| Bill of Material Report (Condensed) |
| SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
| 名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 1000pF | DISCRETE | 1 | C1 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.65M | 4.7uF | DISCRETE | 4 | C2; C3; C8; C18 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | DISCRETE | 8 | C4; C5; C7; C10; C19; C25; C26; C549 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 1.0UF | DISCRETE | 1 | C6 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | DISCRETE | 1 | C11 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 0.1UF | DISCRETE | 2 | C16; C28 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.9 M | 0.1uF | DISCRETE | 16 | C22; C47; C544; C545; C546; C547; C548; C550; C554; C555; C556; C557; C559; C560; C561; C562 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56M | 0.01UF | DISCRETE | 1 | C59 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 12PF | DISCRETE | 2 | C126; C127 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 0.1uF | DISCRETE | 12 | C129; C131; C133; C140; C141; C142; C146; C540; C541; C543; C553; C558 |
| CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | 2.2UF | DISCRETE | 1 | C9 |
| CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | DISCRETE | 1 | C12 |
| CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 220PF | DISCRETE | 1 | C17 |
| CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0MM | 4700 PF | DISCRETE | 2 | C40; C551 |
| CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 10pF | DISCRETE | 2 | C533; C535 |
| CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.27M | 10.0uF | DISCRETE | 5 | C21; C24; C27; C49; C536 |
| CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4MM | 10UF | DISCRETE | 5 | C143; C144; C539; C542; C552 |
| CCE6P8X6P8 | CAP_POL_CCE6P8X6P8_DISCRETE_6.1 | 47uF | DISCRETE | 1 | C128 |
| CON2X8_2P54_TH | HDR_2X8_M_CON2X8_2P54_TH_IO_8.6 | CON 2X8 | IO | 1 | J3 |
| CON3_PWR_JACK_TH_PJ051A | DC_POWER_JACK_SHD_CON3_PWR_JACK | CON PWR 3 | IO | 1 | J16 |
| CON20_2P54_TH | CONN_HDR_10X2_CON20_2P54_TH_IO_ | CON 2X10 | IO | 1 | J5 |
| CON_2RH_10_50 | CONN_HDR_5X2_CON_2RH_10_50_IO_3 | HDR 2X5 | IO | 2 | J12; J14 |
| CON_3X8_100_TH_C041 | HDR-3X8_A_CON_3X8_100_TH_C041_I | SSW-108-01-G-T | IO | 2 | J1; J4 |
| CON_3X10_100_TH_C041 | HDR-3X10_A_CON_3X10_100_TH_C041 | SSW-110-01-G-T | IO | 2 | J2; J6 |
| CON_HDR_4M_100_TH_RA | CONN_HDR_4X1_CON_HDR_4M_100_TH_ | HDR 1X4 RA | IO | 2 | J11; J13 |
| CON_MICROAB_10F_25_SM_RA | MICRO_USB_CONN_10PIN_CON_MICROA | USB_MICRO_AB | IO | 1 | J7 |
| DSN0603-2 | DIODE_BIDIR_DSN0603-2_IC_0.32MM | PESD5V0R1BSF | IC | 3 | D17; D18; D19 |
| ELECTRODE_SQ_15MM | ELECTRODE_ELECTRODE_SQ_15MM_IC_ | Electrode | IC | 2 | SW7; SW8 |
| HDR103_A | CONN_HDR_3X1_HDR103_A_IO_8.74MM | HDR 1X3 | IO | 3 | J10; J104; J107 |
| IND_0402 | INDUCTOR_FERRITE_IND_0402_DISCR | 30 OHM | DISCRETE | 1 | L512 |
| IND_1608 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 330 OHM | DISCRETE | 2 | L1; L2 |
| LED6_5X6MM | LED_TRI_COLOR_LED6_5X6MM_IC_2.6 | LED RED/GRN/BL | IC | 1 | D11 |
| LED_0603 | LED_LED_0603_IC_0.9MM_370-75079 | RED | IC | 1 | D1 |
| LED_0603 | LED_LED_0603_IC_0.67MM_370-7656 | LED GREEN | IC | 1 | D2 |
| LED_0603 | LED_LED_0603_IC_0.85MM_370-7654 | GREEN | IC | 1 | D3 |
| LFPAK5_1P27_5X4 | PMOS_5P_LFPAK5_1P27_5X4_IC_1.2 | PHPT61003PY | IC | 1 | Q1 |
| LQFP100_0P5_14X14 | PS32K144_LQFP_100P_A_0_LQFP100_ | PS32K144HFT0VLLT | IC | 1 | U17 |
| LQFP144_0P5_20X20MM | S32K1XX_LQFP_144P_LQFP144_0P5_2 | PS32K118UEX0MLQT | IC | 1 | U35 |
| POT3_3352T | POT_POT3_3352T_DISCRETE_4.32 MM | 5K | DISCRETE | 1 | R13 |
| QFN8_1P6X1P6MM | 74LVC2T45GM_8P_QFN8_1P6X1P6MM_I | 74LVC2T45GM,125 | IC | 1 | U2 |
| QFN32_S142EP | PK20DX128V_QFN_32P_QFN32_S142EP | MK20DX128VFM5 | IC | 1 | U8 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 4.7K | DISCRETE | 9 | R1; R15; R30; R52; R57; R562; R571; R572; R576 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 330 OHM | DISCRETE | 1 | R2 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | DISCRETE | 21 | R3; R16; R31; R39; R42; R51; R607; R608; R609; R610; R611; R612; R613; R614; R615; R617; R618; R619; R620; R621; R622 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.40 MM_ | 180K | DISCRETE | 1 | R4 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.45 M_1 | 0 | DISCRETE | 2 | R18; R24 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 33 | DISCRETE | 2 | R21; R25 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | DISCRETE | 71 | R32; R35; R47; R49; R119; R120; R122; R123; R124; R125; R126; R127; R128; R129; R130; R131; R136; R137; R152; R153; R154; R155; R156; R161; R162; R164; R169; R529; R532; R577; R578; R579; R580; R581; R582; R583; R584; R585; R586; R587; R588; R589; R590; R591; R592; R629; R630; R632; R633; R635; R637; R638; R640; R641; R642; R643; R644; R645; R646; R647; R648; R649; R651; R652; R653; R654; R655; R656; R657; R658; R668 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | 10.0K | DISCRETE | 2 | R44; R74 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__6 | 10.0K | DISCRETE | 1 | R60 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 10.0K | DISCRETE | 2 | R62; R77 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_1 | 15K | DISCRETE | 1 | R68 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__7 | 1.0K | DISCRETE | 1 | R69 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 10K | DISCRETE | 11 | R121; R573; R574; R575; R598; R601; R603; R604; R623; R662; R663 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_4 | 33K | DISCRETE | 4 | R599; R600; R602; R605 |
| RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__1 | 220 | DISCRETE | 1 | R12 |
| RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_1 | 680 | DISCRETE | 4 | R56; R95; R96; R97 |
| RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__2 | 0 | DISCRETE | 19 | R84; R88; R133; R134; R146; R147; R165; R167; R172; R300; R527; R533; R534; R567; R568; R659; R664; R665; R667 |
| RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__3 | 1.0M | DISCRETE | 1 | R91 |
| RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 0 | DISCRETE | 7 | R117; R593; R624; R625; R626; R660; R661 |
| RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 4.7K | DISCRETE | 2 | R525; R528 |
| RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 MM_ | 4.7K | DISCRETE | 1 | R538 |
| RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 M_1 | 1K | DISCRETE | 3 | R595; R596; R597 |
| RC0805_OV | RES_RC0805_OV_DISCRETE_0.65MM_4 | 2K | DISCRETE | 2 | R80; R171 |
| RC0805_OV | RES_RC0805_OV_DISCRETE_0.65MM_1 | 2.2 | DISCRETE | 1 | R535 |
| RC0805_OV | RES_RC0805_OV_DISCRETE_0.65 MM_ | 10k | DISCRETE | 1 | R537 |
| RC1206_OV | RES_RC1206_OV_DISCRETE_0.6MM_47 | 60.4 | DISCRETE | 2 | R92; R98 |
| SC_75 | NPN_SC_75_IC_0.9 MM_480-75477_M | MMBT3904TT1G | IC | 4 | Q6; Q7; Q8; Q9 |
| SH0603 | RES_SHORT-2_SH0603_DISCRETE_0.1 | 0 | DISCRETE | 4 | SH1; SH11; SH12; SH13 |
| SO8_1P27_4X5 | TJA1027T_8P_SO8_1P27_4X5_IC_1.7 | TJA1027T/20 | IC | 1 | U21 |
| SOD-128 | DIODE_SCHTKY_SOD-128_IC_1.1 MM_ | PMEG3050EP | IC | 2 | D6; D9 |
| SON20_0P5_3P6X5P6 | UJA1169TKF_3_SON20_0P5_3P6X5P6_ | UJA1169TK/F | IC | 1 | U19 |
| SOT23-6_A | MIC2005-0.8YM6_SOT23-6_A_IC_1.4 | MIC2005-0.8YM6 | IC | 1 | U11 |
| SOT23_5S | SPX3819M5_FIX_0_SOT23_5S_IC_1.4 | SPX3819M5-L-3-3 | IC | 1 | U15 |
| SOT891_6P_0P35_1P05X1P05 | NC7WP14_SOT891_6P_0P35_1P05X1P0 | 74LVC2G14GF,132 | IC | 1 | U9 |
| SW4_SPST_4P8X3P6_2P5 | EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8 | EVQ-P2402W | IC | 4 | SW2; SW3; SW5; SW9 |
| TESTPOINT_135_070MIL | TEST_POINT_4_TESTPOINT_135_070M | TESTLOOP | IC | 10 | TS1; TS2; TS3; TS4; TS5; TS6; TS7; TS8; TS9; TS10 |
| TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | IO | 61 | TP5; TP6; TP7; TP8; TP10; TP11; TP12; TP18; TP28; TP29; TP30; TP503; TP504; TP505; TP506; TP507; TP508; TP509; TP510; TP511; TP512; TP513; TP514; TP515; TP516; TP517; TP518; TP519; TP520; TP521; TP523; TP524; TP525; TP528; TP529; TP530; TP531; TP532; TP533; TP534; TP535; TP536; TP537; TP538; TP539; TP540; TP541; TP542; TP543; TP544; TP545; TP546; TP549; TPAD93; TPAD94; TPAD95; TPAD96; TPAD97; TPAD98; TPAD99; TPAD100 |
| TP_TH_063 | TEST_POINT_3_TP_TH_063_IC_5.6MM | 5006 | IC | 2 | GND1; GND2 |
| TP_TH_063 | TEST_POINT_0_TP_TH_063_IC_5.59M | TEST_POINT | IC | 6 | TP9; TP522; TP526; TP527; TP547; TP548 |
| UDFN6_1X1P5MM | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | 74LVCH1T45 | IC | 3 | U4; U7; U10 |
| XQFN8_1P45X1P25MM | NTSX2102GU8H_8P_XQFN8_1P45X1P25 | NTSX2102GU8H | IC | 1 | U1 |
| XQFN8_1P45X1P25MM | NTSX2102GU8H_0_XQFN8_1P45X1P25M | NTSX2102GU8H | IC | 4 | U26; U32; U33; U34 |
| XTAL2_3P3X2P6 | XTAL_CS10_XTAL2_3P3X2P6_IC_1MM_ | 8MHZ | IC | 1 | Y3 |
| XTAL3_3P35X1P45_SM | XTAL_CS_XTAL3_3P35X1P45_SM_IC_0 | 8.00MHZ | IC | 1 | Y1 |
附件:
