| Bill of Material Report (Condensed) |
| SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
| 名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
| 1206LD | LED_1206LD_IC_0.75MM_370-75084_ | LED RED | IC | 1 | D9 |
| C035S | T POINT R_C035S_IC_0.1 MM_280-7 | TEST POINT | IC | 26 | TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP32; TP33; TP34 |
| CC0306_24 | CAP_NP_CC0306_24_DISCRETE_0.61M | 0.01uF | DISCRETE | 2 | C219; C220 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 1000pF | DISCRETE | 9 | C7; C95; C102; C135; C143; C145; C197; C206; C208 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 0.1uF | DISCRETE | 67 | C8; C9; C10; C11; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C54; C57; C58; C59; C60; C61; C62; C63; C64; C66; C67; C68; C70; C71; C72; C73; C74; C75; C76; C78; C79; C81; C84; C85; C86; C87; C88; C89; C90; C91; C93; C97; C98; C100; C107; C109; C110; C111; C112; C114; C117; C119; C122; C154; C155; C167; C172; C179; C186; C187; C188 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_5 | 0.1uF | DISCRETE | 11 | C23; C129; C130; C134; C210; C214; C221; C224; C225; C226; C227 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_3 | 1000pF | DISCRETE | 7 | C53; C115; C116; C120; C123; C180; C228 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.01uF | DISCRETE | 2 | C94; C101 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_4 | 0.01uF | DISCRETE | 2 | C125; C127 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_.55MM | 15PF | DISCRETE | 2 | C132; C133 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 22PF | DISCRETE | 2 | C157; C158 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_6 | 0.22uF | DISCRETE | 8 | C159; C160; C161; C162; C163; C164; C165; C166 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 7.0PF | DISCRETE | 2 | C182; C183 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 10PF | DISCRETE | 2 | C184; C185 |
| CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_7 | 1000pF | DISCRETE | 4 | C212; C213; C222; C223 |
| CC0603 | CAP_NP_CC0603_DISCRETE_0.9MM_15 | 1uF | DISCRETE | 3 | C2; C103; C108 |
| CC0603 | CAP_NP_CC0603_DISCRETE_0.9MM__2 | 1uF | DISCRETE | 26 | C21; C22; C27; C33; C137; C138; C139; C140; C142; C147; C148; C149; C150; C151; C153; C191; C192; C193; C194; C196; C200; C201; C202; C203; C204; C205 |
| CC0603 | CAP_NP_CC0603_DISCRETE_0.87MM_1 | 4.7pF | DISCRETE | 1 | C28 |
| CC0603 | CAP_NP_CC0603_DISCRETE_1.016M_1 | 10uF | DISCRETE | 3 | C47; C48; C189 |
| CC0603 | CAP_NP_CC0603_DISCRETE_1.016MM_ | 10uF | DISCRETE | 6 | C55; C141; C152; C174; C195; C199 |
| CC0603 | CAP_NP_CC0603_DISCRETE_0.9MM__1 | 1uF | DISCRETE | 17 | C56; C65; C69; C80; C82; C83; C92; C96; C99; C106; C113; C118; C121; C124; C126; C168; C178 |
| CC0603 | CAP_NP_CC0603_DISCRETE_1MM_150- | 0.47UF | DISCRETE | 1 | C77 |
| CC0603 | CAP_NP_CC0603_DISCRETE_0.90 MM_ | 0.01uF | DISCRETE | 6 | C136; C144; C146; C198; C207; C209 |
| CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_2 | 4.7uF | DISCRETE | 4 | C49; C50; C51; C52 |
| CC0805 | CAP_NP_CC0805_DISCRETE_1.45MM_1 | 4.7uF | DISCRETE | 1 | C131 |
| CC1206 | CAP_NP_CC1206_DISCRETE_1.27MM_1 | 1.0UF | DISCRETE | 2 | C25; C26 |
| CC1210 | CAP_NP_CC1210_DISCRETE_2.7 MM_1 | 47uF | DISCRETE | 1 | C24 |
| CC3216 | CAP_POL_CC3216_DISCRETE_1.8MM_1 | 1.0UF | DISCRETE | 2 | C6; C105 |
| CC3528-21 | CAP_POL_CC3528-21_DISCRETE_2.1 | 10uF | DISCRETE | 17 | C1; C3; C4; C5; C12; C13; C14; C15; C16; C17; C18; C19; C20; C30; C32; C34; C104 |
| CC3528-21 | CAP_POL_CC3528-21_DISCRETE_2._1 | 22UF | DISCRETE | 2 | C29; C31 |
| CON4_TB_5MM | 282836-4_CON4_TB_5MM_IO_10MM_21 | CON_4_TB | IO | 1 | J1 |
| CON5_USB_RA_SMT | USB_MINI_AB_RECEPTACLE_CON5_USB | CONN USB MINI-B | IO | 1 | J12 |
| CON10_SKT_0P8_SM | CONN_HDR_6X2_CON10_SKT_0P8_SM_I | ERF8-005-05.0-L-DV-L-TR | IO | 1 | J17 |
| CON_2X17F_0P8_SM | CON_2X17_F_CON_2X17F_0P8_SM_IO_ | CON 2x17 | IO | 1 | J23 |
| CON_2X120_QSH_0P5_SMT | QTH-120-02-L-D-A_CON_2X120_QSH_ | CON 2X120 SKT | IO | 2 | J28; J29 |
| CON_60_QTH_0P5_SM | QTH-030-02-L-D-A_CON_60_QTH_0P5 | QTH-030-01-L-D-A-K-TR | IO | 1 | J15 |
| CON_RJ45_2X5_TH | V890-1AX1-A1_14P_CON_RJ45_2X5_T | V890-1AX1-A1 | IO | 1 | J14 |
| DFN10_0P5_3X3 | ISL8010X_DFN_10P_DFN10_0P5_3X3_ | ISL80103IRAJZ | IC | 1 | U1 |
| FUSE_3P2X1P6 | FUSE_FUSE_3P2X1P6_IC_0.84MM_510 | 0.5A | IC | 1 | F1 |
| HDR2X4 | CONN_HDR_4X2_HDR2X4_IO_8.6MM_21 | HDR_2X4 | IO | 1 | J16 |
| HDR102_TMM | JUMPER_2_2MM_HDR102_TMM_IO_5.2M | HDR 1X2 | IO | 16 | J8; J9; J30; J32; J33; J34; J35; J36; J39; J40; J43; J44; J45; J46; J47; J48 |
| HDR103 | CONN_HDR_3X1_HDR103_IO_8.65MM_2 | HDR TH 1X3 | IO | 6 | J6; J10; J18; J21; J37; J42 |
| HDR202_TSM_SM | CONN_HDR_2X2_HDR202_TSM_SM_IO_9 | HDR_2X2 | IO | 7 | J2; J3; J4; J5; J7; J11; J31 |
| HDR206 | CONN_HDR_6X2_HDR206_IO_8.382 MM | HDR_2X6 | IO | 1 | J13 |
| HDR_2X7_045T | CONN_HDR_7X2_HDR_2X7_045T_IO_9. | CON_2X7 | IO | 1 | J24 |
| IND2_8043 | INDUCTOR_FERRITE_A_IND2_8043_DI | 2.2uH | DISCRETE | 1 | L1 |
| IND2_XAL40 | INDUCTOR_IND2_XAL40_DISCRETE_3. | 4.7uH | DISCRETE | 1 | L2 |
| IND_0805 | BEAD_IND_0805_DISCRETE_1.05MM_1 | 330OHM | DISCRETE | 1 | L4 |
| IND_1608 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 600 Ohm | DISCRETE | 5 | L3; L5; L6; L7; L8 |
| LED_0603 | LED_LED_0603_IC_0.8MM_370-75076 | LED_YELLOW | IC | 1 | D2 |
| LED_0603 | LED_LED_0603_IC_0.75MM_370-7578 | BLUE | IC | 4 | D5; D6; D7; D8 |
| QFN18_0P5_3X4 | LT8614_QFN18_QFN18_0P5_3X4_IC_0 | LT8614 | IC | 1 | U2 |
| QFN32_MC1320X | FT232RQ_QFN32_MC1320X_IC_1.05MM | FT232RQ | IC | 1 | U7 |
| RC0201 | RES_RC0201_DISCRETE_0.30 MM_470 | 0 | DISCRETE | 2 | M1; M2 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.40 MM_ | 24K | DISCRETE | 1 | R1 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_2 | 2.87K | DISCRETE | 1 | R6 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 100k | DISCRETE | 1 | R14 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 10K | DISCRETE | 8 | R22; R23; R24; R25; R26; R29; R32; R33 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 4.7K | DISCRETE | 4 | R30; R31; R35; R168 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_1 | 12.1K | DISCRETE | 1 | R36 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_1 | 1.1K | DISCRETE | 2 | R149; R150 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 4.7K | DISCRETE | 2 | R152; R159 |
| RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10K | DISCRETE | 1 | R166 |
| RC0603 | RES_RC0603_DISCRETE_0.6MM_470-7 | 0 | DISCRETE | 19 | R9; R13; R17; R18; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R61; R155; R156 |
| RC0603 | RES_RC0603_DISCRETE_0.55MM_470- | 1.37M | DISCRETE | 1 | R10 |
| RC0603 | RES_RC0603_DISCRETE_0.55 MM_470 | 41.2K | DISCRETE | 1 | R11 |
| RC0603 | RES_RC0603_DISCRETE_0.55MM_47_1 | 412.0K | DISCRETE | 1 | R12 |
| RC0603 | RES_RC0603_DISCRETE_0.55MM_47_2 | 68 | DISCRETE | 2 | R27; R28 |
| RC0603 | RES_RC0603_DISCRETE_0.55 MM_4_1 | 40.2K | DISCRETE | 1 | R37 |
| RC0603 | RES_RC0603_DISCRETE_0.55 MM_4_2 | 300 | DISCRETE | 2 | R38; R39 |
| RC0603 | RES_RC0603_DISCRETE_0.6 MM_470- | 15K | DISCRETE | 1 | R44 |
| RC0603 | RES_RC0603_DISCRETE_0.6MM_470-3 | 560 | DISCRETE | 2 | R65; R167 |
| RC0603 | RES_RC0603_DISCRETE_0.6MM_470_1 | 1K | DISCRETE | 2 | R148; R151 |
| RC0805 | RES_RC0805_DISCRETE_0.7 MM_470- | 100K | DISCRETE | 1 | R5 |
| RC0805 | RES_RC0805_DISCRETE_0.6MM_470-7 | 510 | DISCRETE | 1 | R7 |
| RC0805 | RES_RC0805_DISCRETE_0.7 MM_47_1 | 100K | DISCRETE | 1 | R8 |
| RC0805 | RES_RC0805_DISCRETE_0.46MM_470- | 0.05 | DISCRETE | 3 | R16; R19; R21 |
| RC0805 | RES_RC0805_DISCRETE_0.6MM_470-3 | 560 | DISCRETE | 1 | R90 |
| RC1206 | RES_RC1206_DISCRETE_0.71MM_470- | 120 | DISCRETE | 2 | R146; R164 |
| SKT_BGA257_0P8_30X30_TH | S32R274_257P_SKT_BGA257_0P8_30X | SKT BGA 257 TH + S32R274 | IC | 1 | U11 |
| SO8_1P27_4X5 | TJA1051T_SO_8P_SO8_1P27_4X5_IC_ | TJA1051T/3 | IC | 2 | U14; U16 |
| SOT23 | NPN_SOT23_IC_1.12 MM_480-75173_ | MMBT3904LT1G | IC | 1 | Q2 |
| SOT89_123 | AP1117_SOT89_123_IC_1.60MM_315- | AP1117Y33G-13 | IC | 2 | U3; U4 |
| SW2_SPST_3P5X6P0_5P0 | SW2P_SW2_SPST_3P5X6P0_5P0_IC_5. | EVQ-PE105K | IC | 1 | SW2 |
| TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_210 | TEST POINT BLACK | IO | 5 | TP1; TP2; TP3; TP28; TP29 |
| TO_277A | DIODE_SCH_227A_TO_277A_IC_1.2MM | SS8P3L | IC | 1 | D1 |
| TSOP_6 | MOSFET_P_S1_D4_TSOP_6_IC_1.10MM | SI3443BDV | IC | 1 | Q1 |
| TSOT23_8_0P65_2X1 | LTC2905_TSOT23-8_TSOT23_8_0P65_ | LTC2905 | IC | 1 | U18 |
| VQFN20_0P65_5P15X5P15 | TPS7A7100RGW_VQFN20_0P65_5P15X5 | TPS7A7100 | IC | 1 | U5 |
| WQFN48_0P5_7X7_EP5P05 | KSZ9031RNXUA_48P_EP_WQFN48_0P5_ | KSZ9031RNXUA | IC | 1 | U17 |
| XTAL2_3P3X2P6 | XTAL_CS10_XTAL2_3P3X2P6_IC_0.95 | 40MHZ | IC | 1 | Y3 |
| XTAL_4_7P2X5P2 | XTAL_13Y_XTAL_4_7P2X5P2_IC_1.3M | 25MHZ | IC | 1 | Y1 |
附件:
