作品名:[AD 10][2层] VW2010视频卡(89C51RV2+XC2S100E+SAA7115)PCB文件分享下载
: @# {# i4 U) g7 _
0 {( W+ a0 d- N& r文件描述8 F' m7 t3 V, f9 M6 D
1. 作品用途:VW2010视频卡8 i; Q B) } n; F7 I2 U
2. 软件版本:AD 10
7 ^6 |. v# z$ d6 L4 [% l3. 层数:2层板) w0 H0 K+ `' n3 [1 K; q& B; x
4. 用到的主要芯片:89C51RV2+XC2S100E+SAA7115+SAA7121+MAX3387E
* ]+ x1 P% A1 {$ \, Z) i7 U5 r& f5. PCB尺寸:293.9mm*196.7mm
# Y/ @# }4 V8 n& c
+ d. q% `! _" W6 G5 r4 q+ [作品截图如下:4 E4 F/ C2 S4 K# L; {+ o% L
顶层截图:1 d4 q2 k# K# G* Q/ T9 m" @# k* C
4 c; E8 a9 ^/ v7 V6 B
6 E- S# L3 [+ O; V1 T9 K1 I. r. i底层截图:
r7 Y( ~5 e1 ]
2 T3 h. ~' n" ? j
( p; d) G7 I, n全层截图:) j! E) h2 O9 D3 a2 G8 S9 @
5 `4 {6 F& `( ^ c' K+ Q! y
/ D+ Y. `9 J; G3 ^; ?. q叠层信息截图如下:
$ N4 f5 n. ^& j) r
9 v: |) V7 l+ `2 }; m4 c/ T3 Q
" ^4 G) `/ l; M9 {4 B# M" C, DBOM:
* A, G) d& }! w$ k2 q/ a/ H2 f3 D3 Y| Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | 0603-16V-0.1uF | C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21, C22, C23, C24, C28, C29, C30, C31, C32, C33, C34, C35, C36, C37, C38, C50, C51, C53, C54, C55, C56, C57, C58, C59, C71, C72, C73, C74, C75, C76, C77, C82, C83, C87, C88, C89, C90, C93, C94, C98, C99, C100, C101, C102, C103, C104, C105, C106, C107, C108, C109, C110, C111, C112, C113, C114, C115, C116, C117, C118, C119, C120, C121, C122, C123, C124, C127, C128, C129, C130, C131, C132, C133, C134, C135, C136, C137, C138, C139, C140, C142, C143, C146, C147, C148, C150, C151, C152, C154, C155, C156, C157, C158, C159, C160, C161, C162, C163, C164, C165, C166, C167, C168, C169, C170, C171, C172, C173, C174, C175, C176, C177, C178, C179, C180, C181, C182, C183, C184 | 0603 | 139 | | CAK45-25V-10uF(E) | C25, C26, C27, C52, C64, C65, C78, C79, C80, C81, C86, C95, C96, C97 | CAK45-E | 14 | | CT41L-1812-2C1-50V-474K-0.047uF | C39, C40, C41, C42, C43, C44, C45, C46 | 1812 | 8 | | CC41L-0805-CG-50V-221K-220pF | C47, C48, C49 | 0805 | 3 | | CAK45-10V-47uF(C) | C60, C61, C62, C63 | CAK45-C | 4 | | CAK45-16V-47uF(C) | C66 | CAK45-C | 1 | | CAK45-16V-100uF(F) | C67, C68, C69, C70, C92, C141, C145, C149 | CAK45-F | 8 | | CT41L-0805-50V-680pF | C84, C85 | 0805 | 2 | | CC41L-0805-CG-50V-270pF | C91, C144 | 0805 | 2 | | CC41L-0805-C9-50V--300K-30pF | C125, C126 | 0805 | 2 | | CAK45-10-22uF(C) | C153 | CAK45-C | 1 | | CC41L-0805-CG-50V-150pF | C185, C186, C187 | 0805 | 3 | | XC2S100E-PQ | D1 | PQ208 | 1 | | XC18V01PC20C | D2 | PC20 | 1 | | VW2010 | D3 | BGA365/1.27X20 | 1 | | EL7562 | D4, D5 | QSOP16-EL7562 | 2 | | SAA7121 | D6 | QFP44 | 1 | | UDA1342TS | D7 | SSOP28 | 1 | | CS4331-KS | D8 | SO8 | 1 | | SAA7115 | D9 | QFP100 | 1 | | MAX811-CUS-T(4) | D10 | SOT-143 | 1 | | 89C51RV2 | D11 | ISP1016 | 1 | | CY7C4285/75/65V | D12, D13 | PQFP64 | 2 | | MAX3387E | D14 | SSOP24 | 1 | | AM26LV31 | D15 | D16-26LV31/32 | 1 | | AM26LV32 | D16 | D16-26LV31/32 | 1 | | 7407 | D17 | DIP14 | 1 | | MT48LC2M32B2TG | D18, D19 | TSOP86/.5X11.41 | 2 | | AT49BV1614A | D20 | TSOP48 | 1 | | 32.11M | G1 | SOP_CRST | 1 | | 27MHz | G2 | CRST | 1 | | 12MHz | G3 | XTAL1 | 1 | | SW DIP-8 | K1 | DIP16 | 1 | | RESET | K2 | switch | 1 | | POWER SWITCH | K3 | POWERSWITCH | 1 | | 22uH | L1, L2, L3, L4, L5, L6, L7, L8 | AXIAL0.4 | 8 | | 4.7uH | L9, L10 | INDUCTOR-5 | 2 | | PAD | P1, P2, P3, P4, P5, P6, P7, P8 | PAD1 | 8 | | RMK2012-0.1W-18 | R1, R2, R3 | RMK2012 | 3 | | RMK2012-0.1W-56 | R4, R9, R10 | RMK2012 | 3 | | RMK2012-0.1W-22 | R5, R8, R12, R28, R29, R30, R31, R34, R35, R54, R55, R66, R67 | RMK2012 | 13 | | RMK2012-0.1W-100 | R6, R7, R27 | RMK2012 | 3 | | RMK2012-0.1W-3.3K | R11, R65 | RMK2012 | 2 | | RMK2012-0.1W-100K | R13 | RMK2012 | 1 | | RMK2012-0.1W-10 | R14, R15, R22, R73, R74 | RMK2012 | 5 | | RMK2012-0.1W-4.7 | R16 | RMK2012 | 1 | | RMK2012-0.1W-15K | R17, R18, R19, R20 | RMK2012 | 4 | | RMK2012-0.1W-4.7K | R21, R32, R33, R63, R64 | RMK2012 | 5 | | RMK2012-0.1W-56K | R23, R24 | RMK2012 | 2 | | RMK2012-0.1W-2.4K | R25, R26 | RMK2012 | 2 | | RMK2012-0.1W-10K | R36, R37, R38, R39, R40, R41, R44, R45, R46, R47, R48, R49, R50, R51, R62, R68, R69, R70, R71, R72, R76, R77, R78, R79 | RMK2012 | 24 | | RMK2012-0.1W-470 | R42, R43, R52, R53 | RMK2012 | 4 | | RMK2012-0.1W-1K | R56, R75 | RMK2012 | 2 | | RMK2012-0.1W-2K | R57 | RMK2012 | 1 | | 0-5K | R58, R59 | SIP3 | 2 | | RMK2012-0.1W-39 | R60, R61 | RMK2012 | 2 | | LED | V1, V2, V3, V4 | LED0.1 | 4 | | IN4148 | V5, V6, V7 | Diode0.24 | 3 | | IN5817 | V8 | Diode0.24 | 1 | | TJ3-8 | X1, X2 | SIP8 | 2 | | HEADER 3X2 | X3 | IDC6 | 1 | | POWER | X4 | POWER | 1 | | POWER | X5 | SIP3 | 1 | | HEADER2 | X6, X7, X8, X9, X10, X11 | SIP2 | 6 | | RCA | X12, X13 | RCA | 2 | | S-VIDEO | X14, X15 | S-VIDEO | 2 | | PHONEJACK STEREO SW | X16, X17 | STEREO | 2 | | DB9 | X18, X19, X20 | DB9/F | 3 | | HEADER 2 | X21 | SIP2 | 1 | | HEADER12 | X22 | SIP12 | 1 | | HEADER 16X2 | X23 | IDC34 | 1 | | HEADER 2X2 | X24 | HEAD4 | 1 | 7 \* {' T8 r" I7 a0 \
附件:
4 H1 w3 |0 J% U) j2 Q原理图和PCB源文件如下:2 S5 C5 J; n6 s& K. t* E, n
" c5 t) ~% ?! @0 n
; p1 e( W4 @+ `6 d& \/ E3 Q
