10uF | | C45 | CAP0805 | 10uF | | C46 | CAP0603 | 104 | | C47 | CAP0603 | 104 | | C48 | CAP0603 | 104 | | C49 | CAP0603 | 104 | | C50 | CAP0603 | 104 | | C51 | CAP0603 | 100n,NI | | C52 | CAP0603 | 104 | | C53 | CAP0603 | 102 | | C54 | CAP0603 | 102 | | C55 | CAP0603 | 104 | | C56 | CAP0603 | 104 | | C57 | CAP0603 | 270pF | | C58 | CAP0603 | 100nF | | C59 | CAP0603 | 22P | | C60 | CAP0603 | 10P | | C62 | CAP0603 | 100P | | C63 | CAP0603 | 100nF | | C64 | CAP0603 | 100nF | | C65 | CAP0603 | 100nF | | C66 | CAP0603 | 100nF | | C67 | CAP0603 | 100nF | | C68 | CAP0603 | 100nF | | C69 | CAP0805 | 4.7uF | | C70 | CAP0603 | 104 | | C71 | CAP0603 | 10P | | C72 | CAP0603 | 100nF | | C73 | CAP0603 | 10P | | C74 | CAP0603 | 100nF | | C84 | CAP0603 | 390 | | C85 | CAP0603 | 390 | | C87 | CAP0603 | 1000P | | C88 | CAP0603 | 1000P | | C91 | CAP0603 | 104pF | | C111 | CAP0603 | 10nF/NC | | C112 | CAP0603 | 100nF/NC | | C114 | CAP0603 | 104 | | C115 | CAP0603 | 104 | | C117 | CAP0603 | 47P | | C118 | CAP0603 | 56P | | C119 | CAP0603 | 56P | | C120 | CAP0603 | 10nF | | C121 | CAP0603 | 220P | | C122 | CAP0603 | 22P | | C123 | CAP0603 | 104 | | C124 | CAP0603 | 102 | | C125 | CAP0603A | 1P | | C126 | CAP0603 | 1uF | | C127 | CAP0603 | 103 | | C128 | CAP0603 | 100P | | C129 | CAP0603A | 1P | | C130 | CAP0603 | 10P | | C131 | CAP0603 | 22P | | C132 | CAP0603 | 10P | | C133 | CAP0603 | 22P | | C134 | CAP0603 | 10nF | | C135 | CAP0603 | 10nF | | C136 | CAP0603 | 104 | | C137 | CAP0603 | 10P | | C138 | CAP0603 | 22P | | C139 | CAP0603 | 10nF | | C140 | CAP0603 | 22P | | C141 | CAP0603 | 10P | | C142 | CAP0603 | 10nF | | C143 | CAP0603 | 10P | | C144 | CAP0603 | 10P | | C145 | CAP0603 | 4.7k | | C146 | CAP0603 | 1nF | | C147 | CAP0603 | 2.2nF | | C148 | CAP0603A | 47P | | C149 | CAP0603A | 47P | | C150 | CAP0603 | 1nF | | C151 | CAP0603 | 1nF | | C153 | CAP0603 | 220nF | | C154 | CAP0603 | 10nF | | C170 | CAP0603 | 104 | | C171 | CAP0603 | 104 | | C172 | CAP0603 | 104 | | C173 | CAP0603 | 1uF | | C174 | CAP0603 | 102 | | C201 | CAP0603 | NC | | C302 | CAP0603 | NC/1000P | | C303 | CAP0603 | 100nF | | C305 | 805 | 10uF | | C307 | CAP0805 | 4.7uF | | C503 | CAP0603 | 47pF | | C701 | CAP0603 | 0.1uF | | CE6 | CAPE/2.5/6 | 220uF/16V | | CE7 | CAPE/2/5 | 10uF/10V | | CE8 | CAPE/2/5 | 47uF/25V | | CE9 | CAPE/2/5 | 100uF/16V | | CE10 | CAPE/2/5 | 100u/16V | | CE13 | CAPE/2/5 | 100u/16V | | CE14 | CAPE/2/5 | 100UF/16V | | CE20 | CAPE/2.5/6 | 10UF/50V | | CE24 | CAPE/2/5 | 10uF/16V | | CE25 | CAPE/2.5/6 | 220uF/16V | | CE27 | CAPE/2/5 | 100uF/16V | | CE101 | CAPE/2.5/6 | 470uF/10V | | CE104 | CAPE/2.5/6 | 220uF/16V | | CE304 | CAPE/2/5 | 22uF/50V | | CE501 | CAPE/2/5 | 100uF/16V | | CE701 | CAPE/2/5 | 10uF/35V | | CE702 | CAPE/2.5/6 | 470uF/10V | | CN1 | CON-5/2MM | | | CON101 | CON2.5-8 | 8Pin-2.54 | | D2 | DIO-1210 | M2 | | D3 | DIO-1210 | M2 | | D6 | 1608/8 | BAG63-03 | | D11 | DIO-3 | R2000 | | D12 | DIO-3 | FR104 | | D16 | DIO-3 | R2000 | | D17 | DIO-3 | R2000 | | D18 | DIO-1210 | M2 | | D19 | DIO-3 | IN4001 | | D701 | DIO-1206 | 1N4148 | | D702 | DIO-1206 | 1N4148 | | E1 | RES0603 | NC | | E2 | RES0603 | NC | | H2 | HOLE(F)NH | | | H7 | HOLE(F)NH | | | I1 | HOLE(5.0) | | | IC205 | SOP-8 | XS3045B | | J1 | JACK-CABLEX4P | RFIN | | J2 | JACK-CABLEX4P | RFOUT | | J4 | SMART_CARD | | | J5 | AV4-8.4-10 | | | J7 | USB-A-03B | BLM21P221SG | | J701 | DB9-HM | DB9M | | L1 | IND-0805 | 1.2uH | | L2 | IND-0805 | 2.7uH | | L3 | IND-0805 | 1.8uH | | L4 | IND-0805 | FB | | L5 | IND-0805 | FB | | L6 | IND-0805 | FB | | L7 | IND-0805 | 2.7uH/NC | | L9 | IND-0805 | FB | | L12 | IND-0805 | 1.8uH | | L14 | IND-0805 | 1.2uH | | L15 | IND-0603A | 4.7nH | | MARK1 | MARK | | | MARK2 | MARK | | | MARK3 | MARK | | | MARK4 | MARK | | | MARK8 | MARK | | | MARK9 | MARK | | | N1 | ZL10039 | 5039 | | P1 | HOLE(2.0) | | | P2 | HOLE(2.0) | | | P3 | HOLE(2.0) | | | P4 | HOLE(2.0) | | | P11 | HOLE(0.5) | | | PA1 | HOLE(0.5) | | | PA2 | HOLE(0.5) | | | PA3 | HOLE(0.5) | | | PA4 | HOLE(0.5) | | | PA5 | HOLE(0.5) | | | PA6 | HOLE(0.5) | | | PA7 | HOLE(0.5) | | | PA8 | HOLE(0.5) | | | Q1 | TO-92(EBC) | 8550 | | Q2 | SOT-23 | NC | | Q4 | SOT-23 | 3904 | | Q5 | SOT-23 | 3904 | | Q6 | SOT-23 | 3904 | | Q7 | SOT-23 | NC | | Q9 | TO-92A | | | Q10 | SOT-23 | 3904 | | Q11 | SOT-23 | | | Q12 | SOT-23 | 3906 | | Q16 | SOT-23 | 3904 | | Q18 | TO-92(EBC) | 8550 | | Q28 | SOT-23 | 3904 | | Q701 | SOT-23 | 3906 | | Q702 | SOT-23 | 3904 | | R1 | RES0603 | NC | | R2 | RES0603 | NC | | R3 | RES0603 | 10K,NC | | R4 | RES0603 | 10k | | R5 | RES0603 | 100K | | R6 | RES0603 | NC | | R7 | RES0603 | NC | | R8 | RES0603 | NC | | R9 | RES0603 | NC | | R10 | RES0603 | NC | | R11 | RES0603 | 4.7K | | R12 | RES0603 | 2k2 | | R13 | RES0603 | 12K | | R14 | RES0603 | 3.3K | | R15 | RES0603 | 20K | | R16 | RES0603 | 20K | | R18 | RES0603 | 10k | | R19 | RES0603 | 4k7 | | R20 | RES0603 | 0 | | R22 | RES0603 | 33 | | R23 | RES0603 | 33 | | R24 | RES0603 | 2.7K | | R25 | RES0603 | 1M | | R26 | RES0603 | 4k7 | | R27 | RES0603 | 33 | | R28 | RES0603 | 33 | | R29 | RES0603 | 220R | | R30 | RES0603 | NC | | R34 | RES0603 | 33 | | R35 | RES0603 | 33 | | R36 | RES0603 | 1K | | R37 | RES0603 | 10K | | R38 | RES0603 | 6.04K 1% | | R39 | RES0603 | 10K | | R45 | RES0603 | 2K2 | | R46 | RES0603 | 2K2 | | R49 | RES0603 | 1K | | R50 | RES0603 | 33 | | R51 | RES0603 | 33 | | R52 | RES0805 | 1k8 | | R53 | RES0603 | 4.7K | | R54 | RES0603 | 47R | | R55 | RES0603 | 10K | | R56 | RES0603 | 10K | | R57 | RES0603 | 4k7 | | R66 | RES0603 | 33 | | R67 | RES0603 | 33 | | R75 | RES0603 | 100 | | R79 | RES0603 | 270K | | R80 | RES0603 | 270K | | R81 | RES0603 | 15K | | R82 | RES0603 | 15K | | R83 | RES0603 | 4K7 | | R84 | RES0603 | 4K7 | | R85 | RES0603 | 20K | | R86 | RES0603 | 20K | | R87 | RES0603 | 51K | | R88 | RES0603 | 51K | | R89 | RES0603 | 75 | | R90 | RES0603 | 75 | | R99 | RES0603 | 1k | | R100 | RES0603 | 510 | | R101 | RES0603 | 510 | | R103 | RES0603 | 2k2 | | R104 | RES0603 | 4K7 | | R106 | RES0603 | 47K | | R107 | RES0603 | 47K | | R108 | RES0603 | 4K7 | | R109 | RES0603 | 10K | | R110 | RES0603 | 15R | | R158 | RES0603 | 200R | | R159 | RES0603 | 200R | | R160 | RES0603 | 200R | | R171 | RES0603 | 10K | | R172 | RES0603 | 10K | | R175 | RES0603 | 4K7/NC | | R176 | RES0603 | 4k7/NC | | R177 | RES0603 | 220/NC | | R179 | RES0603 | 150/NC | | R180 | RES0603 | 8.2K | | R181 | RES0603 | 8.2K | | R182 | RES0603 | MBW1608-121 | | R183 | RES0603 | MBW1608-121 | | R184 | RES0603 | 51R | | R185 | RES0603 | 51R | | R186 | RES0603 | 51R | | R187 | RES0603 | 51R | | R188 | RES0603 | 100R | | R189 | RES0603 | 100R | | R190 | RES0603 | MBW1608-121 | | R220 | RES0603 | 1k | | R221 | RES0603 | 100 | | R306 | RES0603 | 10K | | R307 | RES0603 | 33 | | R331 | RES0603 | 0R | | R501 | RES0603 | 20K | | R502 | RES0603 | 20K | | R520 | RES0603 | 75R\NC | | R535 | RES0603 | 2.2K | | R701 | RES0603 | 1K | | R702 | RES0603 | 4K7 | | R703 | RES0603 | 4K7 | | R704 | RES0603 | 2K2 | | R705 | RES0603 | 2K2 | | R706 | RES0603 | 2K2 | | RN1 | RN4 | 33 | | U1 | DPAKA | 1.8V | | U2 | SO28 | | | U4 | FP128M5GA | | | U5 | SOP8-300 | | | U8 | DIP8\SO | JRC4558 | | U10 | SOT-223 | 3.3v | | U15 | SDRAM54 | | | X1 | XTAL | 27MHz | | XS1 | XTAL | 10.111MHz |
* i7 }' R( y3 A3 n+ Y, r
( }0 u1 e, A8 m8 g7 g. t! u ) _" \2 K8 O* a! E- l' T( q
2 z( R: N. r5 R附件: & G! a; h( ?9 M- P) q" u
