作品名:[AD 15][2层] 带霍尔传感器的直流无刷电机设计(STC12C5A60S2+LM393N+FSB50325)原理图、PCB源文件) K9 P! e5 T7 ]) W
z2 U! [0 r) E& r. N+ O& i$ C文件描述
0 f$ d: [% H& n! v4 n5 z3 l5 _1. 作品用途:带霍尔传感器的直流无刷电机 9 T% s4 X ^7 z9 A# c7 v
2. 软件版本:AD 15
' b' q' L, x+ @+ ]3. 层数:2层板+ M* U3 l& P- _" S
4. 用到的主要芯片:STC12C5A60S2+LM393N+FSB50325/ z2 {8 p4 b0 u
5. PCB尺寸:146mm*101mm
* m1 e+ G5 b, k; d# F" ]+ s
- N2 H+ t4 R! A6 Y作品截图如下:
( w) P4 H2 D# J顶层截图:3 K! i* N) }9 a8 m2 O! F ^+ t
8 I% v5 J! x P2 L: ^底层截图:& A V) s+ ^% {& b
8 n% U5 x7 ~& ^
全层截图:
2 ^/ G* F4 A( Q0 x; t( X
) h& Y- J4 t7 \* s1 [叠层信息截图如下:
; }5 P5 n# m0 {( [) A: d) z
/ E" f+ ?5 q" ?. s% O) U9 y; dBOM:
- f+ f2 c2 B3 L- z! U% j| Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | C1 | DIODE25V | 1 | | C2, C5 | DIODE16V | 2 | | Cap Semi | C3, C4, C8, C9, C10, C11, C12, C13, C14, C15, C16, C21, C22, C23, C24, C25, C26, C27 | 0603 | 18 | | 0.1u | C6, C7 | 0603 | 2 | | Cap Pol3 | C17 | ELEC A | 1 | | MJ-179P | CN1 | POWER IN A | 1 | | Header 8 | CN2 | CON_MOTOT | 1 | | Header 8 | CN3, CN4 | HDR1X8 | 2 | | Header 4 | CN5 | HDR1X4 | 1 | | 1N5822 | D1 | DO-214AA | 1 | | 1N4148 | D2, D3, D6, D7 | DSO-F2/D6.1 | 4 | | HER103 | D4, D5, D8 | DO-214AA | 3 | | 1SS404 | D9 | 1SS404 | 1 | | UT | DS2 | LED1206 | 1 | | UB | DS3 | LED1206 | 1 | | VT | DS4 | LED1206 | 1 | | VB | DS5 | LED1206 | 1 | | WT | DS6 | LED1206 | 1 | | WB | DS7 | LED1206 | 1 | | E1_1RMB | E1 | IDC-14 A | 1 | | GND | TP A | 2 | | J6 | J1 | JMP-2 DIP (2.54) | 1 | | J4 | J2 | JMP-2 DIP (2.54) | 1 | | POWER | LED1 | LED1206 | 1 | | IRF7313 | Q1 | SO-G8/Y2.2 | 1 | | Res1 | R1, R2, R3, R4, R5, R6, R7, R8, R9, R11, R12, R13, R14, R15, R16, R17, R18, R19, R21, R22, R23, R24, R25, R26, R27, R29, R31, R33, R35, R36 | 0603 | 30 | | RPot1 | R10 | RES3 | 1 | | 1K | R20, R32, R34 | 0603 | 3 | | Res1 | R28 | 2512 | 1 | | 470 | R30 | 0603 | 1 | | SWITCH_PW | SW1 | SW-3 A | 1 | | SW-PB | SW2, SW4 | KEY_A_(6_X_6) | 2 | | SW DIP-1 | SW3 | DIP_SW_1WAY_SMD | 1 | | MC7805CT | U1 | DPAK | 1 | | LM393N | U2 | SO-G8 | 1 | | FSB50325 | U3 | FSB50325 | 1 | | RL78_RTIO&HCIO | U4 | TSSOP20 | 1 | | SN74HC14N | U5 | SO-G14/E2 | 1 | | LM358N | U6 | SO-G8 | 1 | | SN74HC03D | U7 | SO-G14/E2 | 1 | | SN74HC04D | U8 | SO-G14/E2 | 1 | | 5K | VR1 | VR B | 1 | 附件:# g) F$ C2 [- V. s
原理图和PCB源文件如下:
0 }! n2 f9 P* j8 m
6 G# U3 Q# T m0 D# | L: h G5 a% ?# H1 k1 S# w% z1 T
