查看: 415|回复: 1
matlab好像删错东西,帮助文档用不了了!!!!!
发表于 2020-2-26 17:31 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
本来是下载另一个软件,但是捆绑了一堆破玩意,一气之下就全删了,删完之后,用matlab的时候才发现好像帮助文档用不了了。。。是不是删错东西了?????求大神指点指点=-=! _& C- M0 ?7 }7 E8 K7 @/ @
' ]% U6 ]6 a# B+ ^
错误使用 docsearch (line 34); v+ q  l+ X  E; k+ A
Java exception occurred:' a2 B  d, j7 m0 ~) E: _
java.lang.NullPointerException$ o0 |2 C0 p1 k  u" I9 p, C+ N8 R
8 v( |, s% C  J        at com.mathworks.html.UrlTransformer.transformUrl(UrlTransformer.java:15)1 Y# }8 @( U6 c* ?8 E
! n" v5 r& x% t: d5 J1 d9 ~' ]        at com.mathworks.html.UrlBuildeRFactory.toUrlBuilder(UrlBuilderFactory.java:15)1 m5 \, R6 @5 e; B0 t
( n% }0 }) f! l; r  j% }/ Q
        at com.mathworks.html.UrlBuilder.fromUrl(UrlBuilder.java:87)
  C" N; M. C6 D0 ^  g4 c  k8 v' ]' e# l# E7 f! c3 L( Q6 @5 F
        at com.mathworks.help.helpui.DocRoot.buildSearchPageUrl(DocRoot.java:176)$ u: T6 q" ^/ u; X5 N, h) I; H# V
# ~9 S$ M# B+ T7 p
        at com.mathworks.help.helpui.DocRoot.buildSearchPageUrl(DocRoot.java:163)( X3 u7 w5 c. D7 {
  R. o0 J& Y' y, l
        at com.mathworks.mde.help.JsHelpBrowser.docSearch(JsHelpBrowser.java:197)
. H$ {- r4 ?3 d, l1 Z' @
, ^& W7 |. }" A" p- }3 S        at com.mathworks.mlservices.MLHelpServices.docSearch(MLHelpServices.java:257)/ K3 ?: o4 `& M1 f* E  C4 h) Q: _
% H4 U1 R  |) g2 I
3 e2 \  Z1 r' V4 J! J
5 I2 s2 j/ v' v0 _1 X* Z
. d: R2 r- Q1 Z2 E( s
6 [0 n' e" c" H, z) I. \; o- E8 Z. C+ i  w! S( T/ ]
$ ~7 t+ F' n# C6 f7 r8 L6 f# y% A
/ ^/ _2 ]0 O' I. j! z& l# X  f" l/ D- x3 R2 H5 a
Exception in thread "AWT-EventQueue-0": java.lang.NullPointerException3 a! }: j! A; k, |) }
        at com.mathworks.mlwidgets.help.DocConfigUrlBuilder.getUrlForDocConfig(DocConfigUrlBuilder.java:29)
' I$ g2 Y: o# l9 n* N        at com.mathworks.mlwidgets.help.LightweightHelpPanel.getNavigationUrl(LightweightHelpPanel.java:268)
  ]1 d! _6 E3 C6 {        at com.mathworks.mlwidgets.help.LightweightHelpPanel.setCurrentLocation(LightweightHelpPanel.java:162)
- {! }+ y& B8 _3 K4 {$ Q        at com.mathworks.mde.help.JsHelpBrowserClient.setCurrentLocation(JsHelpBrowserClient.java:192)
$ C6 H8 w* H2 S# D+ `! D- _        at com.mathworks.mde.help.JsHelpBrowserClient.showClient(JsHelpBrowserClient.java:244)& u# W6 j9 i6 o8 d
        at com.mathworks.mde.help.JsHelpBrowser$OpenInNewBrowser.openBrowser(JsHelpBrowser.java:368)& T' \2 ^( T0 d9 Z! A
        at com.mathworks.mde.help.JsHelpBrowser$JsHelpBrowserRunnable.createAndShowBrowser(JsHelpBrowser.java:320)
& g! g1 B' G% n# Y$ f        at com.mathworks.mde.help.JsHelpBrowser$JsHelpBrowserRunnable.run(JsHelpBrowser.java:315), ?% F1 I% t) i
        at com.mathworks.mde.help.JsHelpBrowser.doHelpBrowserTask(JsHelpBrowser.java:282)" a* y; l9 B( G. V
        at com.mathworks.mde.help.JsHelpBrowser.doHelpBrowserTask(JsHelpBrowser.java:276), Z3 j, s: C; N- [. z% G" }" X* k
        at com.mathworks.mde.help.JsHelpBrowser.invoke(JsHelpBrowser.java:56)
& b0 v6 \4 k2 S  d& N2 k& B8 X' a        at com.mathworks.mde.help.JsHelpBrowser.invoke(JsHelpBrowser.java:47)
# l  X3 q/ I( P# d6 y' a. V        at com.mathworks.mlservices.MLHelpServices.invoke(MLHelpServices.java:41)7 f0 |. C: E1 X$ a/ Z# ~9 k' {7 t1 q
        at com.mathworks.mde.desk.MLDesktop$HelpProductPageAction.actionPerformed(MLDesktop.java:3241)4 ^( z5 [- f; \4 L/ a4 |
        at com.mathworks.mwswing.ChildAction.actionPerformed(ChildAction.java:214)2 M9 D: k3 m' P6 E; z! c6 Y
        at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
- i" i- O9 e( F' @. x0 \/ F        at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)6 {; a4 ~( z: }) p; Y
        at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
) t0 u1 y: k; z; X$ G: T1 @        at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)* ?0 a$ D, D7 b$ S0 o
        at com.mathworks.toolstrip.plaf.RegularButtonUI$RegularToolstripButtonListener.mouseReleasedImpl(RegularButtonUI.java:348)
! Q. j7 `, E" o; n) q" |1 r: m: |        at com.mathworks.toolstrip.plaf.RegularButtonUI$RegularToolstripButtonListener.mouseReleased(RegularButtonUI.java:338)
$ z* e) T1 D  d6 C        at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
# A: K+ k3 @; P, ]" ~        at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)9 V- L/ w) y+ {8 I3 d6 [5 {' e
        at java.awt.Component.processMouseEvent(Component.java:6539)
" M) D0 H  z! }8 b3 ~. c        at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
4 p4 k# Z6 |1 z1 q1 g- t* l5 q        at com.mathworks.mwswing.MJButton.processMouseEvent(MJButton.java:350)
& c1 I' D& ?( r        at java.awt.Component.processEvent(Component.java:6304)% X2 d2 a; t/ K. X8 M3 f
        at java.awt.Container.processEvent(Container.java:2239)0 e- `2 W" U; |! A1 k
        at java.awt.Component.dispatchEventImpl(Component.java:4889)
$ J7 e+ E' l: ]        at java.awt.Container.dispatchEventImpl(Container.java:2297)
7 z) i" T& u9 v. M2 Z        at java.awt.Component.dispatchEvent(Component.java:4711)
' N0 A$ Q) t) R        at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
) [2 S1 t/ ^% u  n: _3 d8 F( h        at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
1 O- ?+ Y* G# V8 I( @  I        at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)2 F3 |+ O; Z1 d! w7 n  T
        at java.awt.Container.dispatchEventImpl(Container.java:2283)
, L0 t8 T6 v+ x: p7 U        at java.awt.Window.dispatchEventImpl(Window.java:2746)
+ `/ H. B8 L2 W: M* C        at java.awt.Component.dispatchEvent(Component.java:4711)( F' z3 }; k/ Y- Q
        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)9 ?# @( |3 G$ ~7 t% u6 P8 E9 v
        at java.awt.EventQueue.access$500(EventQueue.java:97)$ K# ]( v: Y; @- L, U4 p* O
        at java.awt.EventQueue$3.run(EventQueue.java:709)
/ l& A0 ~6 ]0 c$ j% b; |        at java.awt.EventQueue$3.run(EventQueue.java:703)
0 U% A( ]! L% G: \( n6 j5 h        at java.security.AccessController.doPrivileged(Native Method)& D* a5 v+ v6 r; B
        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
% A5 m0 d; c4 e- B- W        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)" E0 v6 z2 Y3 Z& R% q% B9 d" M
        at java.awt.EventQueue$4.run(EventQueue.java:733)
# ~4 _2 ]6 ]' a/ _) n# q5 s        at java.awt.EventQueue$4.run(EventQueue.java:731)& w2 K. g) }: H5 E. [2 ~3 e. K! l
, M8 x* l2 x4 A1 X+ G, h8 d        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)6 y, r: Z( h* ]& V9 S8 y' q) p
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)( |! J" m; `& m  A: R* p1 _
        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
1 `  `1 T2 G6 T        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
2 X$ v6 e# s- r- |: ^        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)( C$ u  ?; \) c8 ^. S
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)& L# }) ~/ Y3 Y1 @5 X9 k2 X
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
. I& D6 f7 L$ h# G( m        at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)' v5 D& J" k* J2 ]8 ^
' I( X' H! r5 K8 J2 i  h+ `
6 P8 N" g6 x; ^+ d4 v
1 A% \" I2 y) j* B. q
4 T; j7 P% \* ]. }???????????????????????????????
0 ~* J. _. D- [6 G这是什么玩意?help
3 P' j" K4 P" P$ T+ M2 |& m7 g' k7 _5 S; L5 v0 E
+ N. B* J, |0 N6 i
' d  [$ N8 @7 s4 Y# d. Q/ n
GMT+8, 2025-11-24 01:41 , Processed in 0.140625 second(s), 24 queries , Gzip On.
