作品名:[AD 10][2层] stm32F407+RA8875原理图和PCB源文件
! e# G! |& d+ N
2 Q8 S# Y9 f, g. l0 q& q3 D: U文件描述
1 C; \2 Y- f# X1. 软件版本:AD 10
9 R: D$ p n8 k9 w2. 层数:2层板, p5 ~+ H. ~" ~8 h
3. 用到的主要芯片:STM32F407ZET6# W1 P- s; D$ ^4 S/ m9 z
4. PCB尺寸:246.6mm*148.4mm
; N0 D$ y8 F6 a: [' w' {8 A& c; [) O6 N
作品截图如下:
0 i7 l& D9 A/ ]& ^. Y4 ?) g顶层截图:
3 E+ @" m7 W8 q1 W
# B! ] D, z" Z' z( o% P# X2 A8 w9 L+ N5 P$ o
底层截图:
; h: O1 x; ^; i' @2 e
; F; u: O; c/ u7 `8 U9 d& f( J) F
2 ?3 @6 z0 j1 H5 M: g* B全层截图:
& N+ q2 a R. n. V; ^) Z
8 c4 b, x5 ~$ u4 ] Y+ E) r1 ]9 B/ x
叠层信息截图如下:& L Q% d m7 C+ @. e
% y; ^1 {, [& x( Q. C' j
/ P+ A9 |# e5 W( DBOM:$ j$ ]0 w W' E$ j B
| Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | BAT3V | BAT1 | BATT_N | 1 | | 104 | C1, C7, C9, C14, C15, C16, C17, C18, C19, C20, C21, C34, C37, C38, C63, C65, C69, C70, C73, C77, C78 | C0402 | 21 | | 10 | C4, C5, C6 | C0603 | 3 | | 105 | C8, C79, C80, C81, C84 | C0603 | 5 | | 225 | C10 | C0603 | 1 | | 225 | C11 | C0402 | 1 | | 104 | C12 | C0805 | 1 | | 1uF | C13 | C0603 | 1 | | 6P | C29 | C0402 | 1 | | 22P | C31, C32, C74, C75 | C0603 | 4 | | 106 | C39 | C0402 | 1 | | 106 | C60 | C0805 | 1 | | 104 | C67, C68 | C0603 | 2 | | 220U | C90 | CAP_RB 17 | 1 | | 220U | C91 | CAP_RB 18 | 1 | | 220U | C94 | C1206B | 1 | | C105 | CA1, CA3, CA4 | C1206 | 3 | | C105 | CA14 | C0805 | 1 | | C104 | CL1, CL3, CL4, CL5, CL8, CL10, CL11, CL22, CL23, CL24, CL25, CL26, CL27, CL32, CL33, CL35, CU1, CU2, CU3, CU4, CU5, CU6, CU7, CU8, CU9, CU10 | C0402 | 26 | | C104 | CL2, CL6, CL9 | C0603 | 3 | | C475 | CL7 | CAP_RB 11 | 1 | | C475 | CL18 | C0805 | 1 | | C22 | CL19, CL20 | C0603 | 2 | | C104 | CL21 | C0805 | 1 | | ET0700B3DMA | CN4 | FPC-40-0.5 | 1 | | C107 | CV1 | CAP_RB 03 | 1 | | BYV55 | D2 | SOT-23 | 1 | | 1N4007 | D5 | DO-214AC,SMA | 1 | | D5.7V | D6 | DO-214AA,SMB | 1 | | D Zener | DA9 | D1206 | 1 | | 1N5819 | DA11, DA12 | D1810(SMB) | 2 | | SS14 | DL1 | SOD123 | 1 | | LED_D | DL20 | SS1209-B4C | 1 | | 100uF | EA1 | CAP-RB.2/.4-黑 | 1 | | 470uF | EA2 | CAP-RB.1/.25-蓝 | 1 | | 100uF/16V | EA5 | CAP_RB 10 | 1 | | HR911105 | EARTHNET1 | RJ45 - DL | 1 | | 电流互感器 | H1 | HGQ | 1 | | CT07 | H2 | HX2.54-4 | 1 | | JK2H | J1, J2 | SIP2 | 2 | | USB | J3 | USB3.0 H | 1 | | TF卡 | J4 | TF | 1 | | Relay | K1 | JDQ-HF32F | 1 | | Relay | K3, K4, K5, K6 | G5LE-1-5VDC | 4 | | 100uH | LA1 | L-12*12mm-S | 1 | | 22uH | LL1 | L7163 | 1 | | MIC | MIC2 | MIC1 | 1 | | HX2.54-2P | P1, P3 | HX2.54-2 | 2 | | Header 4 | P2, P12 | HX2.54-4 | 2 | | HEAD2*22 | P7 | HDR2X22 | 1 | | HP2.0-3P | P8 | HX2.54-2 | 1 | | HP2.0-3P | P9 | Hx2.0-3P | 1 | | Header 8X2 | P11 | HDR2X8 | 1 | | DJ6112 | PA1, PA12, PA13, PA14, PA15, PA16, PA17 | DJ6112 | 7 | | DJ6112 | PA2 | HX3.96-3 | 1 | | Header 6 | PA3 | HX3.96-6 | 1 | | Header 4 | PA4 | HX3.96-4 | 1 | | Header 4X2 | PA6, PA7 | HDR2X4 | 2 | | Header 8X2 | PA8, PA10 | IDC2.54-16 | 2 | | Phone_Jack | PH1 | EARPHONE-SMT | 1 | | Header 30 | PL1 | FPC-30 | 1 | | Header 4 | PL2 | FPC-1MMS-08P | 1 | | Header 12 | PL5 | FH12A-15S-0.5SH | 1 | | Header 11 | PP1 | PAM8610 | 1 | | R103 | R1, R2, R3, R4, R5, R6, R8, R16, R34, R36, R50, R55, R63, R64 | R0603 | 14 | | R102 | R7 | R0603 | 1 | | R511 | R9, R24 | R0603 | 2 | | R100 | R10, R11 | R0603 | 2 | | R000 | R12, R13, R14, R15, R17 | R0603 | 5 | | 12V/0.5A | R18, R26 | R1206 | 2 | | R202 | R20, R21, R22, R23 | R0603 | 4 | | R100 | R25 | R1206 | 1 | | R101 | R27, R28 | R0402*4 | 2 | | R22 | R29, R30, R31, R66, R67, RL1, RL2, RL12, RL? | R0603 | 9 | | R473 | R32, R33, R60 | R0603 | 3 | | R203 | R39 | R0603 | 1 | | R681 | R40, R42 | R0603 | 2 | | R472 | R41, R57 | R0603 | 2 | | R472 | R44 | R0603*4 | 1 | | 49R9 | R49 | R0603*4 | 1 | | RL102 | R56, R65 | L0603 | 2 | | 1R0 | R58 | R0603 | 1 | | R102 | R59 | L0805 | 1 | | R102 | RA2, RA4 | R0805 | 2 | | R101 | RA3, RA5, RA6, RA7, RA8, RA9 | R0805 | 6 | | 471D20 | RA18 | CAP_CBB0.4 | 1 | | SHT2x | RH1 | SHT2x | 1 | | 5R1 | RL17 | R0805 | 1 | | 100R | RN1, RN2, RN3, RN4, RN5, RN6, RN7, RN8, RN9, RN10, RN11, RN12, RN13, RN14, RN15, RN17 | R0402*4 | 16 | | KEY_M | S1, S2, S3, S4 | SW-SMD2*4 | 4 | | Trans | T2 | 共模电感 7*8 | 1 | | TFT_LCD | TFTLCD1 | HDR2X17 | 1 | | STM32F407ZET6 | U1 | LQFP144 | 1 | | IS62WV51216 | U6 | TSOP80P1176-44 | 1 | | MPU6050 | U7 | QFN24 | 1 | | 3525A | U11 | GD6500 | 1 | | WM8978 | U12 | QFN32 | 1 | | W25X16 | U16 | SOIC-8 | 1 | | LAN8720 | U17 | QFN24 | 1 | | Optoisolator1 | UA2, UA3 | DIP-4 | 2 | | LM2575S-5.0 | UA5 | TO-263-5 | 1 | | ULN2823LW | UA6 | LW18_N | 1 | | RA8875 | UL1 | LQFP-100 | 1 | | MC74VHC1G125DFT1 | UL2, UL6 | SOT23-5 | 2 | | SN74CBT3257PWLE | UL3 | TSSOP-16L | 1 | | W25Q64 | UL4 | SO-8 | 1 | | GT811 | UL5 | QFN40 D50-0.4 | 1 | | PT4110 | UL9 | SOT-89-5 | 1 | | Jumper | W? | RAD-0.2 | 1 | | XTAL3 | X3 | OSC_HC49l | 1 | | XTAL3 | XL1 | OSC_5032 | 1 | | 8M | XY3 | OSC_32768B | 1 |
9 @3 _# c+ v6 y附件:
! w- _% d$ C' H5 ~原理图和PCB源文件如下:
9 P0 V2 Q$ w) F+ ^( s" E
8 o, T! \8 S' K
- Z/ m( |" N1 H) f4 F9 S |
