作品名:[AD 10][4层] 智能家居物联网 WIFI 芯片 MTK MT7688A+原理图+PCB文件整套资料
/ o! w) h% I" R2 U1 {: \& j
8 m6 @' m4 Z7 v% @) A# J6 |文件描述: n/ Y* l- W) _
1. 作品用途:WIFI 芯片) t& J* n9 X1 |8 x! j
2. 软件版本:AD 10
! B3 \2 d. Q7 g B4 c3. 层数:4层板
5 Q0 K' X. H8 [! W5 Z) F& o4. 用到的主要芯片:MTK MT7688A* e$ p2 M2 L/ [
5. PCB尺寸:180mm*96.9mm( T0 Q) R n; k& z2 l
2 z% h1 v) c+ w- [% y u作品截图如下: x( ]; m* F7 d7 y& \$ ^4 M
顶层截图:
- H! S( [4 A0 H+ B' U
6 n; K8 J9 ?1 ~7 p$ Q: u+ u
, `. R- B3 U& m, p# \底层截图:( q5 X# g) R. _' H/ i* ^
3 j; T$ K! i5 B* G+ i, V& |0 F
5 ?) q3 _7 R" m# [1 i全层截图:
; b/ P* h+ Z$ N% e' B
3 y' c) G$ p- R! L4 m- j
9 e8 ]3 t" w+ m# n1 n4 Y叠层信息截图如下:
) i1 v+ l2 W1 l6 a) S5 r& z
6 t2 c' {) G; q6 V9 B6 |1 j0 t3 L
5 W& d1 D' h! SBOM:
* a8 X) F3 G, M8 o! O% ^5 g9 w| Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | C0402$2F$FCS | C1, C2, C4, C5, C10, C11, C14, C15, C19, C20, C21, C22, C23, C24, C25, C30, C31, C34, C37, C38, C39, C40, C41, C42, C43, C44, C47, C49, C51, C52, C53, C54, C55, C57, C58, C59, C60, C61, C62, C63, C77, C78, C88, C89, C96, C97, C98, C99, C100, C101, C102, C103, C104, C106, C107, C108, C109, C110, C111, C112, C127, C130, C155, C156, C178, C181 | C0402$2F$FCS | 66 | | C0603$2F$FCS | C3, C16, C32, C33, C71, C72, C75, C105, C129, D1, D2 | C0603$2F$FCS | 11 | | C0805 | C56, C67, C69, C74, C90, C92, C94, C95, C113, C118, C119, C121, C122, C131, C132, C138, C145, C146, C148, C154 | C0805 | 20 | | C0402 | C64, C73, C80, C86, C114, C115, C116, C123, C124, C125, C126, C128, C133, C134, C135, C136, C139, C143, C144, C147, C149, C150, C152, C153, C174, C175, C179 | C0402 | 27 | | C0603 | C65, C66, C68, C70, C76, C79, C91, C93, C137, C140, C157, C158, C173 | C0603 | 13 | | SB$2F$1206 | C84, C85, R1 | SB$2F$1206 | 3 | | C1206 | C87, C141, C142 | C1206 | 3 | | C680UF6.3V$2F$D8H11 | C117, C120, C151, C180 | C680UF6.3V$2F$D8H11 | 4 | | COAXIAL$2F$SMD$2F$CON$2F$V$2F$I-PEX | CON1, CON2 | COAXIAL$2F$SMD$2F$CON$2F$V$2F$I-PEX | 2 | | LED$2F$2P$2F$SMD$2F$0603$2F$LT8A22-54-UR86-T5 | D3, D4, D5, D6, D12, D13, D14, D15, D16, D17, D18 | LED$2F$2P$2F$SMD$2F$0603$2F$LT8A22-54-UR86-T5 | 11 | | D$2F$SMD$2F$P6.61$2F$B540C | D7 | D$2F$SMD$2F$P6.61$2F$B540C | 1 | | DO-214AC$2F$SMD$2F$SM5817A | D8, D10 | DO-214AC$2F$SMD$2F$SM5817A | 2 | | R0402$2F$FCS | D9, R36, R37, R38, R39, R52, R53, R54, R83, R93, R96, R97, R98, R99, R101, R102, R103, R104, R105, R106, R107, R109, R110, R111, R112, R113, R114, R115, R116, R117, R118, R119, R120, R121, R122, R123, R124, R125, R126, R134, R135, R136, R156, R157, R158, R159, R160, R161, R162, R163, R164, R165, R166, R167, R168, R169, R170, R171, SR1, SR2, SR3, UC1, UC2 | R0402$2F$FCS | 63 | | F1812 | F1 | F1812 | 1 | | FD | FM1, FM2, FM3, FM4, FM5, FM6 | FD | 6 | | TP$2F$DIP$2F$D1.0 | GND1, GND2, GND3, GND4, GND5, GND6, GND7, GND8, TP20, TP38 | TP$2F$DIP$2F$D1.0 | 10 | | DIP4$2F$P2.54 | J1, J17 | DIP4$2F$P2.54 | 2 | | USB$2F$4P$2F$P2.0$2F$DIP$2F$R$2F$F$2F$SUA-110VB-B2N | J4 | USB$2F$4P$2F$P2.0$2F$DIP$2F$R$2F$F$2F$SUA-110VB-B2N | 1 | | JP10X2$2F$DIP$2F$P2.54 | J12, J13, J27, J28 | JP10X2$2F$DIP$2F$P2.54 | 4 | | DIP5$2F$P2.54 | J14, J18, J26, J29 | DIP5$2F$P2.54 | 4 | | CON10P$2F$SMD$2F$R$2F$F$2F$7SDCN-B0-1X14 | J15 | CON10P$2F$SMD$2F$R$2F$F$2F$7SDCN-B0-1X14 | 1 | | DIP7X2$2F$P2.54 | J16 | DIP7X2$2F$P2.54 | 1 | | DIP4X2$2F$P2.54$2F$DCON4X2 | J19, J22 | DIP4X2$2F$P2.54$2F$DCON4X2 | 2 | | DIP4$2F$P2.54$2F$SIP4 | J20, J23 | DIP4$2F$P2.54$2F$SIP4 | 2 | | JP2$2F$DIP$2F$P2.54 | J21, J24 | JP2$2F$DIP$2F$P2.54 | 2 | | CON$5C$DC-JACK$5C$4.7 | J25 | CON$5C$DC-JACK$5C$4.7 | 1 | | DIP4$2F$W$2F$H$2F$P2.0 | JK1 | DIP4$2F$W$2F$H$2F$P2.0 | 1 | | DIP5X2$2F$P2.54 | JP1, JP2 | DIP5X2$2F$P2.54 | 2 | | DIP10X2$2F$P2.54 | JP3 | DIP10X2$2F$P2.54 | 1 | | JP2X2$2F$DIP$2F$P2.54 | JP7 | JP2X2$2F$DIP$2F$P2.54 | 1 | | DIP5X2$2F$P2.54$2F$M | JS1, JS2 | DIP5X2$2F$P2.54$2F$M | 2 | | L0402$2F$FCS | L6, L7, L8, L9, L10, L15, L16, L17, L18, L19, L21 | L0402$2F$FCS | 11 | | L0805 | L22 | L0805 | 1 | | L0603 | L23, L31, L32 | L0603 | 3 | | L$2F$IND$2F$SMD$2F$VLS252010$2F$TDK | L24, L33 | L$2F$IND$2F$SMD$2F$VLS252010$2F$TDK | 2 | | L$2F$IND$2F$DIP$2F$GDR0810 | L25, L29 | L$2F$IND$2F$DIP$2F$GDR0810 | 2 | | L$2F$IND$2F$SMD$2F$LVS606045-150M | L30 | L$2F$IND$2F$SMD$2F$LVS606045-150M | 1 | | SC-75 | Q1, Q2, Q3, Q4 | SC-75 | 4 | | R0603$2F$FCS | R3, R4, R5, R6, R7, R8, R9, R49, R50, R51 | R0603$2F$FCS | 10 | | R0603 | R29, R31, R75, R212, R213, R232 | R0603 | 6 | | R0402 | R40, R41, R42, R43, R44, R45, R46, R47, R48, R84, R85, R86, R87, R88, R89, R90, R91, R92, R94, R95, R100, R108, R127, R129, R130, R132, R133, R137, R139, R140, R141, R142, R143, R144, R145, R146, R147, R148, R149, R150, R172, R173, R174, R175, R176, R177, R178, R179, R180, R181, R182, R183, R184, R185, R186, R187, R188, R189, R190, R191, R192, R193, R194, R195, R196, R197, R198, R199, R200, R201, R202, R203, R204, R205, R206, R207, R208, R209, R210, R211, R214, R215, R216, R217, R218, R219, R220, R221, R222, R223, R224, R225, R226, R227, R228, R229, R230, R231 | R0402 | 98 | | R1206 | R128 | R1206 | 1 | | R0805 | R138, RC1 | R0805 | 2 | | SW-2P2T-6.3 | S1 | SW-2P2T-6.3 | 1 | | SW-TACT$5C$4.5MM | S2, S3 | SW-TACT$5C$4.5MM | 2 | | SW$2F$16P$2F$SMD$2F$DHN-08F-V-T | S4 | SW$2F$16P$2F$SMD$2F$DHN-08F-V-T | 1 | | TP0.3MM | TP3, TP4, TP5, TP6, TP7, TP8, TP9, TP10, TP11, TP12, TP13, TP14, TP15, TP17, TP18, TP19, TP21, TP22, TP24, TP25, TP26, TP27, TP28, TP29, TP30, TP31, TP32, TP33, TP34, TP35, TP36, TP37 | TP0.3MM | 32 | | MT7628AN$2F$DRQFN156$2F$SMD$2F$P0.5$2F$12X12 | U1 | MT7628AN$2F$DRQFN156$2F$SMD$2F$P0.5$2F$12X12 | 1 | | CRYS$2F$DIP$2F$D5X10.6$2F$GB2000025$2F$ECERA | U2 | CRYS$2F$DIP$2F$D5X10.6$2F$GB2000025$2F$ECERA | 1 | | XTAL-SMD$2F$3.2X2.5 | U3 | XTAL-SMD$2F$3.2X2.5 | 1 | | TRANSFORMER$2F$16P$2F$DIP$2F$HN1674CG | U4 | TRANSFORMER$2F$16P$2F$DIP$2F$HN1674CG | 1 | | RJ45$2F$8P$2F$DIP$2F$R$2F$N3612-002 | U5 | RJ45$2F$8P$2F$DIP$2F$R$2F$N3612-002 | 1 | | SOP8$2F$SMD$2F$P1.27$2F$MX25L1605D | U6 | SOP8$2F$SMD$2F$P1.27$2F$MX25L1605D | 1 | | WSON8$2F$SMD$2F$P1.27$2F$W25N01GV | U7 | WSON8$2F$SMD$2F$P1.27$2F$W25N01GV | 1 | | SOP66$2F$11.8$2F$0.65 | U8 | SOP66$2F$11.8$2F$0.65 | 1 | | SOP8$2F$SMD$2F$P1.27$2F$FR9888 | U9, U11 | SOP8$2F$SMD$2F$P1.27$2F$FR9888 | 2 | | SOT-143$2F$SMD$2F$G693 | U10 | SOT-143$2F$SMD$2F$G693 | 1 | | SOT223-3$2F$SMD$2F$P2.3$2F$AX1007 | U12 | SOT223-3$2F$SMD$2F$P2.3$2F$AX1007 | 1 | | SOP8AG1-1.8 | U13 | SOP8AG1-1.8 | 1 | | TSOT25$2F$5P$2F$SMD$2F$P0.95$2F$S | U14 | TSOT25$2F$5P$2F$SMD$2F$P0.95$2F$S | 1 | | BALUN$2F$SMD$2F$BL1608$2F$ACX | U15, U17 | BALUN$2F$SMD$2F$BL1608$2F$ACX | 2 | 8 m1 X9 t0 a5 D& @0 E2 w0 U, ~
附件:+ a+ q7 S) a6 h" N' Q
原理图和PCB源文件如下:/ j5 q9 T6 v8 t: ?4 z9 S
- q$ S* {4 m$ i4 ]6 m2 Z
# q0 H; J! u8 [6 o+ d+ S |
